4688 connectés
  je remets ça, jai besoin de conseil !
n°1820604
Sanguku
Kamehameha
Posté le 19-09-2002 à 08:49:34  profilanswer
bonjour
ya moyen d'augmenter mon score affreux ?
3DMARK2001 PROJECT FILE
PROJECT
Name My Benchmark
Description
Registration Name
Registration Key
3DMark Version 330
DISPLAY
Platform NVIDIA RIVA TNT
CPU Optimization D3D Software T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format 32 bit
Buffering Double
Refresh Rate Default
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level Low
RESULTS
3DMark Score 361
Game 1 - Car Chase - Low Detail 5.1 fps
Game 1 - Car Chase - High Detail 1.0 fps
Game 2 - Dragothic - Low Detail 4.2 fps
Game 2 - Dragothic - High Detail 1.3 fps
Game 3 - Lobby - Low Detail 11.6 fps
Game 3 - Lobby - High Detail 5.3 fps
Game 4 - Nature Not supported by hardware
Fill Rate (Single-Texturing) 58.4 MTexels/s
Fill Rate (Multi-Texturing) 78.3 MTexels/s
High Polygon Count (1 Light) 0.9 MTriangles/s
High Polygon Count (8 Lights) N/A
Environment Bump Mapping Not supported by hardware
DOT3 Bump Mapping Not supported by hardware
Vertex Shader 2.2 fps
Pixel Shader Not supported by hardware
Advanced Pixel Shader Not supported by hardware
Point Sprites 0.4 MSprites/s
SYSTEM INFO
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer Intel
Family Pentium® II
Internal Clock 351 MHz
Internal Clock Maximum 400 MHz
External Clock 100 MHz
Socket Designation SLOT 1
Type <unknown>
Upgrade Slot 1
Capabilities MMX, CMov, RDTSC
Version Pentium II
CPUID 0x00000652
CACHES
Level 1
Capacity 32 KB
Type Internal
Type Details Synchronous
Error Correction Type <unknown>
Associativity <unknown>
Level 2
Capacity 512 KB
Type External
DIRECTX INFO
DirectX Version 8.1
DIRECTDRAW INFO
DirectDraw Version  4.08.01.0881
DISPLAY DEVICES
Description Primary Display Driver
Manufacturer NVIDIA
Name NVIDIA RIVA TNT
Total Local Video Memory 16 MB
Total Local Texture Memory 16 MB
Total AGP Memory 24 MB
Display Driver nvdisp.drv
Display Driver Version 4.12.01.0650
Driver WHQL Certified No
Max Texture Width  2048
Max Texture Height 2048
Max User Clipping Planes 0
Max Active Hardware Lights 0
Max Texture Blending Stages 8
Textures In Single Pass 2
Vertex Shader Version N/A
Pixel Shader Version N/A
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
Vendor ID 0x10de
Device ID 0x0020
Sub-System ID 0x05501092
Revision 0x04
DISPLAY MODES
Resolution 320x200x16-bit RGB [565]
Resolution 320x240x16-bit RGB [565]
Resolution 400x300x16-bit RGB [565]
Resolution 480x360x16-bit RGB [565]
Resolution 512x384x16-bit RGB [565]
Resolution 640x400x16-bit RGB [565]
Resolution 640x480x16-bit RGB [565]
Resolution 720x480x16-bit RGB [565]
Resolution 720x576x16-bit RGB [565]
Resolution 800x600x16-bit RGB [565]
Resolution 960x720x16-bit RGB [565]
Resolution 1024x768x16-bit RGB [565]
Resolution 1152x864x16-bit RGB [565]
Resolution 1280x1024x16-bit RGB [565]
Resolution 320x200x32-bit RGB [888]
Resolution 320x240x32-bit RGB [888]
Resolution 400x300x32-bit RGB [888]
Resolution 480x360x32-bit RGB [888]
Resolution 512x384x32-bit RGB [888]
Resolution 640x400x32-bit RGB [888]
Resolution 640x480x32-bit RGB [888]
Resolution 720x480x32-bit RGB [888]
Resolution 720x576x32-bit RGB [888]
Resolution 800x600x32-bit RGB [888]
Resolution 960x720x32-bit RGB [888]
Resolution 1024x768x32-bit RGB [888]
Resolution 1152x864x32-bit RGB [888]
Resolution 1280x1024x32-bit RGB [888]
TEXTURE FORMATS
Pixel Format 32-bit ARGB [8888]
Pixel Format 32-bit RGB [888]
Pixel Format 16-bit RGB [565]
Pixel Format 16-bit RGB [555]
Pixel Format 16-bit ARGB [1555]
Pixel Format 16-bit ARGB [4444]
3D Capabilities AGP Texturing, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Rendering to a Window, Mipmap LOD Bias Adjustment
DIRECTSHOW INFO
DirectShow Version 6.03.01.0400
REGISTERED DIRECTSHOW FILTERS
Filter .RAM file Parser
Filter AC3 Parser Filter
Filter ACELP.net Sipro Lab Audio Decoder
Filter ACM Wrapper
Filter ASF ACM Handler
Filter ASF DIB Handler
Filter ASF DJPEG Handler
Filter ASF ICM Handler
Filter ASF JPEG Handler
Filter ASF URL Handler
Filter ASF embedded stuff Handler
Filter ASX file Parser
Filter ASX v.2 file Parser
Filter AVI Decompressor
Filter AVI Draw
Filter AVI Splitter
Filter AVI/WAV File Source
Filter BDA MPEG2 Transport Information Filter
Filter ClearVideo® Decompression Filter
Filter Color Space Converter
Filter DV Muxer
Filter DV Splitter
Filter DV Video Decoder
Filter Default DirectSound Device
Filter Default MidiOut Device
Filter DivX Decoder Filter
Filter DivX MPEG-4 DVD Video Decompressor
Filter File Source (Async.)
Filter File Source (Netshow URL)
Filter File Source (URL)
Filter File stream renderer
Filter IVF source filter
Filter Indeo(R) audio software
Filter Indeo® video 4.4 Decompression Filter
Filter Indeo® video 5.06 Decompression Filter
Filter Internal LMRT Renderer
Filter Internal Script Command Renderer
Filter Line 21 Decoder
Filter Lyric Parser
Filter MIDI Parser
Filter MJPEG Decompressor
Filter MPEG Audio Decoder
Filter MPEG Layer-3 Decoder
Filter MPEG Video Decoder
Filter MPEG-2 Demultiplexer
Filter MPEG-2 Splitter
Filter MPEG-I Stream Splitter
Filter Microsoft MPEG-4 Video Decompressor
Filter Microsoft Screen Video Decompressor
Filter Multi-file Parser
Filter NSC file Parser
Filter Overlay Mixer2
Filter QT Decompressor
Filter QuickTime Movie Parser
Filter SAMI (CC) Parser
Filter TrueMotion 2.0 Decompressor
Filter URL StreamRenderer
Filter VBI Surface Allocator
Filter VGA 16 Color Ditherer
Filter VIVO Audio Decoder Filter
Filter VIVO Video Decoder Filter
Filter Video Renderer
Filter Voxware MetaSound Audio Decoder
Filter Voxware MetaVoice Audio Decoder
Filter WM ASF Reader
Filter WM ASF Writer
Filter WMP CD Filter
Filter WMplug
Filter WST Decoder
Filter Wave Parser
Filter Windows Media Audio Decoder
Filter Windows Media Multiplexer
Filter Windows Media Pad VU Data Grabber
Filter Windows Media Update Filter
Filter Windows Media Video Decoder
Filter Windows Media source filter
Filter XML Graphbuilder
Filter XML Playlist
Filter XTL Loader
MEMORY INFO
Total Physical Memory 256 MB
Free Physical Memory 73.26 MB
Total Pagefile Memory 1.75 GB
Free Pagefile Memory 1.62 GB
MEMORY ARRAYS
Max Module Capacity 32 MB
Location <unknown>
Use <unknown>
Supported Error D&C Parity
Supported Speeds 70ns, 60ns
Supported Types EDO, SDRAM
Supported Voltages 3.3V
MEMORY SLOTS
Installed & Enabled Size 64 MB
Form Factor <unknown>
Frequency 16 MHz
Slot DIMM1
Manufacturer
Type <unknown>
Type Details DIMM, SDRAM
Enabled Size 64 MB
Total Bit Width 0
Data Bit Width 0
Frequency 16 MHz
Slot DIMM2
Manufacturer
Type <unknown>
Enabled Size 64 MB
Total Bit Width 0
Data Bit Width 0
Installed & Enabled Size 128 MB
Frequency 16 MHz
Slot DIMM3
Manufacturer
Type <unknown>
Enabled Size 128 MB
Total Bit Width 0
Data Bit Width 0
Installed & Enabled Size 0  bytes
Frequency 16 MHz
Slot DIMM4
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
MOTHERBOARD INFO
Manufacturer
Model i440BX-SMC60X
Version N/A
BIOS Vendor Award Software International, Inc.
BIOS Version 4.51 PG
BIOS Release Date 05/27/99
BIOS Properties Plug and Play, Flash, AGP
CARD SLOTS
Number 0
Designation ISA
Type ISA
Characteristics 5.0V
Data Bus Width 16
Details Long
Device Class <unknown>
Device Name
Device Manufacturer
Device Driver Date
Device Vendor ID 0x0000
Device ID 0x0000
Device Sub-System ID 0x00000000
Device Revision 0x00
IRQ 0
Number 0
Designation ISA
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 0
Designation ISA
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 0
Designation ISA
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 1
Designation PCI
Type PCI
Data Bus Width 32
Details Available, Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 2
Designation PCI
Type PCI
Data Bus Width 32
Details In Use, Long
Device Class Multi-Function Adapter
Device Name Vortex Multifunction PCI Platform
Device Manufacturer Aureal Semiconductor
Device Driver Date 01-19-1999
Device Vendor ID 0x12eb
Device ID 0x0001
Device Sub-System ID 0x000112eb
Device Revision 0x02
IRQ 12
Number 3
Designation PCI
Type PCI
Data Bus Width 32
Device Class Network Adapter
Device Name Realtek RTL8139(A) PCI Fast Ethernet Adapter
Device Manufacturer Realtek
Device Driver Date 06/08/2000
Device Vendor ID 0x10ec
Device ID 0x8139
Device Sub-System ID 0x813910ec
Device Revision 0x10
IRQ 5
Number 4
Designation PCI
Type PCI
Data Bus Width 32
Device Class SCSI Controller
Device Name Adaptec AIC-7850 PCI SCSI Controller
Device Manufacturer Adaptec
Device Vendor ID 0x9004
Device ID 0x5078
Device Sub-System ID 0x78509004
Device Revision 0x03
IRQ 10
Number 0
Designation AGP
Type AGP
Data Bus Width 32
Device Class Display Adapter
Device Name NVIDIA RIVA TNT
Device Manufacturer NVIDIA
Device Driver Date 12/04/2000
Device Vendor ID 0x10de
Device ID 0x0020
Device Sub-System ID 0x05501092
Device Revision 0x04
IRQ 11
SYSTEM DEVICES
Description Intel 82443BX Pentium(r) II Processor to PCI bridge (with GART support)
Manufacturer Intel
Vendor ID 0x8086
Device ID 0x7190
Subsystem ID 0x00000000
Revision 0x03
Description Intel 82443BX Pentium(r) II Processor to AGP controller
Manufacturer Intel
Vendor ID 0x8086
Device ID 0x7191
Revision 0x03
Description Intel 82371EB PCI to ISA bridge (ISA mode)
Manufacturer Intel
Vendor ID 0x8086
Device ID 0x7110
Revision 0x02
Description Intel 82371EB Power Management Controller
Manufacturer Intel
Vendor ID 0x8086
Device ID 0x7113
Revision 0x02
Revision 1.0
Rate 1x, 2x (2x enabled)
Aperture Size 64 MB
Sideband Addressing supported (enabled)
Fast Write not supported
MONITOR INFO
MONITORS
Name SONY CPD-200ES
Manufacturer SONY Corporation
Max Width 1280
Max Height 1024
POWER SUPPLY INFO
BATTERIES
OPERATING SYSTEM INFO
Operating System Microsoft Windows ME
Version 4.90.3000
Service Pack
Locale FR
Desktop Width 1024
Desktop Height 768
Desktop BPP 16
HARD DISK INFO
HARD DISKS
Name GENERIC IDE  DISK TYPE46
Manufacturer (Standard disk drives)
Capacity 18.64 GB
Model <unknown>
Interface Type <unknown>
Moi je cherche tout ce qui veulent se débarasser de matériels nouveaux! sinon bah bah voilà quoi ! je sais pas quoi vous dire !
n°1820607
bichoco
Posté le 19-09-2002 à 08:52:51  profilanswer
change de pc  :heink:
n°1820610
tooot
Le visiteur.
Posté le 19-09-2002 à 08:55:39  profilanswer
La tnt n'est pas faite pour la 32bit sinon les textures deviennent blanche
n°1820611
Graffin
Demo or Die !
Posté le 19-09-2002 à 08:57:40  profilanswer
et les drivers ? tu peux pas changer ? (->21.xx ou 23.11)
ca a rien donné le lien d'hier :hello:
::Mind is a terrible thing to taste::
n°1820627
tooot
Le visiteur.
Posté le 19-09-2002 à 09:04:42  profilanswer
Prends les drivers 22.80 ca avait monter mon score (c'est 1 tnt vanta)
n°1820629
Sanguku
Kamehameha
Posté le 19-09-2002 à 09:08:37  profilanswer
eh nono le lien d'hier, yavait pas de driver, il mont renvoyer vers www.nvidia.fr et sur ce site, c tout sombre pour moi, je trouve plus la TNT1 ça minkiete !!!
n°1820632
tooot
Le visiteur.
Posté le 19-09-2002 à 09:13:03  profilanswer
ils ne font plus de driver tnt je crois :heink:
n°1820637
Sanguku
Kamehameha
Posté le 19-09-2002 à 09:15:50  profilanswer
DISPLAY
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Buffering Double
FSAA Mode None
c bizarre mais jai po 32 bit sur ma propriete d'affichage !!
ou on peut changer ça ?!?
n°1820640
Sanguku
Kamehameha
Posté le 19-09-2002 à 09:17:13  profilanswer
OOPSSSS :eek2:  :eek2:  :eek2:
n°1820647
bichoco
Posté le 19-09-2002 à 09:24:10  profilanswer
les detonators font tourner tt les cartes y compris les tnt par contre ils apportent aucune amèlioration sur des cartes aussi anciennes
Petit conseil - carte mère pour athlon XP 1700+S.o.S Besoin d'Aide (floppy 1.44)
conseil entre 19pouce ou mon vieux17 avec tft 15poucebesoin d'aide pour changer de processeur
[Conseil d'achat] Que pensez vous de cette R 8500 (rue du commerce) ??Besoin conseils pour achat de nouveaux matos
Achat d'un lecteur DVD besoin de qqs conseilsConseil scanner Rapide et pas trop cher
conseil pour upgrade cg gf2 pro vers radeon 8500....Conseil d'achat Proco+Carte mère + Ram + carte graph
Plus de sujets relatifs à : je remets ça, jai besoin de conseil !
