5226 connectés
Sujet : [NEW] Téléchargez la version RP1 du Service Pack 2 pour Windows 2000 !
rexet A quand le service pack 3 ?? :hot:
[jfdsdjhfuetppo]--Message édité par rexet--[/jfdsdjhfuetppo]
rexet Windows 2000 SRP1 supersedes the patches delivered in the following security bulletins:
Core OS:
MS01-007 (Q285851): Network DDE Agent Requests Can Enable Code to Run in System Context
MS01-011 (Q287397): Malformed Request to Domain Controller can Cause CPU Exhaustion
MS01-013 (Q285156): Windows 2000 Event Viewer Contains Unchecked Buffer
MS01-024 (Q294391): Malformed Request to Domain Controller can Cause Memory Exhaustion
MS01-036 (Q299687): Function Exposed via LDAP over SSL Could Enable Passwords to be Changed
MS01-041 (Q298012): Malformed RPC Request Can Cause Service Failure
MS01-046 (Q252795): Access Violation in Windows 2000 IrDA Driver Can Cause System to Restart
MS02-001 (Q289246): Trusting Domains Do Not Verify Domain Membership of SIDs in Authorization Data
FrontPage Server Extensions:
MS01-035 (Q300477): FrontPage Server Extension Sub-Component Contains Unchecked Buffer
Hyperterminal:
MS00-079 (Q276471): Hyperterminal Buffer Overflow
Indexing Service:
MS01-025 (Q296185): Index Server Search Function Contains Unchecked Buffer
MS01-033 (Q300972): Unchecked Buffer in Index Server ISAPI Extension Could Enable Web Server Compromise
Internet Explorer 5.01:
MS01-051 (Q306121): Malformed Dotless IP Address Can Cause Web Page to be Handled in Intranet Zone
Note: Only the fix for version 5.01 of Internet Explorer is included in the SRP, as this is the version that shipped with Windows 2000. Patches are available for other versions of IE.
Internet Information Service 5.0:
MS01-004 (Q285985): Malformed .HTR Request Allows Reading of File Fragments
MS01-026 (Q293826): 14 May 2001 Cumulative Patch for IIS
MS01-044 (Q301625): 15 August 2001 Cumulative Patch for IIS
Netmeeting:
MS00-077 (Q273854): Netmeeting Desktop Sharing
NNTP Service:
MS01-043 (Q303984): NNTP Service Contains Memory Leak
SMTP Service:
MS01-037 (Q302755): Authentication Error in SMTP Service Could Allow Mail Relaying
Telnet Service:
MS01-031 (Q299553): Predictable Name Pipes Could Enable Privilege Elevation via Telnet
Terminal Service:
MS01-040 (Q292435): Invalid RDP Data Can Cause Memory Leak in Terminal Services
MS01-052 (Q307454): Invalid RDP Data can Cause Terminal Service Failure
rexet Fixes Included in SRP1
SRP1 includes all post-SP2 security updates that have been delivered via Microsoft Security Bulletins . In addition, it also includes a small number of security updates that have not been previously discussed. Because security bulletins are disruptive to customers' normal maintenance procedures, Microsoft typically issues them only when a security issue poses an immediate danger to your systems. Issues that do not meet this standard are typically addressed through other delivery vehicles such as service packs or, in this case, the SRP.
Q252795 MS01-046: Windows 2000 Does Not Support Mapping Virtual COM Ports to Infrared Ports
Q273854 MS00-077: Denial of Service Can Occur with Microsoft NetMeeting
Q276471 MS00-079: Patch for "HyperTerminal Buffer Overflow" Vulnerability In Windows 2000
Q282806 MS01-031: Telnet Service Prevents an Idle Telnet Session from Timing Out
Q285156 MS01-013: Windows 2000 Event Viewer Contains an Unchecked Buffer
Q285851 MS01-007: Patch Available for Network DDE Agent Request Vulnerability
Q285985 MS01-004: Patch Available for New Variant of File Fragment Reading via .HTR Vulnerability
Q286043 MS01-051: Patch Available for Telnet Logging Vulnerability
Q287397 MS01-011: Patch Available for Malformed Domain Controller Service Request Vulnerability
Q287912 MS01-031: Predictable Named Pipes Could Enable Privilege Elevation with Telnet
Q288855 MS01-026: FTP Service Allows Login to Domain Guest Account
Q289243 MS02-001: Forged SID Could Result in Elevated Privileges in Windows 2000
Q289782 INFO: Post Windows 2000 Service Pack 2 COM+ Rollup Hotfix 8 Is Available
Q292435 MS01-040: Invalid RDP Data Can Cause Memory Leak in Terminal Services
Q293826 MS01-026: Pattern-Matching Function Can Cause Access Violation on FTP Server
Q294370 MS01-026: Updated Patch for Microsoft Security Bulletin MS00-060
Q294379 Addressees Appear in Body of SMTP Message Instead of the Header If You Specify Many Addressees
Q294391 MS01-024: Malformed Request to Domain Controller Can Cause Memory Exhaustion
Q294774 MS01-044: IIS Loads ISAPI Extension In-Process Even When Application Is Marked for High Isolation
Q295534 MS01-026: Superfluous Decoding Operation Can Allow Command Execution Through IIS
Q296185 MS01-025: Patch Available for New Variant of the "Malformed Hit-Highlighting" Vulnerability
Q297860 MS01-044: IIS 5.0 Security and Post-Windows NT 4.0 SP5 IIS 4.0 Patch Rollup
Q298009 Cipher.exe Security Tool for the Encrypting File System
Q298012 MS01-041: Malformed RPC Request Can Cause Service Problems
Q298340 MS01-044: Patch Available for WebDAV Denial of Service
Q299553 MS01-031: Logon Command That Contains a Particular Malformation Causes an Access Violation in the Telnet Service
Q299687 MS01-036: Function Exposed By Using LDAP over SSL Could Enable Passwords to Be Changed
Q299796 MS00-077: Denial-of-Service Attack on Port 1720 May Cause a Memory Leak in Conf.exe
Q300477 MS01-035: FPSE: Potential Buffer Overrun Vulnerability in Visual Studio RAD (Remote Application Deployment)
Q300855 MS01-031: Windows 2000 Telnet Security Rollup
Q300901 MS01-031: Telnet Service Allows Logging On to Domain Guest Account
Q300905 MS01-031: Handle Leak in Telnet Service Causes a Denial-of-Service Vulnerability
Q300908 MS01-031: Program Running with Normal Privileges Can Terminate a Telnet Session
Q300972 MS01-033: Unchecked Buffer in Index Server ISAPI Extension Can Enable Web Server Compromise
Q301625 MS01-044: Patch Available for SSI Privilege Elevation Vulnerability
Q302755 MS01-037: Authentication Error in SMTP Service Could Allow Mail Relaying
Q303984 MS01-043: NNTP Service in Windows 2000 Contains a Memory Leak
Q304867 MS01-044: Patch Available for MIME Header Denial of Service Vulnerability
Q305601 MS01-060: FIX: CRT String Format Functions May Underwrite Buffer
Q306118 FPSE2000: List of Issues Fixed in FrontPage Server Extensions Service Release 1.3
Q306121 MS01-051: Malformed "Dotless" IP Address Can Cause a Web Page to Be Handled in the Intranet Zone
Q307454 MS01-052: Invalid RDP Data Can Cause Terminal Services Failure
Q308268 .IDA and .IDQ Mappings Restored After You Install Service Pack or Add/Remove a Windows Component
Q308414 MS01-051: Patch Available for HTTP Request Encoding Vulnerability
Q311355 MS01-041: The Danish Version of Security Hotfix MS01-041 Is Not Installed
Q311371 Terminal Services Sessions Are Disconnected Because of a Decryption Error
Q315404 MS01-052: Clients with an Expired Temporary License May Be Unable to Connect to Terminal Services
rexet
TkP-ACiD a écrit a écrit :
J'connaissais pas thx :) D'ailleurs kd on installe le SP2 en complet faut il installer le SP1 avant ?
Non pas du tout, le SP2 intègre les correctifs du SP1...
COULIX quels sont c correctifs ??
coulix
TkP-ACiD J'connaissais pas thx :) D'ailleurs kd on installe le SP2 en complet faut il installer le SP1 avant ?
CATALINA Merchi!!
vais pas tarder à le dl!! :hello:
VydoLL
carrera a écrit a écrit :
Arrete tu me fais flipper :ouch:
si je perds mon raid 5, je pleure :cry:
essai de trouver les articles chez le contructeur de ton raid et chez MS, il ya des tas de precautions a prendre avec le SRP !
mais g mater ta config, elle n'a rien a voir avec celle kil peut y avoir sur des serveur type netfin ou proliant...donc a priori no pbm...mais verifies qd meme c un conseil
carrera Arrete tu me fais flipper :ouch:
vydoll a écrit a écrit :
le SRP ne pose pas de pbm sur les PC ou les version win2k pro mais pour les pros je vous deconseille de l'installer sur des systeme systeme  IBM netfinity et Compaq Proliant  sans avoir mis les derniere firmware pour le bios, le raid car ce patch semble detruire le raid..... donc mefiance pour les pro
rexet up pour les retardataires :)
VydoLL
rexet a écrit a écrit :
donc pour les nuls c'est bon :??: :D :lol:
ben les "nuls" n'ont pas de serveur netfinity ou de proliant dans leur piole (on m'arait menti) :D
bref je vous dis ca car j'en ai fais moi-meme l'experience au taff...
rexet
rexet
pentier a écrit a écrit :
Tout le monde downloade plutôt.
Allez up.
Moi j'suis pas con, j'ai downloadé avant de poster le message :D !! Bon, je pense que les serveurs krosoft peuvent répondre à une grosse demande mais je suis parano (je me souviens de la sortie du Service Pack 2 et de CounterStrike 1.3, de la folie pour le downloader, à croire que toute la planête s'était donné le mot :ouch:)
VydoLL le SRP ne pose pas de pbm sur les PC ou les version win2k pro mais pour les pros je vous deconseille de l'installer sur des systeme systeme  IBM netfinity et Compaq Proliant  sans avoir mis les derniere firmware pour le bios, le raid car ce patch semble detruire le raid..... donc mefiance pour les pro
Pentier Tout le monde downloade plutôt.
Allez up.
rexet :jap: :D
En fait, tout le monde lit le post (60 déjà) mais personne ne le UP :D
[edtdd]--Message édité par rexet--[/edtdd]
Lemminkainen [:belgarion_cer]
rexet Aucune idée... j'aime pas trop les mis à jour en ligne... je préfère les avoir sous forme de package directement installable :) !!
Pentier On ne le voit pas avec le windows update?
rexet bon ben tout le monde s'en fout :(...
rexet Moi c'est fait, je l'installerai plus tard :)...
Sur la section software, je viens de voir un post dessus et apparemment, l'installation n'a pas posé de problème :) !
Lemminkainen moi je save pas... je le dl de suite :)
rexet Je suis peut être à la masse (et dans ce cas, désolé pour ce post inutile) mais je viens de voir ça sur le web :
Microsoft vient de sortir une mise à jour regroupant tous les patchs de sécurité apparus depuis la sortie du service pack 2 (SP2).
Attention, ce package doit être installé sous Windows 2000 Professional, Server, ou Advanced Server avec le Service Pack 2 installé au préalable. Si vous êtes dans un de ces cas là, je vous conseille donc fortement de mettre à jour votre système.
Avec cette sortie, il semblerait que la sortie du Service Pack 3 pour Windows 2000 soit proche.
(source : adsl-facile.com)
Téléchargez la version complète ici (16.4 Mo)
