939 connectés
  C++
  [Résolu TOUT SEUL] [GTK+] Installation sous CodeBlocks
n°1406923
Lecusto
Posté le 14-07-2006 à 14:28:35  profilanswer
Ayant lu quelques tutoriaux c et c++ j'ai voulu essayer la librairie gtk+ mais deja a l'installation c'est pas rose  :sweat:
J'ai donc suivi les conseils de ce site : http://blog.developpez.com/index.p [...] &tb=1&pb=1
Mais il m'affiche a la compilation ceci dans le build log et je n'y comprends RIEN ...
Project   : GTK+ application
Compiler  : GNU GCC Compiler (called directly)
Directory : C:\Documents and Settings\Lecusto\Bureau\gtk\
Switching to target: default
Compiling: main.c
Usage: mingw32-gcc.exe [options] file...
mingw32-gcc.exe: ./configure: No such file or directory
Options:
  -pass-exit-codes         Exit with highest error code from a phase
  --help                   Display this information
  --target-help            Display target specific command line options
  (Use '-v --help' to display command line options of sub-processes)
  -dumpspecs               Display all of the built in spec strings
  -dumpversion             Display the version of the compiler
  -dumpmachine             Display the compiler's target processor
  -print-search-dirs       Display the directories in the compiler's search path
  -print-libgcc-file-name  Display the name of the compiler's companion library
  -print-file-name=<lib>   Display the full path to library <lib>
  -print-prog-name=<prog>  Display the full path to compiler component <prog>
  -print-multi-directory   Display the root directory for versions of libgcc
  -print-multi-lib         Display the mapping between command line options and
                           multiple library search directories
  -print-multi-os-directory Display the relative path to OS libraries
  -Wa,<options>            Pass comma-separated <options> on to the assembler
  -Wp,<options>            Pass comma-separated <options> on to the preprocessor
  -Wl,<options>            Pass comma-separated <options> on to the linker
  -Xassembler <arg>        Pass <arg> on to the assembler
  -Xpreprocessor <arg>     Pass <arg> on to the preprocessor
  -Xlinker <arg>           Pass <arg> on to the linker
  -save-temps              Do not delete intermediate files
  -pipe                    Use pipes rather than intermediate files
  -time                    Time the execution of each subprocess
  -specs=<file>            Override built-in specs with the contents of <file>
  -std=<standard>          Assume that the input sources are for <standard>
  -B <directory>           Add <directory> to the compiler's search paths
  -b <machine>             Run gcc for target <machine>, if installed
  -V <version>             Run gcc version number <version>, if installed
  -v                       Display the programs invoked by the compiler
  -###                     Like -v but options quoted and commands not executed
  -E                       Preprocess only; do not compile, assemble or link
  -S                       Compile only; do not assemble or link
  -c                       Compile and assemble, but do not link
  -o <file>                Place the output into <file>
  -x <language>            Specify the language of the following input files
                           Permissible languages include: c c++ assembler none
                           'none' means revert to the default behavior of
                           guessing the language based on the file's extension
Options starting with -g, -f, -m, -O, -W, or --param are automatically
 passed on to the various sub-processes invoked by mingw32-gcc.exe.  In order to pass
 other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<URL:http://www.mingw.org/bugs.shtml>.
Linking executable: C:\Documents and Settings\Lecusto\Bureau\gtk\GTKapp.exe
mingw32-g++.exe: .objs\main.o: No such file or directory
Message édité par Lecusto le 15-07-2006 à 11:21:39
  C++
[C+GTK]Résultat diff qd une fonction est lancé par une interface graph[Résolu] Parcourir les éléments de mon formulaire
[Résolu][SQL] Problème classement ASC/DESC sur VARCHAR[Résolu] Problème de droit en lecture! [move_uploaded_file()]
[C#] [RESOLU] FillSchema et Parameters incompatible ?latin_general_ci et pourtant des caractere utf8 apparaissent! [résolu]
[rèsolu]probleme machine virtuelle[ASP.NET] [Résolu] Limiter la taille de la textbox d'un boundfield
JasperReports : installation et utilisation[résolu]modulo en VB
Plus de sujets relatifs à : [Résolu TOUT SEUL] [GTK+] Installation sous CodeBlocks
