5619 connectés
  Flash... comment?
Flash... comment?
n°2443611
aerosimorg
Posté le 14-05-2003 à 17:25:36  profilanswer
salut
je veux flasher mon bios pour qu'un Xp 2000 soit reconnu
voila le liser moi du zip contenant les fichiers pour le flash
je pige pas tout...
             K7V8366A KuDoz 7 BIOS V3.8LCP release note
This disk contains three files:KD7_V38.BIN,README.TXT and AWDFLASH.EXE
1.The checksum of KD7_V38.BIN is 7C66(Hex);
2. How to use AWDFLASH.EXE utility:
   This is a flash memory write/read utility.
IMPORTANT NOTE:
   The AWDFLASH utility could not correctly run in windows (virtual 8086)
   MS-DOS mode. It must be proceeded with the following steps:
      1.Create a bootable system floppy diskette by typing "FORMAT A:/S"
        from the dos prompt under DOS6.XX or WINDOWS9X environment.
      2.Boot system with diskette.
      3.Then run the AWDFLASH utility.
Usage:
      AWDFLASH [BIOSfile1] [BIOSfile2] [/<sw>[/<sw>...]]
     BIOSfile1: New BIOS Name For FLASH Programming
     BIOSfile2: BIOS File For Backing-up the Original BIOS
 <command> function definition:
      cc: clear CMOS;        cp: clear PnP;
      cd: clear DMI.
/sn: No Original BIOS Backup. If this option is chosen:
      Be sure your new BIOS is compatible with your MB. If not, the system
        are damaged.
/sy: Backup Original BIOS to Disk File.
Examples:
        AWDFLASH ****.BIN /py/sn/cd/cp
Warning:
   Avoid power-off incidently in upgrading procedure, or system would fail
   to reboot!
UPDATE DATE:03/27/2003
en gros une fois sous DOS on fait koi? on tape koi?
n°2443658
jln2
Posté le 14-05-2003 à 17:42:07  profilanswer
n°2443668
aerosimorg
Posté le 14-05-2003 à 17:47:09  profilanswer
salut
j'avais pigé ca
mais c'est cette partie:
     cd: clear DMI.
       are damaged.
Examples:
fo ke je tape koi??
n°2443706
beber.done​ux01
oui
Posté le 14-05-2003 à 18:04:20  profilanswer
rien, c'est pour eviter qu'il te pose des questions avant le flashage. tapes simplement "AWDFLASH KD7_V38.BIN" et ca ira tres bien
  Flash... comment?
Kodak DX3600 et compact flash Danelec...Flash BIOS sur ABIT KA7
Ca existe un lecteur Compact Flash sur SCSI?Flash FC-R9100 Radeon
Flash Bios sur DVD Asus E616 16x/48x => prob bizarre!![FLASH BIOS MSI impossible ou quoi ?]
flash annulaireFlash du BIOS échoué...
Je flash mon BIOS ce soir à minuit...encouragez-moi, j'ai peur ! [Ayé]Gros pb de flash bios: SOYO V6BE+
Plus de sujets relatifs à : Flash... comment?
