3504 connectés
  X800PRO => X800XT PE !!!
n°3223230
anoulios23
Posté le 27-05-2004 à 19:48:32  profilanswer
1. Download X800XT 256mb BIOS http://www.mvktech.net/request.php?390
2. Download Flashrom 2.37 http://www.overclockers.ru/cgi-bin/...ashrom_2.37.rar
3. Flash the XT bios using flashrom from a true dos prompt (not a dos prompt within windows!!) and power off after flashing is complete. (command is flashrom -p 0 biosname.rom -f )
4. Remove the card, remove heatsink (3 screws) and join the 2 leftmost points as in this photograph.
http://www.andovernaturalproducts.co.uk/x800Pro1.jpg
5. Reapply the heatsink/fan and some AS5 while you're at it
6. Refit card in machine and boot up. Windows should detect it as a new card and require you to reboot after it's changed drivers.
7. Use ATiTool 0.0.20 to check how many pipes are enabled.
8. Post results here.
I take no responsibility blah blah blah...........
Unless you botch the joining of contacts, or damage the card when removing/refitting heatsink etc, there should be no risk. ATi check all cores with 16 pipes enabled before leaving the plant, this is how they decide which core for pro's and which for XTs.
n°3223261
starconsol​e
Vous n'en reviendrez pas.
Posté le 27-05-2004 à 19:59:31  profilanswer
ce serait bieng de le mettre en FR :)
n°3223264
lupin3
Fisherman Friends
Posté le 27-05-2004 à 20:00:20  profilanswer
Moi je veux bien tester, mais faudrait que vous m'achetiez une X800Pro :whistle: ;)
qui a acheté une x800pro?X800XT PlatinumEdition sorti??
x800xt disponible mais ou?????X800XT ,Disponibilité ??????????
X800pro Sapphire : nouveaux tests avec cata 4.7 béta!influence processeur sur X800pro
Alim Zalman 400w : je crois que c'est rapé pour une X800XT ou cie...[Sondage bête] Gf6800Ultra ou X800XT ?
Plus de sujets relatifs à : X800PRO => X800XT PE !!!
