11364 connectés
Sujet : Comment faire un reset harware d'une webcam creative GO plus
SUPER-MENTEUR If the Video Blaster WebCam Go hangs or locks up, it may be necessary to do a 'Hardware Reset'.
This can be done as follows:
While the unit is OFF, hold down the MODE button.
With the MODE button held down, press and release the ON button.
With the MODE button still held down, press and hold the SNAP SHOT button (button on top of unit used for taking pictures). Now release the MODE button.
Release the SNAP SHOT button. Notice that the display will have all its characters lit, and the unit will beep. Press and release the MODE button once.
The display will count to four and then display a -P-
Press and release the MODE button again, the display will flash = -P- and the unit should beep.
Turn the unit off.
Note: This will remove all previously stored settings and erase any stored pictures in memory.
PS:c le bordel chez creative pour avoir de l'aide  :fou:
Turn the unit off.
SUPER-MENTEUR KKUN l'avait dit sur ce forum je le retrouve pas  :cry:
[jfdsdjhfuetppo]--Message édité par SUPER-MENTEUR--[/jfdsdjhfuetppo]
