5416 connectés
  Gigabyte 9600PRO mal regler
n°2777889
Ozarius200​3
Posté le 16-10-2003 à 22:56:07  profilanswer
Salut a tous
J ai une carte graphique gigabyte ati 9600pro 128 mo ddr,
le probleme c est que j arrive pas a la configure. J ai telecharger power strip et voici le rapport de diagnostique:
Diagnostic report - generated on 16/10/2003
PowerStrip build - 422
Windows build - v.5.1.2600.2.Service Pack 1
DirectX build - v.5.3.0000000.900 built by: DIRECTX
OpenGL renderer - (n/a)
System board
Type - NVidia nVidia-nForce-6A61BA1BC-18
BIOS - Phoenix-Award Bios, 07/24/2003
AGP aperture - 256 MB
AGP transfer mechanism - Désactivé
AGP non-local memory - (n/a)
AGP revision - 3.00
AGP transfer rates supported - 4x, 8x
Current AGP transfer rate - 4x
Sideband addressing - hardware support, but currently disabled
Fast write protocol - hardware support, but currently disabled
AGP texturing - hardware support, but currently disabled
Graphics card #1
Identity - RADEON 9600 SERIES
Memory clock - 297,00 MHz
Engine clock - 398,25 MHz
IRQ - 19, not shared
AGP revision - 3.00
Current AGP transfer rate - (n/a)
Sideband addressing - Enabled
Display driver - ati2dvag.dll, v.6.14.10.6387
DirectX driver - ati2dvag.dll, v.6.14.10.6387
Attached monitor - Écran Plug-and-Play (Microsoft)
Monitor caps (1) - 1600x1200, 75kHz, 85Hz
Device enumeration
RADEON 9600 SERIES (41501002h) - using IRQ19
Giga-Byte Display controller (41701002h)
Abit CPU-to-PCI/AGP bridge (01E010DEh)
NVidia RAM controller (01EB10DEh)
NVidia RAM controller (01EE10DEh)
NVidia RAM controller (01ED10DEh)
NVidia RAM controller (01EC10DEh)
NVidia RAM controller (01EF10DEh)
Abit PCI-to-ISA bridge (006010DEh)
Abit SMBus (006410DEh) - using IRQ11
Abit Universal serial bus (USB) (006710DEh) - using IRQ22
Abit Universal serial bus (USB) (006710DEh) - using IRQ20
Abit Universal serial bus (USB) (006810DEh) - using IRQ21
Abit Ethernet controller (006610DEh) - using IRQ22
Abit Audio device (006B10DEh) - using IRQ20
Abit Audio device (006A10DEh) - using IRQ21
NVidia PCI-to-PCI/AGP bridge (006C10DEh)
Abit IDE controller (006510DEh)
Abit Firewire bus (006E10DEh) - using IRQ21
NVidia PCI-to-PCI/AGP bridge (01E810DEh)
Donc power strip me dit que j ai plein de fonction qui ne sont pas activés ! comment les activer?
De plus je comprend pas pourquoi il detecte ma carte en AGP 4X puisque dans le bios elle est reglé sur 8x!
Merci de votre aide
n°2777992
kannibal
pas glop pas glop........
Posté le 17-10-2003 à 00:03:17  profilanswer
dans le bios
n°2778057
Optitribe
Posté le 17-10-2003 à 01:35:09  profilanswer
Dans les paramètres d'affichage ATI , il y'a un onglet SmartGart qui te permet d'activer l'AGP 8X et le fastwrite (écriture rapide).
Et si je me trompe pas, le Sideband addressing et l'AGP Texturing sont activables directement depuis PowerStrip.
Gigabyte 9600PROcomment régler la sortie tv sur driver nvidia
9700 Pro + ventillo Gigabyte !zalman et gigabyte
Gigabyte 8IPE1000 pro + Radeon 9800= Probléme connu !!Gigabyte 8IPE1000 pro + Hercules 9800 pro = flop...
Gigabyte 8IK1100 Vous etes nasela plus belle démo pour une 9600PRO?
4200 vs 9600pro
Plus de sujets relatifs à : Gigabyte 9600PRO mal regler
