1390 connectés
  C++
  [C++] Problème de compilation d'une appli en C++
n°154365
joce
Architecte / Développeur principal
"BugHunter"
Posté le 08-06-2002 à 18:42:05  profilanswer
Voici les erreurs affichées :
Code :
  1. gcc -g -O2 -fno-rtti -fno-exceptions -Wall -W  -o authvmailmgr  authvmailmgr.o authvlib.o ../lib/libvmailmgr.a -L../lib/courier-authlib -lauthmod -lcrypt
  2. authvlib.o: In function `set_user(pwentry const*)':
  3. /home/admin/vmailmgr-0.96.9/authenticate/authvlib.cc:56: undefined reference to `operator new(unsigned)'
  4. /home/admin/vmailmgr-0.96.9/authenticate/authvlib.cc:59: undefined reference to `operator delete(void*)'
  5. authvlib.o: In function `check(mystring, mystring, bool)':
  6. /home/admin/vmailmgr-0.96.9/authenticate/authvlib.cc:81: undefined reference to `operator new(unsigned)'
  7. /home/admin/vmailmgr-0.96.9/authenticate/authvlib.cc:93: undefined reference to `operator new(unsigned)'
  8. authvlib.o: In function `check(mystring, mystring, bool)':
  9. <cut>
  10. La fonction en question avec la ligne qui merdouille :
  11. void set_user(const pwentry* pw)
  12. {
  13.   pw->export_env();
  14.   if(!!exec_presetuid && execute(exec_presetuid))
  15.     fail_temporary("Execution of presetuid failed" );
  16.   if(setgid(pw->gid) == -1 ||
  17.      setuid(pw->uid) == -1 ||
  18.      chdir(pw->home.c_str()) == -1)
  19.     fail_temporary("Bad user data in password file" );
  20.   domain = new vdomain(*pw);
  21.   config = &domain->config;
  22. }
  23. Le header pour la class vdomain :
  24. class vdomain
  25. {
  26. public:
  27.   const mystring subdir;
  28.   const mystring prefix;
  29.   const configuration config;
  30. private:
  31.   vpwtable* ptable;
  32.   // Helper functions for chattr
  33.   response chpass(vpwentry*, mystring);
  34.   response chdest(vpwentry*, mystring);
  35. public:
  36.   vdomain(const pwentry&);
  37.   vdomain(const pwentry&, mystring, mystring, const configuration&);
  38.   ~vdomain();
  39.   vpwtable* table();
  40.   mystring userdir(mystring username) const;
  41.   // Virtual user manipulation functions
  42.   vpwentry* lookup(mystring name, bool nodefault);
  43.   bool exists(mystring name);
  44.   response set(const vpwentry*, bool onlyadd, mystring maildir = "" );
  45.   response chattr(mystring user, unsigned attr, mystring newval);
  46.   response chattr(const vpwentry*, unsigned attr, mystring newval);
  47.   response deluser(mystring name, bool del_mailbox);
  48.   // Virtual user validation functions
  49.   response validate_forward(mystring);
  50.   bool validate_username(mystring) const;
  51.   bool validate_password(mystring) const;
  52.   static const unsigned ATTR_PASS = 1;
  53.   static const unsigned ATTR_DEST = 2;
  54.   static const unsigned ATTR_HARDQUOTA = 3;
  55.   static const unsigned ATTR_SOFTQUOTA = 4;
  56.   static const unsigned ATTR_MSGSIZE = 5;
  57.   static const unsigned ATTR_MSGCOUNT = 6;
  58.   static const unsigned ATTR_EXPIRY = 7;
  59.   static const unsigned ATTR_MAILBOX_ENABLED = 8;
  60.   static const unsigned ATTR_PERSONAL = 9;
  61. };
  62. Le fichier vdomain.cc :
  63. vdomain::vdomain(const pwentry& user)
  64.   : subdir(), prefix(),
  65.     config(&user.config, user.home + "/" LOCAL_CONFIG_DIR),
  66.     ptable(0)
  67. {
  68. }
  69. vdomain::~vdomain()
  70. {
  71. }
Vous auriez une idée de ce qui pourrait causer ca :??:
Message édité par joce le 06-08-2002 à 18:42:40
n°154367
bilgetz_42
Posté le 08-06-2002 à 18:45:27  profilanswer
vdomain(const pwentry&) const;
al la place de
C'est un constructeur pour le objet constant s
n°154368
joce
&#034;BugHunter&#034;
Posté le 08-06-2002 à 18:51:59  profilanswer
oki, je teste ca :)
n°154369
joce
Posté le 08-06-2002 à 18:52:17  profilanswer
Code :
  1. test smilie :) ;)
n°154371
joce
Posté le 08-06-2002 à 18:55:29  profilanswer
marche pas :/
c++ -DHAVE_CONFIG_H -I. -I. -I../.. -I..    -g -O2 -fno-rtti -fno-exceptions -Wall -W -c vdomain.cc
In file included from vdomain.cc:18:
vdomain.h:23: constructors may not be `const'
n°154385
Willyzekid
Posté le 08-06-2002 à 19:13:10  profilanswer
t'as quelle version de gcc?
en utilisant g++, blablabla...
Horizon pas Net, reste à la buvette!!
n°154550
joce
Posté le 08-06-2002 à 21:10:28  profilanswer
[root@forum] /home/admin/vmailmgr-0.96.9> c++ --version
c++ (GCC) 3.1
Copyright (C) 2002 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Message édité par joce le 06-08-2002 à 21:11:06
n°154576
verdoux
And I'm still waiting
Posté le 08-06-2002 à 21:49:43  profilanswer
Faut virer le const de l'autre abruti et utiliser g++ et non gcc.
n°154577
Willyzekid
Posté le 08-06-2002 à 21:50:43  profilanswer
Mais putain c'est ce que j'ai dit!!! :( :sweat:
Bon c'est vrai qu'en relisant, c'est pas clair :D
Message édité par Willyzekid le 06-08-2002 à 21:51:30
n°154617
joce
Posté le 08-06-2002 à 22:51:51  profilanswer
ah vi tient ca marche tout d'un coup :D
v allez bidouiller le makefile moa :heink:
n°154619
joce
Posté le 08-06-2002 à 22:54:09  profilanswer
dans un autre fichier :
Code :
  1. void fail(const char* msg, const char* execfile, int code)
  2. {
  3.   presetenv("CHECKVPW_ERROR=", msg);
  4.   execute(execfile);
  5.   exit(code);
  6. }
  7. c++ -DHAVE_CONFIG_H -I. -I. -I..  -I../lib    -g -O2 -fno-rtti -fno-exceptions -Wall -W -c checkvpw.cc
  8. checkvpw.cc: In function `void fail(const char*, const char*, int)':
  9. checkvpw.cc:33: `exit' undeclared (first use this function)
  10. checkvpw.cc:33: (Each undeclared identifier is reported only once for each
  11.    function it appears in.)
n°154622
chrisbk
Posté le 08-06-2002 à 22:56:44  profilanswer
pour exit, je crois que c'est :
#include <stdlib.h>
n°154624
Willyzekid
Posté le 08-06-2002 à 22:59:43  profilanswer
#include <stdlib.h>
n°154625
joce
Posté le 08-06-2002 à 22:59:47  profilanswer
putain mais il est horrible ce package de vmailmgr, rien n'est standard :/
n°154626
Willyzekid
Posté le 08-06-2002 à 23:00:11  profilanswer
#include <stdlib.h>
tu commence a me les brouter toi !!! :D
n°154627
chrisbk
Posté le 08-06-2002 à 23:02:07  profilanswer
Ecoute, coyote, y'en a un de nous deux qui est de trop ici, et je crois bien que j'etais la avant toi, alors tu vois ce qu'il te reste a faire :D
n°154628
verdoux
Posté le 08-06-2002 à 23:02:50  profilanswer
Remarque, sur ma debian, g++ trouve tout seul 'exit'.
Apparemment stdio et stdlib sont inclus d'office ...
n°154631
joce
Posté le 08-06-2002 à 23:05:38  profilanswer
surement une nouveauté de gcc 3.0.x ou 3.1, au choix :p
n°154632
verdoux
Posté le 08-06-2002 à 23:06:15  profilanswer
Non, j'ai la version 2.95.2 :D
n°154636
joce
Posté le 08-06-2002 à 23:10:53  profilanswer
non la nouveauté de gcc 3.x c'est surement de pas inclure d'office je veux dire (vu que c'est plus proche de la norme)
Message édité par joce le 06-08-2002 à 23:10:58
n°154645
Willyzekid
Posté le 08-06-2002 à 23:33:42  profilanswer
Oui et c'est pour ca que j'ai demandé la version!!!
Je suis un incompris :( :sweat:
  C++
probleme lors de la creation de mon site ( avec namo webeditor)[VC++.NET] probleme de linkage
[php] probleme avec MkDirProblème requete SQL
probleme de boutons reactifs sous golive 5[utilisation de gcc] étape intermédiare de compilation
probleme avec mon forum phpbb[Java] problème avec le switch
c++ windows: récupérer le nom de l'éxécutable de l'appli[JS] Probleme de select à choix multiples
Plus de sujets relatifs à : [C++] Problème de compilation d'une appli en C++
