1533 connectés
  Delphi/Pascal
  delphi, file Directory problem!!
n°2128140
Esselami
Posté le 23-02-2012 à 20:26:00  profilanswer
Hello All,
well i just started Delphi programming and i kind have a problem:
I made a program which looks like this :
http://imageshack.us/photo/my-imag [...] re1fg.png/
if i click Exercice1 it shows this window :
http://imageshack.us/photo/my-imag [...] re2rq.png/
and if i click on source code it opens a txt file which contain the source code of Ex1 made by C++:
http://imageshack.us/photo/my-imag [...] re3tb.png/
and if i click on Exe it opens a program that i made using C++ :
http://imageshack.us/photo/my-imag [...] re4wo.png/
but here comes the problem, this program works only because i made a directory in Delphi code in Exercice1 and Source Code Buttons like this :http://imageshack.us/photo/my-imag [...] re5zl.png/
and if i go to that directory i find these 2 folders :
http://imageshack.us/photo/my-imag [...] ure6o.png/
which contain E1.txt(Sources) and E1.exe(Ex) but if i move these 2 folders,and click source or exe button nothing happens
So my program lets u choose from 1to20 exercises t hen source code and exe for that exercise made by C++
and i want to keep the C++ Source and exe for each program that's my aim
so please how can i modify the program that even copy those 2 folders to let's say C:\ProgramFiles please help
Message édité par Esselami le 23-02-2012 à 20:33:34
  Delphi/Pascal
Besoin d'aide pour problem entre yoxview et IEOutputStream -> File
Hibernate + GWT = Serialization problem[DELPHI] mettre un | dans un string !
Problème avec file_put_contentsProblème avec file_exists
Problem[DELPHI] Lire les détails d'un fichier ?
vbs type fileActive Directory en VB 2010
Plus de sujets relatifs à : delphi, file Directory problem!!
