2701 connectés
Sujet : [TRES IMPORTANT] -- APPELLE AU PRO DE LA GRAVURE !!!!!!!!!!!
satrincha :cry:
satrincha :cry:
satrincha marche pas avec une vieille version .........  :sweat:
simu planté a 91%
iNET
iNET
1501-4157-6236-6325-1269-9399*
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 05/05/99 22:22:00
Nero Version: 5.5.2.3
Recorder:             <PLEXTOR CD-R PX-R820T>   Version: 1.08 - HA 0 TA 0 - 5.5.2.3
 Adapter driver:      <symc8xx>                 HA 0
 Drive buffer  :      4096kB
CD-ROM:               <PLEXTOR  CD-ROM PX-40TS> Version: 1.13 - HA 0 TA 3 - 5.5.2.3
PLEXTOR CD-R   PX-R820T (Target 0, G:): Autoinsert On, DMA ?, Disconnect On, SyncDataXfer Off
PLEXTOR CD-ROM PX-40TS (Target 3, H:): Autoinsert On, DMA ?, Disconnect On, SyncDataXfer Off
CmdQueuing     : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed     : 0
BUFE           : 0
Physical memory     : 255MB (261616kB)
Free physical memory: 0MB (28kB)
Memory in use       : 65 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: Off
CD-ROM (ISO)
29.1.2002
04:12:10 #1 Text 0 File Reader.cpp, Line 133
 Reader running
04:12:10 #2 Text 0 File Writer.cpp, Line 125
 Writer CD-R   PX-R820T  running
04:12:10 #3 ISO9660GEN -11 File geniso.cpp, Line 4210
 First writeable address = 0 (0x00000000)
04:12:12 #4 Text 0 File ThreadedTransferInterface.cpp, Line 665
 Setup items (original item values)
  0: TRM_DATA_MODE1 (CTransferItem)
     2 indices, index0 (150) not provided
     original CD pos #0 + 354007 (354007) = #354007/78:40.7
     relocatable, CD pos for caching/writing not required/required, no patch infos
04:12:14 #5 Text 0 File Burncd.cpp, Line 1509
 Recorder:  PLEXTOR CD-R PX-R820T;
    CDR code: 00 97 34 21; OSJ entry from: Mitsubishi Chemical
    ATIP Data:
      Special    Info [hex] 1: C0 00 98, 2: 61 22 15 (LI 97:34.21), 3: 4F 3B 4A (LO 79:59.74)
      Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
04:12:14 #6 Text 0 File ThreadedTransferInterface.cpp, Line 800
 Prepare recorder CD-R   PX-R820T  for write in TAO
 DAO infos:
 MCN:
 TOCTYPE: 0x0   Close CD
 Tracks 1 to 1:
    TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 725313536
04:12:14 #7 Text 0 File ThreadedTransferInterface.cpp, Line 828
 Removed 2 run-out blocks from end of track 1.
04:12:14 #8 Text 0 File ThreadedTransferInterface.cpp, Line 665
 Setup items (after recorder preparation)
     -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 354005 blocks [CD-R   PX-R820T ]
04:12:14 #9 Phase 24 File dlgbrnst.cpp, Line 1353
 Caching of files started
04:12:14 #10 Phase 25 File dlgbrnst.cpp, Line 1353
 Caching of files completed
04:12:14 #11 Phase 28 File dlgbrnst.cpp, Line 1353
 Speed measurement started
04:12:15 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1836
 Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
04:15:15 #13 Text 0 File ThreadedTransfer.cpp, Line 218
 all writers idle, stopping conversion
04:15:16 #14 Phase 29 File dlgbrnst.cpp, Line 1353
 Speed measurement completed: 24x (3638 KB/s)
04:15:16 #15 Phase 32 File dlgbrnst.cpp, Line 1353
 Simulation started at 8x (1200 KB/s)
04:15:16 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1836
04:24:10 #17 SCSI -1135 File Cdrdrv.cpp, Line 1351
 SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x033489C8
 Status:     0x04 (0x01, SCSI_ERR)
 HA-Status   0x00 (0x00, OK)
 TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
 Sense Key:  0x03 (KEY_MEDIUM_ERROR)
 Sense Code: 0x0C
 Sense Qual: 0x07
 CDB Data:   0x2A 0x00 0x00 0x04 0xCA 0xF4 0x00 0x00 0x1E 0x00
 Sense Data: 0xF0 0x00 0x03 0x00 0x04 0xCB 0x8A 0x0A
             0x00 0x00 0x00 0x00 0x0C 0x07
04:24:10 #18 mmc -1135 File Writer.cpp, Line 311
 Write error
04:24:10 #19 Text 0 File ThreadedTransfer.cpp, Line 218
04:24:10 #20 Text 0 File ThreadedTransfer.cpp, Line 212
 conversion idle, stopping reader
04:24:10 #21 CDR -201 File WriterStatus.cpp, Line 121
 Invalid writestate
04:24:10 #22 TRANSFER -18 File WriterStatus.cpp, Line 121
 Could not perform EndTrack
04:24:10 #23 Phase 34 File dlgbrnst.cpp, Line 1353
 Simulation failed at 8x (1200 KB/s)
04:24:10 #24 Text 0 File Scsicmd.cpp, Line 371
 SCSI not using temporary buffers
 20 out of 20 temporary buffers allocated
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 05/05/99 22:22:00
File 'IoSubsys\NEROCD95.VXD': Ver=4, 0, 0, 16, size=33451 bytes, created 29/01/02 03:53:16
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 05/05/99 22:22:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 05/05/99 22:22:00
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69578 bytes, created 05/05/99 22:22:00
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 05/05/99 22:22:00
satrincha ici ya toutes les version de néro :
http://www.cdr.cz/software/nero_-_ [...] index.html
satrincha Moi j'ai rien overclocké  :sweat:
mad32 J'ai eu un problème identique...le graveur ne supportait pas la nouvelle fréquence du bus...suite à... overclock :lol:  :lol:  :lol:  :lol:
satrincha :cry:
sais plu, il était bavard
satrincha il te disait pas ca : Could not perform EndTrack
ga pas gardé le message, mais il plantait tt le temps en début de gravure.
Je crois que d'ailleurs les cd restaient vierges.
voilà, vous savez tout : je suis impuissant (à graver ;-)
satrincha y faisait quoi ton graveur comme erreur ?
satrincha a écrit a écrit :
y faisait pas ton graveur ?
pouvez repeter la question ?
satrincha
ameddou a écrit a écrit :
http://www.topqualityfreeware.com/wdll.shtml
mais autrement est ce qu'il lit bien les cd
faut s'enregistrer .........  :cry:
satrincha
antistress a écrit a écrit :
g posé la question à nero qui s'en fout.
bilan je reste scotché sur une vieille version.
Même les nouvelles vesrions avec les anciens drivers aspi n'y change rien.
Pas plus avec les nveaux bien sûr.
satrincha meci pour ton lien mais y'en a du monde ! :??:
oui il lit parfaitement bien les CDs .......
ameddou
:??:  je les trouves ou ???????
avant sa marchait nikel mon graveur mais depuis 1 mois il a bcps de mal et la y veut pus rien !!
mais l'erreur parait logiciel et pourtait elle est hardware ! (j'ai réinstallé tout mon PC)  :sweat:
satrincha :??:  je les trouves ou ???????
ameddou ta essayer de réinstaller des drivers ASPI
djoh
t'as peut etre raison !
vue que mon graveur est vieux ! (3 ans) ......... les news logiciels créé peut etre la merde !!!!!!!!!!
V installer un vieux néro ! :hot:
moi j'ai garder celui que j'ai eu avec mon graveur, j'ai pas trouver d'interet a mettre un nouveau, il fait tout ce que j'attends d'un logiciel de gravure :p
satrincha t'as peut etre raison !
djoh
moi c à cause de ça que je suis revenu au 5.5.2.3.
Après ça passe plus.
et l'interet de mettre a jour nero si il marche ?  :??:
[edtdd]--Message édité par djoh--[/edtdd]
satrincha
Et bien essai avec un autre soft
Easy CD et DiscJugger foire aussi  :sweat:
satrincha
a cause de quoi ??????
ameddou Et bien essai avec un autre soft
satrincha :cry:  :cry:  :cry:
satrincha La simulation foire apres 3%, je peut pus graver ......
j'ai réinstallé mon OS avec néro uniquement !
voila le message :
iNET
x
xxxx-xxxx-xxxx-xxxx-xxxx-xxxx
Windows 98 4.10
Nero Version: 5.5.6.4
Recorder:             <PLEXTOR CD-R PX-R820T>   Version: 1.07 - HA 0 TA 0 - 5.5.6.4
 Bus Type      :      default (0) -> SCSI
CD-ROM:               <PLEXTOR  CD-ROM PX-40TS> Version: 1.10 - HA 0 TA 3 - 5.5.6.4
PLEXTOR CD-R   PX-R820T (Target 0, G:): Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ?
PLEXTOR CD-ROM PX-40TS (Target 3, H:): Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ?
Excluded drive IDs:
CmdQueuing     : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed     : 0
BUFE           : 0
Memory in use       : 57 %
Use Inquiry    : 1
Global Bus Type: default (0)
Wizard: Off
CD-ROM (ISO)
28.1.2002
14:39:04 #1 Text 0 File Reader.cpp, Line 117
 Reader running
14:39:04 #2 Text 0 File Writer.cpp, Line 127
 Writer PLEXTOR  CD-R   PX-R820T  running
14:39:04 #3 ISO9660GEN -11 File geniso.cpp, Line 4307
14:39:04 #4 Text 0 File ThreadedTransferInterface.cpp, Line 679
     original CD pos #0 + 332065 (332065) = #332065/73:47.40
14:39:06 #5 Text 0 File DlgWaitCD.cpp, Line 194
 Last possible write address on media:   359848 (79:59.73)
 Last address to be written:             332067 (73:49.42)
14:39:07 #6 Text 0 File DlgWaitCD.cpp, Line 1331
    ATIP Data:
14:39:10 #7 Text 0 File ThreadedTransferInterface.cpp, Line 824
 Prepare recorder PLEXTOR  CD-R   PX-R820T  for write in TAO
 DAO infos:
 MCN:
 TOCTYPE: 0x0   Close Session
 Tracks 1 to 1:
    TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 680376320
14:39:10 #8 Text 0 File ThreadedTransferInterface.cpp, Line 852
14:39:10 #9 Text 0 File ThreadedTransferInterface.cpp, Line 679
     -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 332063 blocks [PLEXTOR  CD-R   PX-R820T ]
14:39:10 #10 Phase 24 File dlgbrnst.cpp, Line 1436
14:39:10 #11 Phase 25 File dlgbrnst.cpp, Line 1436
14:39:10 #12 Phase 28 File dlgbrnst.cpp, Line 1436
14:39:10 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1950
14:41:15 #14 Text 0 File ThreadedTransfer.cpp, Line 219
14:41:16 #15 Phase 29 File dlgbrnst.cpp, Line 1396
 Speed measurement completed: 35,7x (5 355 Ko/s)
14:41:16 #16 Phase 32 File dlgbrnst.cpp, Line 1436
 Simulation started at 8x (1 200 Ko/s)
14:41:16 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1950
14:50:25 #18 SCSI -1135 File Cdrdrv.cpp, Line 1407
 SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03BDADD8
 Sense Code: 0x0C
 Sense Qual: 0x07
 CDB Data:   0x2A 0x00 0x00 0x04 0xFE 0x25 0x00 0x00 0x1F 0x00
 Sense Data: 0xF0 0x00 0x03 0x00 0x04 0xFE 0xBB 0x0A
14:50:25 #19 mmc -1135 File Writer.cpp, Line 321
 Write error
14:50:25 #20 Text 0 File ThreadedTransfer.cpp, Line 219
14:50:25 #21 CDR -201 File WriterStatus.cpp, Line 145
 Invalid writestate
14:50:25 #22 TRANSFER -18 File WriterStatus.cpp, Line 145
14:50:25 #23 Phase 34 File dlgbrnst.cpp, Line 1436
 Simulation failed at 8x (1 200 Ko/s)
14:50:25 #24 Text 0 File Scsicmd.cpp, Line 371
Existing drivers:
File 'IoSubsys\NEROCD95.VXD': Ver=4, 5, 0, 12, size=37811 bytes, created 28/01/02 14:23:22
HEEELLLLLLLLPPPPPPPPPPPPP  :cry:  :cry:  :cry:
