4237 connectés
Sujet : volant Race Leader Force Feedback port Série DB9
pcvision ah c'est cool que ce petit topic soit la!
cet aprem je fais de la soudure :D
Merci pour l'info!
Merci pour l'info!
flodu pr ceux que ça intéresse tjs...je reviens sur ce topic
g fé la manip..(ya un petit moment déjà)
ça marche nickel!(ss XP...)
3 fils à souder...
un driver USB à installer
die666 alors, pour tous ceux qui ont un race leader force feedback de chez guillemot en dB9 (port serie):
pour le passer en usb et pouvoir s'en servir sous windows XP il faut souder un cable usb sur la carte mere du volant.
voici un copier coller du post trouvé:
> This has cropped up before - lack of serial version drivers of the
> wheel for XP.  I've had a read through what posts I could find, and
> tried a suggestion of using a USB-Serial adaptor, but the drivers for
> that just created a further COM port.
> One person mentioned a USB hack, to whom I've sent a query, but I can
> find no more mention of it.
> Has anyone managed to get this wheel working in XP?  A driver hack
> perhaps, a physical rewiring?
> Any clues would be most welcome.
> Thanks,
> Amos
One very kind Tony_h (whose post was back in Jan!) answered my USB
hack query - with a successful outcome.  The PCB within the housing
has a vacant USB connection area (J5).  In a nutshell, it's just a
simple job of taking a standard USB extension cable, stripping one end
off, and soldering it in place with the following pin counts :
 1 Red
 2 White
 3 Green
 4 Black
The serial cable was removed (a tidy plug/socket job made that easy)
so that the USB cable exited the unit without any further holes.
Plugged it in, XP detected a new device, installed the most recent
drivers (GI_RLFFBWheel98ME2KXP_2514.exe), and away it went.  Even got
split axis for throttle/brake.
Voilou.. ca marche tres tres bien , je viens de le faire sur le mien, donc guillemot avec leur 15 euros, ils peuvent aller se rendormir..
pour les anglophobes :
il y a sur la carte mere du volant un emplacement jp5 (usb) il faut virer l'etain et y enfiler un cable usb en respectant cet emplacement :
1 rouge
 2 blanc
 3 vert
 4 noir
ensuite, installer les drivers xp du volant de chez guillemot (l'usb) et voilou.. vous avez un volant usb. \o/
die666 rEUP ?
moi aussi j'ai ce volant, et j'aimerai savoir comment le faire marcjher, autremement qu'en faisant un dual boot xp /98
Clark_gaybeul ALLEZ UP!
Clark_gaybeul donc ca dois etre possible
sinon si qq a l´adtaptateur USB -> serie, il suffirait de prendre un testeur et regarder quelles broches correspondent les unes aux autres, en usb y a que 3 conneteurs c pas sorcier..
[jfdsdjhfuetppo]--Message édité par Clark_gaybeul le 03-05-2002 à 20:03:58--[/jfdsdjhfuetppo]
Clark_gaybeul ce serait fort sympathique!!
ya bien un microproc avec ecrit USB...qqchose dessus, ds mon volant
agnostica je vais regarder sur le mien (série et usb)...
je ne te promets rien...
Clark_gaybeul Et re UP
Clark_gaybeul j´ai le m probleme que vous les gars, personne ne connait la manip par hasard??
up
[jfdsdjhfuetppo]--Message édité par Clark_gaybeul le 03-05-2002 à 18:45:33--[/jfdsdjhfuetppo]
flodu j'ai aussi reçu ce mail...
mais j'hésite à acheter ce cable, il ne précisent rien, et je n'aime pas la façon dont ils se déchargent de toutes responsabilités dans leur contrat...
j'attend encore un peu...
tu m'excuseras si mon msg ne fait pas avancer les chose ;-)
NEOMATRIX bon j'ai pas de chance !
NEOMATRIX Question:
Je possède un volant Race Leader Force Feedback port Série DB9, je suis sous XP, j'ai contacté Guillemeot qui a diffusé ce produit.
Ils ne vont pas dévelloper de driver pour la version "sérieé de ce volant, en revanche ils me proposent moyennant 16 ? (!) de m'envoyer une fiche technique m'indiquant les manips pour le passer en USB !
Mais ils m'indiquent de signer un courrier comme quoi je reste seul responsable!
Alors pour cette dernière chose je ne suis pas d'accord de payer 16 ?, et ne plus pouvoir en plus bénéficier de la garantie.
Donc, est-ce que quelqu'un connait la mainip (les soudures à effectuer, etc.), car je ne tiens évidement pas dans ces conditions leurs donner 1 seul centime d'euro !
Merci de m'avoir lu.
