11036 connectés
Sujet : Message d'erreur ?
PompUsine Putain !!! QUELLE INSULTE !!!  :ouch:
sebkane Connaissez vous la signification de ce message ?
NT version information:
Major version = 5
Minor version = 1
Build number = 2600
Platform ID = 2
( 3) Scanning "\\.\Scsi0:"
( 8) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 0"
     Error = 2
( 9) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 0"
     Error = 2
(10) Driver = "atapi"
Adapter 0
PortNumber 0
PathId 0
InitiatorBusId 255
MaximumTransferLength 131072
MaximumPhysicalPages 32
AlignmentMask 1
MaxTransferLen 126976
irq 0
port 0
( 3) Scanning "\\.\Scsi1:"
( 8) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 1"
     Error = 2
( 9) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 1"
     Error = 2
Adapter 1
PortNumber 1
PathId 0
InitiatorBusId 255
AlignmentMask 1
irq 0
port 0
( 4) Discovered 2 SCSI ports
(13) length = 6375
(14) Global
(15) Error opening "\\.\Global"
     Error = 6
(14) D:
(17) "\\.\D:" is at SCSI Port 0 Bus 0 Target 1 Lun 0
(20) Driver = "atapi"
     Type = "DiskPeripheral"
(14) NDIS
(14) DISPLAY1
(15) Error opening "\\.\DISPLAY1"
     Error = 5
(14) Root#SYSTEM#0000#{ffbb6e3f-ccfe-4d84-90d9-421418b03a8e}
(14) DISPLAY2
(15) Error opening "\\.\DISPLAY2"
     Error = 5
(14) Root#SYSTEM#0000#{71985f4a-1ca1-11d3-9cc8-00c04f7971e0}
(14) Root#MS_PPPOEMINIPORT#0000#{ad498944-762f-11d0-8dcb-00c04fc3358c}
(14) DmIoDaemon
(14) ACPI#PNP0C0C#2&daba3ff&0#{4afa3d53-74a7-11d0-be5e-00a0c9062857}
(14) Ip
(14) PCI#VEN_1102&DEV_0004&SUBSYS_00511102&REV_03#4&11d
7ad53&0&4840#{65e8773d-8f56-11d0-a3b9-00a0c9223196
(15) Error opening "\\.\PCI#VEN_1102&DEV_0004&SUBSYS_00511102&REV
_03#4&11d7ad53&0&4840#{65e8773d-8f56-11d0-a3b9-00a
0c9223196}"
     Error = 2
(14) DISPLAY3
(15) Error opening "\\.\DISPLAY3"
     Error = 5
(14) {59BFC86D-9267-4FA6-893C-444AFC921BF6}
(14) E:
(17) "\\.\E:" is at SCSI Port 1 Bus 0 Target 0 Lun 0
     Type = "CdRomPeripheral"
(xx) New device handle on existing adapter
     About to send "\\.\E:" into the pipe ...
     CallNamedPipe failed
     Error = 2
(14) IPSECDev
(14) DISPLAY4
(15) Error opening "\\.\DISPLAY4"
     Error = 5
(14) {750E1780-25C4-4CA0-8DAC-827AD5E5683B}
(14) Root#MS_NDISWANIP#0000#{ad498944-762f-11d0-8dcb-00c04fc3358c}
(14) ACPI#PNP0303#4&26102e8&0#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}
(15) Error opening "\\.\ACPI#PNP0303#4&26102e8&0#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}"
     Error = 5
(14) Root#SYSTEM#0000#{9aa4a2cc-81e0-4cfd-802f-0f74526d2bd3}
(14) gi_pci
(14) $VDMLPT1
7ad53&0&4840#{dff220f3-f70f-11d0-b917-00a0c9223196
_03#4&11d7ad53&0&4840#{dff220f3-f70f-11d0-b917-00a
0c9223196}"
     Error = 2
(14) Root#SYSTEM#0000#{3c0d501a-140b-11d1-b40f-00a0c9223196}
(14) Root#SYSTEM#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}
(14) RdpDrDvMgr
(15) Error opening "\\.\RdpDrDvMgr"
     Error = 31
(14) WMIDataDevice
(14) F:
(17) "\\.\F:" is at SCSI Port 1 Bus 0 Target 1 Lun 0
     About to send "\\.\F:" into the pipe ...
     Error = 2
(14) COM1
(14) Volume{a96d3263-2ef8-11d6-971d-806d6172696f}
(17) "\\.\Volume{a96d3263-2ef8-11d6-971d-806d6172696f}" is at SCSI Port 1 Bus 0 Target 0 Lun 0
(xx) Device handle already exists!
(xx) No current drive letter, using existing device handle
(14) Root#SYSTEM#0000#{dff220f3-f70f-11d0-b917-00a0c9223196}
(14) PIPE
(14) SW#{a7c7a5b0-5af3-11d1-9ced-00a024bf0407}#{9B36589
0-165F-11D0-A195-0020AFD156E4}#{d6c5066e-72c1-11d2
-9755-0000f8004788}
(14) Root#SYSTEM#0000#{2eb07ea0-7e70-11d0-a5d6-28db04c10000}
(14) IDE#CdRomYAMAHA_CRW2200E_________________________1
.0D____#5&2fb342a0&0&0.1.0#{53f56308-b6bf-11d0-94f
2-00a0c91efb8b}
(17) "\\.\IDE#CdRomYAMAHA_CRW2200E_________________
________1.0D____#5&2fb342a0&0&0.1.0#{53f56308-b6bf
-11d0-94f2-00a0c91efb8b}" is at SCSI Port 1 Bus 0 Target 1 Lun 0
(20) Driver =
[jfdsdjhfuetppo]--Message édité par sebkane--[/jfdsdjhfuetppo]
