Option Explicit
Private Declare Function QueryPerformanceCounter Lib "Kernel32" (X As Currency) As Boolean
Private Declare Function QueryPerformanceFrequency Lib "Kernel32" (X As Currency) As Boolean
Dim Debut As Currency, Fin As Currency, Freq As Currency
Dim TabFichiers() As String, NbFichiers As Long
Dim sNom As String
Sub SelDossier()
Dim sChemin As String
sChemin = ThisWorkbook.Path
With Application.FileDialog(msoFileDialogFolderPicker)
.InitialFileName = sChemin & "\"
.Title = "Sélectionner le Dossier Racine"
.AllowMultiSelect = False
.InitialView = msoFileDialogViewDetails
.ButtonName = "Sélection Dossier"
.Show
If .SelectedItems.Count > 0 Then
DoEvents
NbFichiers = 0
ShDatas.Cells.Clear
LectureFichiersCSV .SelectedItems(1)
End If
End With
End Sub
Private Sub LectureFichiersCSV(sDossier As String)
Dim sChemin As String, sFichier As String
Dim iNumFree As Integer, i As Long
Dim j As Long
Dim Wkb As Workbook
Application.StatusBar = ""
QueryPerformanceCounter Debut
Close
sChemin = sDossier
iNumFree = FreeFile
Application.ScreenUpdating = False
sNom = "Lecture CSV.csv"
' Recherche Récursive ListeFichiersDossier sDossier, True
' Non Récursive ListeFichiersDossier sDossier, False
If NbFichiers = 0 Then Exit Sub
j = 1
For i = 1 To UBound(TabFichiers)
sFichier = TabFichiers(i)
Set Wkb = Workbooks.Open(Filename:=sFichier, Local:=True)
With ShDatas
.Range("A" & j) = Wkb.Worksheets(1).Range("A1" )
.Range("B" & j) = Wkb.Worksheets(1).Range("B3" )
End With
j = j + 1
Wkb.Close
Application.StatusBar = i & " / " & NbFichiers
Next i
Set Wkb = Nothing
Erase TabFichiers
Application.ScreenUpdating = True
QueryPerformanceCounter Fin
QueryPerformanceFrequency Freq
Application.StatusBar = Application.StatusBar & " : " & Format((Fin - Debut) / Freq, "0.00 s" )
End Sub
Private Sub ListeFichiersDossier(sChemin As String, bInclureSousDossiers As Boolean)
Dim FSO As Object, Dossier As Object, sFichier As String
Dim sPath As String, Pos As Long
Set FSO = CreateObject("Scripting.FileSystemObject" )
Set Dossier = FSO.GetFolder(sChemin)
sFichier = Dir$(sChemin & "\*.csv" )
Do While Len(sFichier) > 0
Pos = InStrRev(sFichier, "\" )
If Right$(sFichier, Len(sFichier) - Pos) <> sNom Then
sPath = sChemin & "\" & sFichier
NbFichiers = NbFichiers + 1
ReDim Preserve TabFichiers(1 To NbFichiers)
TabFichiers(NbFichiers) = sPath
End If
sFichier = Dir$()
Loop
If bInclureSousDossiers Then
For Each Dossier In Dossier.SubFolders
ListeFichiersDossier Dossier.Path, True
Next Dossier
End If
Set Dossier = Nothing
Set FSO = Nothing
End Sub
