Bonsoir à tous,
J'ai deux exercices à faire malheureusement je n'arrive pas à faire le deuxième exo et aucun de mes collègues n'y arrive.
Voici le premier exo:
write a visual Basic program that has two textboxes. the program should swap values between the two textboxes; also include code to exit the program.
voici ce que j'ai fais , est apparemment ça fonction.
Public Class Form1
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim number As Decimal
number = TextBox1.Text
Dim secondnumber As Decimal
secondnumber = TextBox2.Text
TextBox1.Text = secondnumber
TextBox2.Text = number
End Sub
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
Me.Close()
End Sub
Private Sub TextBox1_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TextBox1.TextChanged
End Sub
End Class
Voici maintenant le deuxième exo que j'arrive pas du tout à faire:
Create a transaction-processing program capable of storing a maximum of 100 fixed-lenght records for a company that can have a maximum of 100 customers. Each record consists of an account number(that acts as the record key), a last name, a first name and balance. The program can update an account, create an account and delete an account. The next several sections introduce the techniques neccessary to create this credit-processing program. we now discuss the program used to create the random-acess and the transaction-processing application use to manipulate data. class FrmCreateRandomAccessFilecreate a random-access file.
Merci d'avance
(désolé mais malheureusement mes cours sont en anglais )
