7457 connectés
  Probleme d'install Carte Son sur SN25P
n°4779388
Coffin_Rid​er
Posté le 21-04-2006 à 00:21:07  profilanswer
Bonjour a tous,
Possédant un Shuttle SN25P et ayant marre de ne pouvoir avoir la fonction boost micro comme la majorité des gens je parcours le forum via arena
et m'appercoit que certains ont resolu le probleme.
Je suis donc la procedure donné par certains a savoir:
About VIA Vinyl Envy24PT drivers, missing feature (20db / mic boost, set to front mic) issue
Okey, got it to work. Here's what I did:
Uninstall current driver and reboot
After reboot
- If it ask for driver cancel
- If it auto install. Go to Device manager, find your envy card, right click and uninstall it.
Then delete these keys in registry (If exist):
HKEY_CURRENT_USER\SOFTWARE\QSound Labs, Inc.
HKEY_CURRENT_USER\SOFTWARE\VIA Technologies, INC.
HKEY_LOCAL_MACHINE\SOFTWARE\QSound Labs, Inc.
HKEY_LOCAL_MACHINE\SOFTWARE\VIA Technologies, INC.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EnvyDefault
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Envy24HFS
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\MediaCategories
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1412&DEV_1724&SUBSYS_50361297&REV_01
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\EnvyDefault
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Envy24HFS
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\MediaCategories
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\PCI\VEN_1412&DEV_1724&SUBSYS_50361297&REV_01
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\EnvyDefault
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\Envy24HFS
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\MediaCategories
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Enum\PCI\VEN_1412&DEV_1724&SUBSYS_50361297&REV_01
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0005
(If you cant delete: Edit permission and give yourself full control. Then delete)
Reboot (just to be clean)
- It should NOT auto install
Install latest envy driver, and reboot
And hopefully it works
Apres avoir suivie cette procedure, en redemarrant, je m'appercoit que windows ne cehrche plus a installer la carte son.
Je m'appercoit egalement que le driver de la carte son n'est pas present dans la barre des taches et la ou sa ce gate c'est que je n ai plus de son!
J'essaye de chercher la carte son dans gestionaire de periphérique, mais elle n'apparait plus!!
J'ai reussi a la trouver mais soit en faisant une recherche de periphérique ou soit dans sons et peripheriques audios ( dans le paneau de config )
lorsque je demande a voir les propriétés de la carte son, windows me dit que pour l'état : Les pilotes de ce périphérique ne sont pas installés. (Code 28)
Cliquez sur Réinstaller le pilote pour réinstaller les pilotes de ce périphérique.
j'essaye alors de les installer manuellement mais le pilote qir j'utilise ne s'installe que par un setup !!
j ai installer les pilotes VIA Envy version 5.00b
je suisur winXP SP2
Merci de me dire comment recuperer mon son!!!
Probleme avec ma CM P4V800D-XProblème écran & Carte Graphique
Quel est le meilleur processeur AMD et carte mère ?Gros probléme avec disque dur seagate 7200.8 200go SATA
Probleme Chuck Ati Patch Oblivion Radeon x1900xtProblème carte son Realtek ALC
probleme de ram apres changement tourLa bonne carte graphique du moment?
Plus de sujets relatifs à : Probleme d'install Carte Son sur SN25P
