11375 connectés
Sujet : Configurer télécommande WinTV
bubblegum Lut all,
moi je n'arrive toujours a bien configurer ma telecomande hauppauge.
J'ai bien visité les liens, suivi les indications mais rien n'y fais  :(
Voila mon irremote.ini si vous pouvez me depanner.
Code :
  1. ; FGR 12/09/02 Support firmware V2; 32-bit IR application
  2. ; FILEVERSION 2,33,20343,0
  3. ; includes support for both Classic black, and new PVR remote
  4. ; requires ir.exe 2.33.20343 or later
  5. [Remote]
  6. RepeatDelay=3
  7. ;Beep = 1           ; Sound for MessageBeep() to make for each Remote Keystroke
  8. ;PowerDownSound = 0 ; Sound for MessageBeep() to make when powering down
  9. MenuLoad=1     ; use tray as app launcher
  10. ; map RC5 System Codes to button "name" lookup table
  11. ; Note: 0 (classic remote) conflicts with standard "philips" TV remotes
  12. [SystemCode]
  13. 0=HCWClassic
  14. 31=HCWPVR
  15. ; these tables map actual IR scan codes to button "names" on a per system code
  16. basis
  17. ; Undefined values get the name "CODExx" by default (mostly for debugging)
  18. ; Real buttons on a remote should always get a real button name
  19. ; Note: some button "names" can only be generated by certain remotes
  20. ; Also, note that seemingly similar buttons may have unique names on different
  21. remotes
  22. ; This is to allow treating them differently based on the remote, and the
  23. ; "paradigm" of how they are used.  For example; on old remotes there is a seperate
  24. TV
  25. ; button, but no GRNPOWER button.  So, on old remotes we treat TV as on/off, where
  26. on PVR
  27. ; remote we use the GoMenu function (or RED as On), and the GRNPOWER as Off.
  28. [HCWClassic]
  29. 0=0
  30. 1=1
  31. 2=2
  32. 3=3
  33. 4=4
  34. 5=5
  35. 6=6
  36. 7=7
  37. 8=8
  38. 9=9
  39. 12=RADIO
  40. 13=MUTE
  41. 15=TV
  42. 16=VOLUP
  43. 17=VOLDOWN
  44. 30=RESERVED
  45. 32=CHNLUP
  46. 33=CHNLDOWN
  47. 34=SOURCE
  48. 38=MINIMIZE
  49. 46=FULLSCREEN
  50. [HCWPVR]
  51. 0=0
  52. 1=1
  53. 2=2
  54. 3=3
  55. 4=4
  56. 5=5
  57. 6=6
  58. 7=7
  59. 8=8
  60. 9=9
  61. 46=GREEN
  62. 56=YELLOW
  63. 11=RED
  64. 41=BLUE
  65. 12=FUNC
  66. 13=MENU
  67. 15=MUTE
  68. 16=VOLUP
  69. 17=VOLDOWN
  70. 32=CHNLUP
  71. 33=CHNLDOWN
  72. 61=GRNPOWER
  73. 31=BACK
  74. 37=OK
  75. 59=GO
  76. 60=FULLSCREEN
  77. 55=REC
  78. 54=STOP
  79. 48=PAUSE
  80. 53=PLAY
  81. 50=REWIND
  82. 52=FASTFWD
  83. 30=SKIPFWD
  84. 36=SKIPREV
  85. ; First item in this section IS always the default app if no others found
  86. [Applications]
  87. Default=
  88. WinTV Remote=
  89. ;Win/TV+=
  90. ;Win/TV=
  91. WinTV32=
  92. WinTV32(1)=
  93. WinTV32(2)=
  94. WinTV32(3)=
  95. WinTV32(4)=
  96. WinTV32(5)=
  97. WinTV32(8)=
  98. WinTV32(9)=
  99. WinTV32(10)=
  100. WinTV32(11)=
  101. WinTV32(12)=
  102. FullScreen=
  103. PVRFullScreen=
  104. *task*=
  105. ;*suspend*=
  106. EPGdemo=
  107. VTplus=
  108. Create and Receive=
  109. Debug.txt=
  110. hcwGDisplayWindow=
  111. hcwGo=
  112. Windows Media Player=
  113. ActiveMovie Window=
  114. [Default]
  115. 0=
  116. 1=
  117. 2=
  118. 3=
  119. 4=
  120. 5=
  121. 6=
  122. 7=
  123. 8=
  124. 9=
  125. TV={run(C:\progra~1\K!\K!TVXP~1\K!TV-XP.exe)}
  126. SOURCE={switch(*task*)}{shift}{tab}
  127. MINIMIZE=
  128. FULLSCREEN={alt}{space}x
  129. RESERVED=
  130. ; close current active window; disabled for now
  131. ;GRNPOWER={sys(0xF060)}
  132. ;GUIDE={run(epgdemo.exe)}
  133. GO={gomenu()}
  134. ;GO={run(hcwGo\hcwGo.exe)}
  135. MENU={switch(*task*)}{shift}{tab}
  136. ;;these 3 buttons are not offical yet
  137. RED={close(radio.exe)}{sleep(750)}{run(wintv2k.exe)}
  138. GREEN={close(wintv2k.exe)}{sleep(750)}{run(radio.exe)}
  139. YELLOW={close(radio.exe)}{sleep(750)}{run(..\vtplus\vtplus.exe)}
  140. BLUE={run(C:\Progra~1\Ktv\K!TV-XP\ktv.exe)}
  141. ;;default mappings to drive apps that use APPCOMMANDS on Win2000/XP
  142. MUTE={app(0x80000)}
  143. CHNLUP={app(0x330000)}
  144. CHNLDOWN={app(0x340000)}
  145. VOLUP={app(0xa0000)}
  146. VOLDOWN={app(0x90000)}
  147. REC={app(0x300000)}
  148. STOP={app(0xd0000)}
  149. PAUSE={app(0x2f0000)}
  150. PLAY={app(0x2e0000)}
  151. REWIND={app(0x320000)}
  152. FASTFWD={app(0x310000)}
  153. SKIPFWD={app(0xb0000)}
  154. SKIPREV={app(0xc0000)}
  155. ; built-in IR gomenu()
  156. [WinTV Remote]
  157. OK={enter}
  158. VOLUP={tab}
  159. VOLDOWN={shift}{tab}
  160. BACK={sys(0xF060)}
  161. CHNLUP={shift}{tab}
  162. CHNLDOWN={tab}
  163. FULLSCREEN={enter}
  164. SOURCE={enter}
  165. OK={enter}
  166. GO={enter}
  167. GRNPOWER={esc}
  168. ; external 10ft UI
  169. [hcwGo]
  170. CHNLUP={UP}
  171. CHNLDOWN={DOWN}
  172. VOLUP={RIGHT}
  173. VOLDOWN={LEFT}
  174. FULLSCREEN={enter}
  175. OK={enter}
  176. BACK={BACK}
  177. GRNPOWER={esc}
  178. GO={space}
  179. GREEN={F2}
  180. RED={F3}
  181. [hcwGDisplayWindow]
  182. CHNLUP={home}
  183. CHNLDOWN={end}
  184. VOLUP={pgdn}
  185. VOLDOWN={pgup}
  186. FULLSCREEN={enter}
  187. OK={enter}
  188. BACK={BACK}
  189. GRNPOWER={esc}
  190. GO={space}
  191. ;Note: only tested with Windows Media Player 8
  192. [Windows Media Player]
  193. FULLSCREEN={alt}{enter}
  194. BACK={esc}
  195. MUTE={F8}
  196. VOLUP={F10}
  197. VOLDOWN={F9}
  198. CHNLUP={VK_UP}
  199. CHNLDOWN={VK_DN}
  200. OK={enter}
  201. REC=
  202. STOP={ctrl}s
  203. PAUSE={ctrl}p
  204. PLAY={ctrl}p
  205. REWIND={ctrl}b
  206. FASTFWD={ctrl}f
  207. SKIPFWD={ctrl}{shift}f
  208. SKIPREV={ctrl}{shift}b
  209. 1={alt}1
  210. 2={alt}2
  211. 3={alt}3
  212. YELLOW={ctrl}1
  213. BLUE={ctrl}2
  214. GRNPOWER={alt}{f4}
  215. ;Windows Media Player 8 Full Screen
  216. ; but "ActiveMovie Window" is terribly generic
  217. [ActiveMovie Window]
  218. FULLSCREEN={alt}{enter}
  219. BACK={esc}
  220. MUTE={F8}
  221. VOLUP={F10}
  222. VOLDOWN={F9}
  223. CHNLUP=
  224. CHNLDOWN=
  225. REC=
  226. STOP={findwnd(,Windows Media Player)}{cmd(32809)}
  227. PAUSE={findwnd(,Windows Media Player)}{cmd(32808)}
  228. PLAY={findwnd(,Windows Media Player)}{cmd(32808)}
  229. REWIND={findwnd(,Windows Media Player)}{cmd(32810)}
  230. FASTFWD={findwnd(,Windows Media Player)}{cmd(32811)}
  231. SKIPFWD={findwnd(,Windows Media Player)}{cmd(32812)}
  232. SKIPREV={findwnd(,Windows Media Player)}{cmd(32813)}
  233. 1={alt}1
  234. 2={alt}2
  235. 3={alt}3
  236. YELLOW={ctrl}1
  237. BLUE={ctrl}2
  238. GRNPOWER={alt}{f4}
  239. [VTplus]
  240. 0={ctrl}n0
  241. 1={ctrl}n1
  242. 2={ctrl}n2
  243. 3={ctrl}n3
  244. 4={ctrl}n4
  245. 5={ctrl}n5
  246. 6={ctrl}n6
  247. 7={ctrl}n7
  248. 8={ctrl}n8
  249. 9={ctrl}n9
  250. OK={enter}
  251. FULLSCREEN={alt}{space}x{alt}-x
  252. CHNLUP={ctrl}{up}
  253. CHNLDOWN={ctrl}{down}
  254. VOLUP={ctrl}{F6}
  255. VOLDOWN={ctrl}i
  256. STOP={ctrl}s
  257. RED={cmd(501)}
  258. GREEN={cmd(502)}
  259. YELLOW={cmd(503)}
  260. BLUE={cmd(504)}
  261. FULLSCREEN={alt}{space}r
  262. ; VTplus - new page dialog
  263. [Create and Receive]
  264. 0=0
  265. 1=1
  266. 2=2
  267. 3=3
  268. 4=4
  269. 5=5
  270. 6=6
  271. 7=7
  272. 8=8
  273. 9=9
  274. OK={enter}
  275. CHNLUP={shift}{tab}
  276. CHNLDOWN={tab}
  277. VOLDOWN={left}
  278. VOLUP={right}
  279. BACK={esc}
  280. FULLSCREEN={space}
  281. [EPGdemo]
  282. OK={enter}
  283. VOLUP={tab}
  284. VOLDOWN={shift}{tab}
  285. GRNPOWER={sys(0xF060)}
  286. BACK={BROWSER_BACK}
  287. CHNLUP={shift}{tab}
  288. CHNLDOWN={tab}
  289. FULLSCREEN={enter}
  290. [Radio]
  291. 1=1
  292. 2=2
  293. 3=3
  294. 4=4
  295. 5=5
  296. 6=6
  297. 7=7
  298. 8=8
  299. 9=9
  300. 0=0
  301. MUTE=m
  302. CHNLUP={f12}
  303. CHNLDOWN={f11}
  304. VOLUP={pgup}
  305. VOLDOWN={pgdn}
  306. TV={close(radio.exe)}{run(wintv2k.exe)}
  307. MINIMIZE=n
  308. RESERVED=r
  309. FULLSCREEN=s
  310. SOURCE={enter}
  311. GRNPOWER={close(radio.exe)}
  312. OK={enter}
  313. ; WinTV32 in fullscreen mode
  314. [FullScreen]
  315. 0=0
  316. 1=1
  317. 2=2
  318. 3=3
  319. 4=4
  320. 5=5
  321. 6=6
  322. 7=7
  323. 8=8
  324. 9=9
  325. MUTE={ctrl}m
  326. VOLUP={pgup}
  327. VOLDOWN={pgdn}
  328. CHNLUP=+
  329. CHNLDOWN=-
  330. FULLSCREEN={ctrl}t
  331. TV={alt}{f4}
  332. MINIMIZE={alt}{space}n
  333. SOURCE={ctrl}s
  334. RESERVED={ctrl}t{alt}p{sleep(10000)}{ctrl}t
  335. REC={ctrl}t{cmd(3325)}
  336. STOP={ctrl}f
  337. PAUSE={ctrl}t{cmd(3319)}{sleep(3000)}{ctrl}t
  338. PLAY={ctrl}t{cmd(3323)}
  339. REWIND={cmd(32803)}
  340. FASTFWD={cmd(32780}}
  341. SKIPFWD={cmd(32775)}
  342. SKIPREV={cmd(32879)}
  343. BACK={ctrl}t
  344. ;hcwGo app guys may prefer this
  345. ;GRNPOWER={sys(0xF060)}
  346. GRNPOWER={ctrl}t
  347. BLUE={space}
  348. GREEN={ctrl}t{sleep(100)}{alt}{f4}{sleep(750)}{run(radio.exe)}
  349. ;Live Mode - normal window
  350. [WinTV32]
  351. 0=0
  352. 1=1
  353. 2=2
  354. 3=3
  355. 4=4
  356. 5=5
  357. 6=6
  358. 7=7
  359. 8=8
  360. 9=9
  361. MUTE={ctrl}m
  362. VOLUP={pgup}
  363. VOLDOWN={pgdn}
  364. CHNLUP=+
  365. CHNLDOWN=-
  366. FULLSCREEN={ctrl}t
  367. TV={alt}{f4}
  368. RADIO={alt}{f4}{sleep(750)}{run(radio.exe)}
  369. MINIMIZE={alt}{space}n
  370. SOURCE={ctrl}s
  371. RESERVED={alt}p{sleep(3000)}
  372. BLUE={space}
  373. GRNPOWER={alt}{f4}
  374. ; CC on/off
  375. YELLOW={cmd(32878)}
  376. REC={cmd(3325)}
  377. STOP={ctrl}f
  378. PAUSE={cmd(3319)}{sleep(1500)}
  379. PLAY={cmd(3323)}
  380. BACK={cmd(3327)}
  381. ;some interesting buttons for Live mode
  382. ; Toggle NoTitle mode
  383. REWIND={cmd(32803)}
  384. ; Toggle TV mode
  385. FASTFWD={ctrl}t
  386. ; Start/stop surfing
  387. SKIPFWD={cmd(32775)}
  388. ; last channel
  389. SKIPREV={cmd(32879)}
  390. ;VCR Mode; recording
  391. [WinTV32(1)]
  392. 0=
  393. 1=
  394. 2=
  395. 3=
  396. 4=
  397. 5=
  398. 6=
  399. 7=
  400. 8=
  401. 9=
  402. MUTE={ctrl}m
  403. VOLUP={pgup}
  404. VOLDOWN={pgdn}
  405. CHNLUP=
  406. CHNLDOWN=
  407. FULLSCREEN={ctrl}t
  408. TV=
  409. MINIMIZE={alt}{space}n
  410. SOURCE=
  411. RESERVED=
  412. REC={cmd(3298)}
  413. STOP={cmd(3304)}
  414. PAUSE={cmd(3301)}
  415. PLAY=
  416. REWIND=
  417. FASTFWD=
  418. SKIPFWD=
  419. SKIPREV=
  420. BACK={cmd(3327)}
  421. GRNPOWER=
  422. BLUE={space}
  423. GREEN=
  424. ;VCR Mode; playing
  425. [WinTV32(2)]
  426. 0={alt}y
  427. 1=
  428. 2=
  429. 3=
  430. 4=
  431. 5=
  432. 6=
  433. 7=
  434. 8=
  435. 9=
  436. MUTE={ctrl}m
  437. VOLUP={pgup}
  438. VOLDOWN={pgdn}
  439. CHNLUP=
  440. CHNLDOWN=
  441. FULLSCREEN={ctrl}t
  442. TV={alt}n
  443. MINIMIZE={alt}s
  444. SOURCE=
  445. RESERVED={alt}q
  446. REC={cmd(3298)}
  447. STOP={cmd(3304)}
  448. PAUSE={cmd(3301)}
  449. PLAY={cmd(3299)}
  450. REWIND={cmd(3333)}
  451. FASTFWD={cmd(3334)}
  452. SKIPFWD={cmd(3305)}
  453. SKIPREV={cmd(3306)}
  454. BACK={cmd(3327)}
  455. GRNPOWER={cmd(3327)}
  456. BLUE={space}
  457. ;VCR Mode; paused
  458. [WinTV32(3)]
  459. 0={alt}y
  460. 1=
  461. 2=
  462. 3=
  463. 4=
  464. 5=
  465. 6=
  466. 7=
  467. 8=
  468. 9=
  469. MUTE={ctrl}m
  470. VOLUP={pgup}
  471. VOLDOWN={pgdn}
  472. CHNLUP=
  473. CHNLDOWN=
  474. FULLSCREEN={ctrl}t
  475. TV={alt}n
  476. MINIMIZE={alt}s
  477. SOURCE=
  478. RESERVED={alt}q
  479. REC={cmd(3298)}
  480. STOP={cmd(3304)}
  481. PAUSE={cmd(3301)}
  482. PLAY={cmd(3299)}
  483. REWIND={cmd(3333)}
  484. FASTFWD={cmd(3334)}
  485. SKIPFWD={cmd(3305)}
  486. SKIPREV={cmd(3306)}
  487. BACK={cmd(3327)}
  488. GRNPOWER={cmd(3327)}
  489. BLUE={space}
  490. ;VCR Mode; Live TV
  491. [WinTV32(4)]
  492. 0=0
  493. 1=1
  494. 2=2
  495. 3=3
  496. 4=4
  497. 5=5
  498. 6=6
  499. 7=7
  500. 8=8
  501. 9=9
  502. MUTE={ctrl}m
  503. VOLUP={pgup}
  504. VOLDOWN={pgdn}
  505. CHNLUP=+
  506. CHNLDOWN=-
  507. FULLSCREEN={ctrl}t
  508. TV={alt}{f4}
  509. MINIMIZE={alt}{space}n
  510. SOURCE={ctrl}s
  511. RESERVED={alt}p
  512. REC={cmd(3298)}
  513. STOP={cmd(3327)}
  514. PAUSE={cmd(3319)}{sleep(1500)}
  515. PLAY={cmd(3299)}
  516. REWIND={cmd(3333)}
  517. FASTFWD={cmd(3334)}
  518. SKIPFWD={cmd(3305)}
  519. SKIPREV={cmd(3306)}
  520. BACK={cmd(3327)}
  521. GRNPOWER={cmd(3327)}
  522. BLUE={space}
  523. ;Pause Mode; sliping or paused
  524. [WinTV32(5)]
  525. 0={alt}y
  526. 1=
  527. 2=
  528. 3=
  529. 4=
  530. 5=
  531. 6=
  532. 7=
  533. 8=
  534. 9=
  535. MUTE={ctrl}m
  536. VOLUP={pgup}
  537. VOLDOWN={pgdn}
  538. CHNLUP=
  539. CHNLDOWN=
  540. FULLSCREEN={ctrl}t
  541. TV={alt}n
  542. MINIMIZE={alt}s
  543. SOURCE=
  544. RESERVED={alt}q
  545. REC={cmd(3298)}
  546. STOP={cmd(3327)}
  547. PAUSE={cmd(3301)}
  548. PLAY={cmd(3299)}
  549. REWIND={cmd(3333)}
  550. FASTFWD={cmd(3334)}
  551. SKIPFWD={cmd(3305)}
  552. SKIPREV={cmd(3306)}
  553. BACK={cmd(3327)}
  554. GRNPOWER={cmd(3327)}
  555. BLUE={space}
  556. ;Live Mode - FullScreen
  557. ; or VCR Mode, Live - Fullscreen
  558. [WinTV32(8)]
  559. 0=0
  560. 1=1
  561. 2=2
  562. 3=3
  563. 4=4
  564. 5=5
  565. 6=6
  566. 7=7
  567. 8=8
  568. 9=9
  569. MUTE={ctrl}m
  570. VOLUP={pgup}
  571. VOLDOWN={pgdn}
  572. CHNLUP=+
  573. CHNLDOWN=-
  574. FULLSCREEN={ctrl}t
  575. TV={alt}{f4}
  576. MINIMIZE={alt}{space}n
  577. SOURCE={ctrl}s
  578. RESERVED={ctrl}t{alt}p{sleep(10000)}{ctrl}t
  579. REC={ctrl}t{cmd(3325)}
  580. STOP={ctrl}f
  581. PAUSE={ctrl}t{cmd(3319)}{sleep(3000)}{ctrl}t
  582. PLAY={ctrl}t{cmd(3323)}
  583. REWIND={cmd(32803)}
  584. FASTFWD={cmd(32780}}
  585. SKIPFWD={cmd(32775)}
  586. SKIPREV={cmd(32879)}
  587. BACK={ctrl}t
  588. ;hcwGo app guys may prefer this
  589. ;GRNPOWER={sys(0xF060)}
  590. GRNPOWER={ctrl}t
  591. BLUE={space}
  592. GREEN={ctrl}t{sleep(100)}{alt}{f4}{sleep(750)}{run(radio.exe)}
  593. ;Pause Mode, slipping, or paused Fullscreen
  594. [WinTV32(9)]
  595. 0={alt}y
  596. 1=
  597. 2=
  598. 3=
  599. 4=
  600. 5=
  601. 6=
  602. 7=
  603. 8=
  604. 9=
  605. MUTE={ctrl}m
  606. VOLUP={pgup}
  607. VOLDOWN={pgdn}
  608. CHNLUP=
  609. CHNLDOWN=
  610. FULLSCREEN={ctrl}t
  611. TV={ctrl}t{sleep(1000)}{alt}n{sleep(10000)}{ctrl}t
  612. MINIMIZE={alt}s
  613. SOURCE=
  614. RESERVED={alt}q
  615. REC={ctrl}t{cmd(3298)}
  616. STOP={ctrl}t{cmd(3327)}
  617. PAUSE={cmd(3301)}
  618. PLAY={cmd(3299)}
  619. REWIND={cmd(3333)}
  620. FASTFWD={cmd(3334)}
  621. SKIPFWD={cmd(3305)}
  622. SKIPREV={cmd(3306)}
  623. BACK={ctrl}t{sleep(1000)}{cmd(3327)}
  624. GRNPOWER={ctrl}t
  625. BLUE={space}
  626. GREEN={ctrl}t{sleep(100)}{alt}{f4}{sleep(750)}{run(radio.exe)}
  627. ;VCR Mode, Playing, Fullscreen
  628. [WinTV32(10)]
  629. 0={alt}y
  630. 1=
  631. 2=
  632. 3=
  633. 4=
  634. 5=
  635. 6=
  636. 7=
  637. 8=
  638. 9=
  639. MUTE={ctrl}m
  640. VOLUP={pgup}
  641. VOLDOWN={pgdn}
  642. CHNLUP=
  643. CHNLDOWN=
  644. FULLSCREEN={ctrl}t
  645. TV={ctrl}t{sleep(1000)}{alt}n{sleep(3000)}{ctrl}t
  646. MINIMIZE={alt}s
  647. SOURCE=
  648. RESERVED={cmd(3301)}
  649. REC={ctrl}t{cmd(3298)}
  650. STOP={ctrl}t{cmd(3304)}{sleep(100)}{ctrl}t
  651. PAUSE={cmd(3301)}
  652. PLAY={cmd(3299)}
  653. REWIND={cmd(3333)}
  654. FASTFWD={cmd(3334)}
  655. SKIPFWD={cmd(3305)}
  656. SKIPREV={cmd(3306)}
  657. BACK={ctrl}t{sleep(1000)}{cmd(3327)}
  658. GRNPOWER={ctrl}t
  659. BLUE={space}
  660. GREEN={ctrl}t{sleep(100)}{alt}{f4}{sleep(750)}{run(radio.exe)}
  661. ;VCR Mode, Paused, Fullscreen
  662. [WinTV32(11)]
  663. 0={alt}y
  664. 1=
  665. 2=
  666. 3=
  667. 4=
  668. 5=
  669. 6=
  670. 7=
  671. 8=
  672. 9=
  673. MUTE={ctrl}m
  674. VOLUP={pgup}
  675. VOLDOWN={pgdn}
  676. CHNLUP=
  677. CHNLDOWN=
  678. FULLSCREEN={ctrl}t
  679. TV={alt}{f4}
  680. MINIMIZE={alt}s
  681. SOURCE=
  682. RESERVED={cmd(3301)}
  683. REC={ctrl}t{cmd(3298)}
  684. STOP={ctrl}t{cmd(3327)}
  685. PAUSE={cmd(3301)}
  686. PLAY={cmd(3299)}
  687. REWIND={cmd(3333)}
  688. FASTFWD={cmd(3334)}
  689. SKIPFWD={cmd(3305)}
  690. SKIPREV={cmd(3306)}
  691. BACK={ctrl}t{sleep(1000)}{cmd(3327)}
  692. GRNPOWER={ctrl}t
  693. BLUE={space}
  694. GREEN={ctrl}t{sleep(100)}{alt}{f4}{sleep(750)}{run(radio.exe)}
  695. ;VCR Mode; recording; Fullscreen
  696. [WinTV32(12)]
  697. 0=
  698. 1=
  699. 2=
  700. 3=
  701. 4=
  702. 5=
  703. 6=
  704. 7=
  705. 8=
  706. 9=
  707. MUTE={ctrl}m
  708. VOLUP={pgup}
  709. VOLDOWN={pgdn}
  710. CHNLUP=
  711. CHNLDOWN=
  712. FULLSCREEN={ctrl}t
  713. TV=
  714. RADIO=
  715. MINIMIZE={alt}{space}n
  716. SOURCE=
  717. RESERVED=
  718. REC={cmd(3298)}
  719. STOP={cmd(3304)}
  720. PAUSE={cmd(3301)}
  721. PLAY=
  722. REWIND=
  723. FASTFWD=
  724. SKIPFWD=
  725. SKIPREV=
  726. BACK={ctrl}t
  727. GRNPOWER={ctrl}t
  728. BLUE={space}
  729. GREEN=
  730. ;full screen slip mode
  731. [PVRFullScreen]
  732. 0={alt}y
  733. 1=
  734. 2=
  735. 3=
  736. 4=
  737. 5=
  738. 6=
  739. 7=
  740. 8=
  741. 9=
  742. MUTE={ctrl}m
  743. VOLUP={pgup}
  744. VOLDOWN={pgdn}
  745. CHNLUP=
  746. CHNLDOWN=
  747. FULLSCREEN={ctrl}t
  748. TV={ctrl}t{sleep(1000)}{alt}n{sleep(10000)}{ctrl}t
  749. MINIMIZE={alt}s
  750. SOURCE=
  751. RESERVED={alt}q
  752. REC={ctrl}t{cmd(3298)}
  753. STOP={ctrl}t{cmd(3327)}
  754. PAUSE={cmd(3301)}
  755. PLAY={cmd(3299)}
  756. REWIND={cmd(3333)}
  757. FASTFWD={cmd(3334)}
  758. SKIPFWD={cmd(3305)}
  759. SKIPREV={cmd(3306)}
  760. BACK={ctrl}t{sleep(1000)}{cmd(3327)}
  761. GRNPOWER={ctrl}t
  762. BLUE={space}
  763. GREEN={ctrl}t{sleep(100)}{alt}{f4}{sleep(750)}{run(radio.exe)}
  764. ; TV16 in a Window
  765. [Win/TV]
  766. 0=0
  767. 1=1
  768. 2=2
  769. 3=3
  770. 4=4
  771. 5=5
  772. 6=6
  773. 7=7
  774. 8=8
  775. 9=9
  776. MUTE={ctrl}m
  777. VOLUP={pgup}
  778. VOLDOWN={pgdn}
  779. CHNLUP=+
  780. CHNLDOWN=-
  781. FULLSCREEN={ctrl}t
  782. TV={alt}{f4}
  783. MINIMIZE={alt}{space}n
  784. ;Wintv16 Full Screen TV Mode
  785. [Win/TV+]
  786. 0=0
  787. 1=1
  788. 2=2
  789. 3=3
  790. 4=4
  791. 5=5
  792. 6=6
  793. 7=7
  794. 8=8
  795. 9=9
  796. TV={alt}{f4}
  797. MUTE={ctrl}m
  798. VOLUP={pgup}
  799. VOLDOWN={pgdn}
  800. CHNLUP=+
  801. CHNLDOWN=-
  802. FULLSCREEN={ctrl}t
  803. SOURCE=
  804. MINIMIZE=
  805. ; Special Macro Table for Task Switch Mode
  806. [*task*]
  807. 0=
  808. 1=
  809. 2=
  810. 3=
  811. 4=
  812. 4=
  813. 5=
  814. 6=
  815. 7=
  816. 8=
  817. 9=
  818. RADIO=
  819. MUTE=
  820. TV=
  821. VOLUP={tab}
  822. VOLDOWN={shift}{tab}
  823. ;RESERVED={esc}{^menu}{mode()}
  824. CHNLUP=
  825. CHNLDOWN=
  826. SOURCE={^menu}{mode()}
  827. MINIMIZE=
  828. FULLSCREEN=
  829. GREEN={esc}{^menu}{mode()}
  830. GRNPOWER={esc}{^menu}{mode()}
  831. BACK={esc}{^menu}{mode()}
  832. OK={^menu}{mode()}
  833. ; to use this, open notepad with a document name of debug.txt and set focus to it.
  834. ; debug.txt= must be uncommented in [applications] section as well.
  835. [Debug.txt]
  836. 0=0{enter}
  837. 1=1{enter}
  838. 2=2{enter}
  839. 3=3{enter}
  840. 4=4{enter}
  841. 5=5{enter}
  842. 6=6{enter}
  843. 7=7{enter}
  844. 8=8{enter}
  845. 9=9{enter}
  846. FULLSCREEN=FULLSCREEN{enter}
  847. RADIO=RADIO{enter}
  848. MUTE=MUTE{enter}
  849. TV=TV{enter}
  850. VOLUP=VOLUP{enter}
  851. VOLDOWN=VOLDOWN{enter}
  852. RESERVED=RESERVED{enter}
  853. CHNLUP=CHNLUP{enter}
  854. CHNLDOWN=CHNLDOWN{enter}
  855. SOURCE=SOURCE{enter}
  856. MINIMIZE=MINIMIZE{enter}
  857. SKIPFWD=SKIPFWD{enter}
  858. SKIPREV=SKIPREV{enter}
  859. GRNPOWER=GRNPOWER{enter}
  860. BACK=BACK{enter}
  861. GUIDE=GUIDE{enter}
  862. OK=OK{enter}
  863. MENU=MENU{enter}
  864. REC=REC{enter}
  865. STOP=STOP{enter}
  866. PAUSE=PAUSE{enter}
  867. PLAY=PLAY{enter}
  868. REWIND=REWIND{enter}
  869. FASTFWD=FASTFWD{enter}
  870. GO=GO{enter}
  871. CODE0=CODE0{enter}
  872. CODE1=CODE1{enter}
  873. CODE2=CODE2{enter}
  874. CODE3=CODE3{enter}
  875. CODE4=CODE4{enter}
  876. CODE5=CODE5{enter}
  877. CODE6=CODE6{enter}
  878. CODE7=CODE7{enter}
  879. CODE8=CODE8{enter}
  880. CODE9=CODE9{enter}
  881. CODE10=CODE10{enter}
  882. CODE11=CODE11{enter}
  883. CODE12=CODE12{enter}
  884. CODE13=CODE13{enter}
  885. CODE14=CODE14{enter}
  886. CODE15=CODE15{enter}
  887. CODE16=CODE16{enter}
  888. CODE17=CODE17{enter}
  889. CODE18=CODE18{enter}
  890. CODE19=CODE19{enter}
  891. CODE20=CODE20{enter}
  892. CODE21=CODE21{enter}
  893. CODE22=CODE22{enter}
  894. CODE23=CODE23{enter}
  895. CODE24=CODE24{enter}
  896. CODE25=CODE25{enter}
  897. CODE26=CODE26{enter}
  898. CODE27=CODE27{enter}
  899. CODE28=CODE28{enter}
  900. CODE29=CODE29{enter}
  901. CODE30=CODE30{enter}
  902. CODE31=CODE31{enter}
  903. CODE32=CODE32{enter}
  904. CODE33=CODE33{enter}
  905. CODE34=CODE34{enter}
  906. CODE35=CODE35{enter}
  907. CODE36=CODE36{enter}
  908. CODE37=CODE37{enter}
  909. CODE38=CODE38{enter}
  910. CODE39=CODE39{enter}
  911. CODE40=CODE40{enter}
  912. CODE41=CODE41{enter}
  913. CODE42=CODE42{enter}
  914. CODE43=CODE43{enter}
  915. CODE44=CODE44{enter}
  916. CODE45=CODE45{enter}
  917. CODE46=CODE46{enter}
  918. CODE47=CODE47{enter}
  919. CODE48=CODE48{enter}
  920. CODE49=CODE49{enter}
  921. CODE50=CODE50{enter}
  922. CODE51=CODE51{enter}
  923. CODE52=CODE52{enter}
  924. CODE53=CODE53{enter}
  925. CODE54=CODE54{enter}
  926. CODE55=CODE55{enter}
  927. CODE56=CODE56{enter}
  928. CODE57=CODE57{enter}
  929. CODE58=CODE58{enter}
  930. CODE59=CODE59{enter}
  931. CODE60=CODE60{enter}
  932. CODE61=CODE61{enter}
  933. CODE62=CODE62{enter}
  934. CODE63=CODE63{enter}
  935. ; TODO: Name to number mapping for sending APPCommands ; or general string
  936. replacement??
  937. ; for now, here is a list as reference
  938. ;[APPCommands]
  939. ;APPCOMMAND_BROWSER_BACKWARD       0x10000
  940. ;APPCOMMAND_BROWSER_FORWARD        0x20000
  941. ;APPCOMMAND_BROWSER_REFRESH        0x30000
  942. ;APPCOMMAND_BROWSER_STOP           0x40000
  943. ;APPCOMMAND_BROWSER_SEARCH         0x50000
  944. ;APPCOMMAND_BROWSER_FAVORITES      0x60000
  945. ;APPCOMMAND_BROWSER_HOME           0x70000
  946. ;APPCOMMAND_VOLUME_MUTE            0x80000
  947. ;APPCOMMAND_VOLUME_DOWN            0x90000
  948. ;APPCOMMAND_VOLUME_UP              0xa0000
  949. ;APPCOMMAND_MEDIA_NEXTTRACK        0xb0000
  950. ;APPCOMMAND_MEDIA_PREVIOUSTRACK    0xc0000
  951. ;APPCOMMAND_MEDIA_STOP             0xd0000
  952. ;APPCOMMAND_MEDIA_PLAY_PAUSE       0xe0000
  953. ;APPCOMMAND_LAUNCH_MAIL            0xf0000
  954. ;APPCOMMAND_LAUNCH_MEDIA_SELECT    0x100000
  955. ;APPCOMMAND_LAUNCH_APP1            0x110000
  956. ;APPCOMMAND_LAUNCH_APP2            0x120000
  957. ;APPCOMMAND_BASS_DOWN              0x130000
  958. ;APPCOMMAND_BASS_BOOST             0x140000
  959. ;APPCOMMAND_BASS_UP                0x150000
  960. ;APPCOMMAND_TREBLE_DOWN            0x160000
  961. ;APPCOMMAND_TREBLE_UP              0x170000
  962. ;APPCOMMAND_MICROPHONE_VOLUME_MUTE 0x180000
  963. ;APPCOMMAND_MICROPHONE_VOLUME_DOWN 0x190000
  964. ;APPCOMMAND_MICROPHONE_VOLUME_UP   0x1a0000
  965. ;APPCOMMAND_HELP                   0x1b0000
  966. ;APPCOMMAND_FIND                   0x1c0000
  967. ;APPCOMMAND_NEW                    0x1d0000
  968. ;APPCOMMAND_OPEN                   0x1e0000
  969. ;APPCOMMAND_CLOSE                  0x1f0000
  970. ;APPCOMMAND_SAVE                   0x200000
  971. ;APPCOMMAND_PRINT                  0x210000
  972. ;APPCOMMAND_UNDO                   0x220000
  973. ;APPCOMMAND_REDO                   0x230000
  974. ;APPCOMMAND_COPY                   0x240000
  975. ;APPCOMMAND_CUT                    0x250000
  976. ;APPCOMMAND_PASTE                  0x260000
  977. ;APPCOMMAND_REPLY_TO_MAIL          0x270000
  978. ;APPCOMMAND_FORWARD_MAIL           0x280000
  979. ;APPCOMMAND_SEND_MAIL              0x290000
  980. ;APPCOMMAND_SPELL_CHECK            0x2a0000
  981. ;APPCOMMAND_DICTATE_OR_COMMAND_CONTROL_TOGGLE    0x2b0000
  982. ;APPCOMMAND_MIC_ON_OFF_TOGGLE      0x2c0000
  983. ;APPCOMMAND_CORRECTION_LIST        0x2d0000
  984. ; new for WINXP SP1 - FREESTYLE
  985. ;APPCOMMAND_PLAY        0x2e0000
  986. ;APPCOMMAND_PAUSE       0x2f0000
  987. ;APPCOMMAND_RECORD      0x300000
  988. ;APPCOMMAND_FASTFORW    0x310000
  989. ;APPCOMMAND_FASTBACK    0x320000
  990. ;APPCOMMAND_CHAN_UP     0x330000
  991. ;APPCOMMAND_CHAN_DN     0x340000
  992. ; WinTV2000 Command IDs for PVR functions
  993. ; ID_STREAM_RECORD                3298
  994. ; ID_STREAM_SETUP_VCD             3330 (starts VCD recording)
  995. ; ID_STREAM_PLAY                  3299
  996. ; ID_STREAM_PAUSE                 3301
  997. ; ID_STREAM_STOP                  3304
  998. ; ID_STREAM_FF                    3305 (10 secs fwd)
  999. ; ID_STREAM_REWIND                3306 (10 secs back)
  1000. ; ID_STREAM_EARLIEST              3307 (jump to start)
  1001. ; ID_STREAM_LATEST                3308 (jump to end/near Live)
  1002. ; ID_STREAM_PLAY_BACKWARDS        3333
  1003. ; ID_STREAM_PLAY_FORWARD_FAST     3334
  1004. ; ID_BUTTON_OTP                   3328 (Slip mode; don't pause)
  1005. ; ID_STREAM_START_SLIP_MODE       3319 (Slip mode; start paused)
  1006. ; ID_BUTTON_OTR                   3325 (start recording)
  1007. ; ID_BUTTON_NORMAL_MODE           3327 (back to Live mode, close tray )
  1008. ; ID_BUTTON_FILE_PLAY             3323 (the main app REC button, don't ask)
bubblegum Lut all,
Code :
  5. [Remote]
  6. RepeatDelay=3
  12. [SystemCode]
  13. 0=HCWClassic
  14. 31=HCWPVR
  16. basis
  21. remotes
  24. TV
  26. on PVR
  28. [HCWClassic]
  29. 0=0
  30. 1=1
  31. 2=2
  32. 3=3
  33. 4=4
  34. 5=5
  35. 6=6
  36. 7=7
  37. 8=8
  38. 9=9
  39. 12=RADIO
  40. 13=MUTE
  41. 15=TV
  42. 16=VOLUP
  43. 17=VOLDOWN
  44. 30=RESERVED
  45. 32=CHNLUP
  46. 33=CHNLDOWN
  47. 34=SOURCE
  48. 38=MINIMIZE
  49. 46=FULLSCREEN
  50. [HCWPVR]
  51. 0=0
  52. 1=1
  53. 2=2
  54. 3=3
  55. 4=4
  56. 5=5
  57. 6=6
  58. 7=7
  59. 8=8
  60. 9=9
  61. 46=GREEN
  62. 56=YELLOW
  63. 11=RED
  64. 41=BLUE
  65. 12=FUNC
  66. 13=MENU
  67. 15=MUTE
  68. 16=VOLUP
  69. 17=VOLDOWN
  70. 32=CHNLUP
  71. 33=CHNLDOWN
  72. 61=GRNPOWER
  73. 31=BACK
  74. 37=OK
  75. 59=GO
  76. 60=FULLSCREEN
  77. 55=REC
  78. 54=STOP
  79. 48=PAUSE
  80. 53=PLAY
  81. 50=REWIND
  82. 52=FASTFWD
  83. 30=SKIPFWD
  84. 36=SKIPREV
  86. [Applications]
  87. Default=
  88. WinTV Remote=
  89. ;Win/TV+=
  90. ;Win/TV=
  91. WinTV32=
  92. WinTV32(1)=
  93. WinTV32(2)=
  94. WinTV32(3)=
  95. WinTV32(4)=
  96. WinTV32(5)=
  97. WinTV32(8)=
  98. WinTV32(9)=
  99. WinTV32(10)=
  100. WinTV32(11)=
  101. WinTV32(12)=
  102. FullScreen=
  103. PVRFullScreen=
  104. *task*=
  105. ;*suspend*=
  106. EPGdemo=
  107. VTplus=
  109. Debug.txt=
  111. hcwGo=
  114. [Default]
  115. 0=
  116. 1=
  117. 2=
  118. 3=
  119. 4=
  120. 5=
  121. 6=
  122. 7=
  123. 8=
  124. 9=
  127. MINIMIZE=
  129. RESERVED=
  133. GO={gomenu()}
  156. [WinTV Remote]
  157. OK={enter}
  158. VOLUP={tab}
  162. CHNLDOWN={tab}
  164. SOURCE={enter}
  165. OK={enter}
  166. GO={enter}
  167. GRNPOWER={esc}
  169. [hcwGo]
  170. CHNLUP={UP}
  172. VOLUP={RIGHT}
  173. VOLDOWN={LEFT}
  175. OK={enter}
  176. BACK={BACK}
  177. GRNPOWER={esc}
  178. GO={space}
  179. GREEN={F2}
  180. RED={F3}
  182. CHNLUP={home}
  183. CHNLDOWN={end}
  184. VOLUP={pgdn}
  185. VOLDOWN={pgup}
  187. OK={enter}
  188. BACK={BACK}
  189. GRNPOWER={esc}
  190. GO={space}
  194. BACK={esc}
  195. MUTE={F8}
  196. VOLUP={F10}
  197. VOLDOWN={F9}
  198. CHNLUP={VK_UP}
  200. OK={enter}
  201. REC=
  202. STOP={ctrl}s
  203. PAUSE={ctrl}p
  204. PLAY={ctrl}p
  205. REWIND={ctrl}b
  209. 1={alt}1
  210. 2={alt}2
  211. 3={alt}3
  212. YELLOW={ctrl}1
  213. BLUE={ctrl}2
  219. BACK={esc}
  220. MUTE={F8}
  221. VOLUP={F10}
  222. VOLDOWN={F9}
  223. CHNLUP=
  224. CHNLDOWN=
  225. REC=
  233. 1={alt}1
  234. 2={alt}2
  235. 3={alt}3
  236. YELLOW={ctrl}1
  237. BLUE={ctrl}2
  239. [VTplus]
  240. 0={ctrl}n0
  241. 1={ctrl}n1
  242. 2={ctrl}n2
  243. 3={ctrl}n3
  244. 4={ctrl}n4
  245. 5={ctrl}n5
  246. 6={ctrl}n6
  247. 7={ctrl}n7
  248. 8={ctrl}n8
  249. 9={ctrl}n9
  250. OK={enter}
  256. STOP={ctrl}s
  257. RED={cmd(501)}
  264. 0=0
  265. 1=1
  266. 2=2
  267. 3=3
  268. 4=4
  269. 5=5
  270. 6=6
  271. 7=7
  272. 8=8
  273. 9=9
  274. OK={enter}
  276. CHNLDOWN={tab}
  277. VOLDOWN={left}
  278. VOLUP={right}
  279. BACK={esc}
  281. [EPGdemo]
  282. OK={enter}
  283. VOLUP={tab}
  288. CHNLDOWN={tab}
  290. [Radio]
  291. 1=1
  292. 2=2
  293. 3=3
  294. 4=4
  295. 5=5
  296. 6=6
  297. 7=7
  298. 8=8
  299. 9=9
  300. 0=0
  301. MUTE=m
  302. CHNLUP={f12}
  303. CHNLDOWN={f11}
  304. VOLUP={pgup}
  305. VOLDOWN={pgdn}
  307. MINIMIZE=n
  308. RESERVED=r
  309. FULLSCREEN=s
  310. SOURCE={enter}
  312. OK={enter}
  314. [FullScreen]
  315. 0=0
  316. 1=1
  317. 2=2
  318. 3=3
  319. 4=4
  320. 5=5
  321. 6=6
  322. 7=7
  323. 8=8
  324. 9=9
  325. MUTE={ctrl}m
  326. VOLUP={pgup}
  327. VOLDOWN={pgdn}
  328. CHNLUP=+
  329. CHNLDOWN=-
  331. TV={alt}{f4}
  333. SOURCE={ctrl}s
  336. STOP={ctrl}f
  343. BACK={ctrl}t
  347. BLUE={space}
  350. [WinTV32]
  351. 0=0
  352. 1=1
  353. 2=2
  354. 3=3
  355. 4=4
  356. 5=5
  357. 6=6
  358. 7=7
  359. 8=8
  360. 9=9
  361. MUTE={ctrl}m
  362. VOLUP={pgup}
  363. VOLDOWN={pgdn}
  364. CHNLUP=+
  365. CHNLDOWN=-
  367. TV={alt}{f4}
  370. SOURCE={ctrl}s
  372. BLUE={space}
  374. ; CC on/off
  377. STOP={ctrl}f
  388. ; last channel
  391. [WinTV32(1)]
  392. 0=
  393. 1=
  394. 2=
  395. 3=
  396. 4=
  397. 5=
  398. 6=
  399. 7=
  400. 8=
  401. 9=
  402. MUTE={ctrl}m
  403. VOLUP={pgup}
  404. VOLDOWN={pgdn}
  405. CHNLUP=
  406. CHNLDOWN=
  408. TV=
  410. SOURCE=
  411. RESERVED=
  415. PLAY=
  416. REWIND=
  417. FASTFWD=
  418. SKIPFWD=
  419. SKIPREV=
  421. GRNPOWER=
  422. BLUE={space}
  423. GREEN=
  425. [WinTV32(2)]
  426. 0={alt}y
  427. 1=
  428. 2=
  429. 3=
  430. 4=
  431. 5=
  432. 6=
  433. 7=
  434. 8=
  435. 9=
  436. MUTE={ctrl}m
  437. VOLUP={pgup}
  438. VOLDOWN={pgdn}
  439. CHNLUP=
  440. CHNLDOWN=
  442. TV={alt}n
  444. SOURCE=
  456. BLUE={space}
  458. [WinTV32(3)]
  459. 0={alt}y
  460. 1=
  461. 2=
  462. 3=
  463. 4=
  464. 5=
  465. 6=
  466. 7=
  467. 8=
  468. 9=
  469. MUTE={ctrl}m
  470. VOLUP={pgup}
  471. VOLDOWN={pgdn}
  472. CHNLUP=
  473. CHNLDOWN=
  475. TV={alt}n
  477. SOURCE=
  489. BLUE={space}
  491. [WinTV32(4)]
  492. 0=0
  493. 1=1
  494. 2=2
  495. 3=3
  496. 4=4
  497. 5=5
  498. 6=6
  499. 7=7
  500. 8=8
  501. 9=9
  502. MUTE={ctrl}m
  503. VOLUP={pgup}
  504. VOLDOWN={pgdn}
  505. CHNLUP=+
  506. CHNLDOWN=-
  508. TV={alt}{f4}
  510. SOURCE={ctrl}s
  522. BLUE={space}
  524. [WinTV32(5)]
  525. 0={alt}y
  526. 1=
  527. 2=
  528. 3=
  529. 4=
  530. 5=
  531. 6=
  532. 7=
  533. 8=
  534. 9=
  535. MUTE={ctrl}m
  536. VOLUP={pgup}
  537. VOLDOWN={pgdn}
  538. CHNLUP=
  539. CHNLDOWN=
  541. TV={alt}n
  543. SOURCE=
  555. BLUE={space}
  558. [WinTV32(8)]
  559. 0=0
  560. 1=1
  561. 2=2
  562. 3=3
  563. 4=4
  564. 5=5
  565. 6=6
  566. 7=7
  567. 8=8
  568. 9=9
  569. MUTE={ctrl}m
  570. VOLUP={pgup}
  571. VOLDOWN={pgdn}
  572. CHNLUP=+
  573. CHNLDOWN=-
  575. TV={alt}{f4}
  577. SOURCE={ctrl}s
  580. STOP={ctrl}f
  587. BACK={ctrl}t
  591. BLUE={space}
  594. [WinTV32(9)]
  595. 0={alt}y
  596. 1=
  597. 2=
  598. 3=
  599. 4=
  600. 5=
  601. 6=
  602. 7=
  603. 8=
  604. 9=
  605. MUTE={ctrl}m
  606. VOLUP={pgup}
  607. VOLDOWN={pgdn}
  608. CHNLUP=
  609. CHNLDOWN=
  613. SOURCE=
  625. BLUE={space}
  628. [WinTV32(10)]
  629. 0={alt}y
  630. 1=
  631. 2=
  632. 3=
  633. 4=
  634. 5=
  635. 6=
  636. 7=
  637. 8=
  638. 9=
  639. MUTE={ctrl}m
  640. VOLUP={pgup}
  641. VOLDOWN={pgdn}
  642. CHNLUP=
  643. CHNLDOWN=
  647. SOURCE=
  659. BLUE={space}
  662. [WinTV32(11)]
  663. 0={alt}y
  664. 1=
  665. 2=
  666. 3=
  667. 4=
  668. 5=
  669. 6=
  670. 7=
  671. 8=
  672. 9=
  673. MUTE={ctrl}m
  674. VOLUP={pgup}
  675. VOLDOWN={pgdn}
  676. CHNLUP=
  677. CHNLDOWN=
  679. TV={alt}{f4}
  681. SOURCE=
  693. BLUE={space}
  696. [WinTV32(12)]
  697. 0=
  698. 1=
  699. 2=
  700. 3=
  701. 4=
  702. 5=
  703. 6=
  704. 7=
  705. 8=
  706. 9=
  707. MUTE={ctrl}m
  708. VOLUP={pgup}
  709. VOLDOWN={pgdn}
  710. CHNLUP=
  711. CHNLDOWN=
  713. TV=
  714. RADIO=
  716. SOURCE=
  717. RESERVED=
  721. PLAY=
  722. REWIND=
  723. FASTFWD=
  724. SKIPFWD=
  725. SKIPREV=
  726. BACK={ctrl}t
  728. BLUE={space}
  729. GREEN=
  732. 0={alt}y
  733. 1=
  734. 2=
  735. 3=
  736. 4=
  737. 5=
  738. 6=
  739. 7=
  740. 8=
  741. 9=
  742. MUTE={ctrl}m
  743. VOLUP={pgup}
  744. VOLDOWN={pgdn}
  745. CHNLUP=
  746. CHNLDOWN=
  750. SOURCE=
  762. BLUE={space}
  765. [Win/TV]
  766. 0=0
  767. 1=1
  768. 2=2
  769. 3=3
  770. 4=4
  771. 5=5
  772. 6=6
  773. 7=7
  774. 8=8
  775. 9=9
  776. MUTE={ctrl}m
  777. VOLUP={pgup}
  778. VOLDOWN={pgdn}
  779. CHNLUP=+
  780. CHNLDOWN=-
  782. TV={alt}{f4}
  785. [Win/TV+]
  786. 0=0
  787. 1=1
  788. 2=2
  789. 3=3
  790. 4=4
  791. 5=5
  792. 6=6
  793. 7=7
  794. 8=8
  795. 9=9
  796. TV={alt}{f4}
  797. MUTE={ctrl}m
  798. VOLUP={pgup}
  799. VOLDOWN={pgdn}
  800. CHNLUP=+
  801. CHNLDOWN=-
  803. SOURCE=
  804. MINIMIZE=
  806. [*task*]
  807. 0=
  808. 1=
  809. 2=
  810. 3=
  811. 4=
  812. 4=
  813. 5=
  814. 6=
  815. 7=
  816. 8=
  817. 9=
  818. RADIO=
  819. MUTE=
  820. TV=
  821. VOLUP={tab}
  824. CHNLUP=
  825. CHNLDOWN=
  827. MINIMIZE=
  828. FULLSCREEN=
  835. [Debug.txt]
  836. 0=0{enter}
  837. 1=1{enter}
  838. 2=2{enter}
  839. 3=3{enter}
  840. 4=4{enter}
  841. 5=5{enter}
  842. 6=6{enter}
  843. 7=7{enter}
  844. 8=8{enter}
  845. 9=9{enter}
  849. TV=TV{enter}
  862. OK=OK{enter}
  864. REC=REC{enter}
  870. GO=GO{enter}
  936. replacement??
  938. ;[APPCommands]
mems Merci j'ai vu sur le site de hauppauge je vais m'en inspirer.
vrtcm Avec ces paramètres je peux :
Utiliser Winamp, eteindre le PC (La séquence de touche Alt+F4 ferme toute les fenêtres, et qand il n'y a plus de fenêtre demande de fermer Windows ...)
Je commande aussi BSPlayer pour lecture de Divx;) (Réglages du son, Pause, Lecture, avance rapide + retour rapide)
Une fois que K!TV 1.1.0.3 est lancé c'est lui qui gère la télécommande. Il relance WinTV Remote Controller lorsque K!TV est quitté.
[Default]
0={end}
1=s
2=v
3=r
4={left}
5={enter}
6={right}
7={pgdn}
8={home}
9={pgup}
CHNLUP=b
CHNLDOWN=z
VOLUP={up}
VOLDOWN={down}
SOURCE={ctrl}{tab}
MINIMIZE={alt}{f4}
MUTE=c
FULLSCREEN=x
RESERVED={enter}
Radio={run(C:\progra~1\winamp\winamp.exe)}
mems Je fait pareil aussi avec la telecommande mais j'ai rencontrer deux probleme mon poste ne s'eteint pas a distance pourtant la  ligne de commande est bonne mais il me met le message vous pouvez eteindre votre ordinateur.
Et je cherche les racourcis clavier pour monter et descendre le sons.
Si vous pouver m'aider.
Je conseille fortement le Ktv au wtv2000
Ligne de commandfe pour eteindre l'ordi sous XP:
shutdown.exe -s -t 0
Ligne de commande pour le irremote.ini eteindre l'ordi:
{run(C:\Progra~1\K!TV-XP\\shutdown.exe -s -t 0)}
Ligne de commande pour le irremote.ini lancer Ktv a la place de wtv2000 :
{close(radio.exe)}{run(C:\Progra~1\K!TV-XP\\K!TV-XP.exe)}
PS:Faite une sauvegarde du irremote.ini avavnt modif tous ca sous XP
the_farbarian Je ne pense pas, à priori, la télécommande émule le clavier donc ...
Et puis l'intéret ?
vrtcm J'ai K!TV 1.1.0.3, un chipset VIA (cf config) et ca marche nickel.
Question : Est ce qu'il est possible avec la télécommande hauppauge de bouger le curseur de souris ?
thenutskiller Pas de chipset VIA, pas de problèmes!
the_farbarian non j'ai une Elite K7S5A -> SIS 735
thenutskiller Tu as un chipset VIA ?
the_farbarian Dans ce cas...
Moi c'est le contraire ...
thenutskiller K!TV à une image complètement pourrie chez moi (bug VIA/AGP oblige)...
the_farbarian j'ai tout taper pour rien  :cry:
Essai K!TV, tu trouveras facilement sur Internet.
Je crois que ce n'est pas possible d'aller plus vite.
Le pb de K!TV, c'est que l'on ne peut pas faire d'acquisition (enfin j'ai pas encore tester, je peux pas dire ...)
Vraiment WinTV m'a très vite pris la tete !
thenutskiller J'ai réussi ça marche.
Comment faire pour que le changement de chaine soit immédiat (ne pas attendre 2 ou 3 secondes après avoir appuyé sur la touche de la télécommande) ?
the_farbarian Donc si j'ai bien compris, ton pb c'est que quand tu appuis sur le 1 de la telecommande, il affiche n'importe quoi et tu voudrais le canal 22 ?
En ce cas, tu édites le fichier irremote et sous [wintv], quand tu vois
1=
2=
3=
tu mets
1=22
2=le canal de la chaine 2
3=le canal de la chaine 3
etc ...
Pense à faire une sauvegarde de ton fichier!
Et pour prendre en compte les modifs, il faut quitter l'application irremote (tu dois avoir une petite icone dans la barre des taches en bas à droite, tu fais quitter) et puis tu la relance (dans le dossier de hauppauge du menu demarrer)
normalement, ca devrait marcher ...
thenutskiller La télécommande fonctionne, mais je n'arrive pas à configurer les touches numériques pour accéder directement aux fréquences des chaines.
the_farbarian :??:
Je suis sous XP aussi, et j'ai installé le logiciel et puis ca a marché tout de suite ...
Je reflechis un peu, mais la comme ca, je comprends pas...
t'es bien sur d'avoir correctement branché le recepteur, d'avoir mis les piles dans le bon sens (OK, je sais, c'est con mais on ne sait jamais...)
Sinon, ta carte fonctionne bien ??
thenutskiller Je suis sous XP et je n'arrive pas à faire fonctionner la télécommande comme tu dis avec le fichier IRREMOTE.INI (même en suivant les instructions du manuel de la WinTV).
the_farbarian Il faut modifier le fichier irremote.ini dans le répertoire de windows.
Tu mets 1=22 si la chaine 1 est au canal 22.
Cela dit, K!TV est pour moi de meilleure qualité que WinTV.
En bidouillant un peu, tu pourras utiliser ta télécommande pour naviguer dans windows, lancer toutes tes applis (winamp ...)
Mais ca ne fait qu'une semaine que je l'ai et je ne suis pas encore expert.
Va voir sur le site de Hauppauge (http://www.hauppauge.fr)
>> utiliser sa WinTV à 100%
Tu trouveras un fichier irremote.ini avec l'utilisation pour winamp.
Amuse-toi bien, et si tu as plus de détails, je suis prenneur.
Pour l'instant, j'ai un peu bidouillé pour la faire marcher avec K!TV, mais je n'ai toujours pas compris comment cela marche exactement...
thenutskiller Je voudrais pouvoir utiliser la télécommande avec Wintv32 pour mettre le canal correspondant à une chaine avec les touches numériques de la telecommande. Par exemple, en appuyant sur 1, le programme wintv32 devrait se mettre sur le canal 22.
