3666 connectés
  Probléme Carte Graphique ( OpenGl)
n°2921645
al59
Posté le 04-01-2004 à 16:49:53  profilanswer
Bonjour , je suis chez un ami il a une ATI Rage 128 Pro 4X AGP TMDS
et windows XP
on veut installer un jeu , il s'installe bien mais des qu'on le lance jai un message d'erreur :
Erreur Fatale :
Chargement de Open GL impossible. Verifiez que vous avez correctement installé les pilotes les plus recent de carte graphique
jai ça aussi :
COD MP 1.1 build win-x86 Oct 8 2003
----- FS_Startup -----
Current language: english
Current search path:
D:\PROGRA~1\CALLOF~1\main\pak6.pk3 (3 files)
D:\PROGRA~1\CALLOF~1\main\pak5.pk3 (4858 files)
D:\PROGRA~1\CALLOF~1\main\pak4.pk3 (1668 files)
D:\PROGRA~1\CALLOF~1\main\pak3.pk3 (1992 files)
D:\PROGRA~1\CALLOF~1\main\pak2.pk3 (694 files)
D:\PROGRA~1\CALLOF~1\main\pak1.pk3 (2642 files)
D:\PROGRA~1\CALLOF~1\main\pak0.pk3 (12828 files)
D:\PROGRA~1\CALLOF~1/main
File Handles:
29633 files in pk3 files
execing default_mp.cfg
couldn't exec language.cfg
couldn't exec config_mp.cfg
couldn't exec autoexec_mp.cfg
========= autoconfigure
configure_mp.csv: using configuration 1200 cpu MHz 256 sys MB 64 vid MB
execing configure_mp.cfg
cl_language will be changed upon restarting.
fs_basepath is write protected.
fs_homepath is write protected.
WARNING: No language string information available for english
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Measured CPU speed is 1.80 GHz
System memory is 256 MB (capped at 1 GB)
Video card memory is 64 MB
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
----- Client Initialization -----
Resolving codmotd.activision.com
Couldn't resolve address
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...shutting down QGL
...unloading OpenGL DLL
Forcing 640x480 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 3: 640 480 FS
...calling CDS: ok
...created window@0,0 (640x480)
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
----- CL_Shutdown -----
RE_Shutdown( 1 )
Chargement de OpenGL impossible. Vérifiez que vous avez correctement installé les pilotes les plus récents de carte graphique depuis le site officiel du constructeur.
je suis aller sur touslesdrivers.com
et sur ati.com
jai telecharger les driver et il me dise quil sont pas compatible ...
jai  aussi dll un opengl.dll (trouvé sur telecharger.com) pour quake mais ca fonctionne pas non plus... :(
qq1 a une idéé ??
merci bien
Manuel carte mère PCCHIPS ES8mcarte mère Athlon + SD-RAM ?
Problème de gravure avec DVD+R sur DVR-106dCarte mere Asrock K7s8x fiable et stable?????
Question sur le remplacement de ma carte mère DCD :(Reboot sans arret (Asus A7N8X) Probleme Réglé
probleme de cablage hdd sataCarte Mère HS MSI KT3 Ultra, quoi prendre à la place?
kill bill ; windows a kek probleme chez moiProblème de démarrage MSI K7T Turbo2 (MS-6330v5)
Plus de sujets relatifs à : Probléme Carte Graphique ( OpenGl)
