2726 connectés
  VB/VBA/VBS
  Permission non accordée : erreur avec VBS
n°1883673
kinsoi
Posté le 12-05-2009 à 12:56:27  profilanswer
Je lance un script VBS avec le compte utilisateur sur un domaine.
J'ai cette erreur :
http://img16.imageshack.us/img16/8373/erreurbs.png
Et le script est le suivant :
Code :
  1. Set FSO = CreateObject("Scripting.FileSystemObject" )
  2. Set objNetwork = CreateObject("Wscript.Network" )
  3. strUsername = objNetwork.username
  4. set objWMI = GetObject("winmgmts:root\cimv2" )
  5. sQuery = "Select * from Win32_process Where Name = 'nlnotes.exe'"
  6. For Each oproc In objWMI.execquery(sQuery)
  7. oproc.Terminate()
  8. Next
  9. rep = "\\172.16.17.1\save\" & strUserName
  10. if FSO.FolderExists(rep)Then
  11. set fold = FSO.GetFolder(rep)
  12. if fold.Attributes <> 18 then
  13.  fold.Attributes = 18
  14. end if
  15. else
  16. set fold = FSO.CreateFolder(rep)
  17. set fold = FSO.GetFolder(rep)
  18. fold.Attributes = 18
  19. end if
  20. for i=1 to 8
  21. select case (i)
  22.  case 1 : source = "c:\lotus\notes\data\"
  23.    destination = rep & "\notes_data\"
  24.  case 3 : source = "C:\Documents and Settings\" & strUserName & "\Bureau\"
  25.    destination = rep & "\Bureau\"
  26.  case 4 : source = "C:\Documents and Settings\" & strUserName & "\Favoris\"
  27.    destination = rep & "\Favoris\"
  28.  case 4 : source = "C:\Documents and Settings\" & strUserName & "\Mes documents\"
  29.    destination = rep & "\Mes documents\"
  30. end select
  31. runcopy source, destination
  32. next
  33. function runcopy(src, dest)
  34. if not  FSO.FolderExists(dest) then
  35.  set flddest = FSO.CreateFolder(dest)
  36. end if
  37. For each Fichier in FSO.GetFolder(src).Files
  38.   set File = FSO.GetFile(Fichier)
  39.   Obj = File.Name
  40.   if not FSO.FileExists(dest & Obj) then
  41.    FSO.CopyFile src & Obj, dest, true
  42.   else
  43.    DestItem = dest & Obj
  44.    set DestObj = FSo.GetFile(DestItem)
  45.    if CDate(File.DateLastModified) > CDate(DestObj.DateLastModified) then
  46.     FSO.CopyFile src & Obj, dest, true
  47.    end if
  48.   end if
  49. Next
  50. If FSO.FolderExists(src) Then
  51.   For each Fld in  FSO.GetFolder(src).SubFolders
  52.   newdest = dest & Fld.Name & "\"
  53.   newsrc = src & Fld.Name & "\"
  54.   runcopy newsrc, newdest
  55.   Next
  56. End If
  57. end function
En gros je veux lancer un script qui me copie le repertoire lotus notes, favoris, mes documents et le bureau de l'utilisateur lancant le script. Les données sont copier sur un serveur distant.
Merci d'avance,
Kevin
n°1883682
olivthill
Posté le 12-05-2009 à 13:55:41  profilanswer
La ligne 56 est
Le message dit que ce n'est pas autorisé. J'aurais tendance à penser que c'est vrai.
Maintenant, il y a deux hypothèses. Soit le problème vient de la copie à distance, soit vient d'autorisations d'accès liées à ce répertoire. Pour le savoir, il faudrait faire des tests complémentaires, par exemple en copiant sur un répertoire local, ou bien en copiant des choses dans ce répertoire de destination mais à partir d'un autre répertoire de la même machine.
Bon courage !
n°1883692
kinsoi
Posté le 12-05-2009 à 14:09:17  profilanswer
Merci pour ta réponse ... qui m'a permis de trouver le soucis :D ! J'ai oublié de mettre les droits sur un des repertoires :o !
Sinon  deuxieme petite question est-ce possible de mettre une barre de progression ou une fenetre qui s'affiche quand la copie est finie ?
Merci,
Kevin
  VB/VBA/VBS
[VBS] Est-il possible d'intercepter un killerreur "not a statement" en java
Mon site marque cette erreur lors de l ouverture[VBS] Creation d'utilisateurs et d'OUs sous AD (2003) avec input box
Passage de données de flash à php via un LoadVars : erreur en localmysql et c++ sous codeblocks erreur o niveau de insert
[Hibernate] erreur accès à la base (après un jour)[ksh ou bash] Erreur avec sed
[VBS] goto en VBSMySQL-Logiciel métier Erreur
Plus de sujets relatifs à : Permission non accordée : erreur avec VBS
