1168 connectés
  C#/.NET managed
  déployer asp.net problème d'hébergement
n°2264395
pureheart
Be Your Best
Posté le 14-08-2015 à 10:11:13  profilanswer
Hi All,
My apologize if I write in English because I just migrated to France and my French is not so good. I just keep learning. :) :)
I have hosted my asp.net site with hostforlife.eu windows hosting. I am getting error 500 internal server error
In the web.config file I have included
<system.webServer>
<httpErrors errorMode="Detailed" />
<asp scriptErrorSentToBrowser="true"/>
</system.webServer>
<system.web>
<customErrors mode="Off"/>
<compilation debug="true"/>
</system.web>
this is my web.config file<connectionStrings>
<add name="conn" connectionString=" Server=xxx.db.xxxx.hostedresource.com; Database=xxx; User ID=xxx; Password=xxx; Trusted_Connection=False" providerName="System.Data.SqlClient" /> <remove name="LocalSqlServer"/> <add name="LocalSqlServer" connectionString=" Server=xxx.db.xxxx.hostedresource.com; Database=xxx; User ID=xxx; Password=xxx; Trusted_Connection=False" providerName="System.Data.SqlClient" />
    </connectionStrings>
    <configuration>
    <system.webServer>
    </system.webServer>
    <system.web>
    </system.web>
    </configuration>
This is my code behind
using System;
    using System.Data;
    using System.Configuration;
    using System.Collections;
    using System.Web;
    using System.Web.Security;
    using System.Web.UI;
    using System.Web.UI.WebControls;
    using System.Web.UI.WebControls.WebParts;
    using System.Web.UI.HtmlControls;
    using System.Data.SqlClient;
    public partial class _Default : System.Web.UI.Page
        protected void Page_Load(object sender, EventArgs e)
        protected void Button1_Click(object sender, EventArgs e)
            string aa = ConfigurationManager.ConnectionStrings["conn"].ConnectionString;
            SqlConnection con = new SqlConnection(aa);
            con.Open();
            string name = TextBox1.Text;
            string pwd = TextBox2.Text;
            string str = "insert into login values('" + name + "', '" + pwd + "', '" + pwd + "', '" + pwd + "')";
            SqlCommand cmd = new SqlCommand(str, con);
            cmd .ExecuteNonQuery ();
Could you please kindly point what is the issue? Any suggesstion?
Thank you
  C#/.NET managed
[C#] Problème récup fabrique de la classe COMProbleme de validation CSS2.1) : balise <style> et autre
Problème d'envoi de mailsproblème GIT
Problème de données php dans envoi de mail htmlPetit problème Java
Requête mysql problemeProblème filtrage macro
Problème d'image et de lien hypertexteProblème de script
Plus de sujets relatifs à : déployer asp.net problème d'hébergement
