Bas de page | |
Auteur | Sujet : sommes multiple |
Publicité | Posté le 13-04-2004 à 14:22:07 |
GOOOOO | Je travaille avec Oracle. Les durées que je devrai avoir sont 6000 (j'ai oublié un - : 6000+6000-6000=6000) et 3000
Beegee | tu peux essayer d'utiliser la requête que je t'ai mise au-dessus, avec les bons noms de champs, et me dire ce que ça donne ?
GOOOOO | En fait, la base de données est une bd Oracle, mais j'utilise BusinessObjects pour créer un rapport . Donc, je vais voir si ta requête est faisable en BO ou sous Designer.
GOOOOO | Bon, j'ai essayé ton truc : |
GOOOOO | Salut.
GOOOOO | t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: t1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: :pt1cable: |
Sujets relatifs | |
mail() to cc bcc multiple | [MYSQL] UPDATE multiple sur une table [Résolu] |
[vba] jointure multiple | Verification formu JS sur un Select multiple |
[html / php] pb avec formulaire multiple dans un meme page ? | upload + choix multiple |
[HTML]bouton radio multiple avec zone de texte | select multiple et value |
regex: matching multiple | Pb avec un formulaire à sélection multiple |
Plus de sujets relatifs à : sommes multiple |
