4418 connectés
  Nouveaux drivers Radeon Omega !
n°1126048
remchar
Bee's Powâaaaa
Posté le 25-01-2002 à 22:59:10  profilanswer
n°1126067
graffy
Al Pacino
Posté le 25-01-2002 à 23:05:37  profilanswer
Euuuhhh ils ont quoi de mieux....plus stables ???
donne des précisions ??
n°1126083
remchar
Bee's Powâaaaa
Posté le 25-01-2002 à 23:09:20  profilanswer
c'est une version amélioré des drivers officiels !
n°1128708
remchar
Bee's Powâaaaa
Posté le 27-01-2002 à 00:14:37  profilanswer
les essayer c'est les adopter ! :D
n°1129415
remchar
Bee's Powâaaaa
Posté le 27-01-2002 à 13:00:01  profilanswer
OMEGADRIVE here!
This are my "optimized" drivers for the ATI Radeon family
of video cards, this version (Omega 1.4.12) is for
Windows 9x/ME.
Special note:
THIS DRIVERS ARE MADE FOR GAMES, NOT BENCHMARKS!!!
THEY FIX GRAPHICAL ERRORS, STABILITY PROBLEMS
AND SOME SPEED ISSUES ONLY IN GAMES.
THEY ADD VISUAL QUALITY, STABILITY AND MORE OPTIONS.
IF YOU WANT DRIVERS FOR BENCHMARKS DOWNLOAD ATI'S
ORIGINAL DRIVERS INSTEAD FOR 3DMARK2K1 AND OTHER
BENCHMARKS.
New (Omega 1.4.12):
* Using the core drivers 9012, they are a VERY BIG improvment over
  the last ones.
* Fixed the NATURE speed test in 3dm2k1 with my drivers, now you
  should see a really big improvement.
* Included some new goodies with the drivers, they are in the extracted
  folder, Enjoy!
Old (Omega 1.4.08a):
* Re-Enabled HierarchicalZ for D3D and OpenGL, the speed problems
  where greater than graphics problems, now the speed should be
  up to par with the ATI drivers.
* Changed an ATI setting that makes the drivers IGNORE your Windows
  monitor settings and use ATI's internal settings instead.  Anyone
  with refresh rate problems or lockups when starting some games
  after version 72xx of ATI's drivers should try these now and see
  if the problem goes away.
* Now 1280x960 should be working with higher refresh rates again,
  tried to fix other refesh rates, but ATI hard coded the refresh
  rate for 960x720 and other resolutions, so there is no change
  there.
Old (Omega 1.4.08):
* Re-incorporated the 848x480 resolution since somebody informed
  me that it is used for Widescreen Video Output, but I still
  think is completly useless as a desktop resolution.
* Added a new custom resolution, 960x720, but the only problem
  is that it only runs in 60Hz, other refresh rates didn't worked.
* Re-enabled "FogTable" emulation ONLY for the 8500 Radeon cards
  since it's the only Radeon card that supports it.
* Disabled HierarchicalZ in OpenGL and Direct3D, it was giving
  problems for many people and the speed change in games is
  almost null.
* Added a new fix that will prevent the "OpenGL driver not
  found" error in ANY OpenGL game.
* Included the Dx Control Panel with the drivers.
* Re-enabled V-Sinc by default.
* Included the extra Language removal tool.
n°1129697
Djall
Posté le 27-01-2002 à 14:44:41  profilanswer
moi je trouve que les drivers officiels pour xp sont pas top pour la lecture dvd (qualité, petites saccades) mm les divx (courtes accelerations de la vidéo) est ce que y'a des meilleurs drivers sur www.rage3d.com ? ma carte radeon vivo 64 DDR
n°1129952
Clarkent
Musclor le shérif de l'espace
Posté le 27-01-2002 à 16:44:47  profilanswer
a quand des pilotes ati :/.
"PAR LE POUVOIR DU CRÂNE ANCESTRAL, JE DETIENS LA FORCE TOUTE PUISSANTE".
n°1129953
Clarkent
Posté le 27-01-2002 à 16:45:02  profilanswer
car la ca fait plus de deux mois que les anciens sont sortis.
n°1130890
remchar
Bee's Powâaaaa
Posté le 27-01-2002 à 21:26:20  profilanswer
vache folle a écrit a écrit :
Up, tu vois vraiment une différence ?
tu m'étonnes , c'est le jour et la nuit !
n°1130912
Lordben007
Membre Premium
Posté le 27-01-2002 à 21:35:19  profilanswer
Comme Hercules est partenaire avec ATI , y'aura sans doute un vrai suivi des drivers maintenant non ?
Si c'est le cas, je prendrai bien le Radeon 8500 de chez Hercules( Il est pas cher du tout en plus )
Topic Ventes
n°1130915
Clarkent
Posté le 27-01-2002 à 21:36:57  profilanswer
euh hercules meme pour ces cartes nvidia ne faisait aps specialement de mise a jour et c etait des maj des pilotes nvidia pas des pilotes fait apr hercules lui meme.
n°1130918
THE REAL K​RYSTOPHE
ストリートファイターBrasileiro NTSC-J
Posté le 27-01-2002 à 21:38:25  profilanswer
ZONT KOA DE BIEN ceux poor w98 ??
ya la rezo 1280X960 ?
n°1131001
remchar
Bee's Powâaaaa
Posté le 27-01-2002 à 22:13:20  profilanswer
oui ya la rezo 1280 :D
n°1131040
Clarkent
Posté le 27-01-2002 à 22:27:00  profilanswer
de toutes maniere cette res on peut la rajouter manuellement.
n°1131056
barbarella
Posté le 27-01-2002 à 22:31:15  profilanswer
Bon ben j'ai testé (enfin un peu) les omega 9012 sous W98 avec serious sam. Je gagne 1 a 2% dans les benchmark. mais bon mon P3-933 limite pas mal. Donc moi je considère qu'ils sont bien pour l'instant.
Ils semble gérer correctement le refres ecran, ça c'est cool :)
TRK :
Comment tu le trouves SS2 ? moi j'suis au 2/3 est c'est splendide :)
n°1135113
THE REAL K​RYSTOPHE
Posté le 29-01-2002 à 12:06:20  profilanswer
SYMPA C DRIVERS
MOA SS2 j adooorrrrrrrrrrrrrrrrrr !!!!!!!!!!
Je ne trouve pas de drivers potables pour WindowsXP pour ma webcamWindowsUpdate: Drivers certifiés Promise Raid
Niveau de bruit des ventilos Radeon et GeForce 3risques des drivers pour cartes mères?
drivers pour appli 3d pro.Drivers Gf3 ti 200 lequels..
c koi ki marche mieux ente ati radéon 32sdr & ve 32ddr ???Radeon VIVO, XP et OpenGL
3 D PROPHET G FORCE3 TI 500 PROBLEME DE DRIVERSdrivers A7A266-E
Plus de sujets relatifs à : Nouveaux drivers Radeon Omega !
