1840 connectés
  Delphi/Pascal
  [Delphi]Interface 1 Wire Micro Lan avec Driver Java ! c est possible ?
n°237226
KrzAramis
Help Me
Posté le 30-10-2002 à 13:54:54  profilanswer
Salut a tous. Je dois developper une application sur un reso 1 Wire Micro LAn. Je fais un tour sur le site officiel et la ils disent que les driver marchent sure pour C/C++ et VB car developper en Java. Mais ne disent rien pour delphi.
Alors je vous pose la question: Est ce possible de travailler avec ce reso en invoquant des "driver" Java ?
As follow
[quote]getAdapter (adapterName, portName) :  Finds, opens, and verifies the specified adapter on
 the indicated port.
getDefaultAdapter()  : Finds, opens, and verifies the default
     adapter and port. Looks for the default
     adapter/port in the onewire.properties
     file
targetFamily(family)  : Takes a hexadecimal value to selectively search for
      this desired family type. If this method is used, then
      no devices of other families will be found by any of
      the search methods.
 DS1990A: family = &H01
   DS2406(P): family = &H12
setSpeed(speed) : Sets the new speed of data transfer on the 1-Wire
  Network.
  speed :
? 0 (SPEED_REGULAR) set to normal communication speed
? 1 (SPEED_FLEX) set to flexible communication speed used for long lines
? 2 (SPEED_OVERDRIVE) set to normal communication speed to overdrive
? 3 (SPEED_HYPERDRIVE) set to normal communication speed to hyper drive
? >3 future speeds
beginExclusive(blocking) : Gets exclusive use of the 1-Wire to communicate
  with an iButton or 1-Wire Device.
If want to block waiting for an exclusive access to the adapter: blocking = true
reset() : Sends a Reset to the 1-Wire Network.
setSearchAllDevices() : Sets the 1-Wire Network search to find all iButtons
  and 1-Wire devices.
findFirstDevice() : Returns ?True? if the first iButton or 1-Wire device
  is found on the 1-Wire Network. If no devices are
  found, then ?False? will be returned.
findNextDevice() : Returns ?True? if the next iButton or 1-Wire device
  is found. The previous 1-Wire device found is used
  as a starting point in the search. If no more devices
  are found then ?False? will be returned.
getAddressAsString() : Gets the 'current' 1-Wire device address being used
  by the adapter as a String. This address is the last
  iButton or 1-Wire device found in a search
  (findNextDevice()...).
setupContainer (sourceAdapter, newAddress)
  : Provides this container with the adapter object used
   to access this device and the address of the iButton
   or 1-Wire device.
sourceAdapter :  adapter object required to
 communicate with this iButton
newAddress : address of this 1-Wire device
readDevice() : Retrieves the 1-Wire device sensor state.
getLatchState (channel, state) : Checks the latch state of the indicated channel.
    Boolean function gives back ?True? if channel
    is open and ?False? if it is closed.
     PIO A : channel = 0
     PIO B  : channel = 1
     Dim state As Object / state = adapter.readDevice
setLatchState (channel, latchState, doSmart, state)
    : Sets the latch state of the indicated channel.
     PIO A : channel = 0
     PIO B  : channel = 1
     To close:  latchState = False
     To open: latchState = True
     Dim doSmart As Boolean / doSmart = False
writeDevice (state)           : Writes the 1-Wire device sensor state that have been
   changed by 'set' methods.
getLevel (channel, state)  : Checks the sensed level on the indicated channel.
     Boolean function gives back ?True? if the channel
     is activated, otherwise ?False?
     PIO A : channel = 0
     PIO B  : channel = 1
endExclusive() : Relinquishes exclusive control of the 1-Wire
  Network.
Merci.
J ose pas vous demander qq conseil pour les  utiliser. Si !
The Only Way for Evils to Triumph is for Good Men to do Nothing @->-- Cours Réseaux@->-- Mon Site
n°237408
KrzAramis
Help Me
Posté le 30-10-2002 à 16:50:50  profilanswer
[:rv82]
n°238304
KrzAramis
Help Me
Posté le 01-11-2002 à 13:25:45  profilanswer
le peripherique que j utilise (Dallas iButton) est connecte au Reseau 1 Wire MicroLAn. Ce reseau je peux y acceder grace a un adaptateur branche sur mon port COM1.
Maintenant, je sais qu il est  impossible d utiliser ce LAN comme ca. D ou l utilisation de drivers.
Ce que je veux savoir c est comment je fais pour acceder au functions incluses dans les drivers a partir de Delphi.
Merci!
Delphi 6.0 Enterprise Full English
Win Xp Pro
  Delphi/Pascal
[Delphi] débutant problème délimiteur[Java]TCP Client ne marche que partiellement pkoi?[Resolu]
[Perl, C, C++, JAVA, etc.] besoin de conseil sur prog à faire(delphi ;C++ builder) afficher un point rapidement a l'ecran
Best practice Java : déclaration d'1 variable (locale) dans une bouclekel java fau ke je telecharge pour jouer les jeux de yahoo???
[JAVA] Peut on faire un lecteur mp3 en java ?[VB] lien entre une appli VB et une base MYSQL , possible ???
Newbies en java[JAVA] Ne pas afficher de caractères dans le champ mot-de-passe
Plus de sujets relatifs à : [Delphi]Interface 1 Wire Micro Lan avec Driver Java ! c est possible ?
Hit-Parade
