4104 connectés
  performance 3D avec patch 1.3 pour farcry , question ?...
n°3614512
netpower
Posté le 06-11-2004 à 16:13:26  profilanswer
salut
voila  je viens de lire le test a propos des carte 3D haut de gamme actuel et le patch 1.3 pour farcry ici :
http://www.firingsquad.com/hardware/far_cry_1.3/
et il parle dune nouvelle technologie implémenté par Crytek qui se nomme HDR
-"Crytek has implemented the GeForce6’s OpenEXR technology for HDR, and the results are pretty impressive:"
comment se trouve cette techniologie et comment lactivé ??
@+ Netpower  addict
n°3614550
Stoffinato​r
Posté le 06-11-2004 à 16:27:29  profilanswer
Méthode pour régler le HDR:
(pompée sur un autre forum)
"1. Find the file called "system.cfg" in your FarCry folder(Example: C:Program FilesUbisoftCrytekFar Cry)
2. Open this file with a text editor (such as Windows own notepad).
3. Here you’ll find 4 strings, that is related to HDR(I have added a little notice to each setting, explaining what I believe to have experienced by trying and changing them. Altering the settings won’t blow up your computer, but if you want to be able to use the standard values after experimenting, you better write those down first):
r_HDRBrightOffset = "6.000000" (lower value = brighter HDR lighting)
r_HDRBrightThreshold = "3.000000" (lower value = brighter HDR “eye blinding” effect)
r_HDRLevel = "0.600000" (higher value = more light blooming)
r_HDRRendering = "0" (0=HDR is disabled and the other 3 settings ignored. 1-11 enables different methods of HDR. 7 seems to be the preferred all-round best choice and is recommended if you don’t want to try all of the different HDR modes.)
4. To enable HDR, you only need to change r_HDRRendering = "0" to r_HDRRendering = "7".
If you want to adjust how the HDR is displayed, you need to alter one of the other settings described above.
(Btw, you can also activate HDR within the game by typing r_HDRRendering 7 in the console, but by using the first method, you don’t need to do this everytime.)
5. Save the changes to the file and start FarCry
PS: Remember to disable AA(AntiAliasing) before activating HDR."
performance du systeme?Petite question sur LE NO NAME
Question pour voir si la MB est nazeoverclocking, une question toute bete
question sur mon p4 help !!!Question bundle Asus 6800GE
question de garantie disque durQuestion sur RAM
DLL ou not OCX that's the question !Config PC - Question sur la CG
Plus de sujets relatifs à : performance 3D avec patch 1.3 pour farcry , question ?...
