1148 connectés
  Langages fonctionnels
  Erreur Instruction 'MoveComplete'
n°1813021
eX-
Posté le 17-11-2008 à 15:09:16  profilanswer
je suis sur visual studio team system pour configurer le module de test par rapport à un projet:
test de charge sur un site web (en l'occurence un formulaire dinscription, un asp_form)
J'arrive à passer toutes les etapes sauf la derniere qui me dit ceci :
_________________________________________________________________
Server Error in '/nutrinet-beta' Application.
The command 'MoveComplete' is not valid for the previous step, make sure the step type is not changed between postbacks.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.InvalidOperationException: The command 'MoveComplete' is not valid for the previous step, make sure the step type is not changed between postbacks.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[InvalidOperationException: The command 'MoveComplete' is not valid for the previous step, make sure the step type is not changed between postbacks.]
System.Web.UI.WebControls.Wizard.OnBubbleEvent(Object source, EventArgs e) +1650930
System.Web.UI.WebControls.WizardChildTable.OnBubbleEvent(Object source, EventArgs args) +17
System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +35
System.Web.UI.WebControls.LinkButton.OnCommand(CommandEventArgs e) +115
System.Web.UI.WebControls.LinkButton.RaisePostBackEvent(String eventArgument) +163
System.Web.UI.WebControls.LinkButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +7
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +11
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +174
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5102
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
Si quelqu'un a une idée, elle serai etudiée avec bienveillance
bien placer un message d'erreur dans un formulaire[ C ] Erreur de segmentation (core dumped)
pb erreur dans mon codeErreur d’exécution 7, mémoire insuffisante
erreur " objet requis "Erreur 500 sur 1and1
erreur 500 : problème envoi de formulaire par mailtraitement d'erreur avec popen()
erreur de login page de connection - php ODBCErreur d'execution 13
Plus de sujets relatifs à : Erreur Instruction 'MoveComplete'
