3015 connectés
  VB/VBA/VBS
  Problème classe vb.net
n°2284558
sofianesof​tware
Posté le 03-07-2016 à 05:26:22  profilanswer
Bonjours voilà j'ai essayer plusieur theme pour ma form mais tous mes theme me mes sa :
http://prntscr.com/bo44bh Donc je sais pas comment faire. Le theme que j'ai enregistrer et dans une classe voilà le theme :[spoiler] [cpp]'[INFO]
'ThemeBase Creator: Aeonhack
'Site: *********
'[DATE]
'Created: 08/02/2011
'Changed: 12/06/2011
'[VERSION]
'ThemeBase Version: 1.5.4
'[INFO]
'Theme Creator: Novi
'Theme Name: CarbonOrainsTheme
'[DATE]
'Created: 7/14/2013
'Changed: 7/26/2013
'Released: 7/27/2013
'[VERSION]
'Version: 1.1
'[CREDITS]
'Thanks to Mavamaarten for the tut =))
'Thanks to Aeonhack for the important ThemeBase154
'--------[/CREDITS]------------
#Region "Imports"
Imports System, System.IO, System.Collections.Generic
Imports System.Drawing, System.Drawing.Drawing2D
Imports System.ComponentModel, System.Windows.Forms
Imports System.Runtime.InteropServices
Imports System.Drawing.Imaging
Imports System.Windows.Forms.TabControl
Imports System.ComponentModel.Design
#End Region
#Region "THEMEBASE"
MustInherit Class ThemeContainer154
    Inherits ContainerControl
#Region " Initialization "
    Protected G As Graphics, B As Bitmap
    Sub New()
        SetStyle(DirectCast(139270, ControlStyles), True)
        _ImageSize = Size.Empty
        Font = New Font("Verdana", 8S)
        MeasureBitmap = New Bitmap(1, 1)
        MeasureGraphics = Graphics.FromImage(MeasureBitmap)
        DrawRadialPath = New GraphicsPath
        InvalidateCustimization()
    End Sub
    Protected NotOverridable Overrides Sub OnHandleCreated(ByVal e As EventArgs)
        If DoneCreation Then InitializeMessages()
        ColorHook()
        If Not _LockWidth = 0 Then Width = _LockWidth
        If Not _LockHeight = 0 Then Height = _LockHeight
        If Not _ControlMode Then MyBase.Dock = DockStyle.Fill
        Transparent = _Transparent
        If _Transparent AndAlso _BackColor Then BackColor = Color.Transparent
        MyBase.OnHandleCreated(e)
    End Sub
    Private DoneCreation As Boolean
    Protected NotOverridable Overrides Sub OnParentChanged(ByVal e As EventArgs)
        MyBase.OnParentChanged(e)
        If Parent Is Nothing Then Return
        _IsParentForm = TypeOf Parent Is Form
            If _IsParentForm Then
                ParentForm.FormBorderStyle = _BorderStyle
                ParentForm.TransparencyKey = _TransparencyKey
                If Not DesignMode Then
                    AddHandler ParentForm.Shown, AddressOf FormShown
                End If
            End If
            Parent.BackColor = BackColor
        End If
        OnCreation()
        DoneCreation = True
        InvalidateTimer()
    End Sub
#End Region
    Private Sub DoAnimation(ByVal i As Boolean)
        OnAnimation()
        If i Then Invalidate()
    End Sub
    Protected NotOverridable Overrides Sub OnPaint(ByVal e As PaintEventArgs)
        If Width = 0 OrElse Height = 0 Then Return
        If _Transparent AndAlso _ControlMode Then
            PaintHook()
            e.Graphics.DrawImage(B, 0, 0)
        Else
            G = e.Graphics
            PaintHook()
        End If
    End Sub
    Protected Overrides Sub OnHandleDestroyed(ByVal e As EventArgs)
        RemoveAnimationCallback(AddressOf DoAnimation)
        MyBase.OnHandleDestroyed(e)
    End Sub
    Private HasShown As Boolean
    Private Sub FormShown(ByVal sender As Object, ByVal e As EventArgs)
        If _ControlMode OrElse HasShown Then Return
        If _StartPosition = FormStartPosition.CenterParent OrElse _StartPosition = FormStartPosition.CenterScreen Then
            Dim SB As Rectangle = Screen.PrimaryScreen.Bounds
            Dim CB As Rectangle = ParentForm.Bounds
            ParentForm.Location = New Point(SB.Width \ 2 - CB.Width \ 2, SB.Height \ 2 - CB.Width \ 2)
        End If
        HasShown = True
    End Sub
#Region " Size Handling "
    Private Frame As Rectangle
    Protected NotOverridable Overrides Sub OnSizeChanged(ByVal e As EventArgs)
        If _Movable AndAlso Not _ControlMode Then
            Frame = New Rectangle(7, 7, Width - 14, _Header - 7)
        End If
        InvalidateBitmap()
        Invalidate()
        MyBase.OnSizeChanged(e)
    End Sub
    Protected Overrides Sub SetBoundsCore(ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal specified As BoundsSpecified)
        If Not _LockWidth = 0 Then width = _LockWidth
        If Not _LockHeight = 0 Then height = _LockHeight
        MyBase.SetBoundsCore(x, y, width, height, specified)
    End Sub
#End Region
#Region " State Handling "
    Protected State As MouseState
    Private Sub SetState(ByVal current As MouseState)
        State = current
        Invalidate()
    End Sub
    Protected Overrides Sub OnMouseMove(ByVal e As MouseEventArgs)
        If Not (_IsParentForm AndAlso ParentForm.WindowState = FormWindowState.Maximized) Then
            If _Sizable AndAlso Not _ControlMode Then InvalidateMouse()
        End If
        MyBase.OnMouseMove(e)
    End Sub
    Protected Overrides Sub OnEnabledChanged(ByVal e As EventArgs)
        If Enabled Then SetState(MouseState.None) Else SetState(MouseState.Block)
        MyBase.OnEnabledChanged(e)
    End Sub
    Protected Overrides Sub OnMouseEnter(ByVal e As EventArgs)
        SetState(MouseState.Over)
        MyBase.OnMouseEnter(e)
    End Sub
    Protected Overrides Sub OnMouseUp(ByVal e As MouseEventArgs)
        MyBase.OnMouseUp(e)
    End Sub
    Protected Overrides Sub OnMouseLeave(ByVal e As EventArgs)
        If GetChildAtPoint(PointToClient(MousePosition)) IsNot Nothing Then
                Cursor = Cursors.Default
                Previous = 0
            End If
        End If
        MyBase.OnMouseLeave(e)
    End Sub
    Protected Overrides Sub OnMouseDown(ByVal e As MouseEventArgs)
        If e.Button = Windows.Forms.MouseButtons.Left Then SetState(MouseState.Down)
        If Not (_IsParentForm AndAlso ParentForm.WindowState = FormWindowState.Maximized OrElse _ControlMode) Then
            If _Movable AndAlso Frame.Contains(e.Location) Then
                Capture = False
                WM_LMBUTTONDOWN = True
                DefWndProc(Messages(0))
            ElseIf _Sizable AndAlso Not Previous = 0 Then
                Capture = False
                DefWndProc(Messages(Previous))
            End If
        End If
        MyBase.OnMouseDown(e)
    End Sub
    Private WM_LMBUTTONDOWN As Boolean
    Protected Overrides Sub WndProc(ByRef m As Message)
        MyBase.WndProc(m)
        If WM_LMBUTTONDOWN AndAlso m.Msg = 513 Then
            WM_LMBUTTONDOWN = False
            If Not _SmartBounds Then Return
            If IsParentMdi Then
                CorrectBounds(New Rectangle(Point.Empty, Parent.Parent.Size))
            Else
                CorrectBounds(Screen.FromControl(Parent).WorkingArea)
            End If
        End If
    End Sub
    Private GetIndexPoint As Point
    Private B1, B2, B3, B4 As Boolean
    Private Function GetIndex() As Integer
        GetIndexPoint = PointToClient(MousePosition)
        B1 = GetIndexPoint.X < 7
        B2 = GetIndexPoint.X > Width - 7
        B3 = GetIndexPoint.Y < 7
        B4 = GetIndexPoint.Y > Height - 7
        If B1 AndAlso B3 Then Return 4
        If B1 AndAlso B4 Then Return 7
        If B2 AndAlso B3 Then Return 5
        If B2 AndAlso B4 Then Return 8
        If B1 Then Return 1
        If B2 Then Return 2
        If B3 Then Return 3
        If B4 Then Return 6
        Return 0
    End Function
    Private Current, Previous As Integer
    Private Sub InvalidateMouse()
        Current = GetIndex()
        If Current = Previous Then Return
        Previous = Current
        Select Case Previous
            Case 0
            Case 1, 2
                Cursor = Cursors.SizeWE
            Case 3, 6
                Cursor = Cursors.SizeNS
            Case 4, 8
                Cursor = Cursors.SizeNWSE
            Case 5, 7
                Cursor = Cursors.SizeNESW
        End Select
    End Sub
    Private Messages(8) As Message
    Private Sub InitializeMessages()
        Messages(0) = Message.Create(Parent.Handle, 161, New IntPtr(2), IntPtr.Zero)
        For I As Integer = 1 To 8
            Messages(I) = Message.Create(Parent.Handle, 161, New IntPtr(I + 9), IntPtr.Zero)
        Next
    End Sub
    Private Sub CorrectBounds(ByVal bounds As Rectangle)
        If Parent.Width > bounds.Width Then Parent.Width = bounds.Width
        If Parent.Height > bounds.Height Then Parent.Height = bounds.Height
        Dim X As Integer = Parent.Location.X
        Dim Y As Integer = Parent.Location.Y
        If X < bounds.X Then X = bounds.X
        If Y < bounds.Y Then Y = bounds.Y
        Dim Width As Integer = bounds.X + bounds.Width
        Dim Height As Integer = bounds.Y + bounds.Height
        If X + Parent.Width > Width Then X = Width - Parent.Width
        If Y + Parent.Height > Height Then Y = Height - Parent.Height
        Parent.Location = New Point(X, Y)
    End Sub
#End Region
#Region " Base Properties "
    Overrides Property Dock As DockStyle
        Get
            Return MyBase.Dock
        End Get
        Set(ByVal value As DockStyle)
            If Not _ControlMode Then Return
            MyBase.Dock = value
        End Set
    End Property
    Private _BackColor As Boolean
    <Category("Misc" )>
    Overrides Property BackColor() As Color
        Get
            Return MyBase.BackColor
        End Get
        Set(ByVal value As Color)
            If value = MyBase.BackColor Then Return
            If Not IsHandleCreated AndAlso _ControlMode AndAlso value = Color.Transparent Then
                _BackColor = True
                Return
            End If
            MyBase.BackColor = value
            If Parent IsNot Nothing Then
                If Not _ControlMode Then Parent.BackColor = value
                ColorHook()
            End If
        End Set
    End Property
    Overrides Property MinimumSize As Size
        Get
            Return MyBase.MinimumSize
        End Get
        Set(ByVal value As Size)
            MyBase.MinimumSize = value
            If Parent IsNot Nothing Then Parent.MinimumSize = value
        End Set
    End Property
    Overrides Property MaximumSize As Size
        Get
            Return MyBase.MaximumSize
        End Get
            MyBase.MaximumSize = value
            If Parent IsNot Nothing Then Parent.MaximumSize = value
        End Set
    End Property
    Overrides Property Text() As String
        Get
            Return MyBase.Text
        End Get
        Set(ByVal value As String)
            MyBase.Text = value
            Invalidate()
        End Set
    End Property
    Overrides Property Font() As Font
        Get
            Return MyBase.Font
        End Get
        Set(ByVal value As Font)
            MyBase.Font = value
            Invalidate()
        End Set
    End Property
    <Browsable(False), EditorBrowsable(EditorBrowsableState.Never), DesignerSerializationVisibility(DesignerSerializationVisibility.Hidden)>
    Overrides Property ForeColor() As Color
        Get
            Return Color.Empty
        End Get
        End Set
    End Property
    Overrides Property BackgroundImage() As Image
        Get
            Return Nothing
        End Get
        Set(ByVal value As Image)
        End Set
    End Property
    Overrides Property BackgroundImageLayout() As ImageLayout
        Get
            Return ImageLayout.None
        End Get
        Set(ByVal value As ImageLayout)
        End Set
    End Property
#End Region
#Region " Public Properties "
    Private _SmartBounds As Boolean = True
    Property SmartBounds() As Boolean
        Get
            Return _SmartBounds
        End Get
        Set(ByVal value As Boolean)
            _SmartBounds = value
        End Set
    End Property
    Private _Movable As Boolean = True
    Property Movable() As Boolean
        Get
            Return _Movable
        End Get
            _Movable = value
        End Set
    End Property
    Private _Sizable As Boolean = True
    Property Sizable() As Boolean
        Get
            Return _Sizable
        End Get
            _Sizable = value
        End Set
    End Property
    Private _TransparencyKey As Color
    Property TransparencyKey() As Color
        Get
            If _IsParentForm AndAlso Not _ControlMode Then Return ParentForm.TransparencyKey Else Return _TransparencyKey
        End Get
            If value = _TransparencyKey Then Return
            _TransparencyKey = value
                ParentForm.TransparencyKey = value
                ColorHook()
            End If
        End Set
    End Property
    Private _BorderStyle As FormBorderStyle
    Property BorderStyle() As FormBorderStyle
        Get
            If _IsParentForm AndAlso Not _ControlMode Then Return ParentForm.FormBorderStyle Else Return _BorderStyle
        End Get
        Set(ByVal value As FormBorderStyle)
            _BorderStyle = value
                ParentForm.FormBorderStyle = value
                If Not value = FormBorderStyle.None Then
                    Movable = False
                    Sizable = False
                End If
            End If
        End Set
    End Property
    Private _StartPosition As FormStartPosition
    Property StartPosition As FormStartPosition
        Get
            If _IsParentForm AndAlso Not _ControlMode Then Return ParentForm.StartPosition Else Return _StartPosition
        End Get
        Set(ByVal value As FormStartPosition)
            _StartPosition = value
                ParentForm.StartPosition = value
            End If
        End Set
    End Property
    Private _NoRounding As Boolean
    Property NoRounding() As Boolean
        Get
            Return _NoRounding
        End Get
        Set(ByVal v As Boolean)
            _NoRounding = v
            Invalidate()
        End Set
    End Property
    Private _Image As Image
    Property Image() As Image
        Get
            Return _Image
        End Get
            If value Is Nothing Then _ImageSize = Size.Empty Else _ImageSize = value.Size
            _Image = value
            Invalidate()
        End Set
    End Property
    Private Items As New Dictionary(Of String, Color)
    Property Colors() As Bloom()
        Get
            Dim T As New List(Of Bloom)
            Dim E As Dictionary(Of String, Color).Enumerator = Items.GetEnumerator
            While E.MoveNext
                T.Add(New Bloom(E.Current.Key, E.Current.Value))
            End While
            Return T.ToArray
        End Get
        Set(ByVal value As Bloom())
            For Each B As Bloom In value
                If Items.ContainsKey(B.Name) Then Items(B.Name) = B.Value
            Next
            ColorHook()
            Invalidate()
        End Set
    End Property
    Private _Customization As String
    Property Customization() As String
        Get
            Return _Customization
        End Get
            If value = _Customization Then Return
            Dim Data As Byte()
            Dim Items As Bloom() = Colors
            Try
                Data = Convert.FromBase64String(value)
                For I As Integer = 0 To Items.Length - 1
                    Items(I).Value = Color.FromArgb(BitConverter.ToInt32(Data, I * 4))
                Next
            Catch
                Return
            End Try
            _Customization = value
            Colors = Items
            ColorHook()
            Invalidate()
        End Set
    End Property
    Private _Transparent As Boolean
    Property Transparent() As Boolean
        Get
            Return _Transparent
        End Get
            _Transparent = value
            If Not (IsHandleCreated OrElse _ControlMode) Then Return
            If Not value AndAlso Not BackColor.A = 255 Then
                Throw New Exception("Unable to change value to false while a transparent BackColor is in use." )
            End If
            SetStyle(ControlStyles.Opaque, Not value)
            SetStyle(ControlStyles.SupportsTransparentBackColor, value)
            InvalidateBitmap()
            Invalidate()
        End Set
    End Property
#End Region
#Region " Private Properties "
    Private _ImageSize As Size
    Protected ReadOnly Property ImageSize() As Size
        Get
            Return _ImageSize
        End Get
    End Property
    Private _IsParentForm As Boolean
    Protected ReadOnly Property IsParentForm As Boolean
        Get
            Return _IsParentForm
        End Get
    End Property
    Protected ReadOnly Property IsParentMdi As Boolean
        Get
            If Parent Is Nothing Then Return False
            Return Parent.Parent IsNot Nothing
        End Get
    End Property
    Private _LockWidth As Integer
    Protected Property LockWidth() As Integer
        Get
            Return _LockWidth
        End Get
        Set(ByVal value As Integer)
            _LockWidth = value
            If Not LockWidth = 0 AndAlso IsHandleCreated Then Width = LockWidth
        End Set
    End Property
    Private _LockHeight As Integer
    Protected Property LockHeight() As Integer
        Get
            Return _LockHeight
        End Get
            _LockHeight = value
            If Not LockHeight = 0 AndAlso IsHandleCreated Then Height = LockHeight
        End Set
    End Property
    Private _Header As Integer = 24
    Protected Property Header() As Integer
        Get
            Return _Header
        End Get
        Set(ByVal v As Integer)
            _Header = v
                Frame = New Rectangle(7, 7, Width - 14, v - 7)
                Invalidate()
            End If
        End Set
    End Property
    Private _ControlMode As Boolean
    Protected Property ControlMode() As Boolean
        Get
            Return _ControlMode
        End Get
            _ControlMode = v
            InvalidateBitmap()
            Invalidate()
        End Set
    End Property
    Private _IsAnimated As Boolean
    Protected Property IsAnimated() As Boolean
        Get
            Return _IsAnimated
        End Get
            _IsAnimated = value
            InvalidateTimer()
        End Set
    End Property
#End Region
#Region " Property Helpers "
    Protected Function GetPen(ByVal name As String) As Pen
        Return New Pen(Items(name))
    End Function
    Protected Function GetPen(ByVal name As String, ByVal width As Single) As Pen
        Return New Pen(Items(name), width)
    End Function
    Protected Function GetBrush(ByVal name As String) As SolidBrush
        Return New SolidBrush(Items(name))
    End Function
    Protected Function GetColor(ByVal name As String) As Color
        Return Items(name)
    End Function
    Protected Sub SetColor(ByVal name As String, ByVal value As Color)
        If Items.ContainsKey(name) Then Items(name) = value Else Items.Add(name, value)
    End Sub
    Protected Sub SetColor(ByVal name As String, ByVal r As Byte, ByVal g As Byte, ByVal b As Byte)
        SetColor(name, Color.FromArgb(r, g, b))
    End Sub
    Protected Sub SetColor(ByVal name As String, ByVal a As Byte, ByVal r As Byte, ByVal g As Byte, ByVal b As Byte)
        SetColor(name, Color.FromArgb(a, r, g, b))
    End Sub
    Protected Sub SetColor(ByVal name As String, ByVal a As Byte, ByVal value As Color)
        SetColor(name, Color.FromArgb(a, value))
    End Sub
    Private Sub InvalidateBitmap()
            B = New Bitmap(Width, Height, PixelFormat.Format32bppPArgb)
            G = Graphics.FromImage(B)
        Else
            G = Nothing
            B = Nothing
        End If
    End Sub
    Private Sub InvalidateCustimization()
        Dim M As New MemoryStream(Items.Count * 4)
        For Each B As Bloom In Colors
            M.Write(BitConverter.GetBytes(B.Value.ToArgb), 0, 4)
        Next
        M.Close()
        _Customization = Convert.ToBase64String(M.ToArray)
    End Sub
    Private Sub InvalidateTimer()
        If DesignMode OrElse Not DoneCreation Then Return
        If _IsAnimated Then
            AddAnimationCallback(AddressOf DoAnimation)
        Else
        End If
    End Sub
#End Region
#Region " User Hooks "
    Protected MustOverride Sub ColorHook()
    Protected MustOverride Sub PaintHook()
    Protected Overridable Sub OnCreation()
    End Sub
    Protected Overridable Sub OnAnimation()
    End Sub
#End Region
#Region " Offset "
    Private OffsetReturnRectangle As Rectangle
    Protected Function Offset(ByVal r As Rectangle, ByVal amount As Integer) As Rectangle
        OffsetReturnRectangle = New Rectangle(r.X + amount, r.Y + amount, r.Width - (amount * 2), r.Height - (amount * 2))
        Return OffsetReturnRectangle
    End Function
    Private OffsetReturnSize As Size
    Protected Function Offset(ByVal s As Size, ByVal amount As Integer) As Size
        OffsetReturnSize = New Size(s.Width + amount, s.Height + amount)
        Return OffsetReturnSize
    End Function
    Private OffsetReturnPoint As Point
    Protected Function Offset(ByVal p As Point, ByVal amount As Integer) As Point
        OffsetReturnPoint = New Point(p.X + amount, p.Y + amount)
        Return OffsetReturnPoint
    End Function
#End Region
#Region " Center "
    Private CenterReturn As Point
    Protected Function Center(ByVal p As Rectangle, ByVal c As Rectangle) As Point
        CenterReturn = New Point((p.Width \ 2 - c.Width \ 2) + p.X + c.X, (p.Height \ 2 - c.Height \ 2) + p.Y + c.Y)
        Return CenterReturn
    End Function
    Protected Function Center(ByVal p As Rectangle, ByVal c As Size) As Point
        CenterReturn = New Point((p.Width \ 2 - c.Width \ 2) + p.X, (p.Height \ 2 - c.Height \ 2) + p.Y)
        Return CenterReturn
    End Function
    Protected Function Center(ByVal child As Rectangle) As Point
        Return Center(Width, Height, child.Width, child.Height)
    End Function
    Protected Function Center(ByVal child As Size) As Point
    End Function
    Protected Function Center(ByVal childWidth As Integer, ByVal childHeight As Integer) As Point
        Return Center(Width, Height, childWidth, childHeight)
    End Function
    Protected Function Center(ByVal p As Size, ByVal c As Size) As Point
        Return Center(p.Width, p.Height, c.Width, c.Height)
    End Function
    Protected Function Center(ByVal pWidth As Integer, ByVal pHeight As Integer, ByVal cWidth As Integer, ByVal cHeight As Integer) As Point
        CenterReturn = New Point(pWidth \ 2 - cWidth \ 2, pHeight \ 2 - cHeight \ 2)
        Return CenterReturn
    End Function
#End Region
#Region " Measure "
    Private MeasureBitmap As Bitmap
    Private MeasureGraphics As Graphics
    Protected Function Measure() As Size
        SyncLock MeasureGraphics
            Return MeasureGraphics.MeasureString(Text, Font, Width).ToSize
        End SyncLock
    End Function
    Protected Function Measure(ByVal text As String) As Size
            Return MeasureGraphics.MeasureString(text, Font, Width).ToSize
        End SyncLock
    End Function
#End Region
#Region " DrawPixel "
    Private DrawPixelBrush As SolidBrush
    Protected Sub DrawPixel(ByVal c1 As Color, ByVal x As Integer, ByVal y As Integer)
        If _Transparent Then
            B.SetPixel(x, y, c1)
        Else
            DrawPixelBrush = New SolidBrush(c1)
            G.FillRectangle(DrawPixelBrush, x, y, 1, 1)
        End If
    End Sub
#End Region
#Region " DrawCorners "
    Private DrawCornersBrush As SolidBrush
    Protected Sub DrawCorners(ByVal c1 As Color, ByVal offset As Integer)
        DrawCorners(c1, 0, 0, Width, Height, offset)
    End Sub
    Protected Sub DrawCorners(ByVal c1 As Color, ByVal r1 As Rectangle, ByVal offset As Integer)
        DrawCorners(c1, r1.X, r1.Y, r1.Width, r1.Height, offset)
    End Sub
    Protected Sub DrawCorners(ByVal c1 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal offset As Integer)
        DrawCorners(c1, x + offset, y + offset, width - (offset * 2), height - (offset * 2))
    End Sub
    Protected Sub DrawCorners(ByVal c1 As Color)
        DrawCorners(c1, 0, 0, Width, Height)
    End Sub
    Protected Sub DrawCorners(ByVal c1 As Color, ByVal r1 As Rectangle)
        DrawCorners(c1, r1.X, r1.Y, r1.Width, r1.Height)
    End Sub
    Protected Sub DrawCorners(ByVal c1 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer)
        If _NoRounding Then Return
            B.SetPixel(x + (width - 1), y, c1)
            B.SetPixel(x, y + (height - 1), c1)
            B.SetPixel(x + (width - 1), y + (height - 1), c1)
        Else
            DrawCornersBrush = New SolidBrush(c1)
            G.FillRectangle(DrawCornersBrush, x, y, 1, 1)
            G.FillRectangle(DrawCornersBrush, x + (width - 1), y, 1, 1)
            G.FillRectangle(DrawCornersBrush, x, y + (height - 1), 1, 1)
            G.FillRectangle(DrawCornersBrush, x + (width - 1), y + (height - 1), 1, 1)
        End If
    End Sub
#End Region
#Region " DrawBorders "
    Protected Sub DrawBorders(ByVal p1 As Pen, ByVal offset As Integer)
        DrawBorders(p1, 0, 0, Width, Height, offset)
    End Sub
    Protected Sub DrawBorders(ByVal p1 As Pen, ByVal r As Rectangle, ByVal offset As Integer)
        DrawBorders(p1, r.X, r.Y, r.Width, r.Height, offset)
    End Sub
    Protected Sub DrawBorders(ByVal p1 As Pen, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal offset As Integer)
        DrawBorders(p1, x + offset, y + offset, width - (offset * 2), height - (offset * 2))
    End Sub
    Protected Sub DrawBorders(ByVal p1 As Pen)
        DrawBorders(p1, 0, 0, Width, Height)
    End Sub
    Protected Sub DrawBorders(ByVal p1 As Pen, ByVal r As Rectangle)
        DrawBorders(p1, r.X, r.Y, r.Width, r.Height)
    End Sub
    Protected Sub DrawBorders(ByVal p1 As Pen, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer)
        G.DrawRectangle(p1, x, y, width - 1, height - 1)
    End Sub
#End Region
#Region " DrawText "
    Private DrawTextPoint As Point
    Private DrawTextSize As Size
    Protected Sub DrawText(ByVal b1 As Brush, ByVal a As HorizontalAlignment, ByVal x As Integer, ByVal y As Integer)
        DrawText(b1, Text, a, x, y)
    End Sub
    Protected Sub DrawText(ByVal b1 As Brush, ByVal text As String, ByVal a As HorizontalAlignment, ByVal x As Integer, ByVal y As Integer)
        If text.Length = 0 Then Return
        DrawTextSize = Measure(text)
        DrawTextPoint = New Point(Width \ 2 - DrawTextSize.Width \ 2, Header \ 2 - DrawTextSize.Height \ 2)
        Select Case a
            Case HorizontalAlignment.Left
                G.DrawString(text, Font, b1, x, DrawTextPoint.Y + y)
            Case HorizontalAlignment.Center
                G.DrawString(text, Font, b1, DrawTextPoint.X + x, DrawTextPoint.Y + y)
            Case HorizontalAlignment.Right
                G.DrawString(text, Font, b1, Width - DrawTextSize.Width - x, DrawTextPoint.Y + y)
        End Select
    End Sub
    Protected Sub DrawText(ByVal b1 As Brush, ByVal p1 As Point)
        If Text.Length = 0 Then Return
        G.DrawString(Text, Font, b1, p1)
    End Sub
    Protected Sub DrawText(ByVal b1 As Brush, ByVal x As Integer, ByVal y As Integer)
        G.DrawString(Text, Font, b1, x, y)
    End Sub
#End Region
#Region " DrawImage "
    Private DrawImagePoint As Point
    Protected Sub DrawImage(ByVal a As HorizontalAlignment, ByVal x As Integer, ByVal y As Integer)
        DrawImage(_Image, a, x, y)
    End Sub
    Protected Sub DrawImage(ByVal image As Image, ByVal a As HorizontalAlignment, ByVal x As Integer, ByVal y As Integer)
        If image Is Nothing Then Return
        DrawImagePoint = New Point(Width \ 2 - image.Width \ 2, Header \ 2 - image.Height \ 2)
        Select Case a
                G.DrawImage(image, x, DrawImagePoint.Y + y, image.Width, image.Height)
                G.DrawImage(image, DrawImagePoint.X + x, DrawImagePoint.Y + y, image.Width, image.Height)
                G.DrawImage(image, Width - image.Width - x, DrawImagePoint.Y + y, image.Width, image.Height)
        End Select
    End Sub
    Protected Sub DrawImage(ByVal p1 As Point)
        DrawImage(_Image, p1.X, p1.Y)
    End Sub
    Protected Sub DrawImage(ByVal x As Integer, ByVal y As Integer)
        DrawImage(_Image, x, y)
    End Sub
    Protected Sub DrawImage(ByVal image As Image, ByVal p1 As Point)
        DrawImage(image, p1.X, p1.Y)
    End Sub
    Protected Sub DrawImage(ByVal image As Image, ByVal x As Integer, ByVal y As Integer)
        G.DrawImage(image, x, y, image.Width, image.Height)
    End Sub
#End Region
#Region " DrawGradient "
    Private DrawGradientBrush As LinearGradientBrush
    Private DrawGradientRectangle As Rectangle
    Protected Sub DrawGradient(ByVal blend As ColorBlend, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer)
        DrawGradientRectangle = New Rectangle(x, y, width, height)
        DrawGradient(blend, DrawGradientRectangle)
    End Sub
    Protected Sub DrawGradient(ByVal blend As ColorBlend, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal angle As Single)
        DrawGradient(blend, DrawGradientRectangle, angle)
    End Sub
    Protected Sub DrawGradient(ByVal blend As ColorBlend, ByVal r As Rectangle)
        DrawGradientBrush = New LinearGradientBrush(r, Color.Empty, Color.Empty, 90.0F)
        DrawGradientBrush.InterpolationColors = blend
        G.FillRectangle(DrawGradientBrush, r)
    End Sub
    Protected Sub DrawGradient(ByVal blend As ColorBlend, ByVal r As Rectangle, ByVal angle As Single)
        DrawGradientBrush = New LinearGradientBrush(r, Color.Empty, Color.Empty, angle)
    End Sub
    Protected Sub DrawGradient(ByVal c1 As Color, ByVal c2 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer)
        DrawGradient(c1, c2, DrawGradientRectangle)
    End Sub
    Protected Sub DrawGradient(ByVal c1 As Color, ByVal c2 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal angle As Single)
        DrawGradient(c1, c2, DrawGradientRectangle, angle)
    End Sub
    Protected Sub DrawGradient(ByVal c1 As Color, ByVal c2 As Color, ByVal r As Rectangle)
        DrawGradientBrush = New LinearGradientBrush(r, c1, c2, 90.0F)
    End Sub
    Protected Sub DrawGradient(ByVal c1 As Color, ByVal c2 As Color, ByVal r As Rectangle, ByVal angle As Single)
        DrawGradientBrush = New LinearGradientBrush(r, c1, c2, angle)
    End Sub
#End Region
#Region " DrawRadial "
    Private DrawRadialPath As GraphicsPath
    Private DrawRadialBrush1 As PathGradientBrush
    Private DrawRadialBrush2 As LinearGradientBrush
    Private DrawRadialRectangle As Rectangle
    Sub DrawRadial(ByVal blend As ColorBlend, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer)
        DrawRadialRectangle = New Rectangle(x, y, width, height)
        DrawRadial(blend, DrawRadialRectangle, width \ 2, height \ 2)
    End Sub
    Sub DrawRadial(ByVal blend As ColorBlend, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal center As Point)
        DrawRadial(blend, DrawRadialRectangle, center.X, center.Y)
    End Sub
    Sub DrawRadial(ByVal blend As ColorBlend, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal cx As Integer, ByVal cy As Integer)
        DrawRadial(blend, DrawRadialRectangle, cx, cy)
    End Sub
    Sub DrawRadial(ByVal blend As ColorBlend, ByVal r As Rectangle)
        DrawRadial(blend, r, r.Width \ 2, r.Height \ 2)
    End Sub
    Sub DrawRadial(ByVal blend As ColorBlend, ByVal r As Rectangle, ByVal center As Point)
        DrawRadial(blend, r, center.X, center.Y)
    End Sub
    Sub DrawRadial(ByVal blend As ColorBlend, ByVal r As Rectangle, ByVal cx As Integer, ByVal cy As Integer)
        DrawRadialPath.Reset()
        DrawRadialPath.AddEllipse(r.X, r.Y, r.Width - 1, r.Height - 1)
        DrawRadialBrush1 = New PathGradientBrush(DrawRadialPath)
        DrawRadialBrush1.CenterPoint = New Point(r.X + cx, r.Y + cy)
        DrawRadialBrush1.InterpolationColors = blend
        If G.SmoothingMode = SmoothingMode.AntiAlias Then
            G.FillEllipse(DrawRadialBrush1, r.X + 1, r.Y + 1, r.Width - 3, r.Height - 3)
        Else
            G.FillEllipse(DrawRadialBrush1, r)
        End If
    End Sub
    Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer)
        DrawRadial(c1, c2, DrawGradientRectangle)
    End Sub
    Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal angle As Single)
        DrawRadial(c1, c2, DrawGradientRectangle, angle)
    End Sub
    Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal r As Rectangle)
        DrawRadialBrush2 = New LinearGradientBrush(r, c1, c2, 90.0F)
    End Sub
    Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal r As Rectangle, ByVal angle As Single)
        DrawRadialBrush2 = New LinearGradientBrush(r, c1, c2, angle)
        G.FillEllipse(DrawGradientBrush, r)
    End Sub
#End Region
#Region " CreateRound "
    Private CreateRoundPath As GraphicsPath
    Private CreateRoundRectangle As Rectangle
    Function CreateRound(ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal slope As Integer) As GraphicsPath
        CreateRoundRectangle = New Rectangle(x, y, width, height)
        Return CreateRound(CreateRoundRectangle, slope)
    End Function
    Function CreateRound(ByVal r As Rectangle, ByVal slope As Integer) As GraphicsPath
        CreateRoundPath = New GraphicsPath(FillMode.Winding)
        CreateRoundPath.AddArc(r.X, r.Y, slope, slope, 180.0F, 90.0F)
        CreateRoundPath.AddArc(r.Right - slope, r.Y, slope, slope, 270.0F, 90.0F)
        CreateRoundPath.AddArc(r.Right - slope, r.Bottom - slope, slope, slope, 0.0F, 90.0F)
        CreateRoundPath.AddArc(r.X, r.Bottom - slope, slope, slope, 90.0F, 90.0F)
        CreateRoundPath.CloseFigure()
        Return CreateRoundPath
    End Function
#End Region
End Class
MustInherit Class ThemeControl154
    Inherits Control
    Sub New()
        InvalidateCustimization() 'Remove?
    End Sub
        ColorHook()
    End Sub
            OnCreation()
            DoneCreation = True
            InvalidateTimer()
        End If
    End Sub
#End Region
        OnAnimation()
    End Sub
            PaintHook()
        Else
            G = e.Graphics
            PaintHook()
        End If
    End Sub
    End Sub
            InvalidateBitmap()
        End If
        Invalidate()
    End Sub
    End Sub
#End Region
    Private InPosition As Boolean
        InPosition = True
    End Sub
        If InPosition Then SetState(MouseState.Over)
        MyBase.OnMouseUp(e)
    End Sub
    End Sub
        InPosition = False
    End Sub
    End Sub
        State = current
        Invalidate()
    End Sub
#End Region
        Get
            Return Color.Empty
        End Get
        End Set
    End Property
        Get
            Return Nothing
        End Get
        End Set
    End Property
        Get
        End Get
        End Set
    End Property
        Get
            Return MyBase.Text
        End Get
            MyBase.Text = value
            Invalidate()
        End Set
    End Property
        Get
            Return MyBase.Font
        End Get
            MyBase.Font = value
            Invalidate()
        End Set
    End Property
    <Category("Misc" )>
        Get
        End Get
            If Not IsHandleCreated AndAlso value = Color.Transparent Then
                _BackColor = True
                Return
            End If
            If Parent IsNot Nothing Then ColorHook()
        End Set
    End Property
#End Region
        Get
            Return _NoRounding
        End Get
            _NoRounding = v
            Invalidate()
        End Set
    End Property
        Get
            Return _Image
        End Get
            Else
            End If
            _Image = value
            Invalidate()
        End Set
    End Property
        Get
            Return _Transparent
        End Get
            If Not IsHandleCreated Then Return
            End If
            If value Then InvalidateBitmap() Else B = Nothing
            Invalidate()
        End Set
    End Property
        Get
            While E.MoveNext
            End While
            Return T.ToArray
        End Get
            Next
            ColorHook()
            Invalidate()
        End Set
    End Property
        Get
        End Get
            Dim Data As Byte()
            Try
                Next
            Catch
                Return
            End Try
            Colors = Items
            ColorHook()
            Invalidate()
        End Set
    End Property
#End Region
        Get
            Return _ImageSize
        End Get
    End Property
        Get
            Return _LockWidth
        End Get
            _LockWidth = value
        End Set
    End Property
        Get
            Return _LockHeight
        End Get
            _LockHeight = value
        End Set
    End Property
        Get
            Return _IsAnimated
        End Get
            _IsAnimated = value
            InvalidateTimer()
        End Set
    End Property
#End Region
    End Function
    End Function
    End Function
        Return Items(name)
    End Function
    End Sub
    End Sub
    End Sub
    End Sub
    End Sub
        Next
        M.Close()
    End Sub
        If _IsAnimated Then
        Else
        End If
    End Sub
#End Region
    End Sub
    End Sub
#End Region
#Region " Offset "
    End Function
    End Function
    End Function
#End Region
#Region " Center "
        Return CenterReturn
    End Function
        Return CenterReturn
    End Function
    End Function
    End Function
    End Function
    End Function
        Return CenterReturn
    End Function
#End Region
#Region " Measure "
    Private MeasureGraphics As Graphics 'TODO: Potential issues during multi-threading.
    End Function
    End Function
#End Region
        Else
        End If
    End Sub
#End Region
    End Sub
    End Sub
    End Sub
    End Sub
    End Sub
        Else
        End If
    End Sub
#End Region
    End Sub
    End Sub
    End Sub
    End Sub
    End Sub
    End Sub
#End Region
    End Sub
        DrawTextPoint = Center(DrawTextSize)
        Select Case a
        End Select
    End Sub
    End Sub
    End Sub
#End Region
    End Sub
        DrawImagePoint = Center(image.Size)
        Select Case a
        End Select
    End Sub
    End Sub
    End Sub
    End Sub
    End Sub
#End Region
    End Sub
    End Sub
    End Sub
    End Sub
    End Sub
    End Sub
    End Sub
    End Sub
#End Region
    End Sub
    End Sub
    End Sub
    End Sub
    End Sub
        Else
        End If
    End Sub
        DrawRadial(c1, c2, DrawRadialRectangle)
    End Sub
        DrawRadial(c1, c2, DrawRadialRectangle, angle)
    End Sub
        G.FillEllipse(DrawRadialBrush2, r)
    End Sub
    End Sub
#End Region
    End Function
  VB/VBA/VBS
[C#] Problème récup fabrique de la classe COMProbleme construction Classe
problème classe php[Java/JEE] [Résolu] Comportement Calendar selon Locale
Problème de syntaxe. Mettre 2 classes pour une pageprobleme d'assignation de valeur avec un tableau dans une classe
Problème d'héritage depuis une classe abstraiteDoxygen (problème avec des noms de variable/de classe)
(DEBUTANT) Probleme de classe en c++Problème de classe
Plus de sujets relatifs à : Problème classe vb.net
