4073 connectés
Sujet : Windows XP est bloquer apres 4 changement de matos [article inside]
myturtle Euh,je déboque aussi :D débloque
cycojesus Corporate...
...RULEZZZZZZZZZZZZ
myturtle y déboque facile bilou comme son xp! :lol:
brutalos
HappyHarry a écrit a écrit :
ca fait un bail que c connu ca ...
 :eek2: etait pas au courant
HappyHarry ca fait un bail que c connu ca ...
brutalos Voila l'article (merci billou) :
Microsoft has said that they will be giving MSDN subscribers some slack on Windows XP. Microsoft has said the MSDN versions of Windows XP will have ten licenses, so a developer can install on ten machines with no questions asked. According to Microsoft's Technical Bulletin <http://www.microsoft.com/piracy/basics/activation/windowsproductactivationtechnicalmarketbulletin.doc>, users will be able to automatically reactivate with new configurations (massive hardware changes) up to four times per year per license. Microsoft is preliminarily calling this "Time-based automatic acceptance of Internet Activation". This allows the developer, as well as users, to make major changes to a particular system, and just automatically reactivate without requiring additional licenses.
 [:brutalos]
Le lien :
http://www.extremetech.com/article [...] 3D8,00.asp
[jfdsdjhfuetppo]--Message édité par Brutalos--[/jfdsdjhfuetppo]
