9465 connectés
  [AVIS]kk'un a un ViewSonic 19" P90f
n°1531618
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 20:50:50  profilanswer
http://www.viewsonic.com/products/crt_p90f.htm
Features
0.24mm stripe pitch
This ultra-fine stripe pitch produces clear, crisp images with rich, vivid color, even at the highest resolutions.
1920 x 1440 maximum resolution
Displays a maximum resolution of 1920 x 1440 at 73Hz flicker-free refresh rate for easy-on-the-eyes viewing.
1920 x 1440 @ 73Hz
1800 x 1440 @ 73Hz
1600 x 1200 @ 87Hz
1280 x 1024 @ 101Hz
PerfectFlat® screen
Absolutely flat screen provides realistically proportioned, precise images with reduced reflection, image distortion and eye fatigue.
SuperContrast screen
Advanced glass filter with a low transmission rate assures bright, bold colors.
One-Touch Auto-Adjust function
Size and position automatically adjust with the touch of a button, filling the screen at any resolution.
OSD[/Power] lock function
When activated, user-controlled OSD/Power lock function prevents changes to monitor settings, maintaining an optimized image setting.
ARAG® screen treatment
This specially formulated anti-reflection, anti-glare screen treatment uses a multi-layer process to eliminate reflection while maintaining the highest image quality.
ViewSonic Wizard
This software provides user-friendly installation.
TCO'99 and ENERGY STAR® certified
PC and Mac® compatible
Three year limited warranty
24/7 free technical and customer support*
http://www.viewsonic.com/images/IMG_p90f_lrg.jpg
J'aurais voulu savoir ce qu'il vaut...
Message édité par spartacus le 16-06-2002 à 20:53:46
Lone Wolf Rider
n°1531724
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 21:51:16  profilanswer
personne? je voulias savoir le quel du G90f ou du P90f prendre
Lone Wolf Rider
n°1531795
jujuf1
Je suis un chat
Posté le 16-06-2002 à 22:10:40  profilanswer
c un nouveau model çà non ?
n°1531837
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 22:17:30  profilanswer
oui, il est nouveau, en 1024*1280 il est a 101Hz alors que le G30f est a 89Hz d'ou ma question le quel choisir? sachant que le P90f est 500frs plus cher.
Message édité par spartacus le 16-06-2002 à 22:17:55
Lone Wolf Rider
n°1531844
jujuf1
Je suis un chat
Posté le 16-06-2002 à 22:18:37  profilanswer
si ce n'est pas un trinitron çà peut etre tres interessant car les lignes çà m'embete
n°1531859
jujuf1
Je suis un chat
Posté le 16-06-2002 à 22:21:00  profilanswer
c koi les specs du g30 ?
n°1531865
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 22:21:45  profilanswer
non c'est pas un trinitron c un perfectflat derivé du diamondtron je crois ( regardes le test de HFR sur les moniteur 19" et regardes le P95f, c le meme tube )
Lone Wolf Rider
n°1531876
jujuf1
Je suis un chat
Posté le 16-06-2002 à 22:23:15  profilanswer
ah bah justeùment le p95f c un trinitron : il a les deux lignes
n°1531881
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 22:24:05  profilanswer
les spef du G30f
Features
0.21 horizontal dot pitch
0.25 diagonal dot pitch
1600 x 1200 maximum resolution
Displays a maximum resolution of 1600 x 1200 at 77Hz flicker-free refresh rate for easy-on-the-eyes viewing.
1600 x 1200 @ 77Hz
1280 x 1024 @ 89Hz
1024 x 768 @ 118Hz
PerfectFlat® screen
SuperClear® technology
SuperClear screen technology incorporates enhanced phosphor treatment and optimized glass filter to deliver vivid colors and image clarity.
OnView® controls
Screen adjustments are made via an on-screen menu using simple controls.
USB hub-compatible base
Base design allows easy integration of the optional ViewSonic USB (Universal Serial Bus) hub for convenient USB peripheral connection.
Plug & Play +
http://www.viewsonic.com/images/IMG_g90f_lrg.jpg
Lone Wolf Rider
n°1531896
jujuf1
Je suis un chat
Posté le 16-06-2002 à 22:26:49  profilanswer
ya aps a hesiter: mais 500 balles de plus
ta vu la difference des rafraichissments c tres important
n°1531897
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 22:27:02  profilanswer
effectivment c un derivée du trinitron mais j'ais cru lire kke part que ct pas du Sony mais du mistsu avec en plus une pellicule de phospore pour une meilleur couleur.
Lone Wolf Rider
n°1531904
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 22:28:25  profilanswer
oauis mais pour le moment j'ais que une pauvre GTS alors peut etre que utiliser les 500frs pour les mettre dans une GF3 ou une ti4200 aurait ete plus judicieu, t'en pense koi?
Lone Wolf Rider
n°1531907
jujuf1
Je suis un chat
Posté le 16-06-2002 à 22:29:39  profilanswer
ok. en touyt cas ya les deux lignes: pour certains çà pose probleme, pour dautre pas de pb. Moi j'ai vu un sony et on mavait parlé des lignes alors je les ai vu par contre dans les jeux on les voit pas. Sinon çà me parait un bon choix. en fait c koi qui le differe du p95f et quel est son prix
n°1531915
jujuf1
Je suis un chat
Posté le 16-06-2002 à 22:56:27  profilanswer
upup
n°1531917
jujuf1
Je suis un chat
Posté le 16-06-2002 à 22:58:01  profilanswer
non sciceremrent car si on depense 3000 balle pour un ecran, autant en depenser 3500 car le rafraichissment c important et jouez en 1600 avec un 87 hertz c le luxe. Moi c mon avis... maintenant
n°1531920
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 22:59:34  profilanswer
ce qui difere les P90f du p95f ce sont les frequence...et le prix
un test ici http://www.hardware.fr/html/articl [...] 22&page=13
le p90f est dispo a 3000Frs chez clust.
pour les barre grise je m'en fou, je prefere avoir de belle couleur et un frequece elevée que de ne pas avoir de barres grise ( je pense la au tube Flatron )
PS: scuze pour le tps de reponse, je pouvais plus acceder au forum, plantage du serveur?
Message édité par spartacus le 16-06-2002 à 23:01:26
Lone Wolf Rider
n°1531922
jujuf1
Je suis un chat
Posté le 16-06-2002 à 23:00:05  profilanswer
un ecran tu le gardera tres longtemps de plus. donc c pas de largent par les fenetre. Quand les jeux en hautes resolutions seeront monnaies courante bah taura un taux de rafrachissemment bon
n°1531930
jujuf1
Je suis un chat
Posté le 16-06-2002 à 23:02:22  profilanswer
j'ai été tres lontemps interessé par le p95 mais ya des gars qui se sont pleind de defauts ... je sais pas si c resolu. Pense à çà aussi. EN tout cas le p90 me parait bon rapport qualité prix çà c sur
n°1531933
jujuf1
Je suis un chat
Posté le 16-06-2002 à 23:03:52  profilanswer
moi pour linsatnt mon coup de coeur car je songe aussi au 19 pouce c pour çà que je susi interessé au topic c le LG 915 ft
n°1531934
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 23:04:20  profilanswer
bon je v me prendre ca alors je pense, un petit P90f, miam miam, je m'occupe de ca a la fin de la semaine et je reviendrai deonner mon avis dès reception
Lone Wolf Rider
n°1531940
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 23:05:51  profilanswer
c koi les frequence du LG?
Lone Wolf Rider
n°1531942
jujuf1
Je suis un chat
Posté le 16-06-2002 à 23:06:08  profilanswer
okay :) good luck et jespere que ten seras content ehehe ( au fait si tu compte te racheter une carte graph, vu la tailel de ton ecran, tu va jouer dans les ahutes resolution donc previligie les 128 mo meme si elels sont un peu inferieure aux 64 en perf. En haute resolution, elles reprennent l'avantage )
n°1531949
jujuf1
Je suis un chat
Posté le 16-06-2002 à 23:07:51  profilanswer
un ptit 89 en 1600 je crois
n°1531954
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 23:08:51  profilanswer
nop, presque
- Résolution de travail : 1280*1024 / 95Hz
- Résolution max. : 1600*1280 / 85 Hz
il est aussi 500Frs plus cher, hum pour moi 3500frs c trop qd meme.
Lone Wolf Rider
n°1531961
jujuf1
Je suis un chat
Posté le 16-06-2002 à 23:11:09  profilanswer
si tu parle du lg là tu t trompé attends je vais te passer celels que je sais
n°1531968
jujuf1
Je suis un chat
Posté le 16-06-2002 à 23:12:54  profilanswer
n°1532042
spartacus
Talk Shit, Get Shot
Posté le 16-06-2002 à 23:32:59  profilanswer
ché pas, ce sont les chiffre de clust pour le LG.
Lone Wolf Rider
n°1532133
spartacus
Talk Shit, Get Shot
Posté le 17-06-2002 à 00:05:00  profilanswer
http://www.lge.com/c_product/catal [...] ion=1,18,1
c bien 85 en 1600*1200
Message édité par spartacus le 17-06-2002 à 00:05:28
Lone Wolf Rider
n°1532155
jujuf1
Je suis un chat
Posté le 17-06-2002 à 00:11:32  profilanswer
oui c e quil disent mais je crois kon peut le monter à 89 mais pour quelques Hz ....
n°1541947
Perfect Da​rk
Posté le 20-06-2002 à 08:50:07  profilanswer
Il a un pitch de 0.24 en plus, ce qui est mieux que les 0.25 du P95F, à part la légère diff de fréquence, il est supèrieur ...
n°1541967
spartacus
Talk Shit, Get Shot
Posté le 20-06-2002 à 23:10:31  profilanswer
oauis c vrai et pi il parait que le p90f n'a pas de ligne (de meme que le G90f), tandis que le p95f en a lui, bref il me tarde de le recevoir :love:
Lone Wolf Rider
n°1542035
DrGreenthu​mb
Posté le 20-06-2002 à 23:35:15  profilanswer
Viewsonic:on entend jamais de méchantes critiques à son sujet.
C'est des bons écrans mais parfois assez mal distribué en France.
Thermaltake - Volcano 7+ Silent Storm (P4) : des avis !!!!!!!!!!!!!!!!Iiyama LS902UT : Un avis éclairé ?
Votre avis sur cartes graphiquesAVIS au possesseur de PENTIUM IV
¤ Demande d'avis ¤besoin de votre avis
choisir la config la moins chere pour qqun de la famille. Votre avis ?GateLock X200 votre avis ;)
C quoi la différence entre un Viewsonic P95F et un G90FEPSON vs CANON faites moi part de votre avis svp
Plus de sujets relatifs à : [AVIS]kk'un a un ViewSonic 19" P90f
