7467 connectés
  Le nouvo iMac vous parait comment ?
 Page :   1  2  3
Page Précédente
n°1073886
Je@nb
Kindly give dime
Posté le 07-01-2002 à 20:01:03  profilanswer
Vous le trouvez comment ?
http://jbpaux.multimania.com/imac1.jpg
http://jbpaux.multimania.com/imac2.gif
Les infos sur les prix et les composants :
Modèle : M8672LL/A
Processor :  700-MHz PowerPC G4
Memory : 128MB
Hard disk drive1 40GB Ultra ATA
Optical drive CD-RW
Graphics support NVIDIA GeForce2 MX with 32MB of DDR
FireWire Two ports
USB Five ports
VGA video mirroring Yes
Modem3 56K
Ethernet 10/100BASE-T
Wireless networking 4 AirPort ready
Apple Pro Speakers No
Modèle : M7677LL/A
Hard disk drive1 : 40GB Ultra ATA
Memory : 256Mb
Combo (DVD-ROM/CD-RW)
Graphics support : NVIDIA GeForce2 MX with 32MB of DDR RAM
FireWire Two ports
USB Five ports
Modem3 56K
Apple Pro Speakers Yes
Modèle :  M8535LL/A
Processor : 800-MHz  PowerPC G4
Hard disk drive1  : 60GB Ultra ATA
Memory : 256Mb
SuperDrive (DVD-R/CD-RW)
FireWire Two ports
USB Five ports
Modem3 56K
Processor and memory
? 700- or 800-MHz PowerPC G4 processor with
Velocity Engine
? 256K on-chip level 2 cache at full processor speed
? 100-MHz system bus
? 128MB or 256MB of SDRAM expandable to 1GB;
one factory-installed 168-pin DIMM and one open
user-accessible SO-DIMM slot
Storage
? 40GB or 60GB Ultra ATA hard disk drive1
? One of the following optical drives:
?CD-RW drive (writes CD-R discs at 24x speed,
writes CD-RW discs at 10x speed, reads CDs at
32x speed)
?DVD-ROM/CD-RW Combo drive (reads DVDs at
8x speed, writes CD-R discs at 12x speed, writes
CD-RW discs at 8x speed, reads CDs at 32x speed)
?SuperDrive (combination DVD-R/CD-RW drive; writes
DVD-R discs at 2x speed, reads DVDs at 6x speed,
writes CD-R and CD-RW discs at 8x speed, reads
CDs at 24x speed)
? Support for external FireWire and USB storage
devices
Display
? Built-in 15-inch (viewable) TFT active-matrix liquid
crystal display
? Millions of colors at 1024-by-768-pixel resolution
? Typical viewing angle: 120 degrees horizontal;
90 degrees vertical
? Typical brightness: 200 candela per meter squared
? Typical contrast ratio: 300:1
Graphics support
? NVIDIA GeForce2 MX graphics processor with
AGP 2X support
? 32MB of dedicated Double Data Rate (DDR)
video memory
? Three flicker-free screen resolutions: 640 by 480
pixels, 800 by 600 pixels, and 1024 by 768 pixels
(optimum resolution)
? 24-bit true color at all resolutions for displaying
millions of colors
Communications
? Built-in 56K V.90 modem (RJ-11 connector)3
? Built-in 10/100BASE-T Ethernet (RJ-45 connector)
? Built-in antennas and card slot for optional 11-Mbps
AirPort Card; IEEE 802.11b compliant4
Peripheral connections
? Two 400-Mbps FireWire (IEEE 1394) ports7;
8 watts shared
? Three USB 1.1 ports on computer (shared on two
12-Mbps controllers); two USB 1.1 ports on keyboard
? Support for FireWire target disk mode for high-speed
transfer of files between two computers
Audio
? Built-in speaker
? Apple Pro Speakers (9 watts each)2
? Internal 18-watt digital amplifier
? Apple speaker minijack for connection to Apple
Pro Speakers
? Headphone jack
? Built-in microphone for speech recognition and
audio recording
? Support for external USB audio devices
Video
? Mini-VGA output port (requires VGA display adapter)
? Support for video mirroring: external devices display
an image identical to that shown on the built-in
display
? Output resolutions: 640 by 480 pixels at 60 Hz,
800 by 600 pixels at 75 Hz, and 1024 by 768 pixels
at 75 Hz
Keyboard and mouse
? Apple Pro Keyboard with 15 function keys, 4 arrow
keys (inverted ?T? arrangement), audio controls,
and media-eject key; two built-in USB 1.1 ports;
two-position tilt
? Apple Pro Mouse with optical sensor for precise
cursor control
Electrical requirements and agency approvals
? Line voltage: 90V to 264V AC
? Frequency: 47 to 63 Hz, single phase
? Maximum continuous power: 130W
? Meets ENERGY STAR requirements
Environmental requirements
? Operating temperature: 50° to 95° F (10° to 35° C)
? Storage temperature: ?40° to 185° F (?40° to 85° C)
? Relative humidity: 5% to 95% noncondensing
? Maximum operating altitude: 10,000 feet
Size and weight
? Height: 12.95 inches (32.9 cm) minimum;
20.0 inches (50.9 cm) maximum
? Width: 15.1 inches (38.3 cm) minimum;
16.3 inches (41.5 cm) maximum
? Depth: 10.6 inches (27.0 cm) minimum;
? Diameter of base: 10.6 inches (27.0 cm)
? Weight: 21.3 pounds (9.7 kg)8
[edtdd]--Message édité par Je@nb--[/edtdd]
n°1073895
yannick_fr​ere
Posté le 07-01-2002 à 20:03:52  profilanswer
Euuh ...
le site d'Apple est légèrement engorgé à cette heure-ci ! Je voterai plus tard ;o)
n°1073898
hackerzoo
et le hacker joue.
Posté le 07-01-2002 à 20:05:01  profilanswer
comme dab c'est de la daube sauf que ce coups ci ca se sent pas  [:hackerzoo]
mon athlon brule d'amour pour moi et pour ca pas besoins de virer le ventilo et de toute facons virer le ventilo c'est con et win xp c'est terrible.
n°1073903
rene pierr​e
Posté le 07-01-2002 à 20:07:20  profilanswer
moi j'aurais preferé marquer que steve jobs nous lache la grappe,a chaque fois qu'un proco il sort sur PC a aucun moment je l'ai vu comparé a un proco Mac mais l'inverse ...et ça gonfle on s'en fout de sa vie on est deja assez emmerdé comme ça... ;)
n°1073916
Rick The A​lone
Posté le 07-01-2002 à 20:13:09  profilanswer
Look plutôt sympa
Puissance : je sais pas j'ai un PC môa ! Pis si tout le monde avait un mac, il y aurait plus les petites gue-guerres habituelles ;)
Ecran c'est vrais que 15" c'est un peu juste
Evolutivité : Bof ! Perso, je prendrais pas ... je viens même de commander un nouveau boitier pour le mien car l'actuel est plein ;)
Alors j'ai voté pour Obiwan...
Rick The Alone :D
n°1073993
Je@nb
Kindly give dime
Posté le 07-01-2002 à 20:37:41  profilanswer
sinon je trouve pourris c que qd ils comparent il conparent les Mac à ché pas cb d'? tandis que c des PC pas chèr et en + avec des P4  :gun:
Mettez à prix égal un Athlon XP et leur G4 on verra la diffénrence
n°1074313
schumacher
Posté le 07-01-2002 à 21:57:30  profilanswer
le design est osé qd meme mais bon :heink:
au niveau clavier souris, c intégré au machin ?
L'impôt appauvrit l'ignorant et enrichit le connaisseur.
n°1074615
Space
Profil: Maux des rateurs
Posté le 07-01-2002 à 22:55:10  profilanswer
pas du tout d accord,c tres bien...............pour les meufs.
n°1074630
freeman56
Posté le 07-01-2002 à 22:58:02  profilanswer
ça coute combien?  :??:
n°1074638
steph_d
Posté le 07-01-2002 à 22:59:05  profilanswer
J'aime pas les macs mais c'est sur que pour ceux qui font pas de jeux, pas d'appli pros, et qui n'ont de place que dans leur salon , il a sa place.
Dommage qu'ils ne soient pas allés au bout du concept en faisant le clavier et la souris sans fil...
n°1074665
verdoux
And I'm still waiting
Posté le 07-01-2002 à 23:04:01  profilanswer
Ca ira très bien sur la commode Louis XV du couloir.
n°1074680
el cabron
me gusta el perico
Posté le 07-01-2002 à 23:07:02  profilanswer
faut reconnaitre qu APPLE ne manque pas d imagination....
je suis curieux de tester la bete ....
n°1074683
aragornz
Posté le 07-01-2002 à 23:07:29  profilanswer
:) le droit à la différence ça vous dit qquchose !
Avouez simplement que le design est au moins novateur. On aime ou pas c a chacun de voir.
Pi pour les gens qui font de la bureautique, un peu de photo et de video numérique, surfent sur le net et n'ont pas envie de bidouiller leur machine ben c'est pas mal.
Pour bcp acheter une bécane la brancher et qu'elle marche sans qu'il se prennent la tête ça compte.
C'est pas mon trip à moi mais c'est celui de certains, donc je reste tolérent.
C'est pas pcq j'ai un PC et que je sais m'en servir que je vais me foutre de la gueule des macs et de leurs utilisateurs. ;)
 ;)  :hello:
n°1074701
steph_d
Posté le 07-01-2002 à 23:10:02  profilanswer
La qualité de l'assemblage semble etre assez soigné chez Apple, leur seconde (et derniere :D ) qualité avec le design
n°1074713
everybodie
Posté le 07-01-2002 à 23:13:09  profilanswer
j'aime particulierement la phrase suivante :
"Expect spectacular 3D effects
The new iMac ships combat-ready with an advanced graphics processing capability, thanks to its NVIDIA GeForce2 MX graphics processing unit."
sinon c vrai il est pas mal pour ceux qui veulent ce servir que d'un imac ...
[edtdd]--Message édité par everybodie--[/edtdd]
n°1074717
el cabron
me gusta el perico
Posté le 07-01-2002 à 23:14:16  profilanswer
t oublis MAC OS X qui en plus d etre stable (j ai pas dit  absence de bug  :lol: )est vraiment tres beau et tres simple a utiliser....
Rechercher le bonheur, c'est l'occupation des gens tristes.
n°1074727
Master_Jul
Posté le 07-01-2002 à 23:15:58  profilanswer
En tout cas, ils ont fait des économies sur la carte graphique, ils iront pas loin avec une MX... comment ca le proc ne suit déjà plus ? :D
n°1074748
Tetedeienc​h
Head Of God
Posté le 07-01-2002 à 23:25:18  profilanswer
Humpf, C vrai que toi, tu compares directement via les Mhz...
Deux proco a l'architecture radicalement différente ( PowerPC et notre x86 )
Félicitations.
L'ingénieur chipset nortiaux : Une iFricandelle svp ! "Spa du pâté, hin!" ©®Janfynette | "La plus grosse collec vivante de bans abusifs sur pattes" | OCCT v16 OUT !
n°1074758
steph_d
Posté le 07-01-2002 à 23:28:21  profilanswer
Les OS qui sont des surcouches graphiques à un shell quelqu'il soit j'ai déjà donné :D
n°1074781
PlyOne
Posté le 07-01-2002 à 23:37:26  profilanswer
Ho ptain mais on dirait VRAIMENT une lampe !
Ouahaha ils sont comiques chez Apple mais quand est-ce qu'ils sortiront un ordinateur (oui pas un objet de déco new age ou de l'électro ménager)
n°1074806
sasounian
Posté le 07-01-2002 à 23:45:10  profilanswer
c aps pour dire..mais si il y avait ts les logiciels pc sur mac..ca fait longtemsp que j'aurai un mac.. Le systeme MAC OS est vraiment le meilleur. Avant j'avasi un mac mais acause de ce sale microsoft qui bouffe tt le marché je me sis mis au PC....aux emmerdes :lol:
n°1074825
noliv
Posté le 07-01-2002 à 23:52:55  profilanswer
pas d'applis pro??? mais euh, t'es sur que ca va? Riens que dans les domaines de la mise en page, de la production musicale, du traitement video, les Macs sont tres repandus avec des applis tres pros. Pour la bureautique, il y a MS Office X. C'est pas des applis pro peut etre? Pour les memes domaines mais en amateur, il y a plein d'applis GRATUITES et de qualite faites par Apple. Le tout sur un Unix plutot novateur et tres efficace.
Le Mac a ses defaut, c'est pas la peine d'en inventer d'autres... je ne vois pas l'interet.
n°1074833
el cabron
me gusta el perico
Posté le 07-01-2002 à 23:54:31  profilanswer
UNIX c est quand meme une bonne base  ;)
n°1074839
fute77
Life Is Short ! Have Fun !
Posté le 07-01-2002 à 23:56:24  profilanswer
si ils mettent un CDE ca sera stable
voir un windowmaker ou un kde  :D
"Si il y avait un impot sur la connerie, l'Etat s'autofinancerai" J Yanne
n°1074857
noliv
Posté le 08-01-2002 à 00:03:37  profilanswer
Je l'utilise quotidiennement: Conclusion: AUCUN probleme de stabilite.
n°1074877
fute77
Posté le 08-01-2002 à 00:10:29  profilanswer
vi CDE c'est stable  :na:  :p
n°1074884
Posté le 08-01-2002 à 00:11:58  answer
Oui, c de la pub déguisée pour Pixar (cf leur logo) qui appartient à... Steeve jobs !
n°1074890
el cabron
me gusta el perico
Posté le 08-01-2002 à 00:13:09  profilanswer
moi aussi ( SAV) la stabilite des OS :sarcastic:  (sauf le X.1)
n°1074904
HarryTuttl​e
Posté le 08-01-2002 à 00:16:09  profilanswer
' Tain L'enfer !! j'en commande 25 pallettes pour tous les blaires qui en sont encore a demander AMD vs INTEL .. ATI vs NVIDIA ... Ma tante VS mon Oncle !!! Ca nous fera des vacances ...
Heu p'tites question au hazard ? C'est quoi qu'est mieux ? Une méga config qui marche du feu de dieu sans aucuns blèmes ou alors un gros bouzin plein de bugs de la mort qui tuent ? (Pardon pour la question : C'est pour faire "tendance" ).
L'important n'est pas de connaitre la solution, mais de savoir POURQUOI c'est la solution.
n°1074934
mavo
Posté le 08-01-2002 à 00:26:25  profilanswer
Cé pas pour les newbies un imac? :heink:
http://www3.sympatico.ca/lise.brassard/
n°1074942
The NBoc
Quo Modo Deum
Posté le 08-01-2002 à 00:29:12  profilanswer
vous seriez surpris des perfs reelles d un G4 ...
n°1074944
The NBoc
Quo Modo Deum
Posté le 08-01-2002 à 00:29:34  profilanswer
a votre pourquoi il a été interdit dans plusieurs pays???
n°1074947
The NBoc
Quo Modo Deum
Posté le 08-01-2002 à 00:30:02  profilanswer
au niveau de la puissance de calcul brute c une BOMBE!!
n°1074948
el cabron
me gusta el perico
Posté le 08-01-2002 à 00:30:10  profilanswer
c est pour ceux qui considerent qu on a pas besoin d etre mecanicien pour conduire une voiture......
n°1075340
rene pierr​e
Posté le 08-01-2002 à 10:19:40  profilanswer
a ceux qui s'etonne qu'on s'en prend a APPLE fo pas oublier que les slogans a la con ce sont eux qui les font!!et niveau connerie pour atteindre celui de :To go where no PC has gone before.
on peut se larguer alors ,moi aussi je sais faire dans l'absurde la preuve!!
n°1075362
boumbastic
Posté le 08-01-2002 à 10:29:31  profilanswer
je bosse sur des macs tte la journee, en pro (montage AVID) en PAO et en bureautique. je passe tt mon tps a depanner ces saloperies, instables et lentes a souhait. et puis au prix ou on les paye c vraiment enervant.
je peux vous dire que c vraiment de la merde et les perfs d'un G4 c a pleurer de rire, desole de vous le dire, lorsqu'on le compare a un pc recent pour un prix equivalent.
et c theoriquement pas des g4 de merde : silver G4 Bi pro 800 MHz.
voila c'etait mon coup de gueule, mais bon quand une station de montage AVID a + de 500 000 F est immobilisee a cause d'un petit G4 bien pourri mais tres beau, ca a tendance a m'enerver, surtout que c bibi qui doit se demerder avec....
[edtdd]--Message édité par BOUMBASTIC--[/edtdd]
n°1075374
warmasterc​s
Posté le 08-01-2002 à 10:34:57  profilanswer
C pas encore mort Apple ?
un sabre est une arme. le kenjutsu, une technique de mort. Peu importent les bonnes intentions, c'est la seul vérité. On tue pour protéger. On tue pour que d'autres vivent. C'est ca, la vérité du sabre.
n°1075383
boumbastic
Posté le 08-01-2002 à 10:36:24  profilanswer
si
 je m'en occupe !!
n°1075385
Ken
H.P. Lovecraft forever !!!
Posté le 08-01-2002 à 10:38:04  profilanswer
Reconnaîssez au-moins que le design est innovant !
Et comparez ce qui est comparable : il faut comparer ces nouveaux imac à l'offre gds constructeurs pc (packard-bell, compaq ...) et non aux machines d'assembleurs !
On se rend compte alors que leur prix est raisonnable pour qq'un qui souhaite juste surfer, faire du traitement de texte et jouer un peu (la majorité des utilisateurs lambda, donc !  :p ).
Notre forum de passionnés n'est pas représentatif du panel informatique du Français moyen.
[edtdd]--Message édité par Ken--[/edtdd]
Croire en Dieu est néfaste à l'émancipation individuelle.   "N'est pas mort ce qui à jamais dort, et au long des siècles peut mourir même la mort" HPL
n°1075426
ixemul
Nan mais sans blague ! ⚡
Posté le 08-01-2002 à 11:01:19  profilanswer
Hum... ya de moins en moins de passionnés sur ce forum
 Page :   1  2  3
Page Précédente
il parait que le pris de la ram (ddr et sdram) va doubler dans 3 joursordi nouvo = escargot
Plus de sujets relatifs à : Le nouvo iMac vous parait comment ?
