3835 connectés
  Carte Mere abit instalations help
n°6149752
antec74
Posté le 12-01-2008 à 13:33:33  profilanswer
Bonjours a tous, je viens de monter mon pc,et maintenant je dois installer mon BIOS de ma C.M abit ip35 pro seulement mon manuelle et tout en anglais je ne comprend rien. Y-a-t-il des sites qui propose de manulel en francais ?
merci 'avance
n°6149768
redbull911​1
Posté le 12-01-2008 à 13:38:55  profilanswer
pourquoi tu veux installer ton bios
n°6149791
antec74
Posté le 12-01-2008 à 13:47:38  profilanswer
bin il y a un cd est c'est que il faut le metre pour tous parametre ....
n°6149795
antec74
Posté le 12-01-2008 à 13:48:41  profilanswer
le truc trop technique :BIOS Setup
This motherboard provides a programmable EEPROM so that you can update the BIOS utility.
The BIOS (Basic Input/Output System) is a program that deals with the basic level of
communication between processor and peripherals. Use the BIOS Setup program only when
installing motherboard, reconfiguring system, or prompted to “Run Setup”. This chapter
explains the Setup Utility of BIOS utility.
After powering up the system, the BIOS message appears on the screen, the memory count
begins, and then the following message appears on the screen:
PRESS DEL TO ENTER SETUP
If this message disappears before you respond, restart the system by pressing <Ctrl> + <Alt>
+ <Del> keys, or by pressing the Reset button on the computer chassis. Only when these two
methods fail should you restart the system by powering it off and then back on.
After pressing <Del> key, the main menu screen appears.
Phoenix – AwardBIOS CMOS Setup Utility
► uGuru Utility ► PnP/PCI Configurations
► Standard CMOS Features Load Fail-Safe Defaults
► Advanced BIOS Features Load Optimized Defaults
► Advanced Chipset Features Set Password
► Integrated Peripherals Save & Exit Setup
► Power Management Setup Exit Without Saving
Esc: Quit
F10: Save & Exit Setup
F6 : Save PROFILE To BIOS
n°6149804
redbull911​1
Posté le 12-01-2008 à 13:51:43  profilanswer
tu t'en fou il y en a un d'usine dans ta carte mére, si tu n'as pas de soucis pas besoin de le mettre a jour
n°6149806
antec74
Posté le 12-01-2008 à 13:52:57  profilanswer
oki je vais essayer mais alors je lance mon cd windows vista et c tou ? pas besoins de rien parametrer ... ????
n°6149812
redbull911​1
Posté le 12-01-2008 à 13:55:53  profilanswer
exactement,
tu n'as pas besoin de mettre a jour ton bios pour le paramétrer tu fais au demarrage del ou f2 ou autre chose et tu rentre dans le bios
n°6149816
antec74
Posté le 12-01-2008 à 13:57:43  profilanswer
oki merci
remplacement carte graphique GRILLÉEntrée line in de la carte son d'un Pc
Choix carte graphique svp !Quelle carte choisir ?? x800-x1650-7600gs
carte mere pour E2180 pouvant supporter 2 DD en idea l'aide carte graphique !!!!!!!!!!!
Besoin d'aide !!! Help !!! A votre bon coeurquelle carte dx10 pour +/- 120 €
incompatibilité carte mère carte graphique
Plus de sujets relatifs à : Carte Mere abit instalations help
