4718 connectés
Sujet : 3DMark2001 ne marche pas sous XP ?
tharkie Moi, ça marche...
tiens...
System Information
Time of this report: 1/29/2002, 18:42:08
       Machine name: THUNDERBIRD
   Operating System: Microsoft Windows XP Professionnel (5.1, Build 2600) (2600.xpclient.010817-1148)
           Language: French (Regional Setting: French)
System Manufacturer: 761686
       System Model: AWRDACPI
               BIOS: 761686 - 42302e31
          Processor: AMD Athlon(tm) processor,  MMX,  3DNow, ~1620MHz
             Memory: 512MB RAM
          Page File: 204MB used, 1174MB available
Primary File System: n/a
    DirectX Version: DirectX 8.1 (4.08.01.0810)
DX Setup Parameters: Not found
     DxDiag Version: 5.01.2600.0000 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: The file nv4_disp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs.  You may be able to get a signed driver from the manufacturer of the hardware device.
                     Direct3D test results: Tous les tests ont été réussis.
        Sound Tab 1: The file cmaudio.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs.  You may be able to get a signed driver from the manufacturer of the hardware device.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Components
Display Devices
        Card name: Nvidia GeForce3 Ti 200
     Manufacturer: NVIDIA
        Chip type: GeForce3 Ti 200
         DAC type: Integrated RAMDAC
        Device ID: Enum\PCI\VEN_10DE&DEV_0201&SUBSYS_00000000&REV_A3
   Display Memory: 64.0 MB
     Current Mode: 1600 x 1200 (32 bit) (75Hz)
          Monitor: Écran Plug-and-Play
  Monitor Max Res: 1600,1200
      Driver Name: nv4_disp.dll
   Driver Version: 6.13.10.2720 (English)
      DDI Version: 8 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 1/15/2002 15:06:00, 3382509 bytes
    Driver Signed: No
  WHQL Date Stamp: None
              VDD:
         Mini VDD: nv4_mini.sys
    Mini VDD Date: 1/15/2002 15:06:00, 870029 bytes
Device Identifier: {D7B71E3E-4141-11CF-1069-0A2001C2CB35}
        Vendor ID: 0x10DE
        Device ID: 0x0201
        SubSys ID: 0x00000000
      Revision ID: 0x00A3
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result:
 D3D7 Test Result: All tests were successful.
 D3D8 Test Result: All tests were successful.
[edtdd]--Message édité par tharkie--[/edtdd]
tiens...
System Information
             Memory: 512MB RAM
DxDiag Notes
DirectX Components
Display Devices
    Driver Signed: No
              VDD:
        Vendor ID: 0x10DE
        Device ID: 0x0201
      Revision ID: 0x00A3
         Registry: OK
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result:
lacogne Bon j'ai installé les derniers drivers 27.20 et même problème. Même message d'erreur. Alors j'ai fait un dxdiag et j'obtiens belle et bien un message d'erreur lors du second test direct3d :
System Information
Time of this report: 1/29/2002, 18:31:08
Machine name: LACOGNE
System Manufacturer: MSI
System Model: MS-6380
BIOS: Version 1.00
Processor: AMD Athlon(tm) Processor,  MMX,  3DNow, ~1532MHz
Memory: 384MB RAM
Page File: 98MB used, 632MB available
DxDiag Notes
Direct3D test results: Échec à l'étape 5 (GetDeviceCaps): HRESULT = 0x8876086a (3D non disponible)
Sound Tab 1: No problems found.
Display Devices
Card name: NVIDIA GeForce3
Chip type: GeForce3
Device ID: Enum\PCI\VEN_10DE&DEV_0200&SUBSYS_03E910B0&REV_A3
Current Mode: 1280 x 1024 (32 bit) (100Hz)
Monitor: Iiyama A901HT,       VisionMaster Pro 450
Monitor Max Res: 1920,1440
DDI Version: 7
Driver Date/Size: 1/15/2002 15:06:36, 3382509 bytes
Driver Signed: No
VDD:
Mini VDD: nv4.sys
Mini VDD Date: 8/17/2001 20:50:26, 731648 bytes
Device Identifier: {D7B71E3E-4140-11CF-A079-E32301C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0200
SubSys ID: 0x03E910B0
Revision ID: 0x00A3
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result:
D3D8 Test Result:
Failure at step 5 (GetDeviceCaps): HRESULT = 0x8876086a (3D not available)
tharkie avec XP, j'ai juste les via 4en1 4.37, sur ma KG7, et les détonator 27.20... un régal ;)
lacogne Le seul patch que j'ai installé c'est le via latency 019
lacogne Drivers 21.83.
Via 4.1 pas installé. (drivers winxp d'origine)
Dimebag Darrell J'ai pas de Gforce moi je parle des DRIVERS VIA ce sont eux qui foutent la merde avec Direct-X !
j'ai eu ce genre de problème avec ma Radeon 7200  (ça ne dépend pas des drivers carte graphique)  :gun:  :cry:  :lol:  :??:  :bounce:  :fuck:  :non:  :ange:
cyberfred sous xp marche tres bien 3d mark 2001, perso j'ai les 23.11 et ca roule nickel!!!
DraX kel driver deto pour ta carte?
Dimebag Darrell Pas normal !!
tu as installé les drivers VIA ??? (4.37(a)) ???
sous XP je recommande de ne pas mettre ces Drivers !! ils ne servent à rien !! (ma machine tourne sans et elle va aussi bien qu'avec !)
si, ils servent tout simplement à faire branler une bécanne !!!!
formate ta machine et installe 3Dmark 2001 et fais le test avec ta Geforce 3 !!
 :gun:
tharkie marche très bien chez moi !
lacogne Je l'ai installé sous WIN XP et lorsque je lance il m'affiche le message d'erreur suivant :
3DMark2001 requires a Directx 8 compatible 3D Accelerator.
Arf j'ai une Geforce 3.
Comprend pas.
