2694 connectés
  Photo numérique
  Appareil
  [ Topic unique] Canon Powershot S60
 Page :   1  2  3  4
Page Précédente
n°287673
flash007
Posté le 14-05-2004 à 09:04:57  profilanswer
http://www.imaging-resource.com/PRODS/S60/S60A.HTM
Enfin un APN compact 28-100 mm avec un vrai grand-angle !
Ce que j'attendais depuis longtemps.
Message édité par flash007 le 14-05-2004 à 14:37:04
n°287678
flash007
Posté le 14-05-2004 à 09:11:50  profilanswer
- 5.0-megapixel CCD delivering up to 2,592 x 1,944-pixel resolution images.
- 1.8-inch, color LCD monitor.
- 3.6x optical zoom lens, 5.8-20.7mm (equivalent to a 28-100mm lens on a 35mm camera) with auto and manual focus, adjustable focus area, 9-point AiAF in Auto and Image Zone modes, and focus bracketing.
- Up to 4.1x digital telephoto.
- Full automatic, program AE, shutter priority, aperture priority, and manual exposure modes, as well as five preset exposure modes and a Custom mode.
- Manually adjustable aperture settings from f/2.8 to f/8.0, depending on zoom setting (f/5.3 at max optical zoom).
- Manually adjustable shutter speed settings from 1/2000 to 15 seconds. (Aperture of f/4 or smaller aperture is required to achieve 1/2000 sec.)
- ISO sensitivity equivalents: Auto, 50, 100, 200, and 400.
- Three metering modes: Evaluative, center-weighted average, and spot metering
- White balance setting with nine modes, including a new underwater mode, and a manual setting.
- Built-in flash with five operating modes and flash exposure compensation (power adjustment in Manual mode).
- RemoteCapture utilities for controlling the camera from a computer.
- JPEG and RAW still image file formats, movies saved as AVI / Motion JPEG and WAVE formats.
- Images saved to CompactFlash Type I or II memory cards, 32MB card included.
- Movie mode with sound.
- Interval shooting mode, plus two Continuous Shooting modes.
- Stitch-Assist mode for creating panoramic pictures.
- Record up to 60 seconds of sound with individual images.
- DPOF (Digital Print Order Format) compatibility.
- USB cable for high-speed connection to a computer.
- Canon Digital Camera utility application, plus application software bundle. (Previous versions included ArcSoft PhotoStudio and VideoImpression software, I'll report the bundle that appears with the production models when I receive one.)
- Powered by Canon NB-2LH rechargeable lithium-ion battery pack, with optional AC adapter. (Increased power capacity over the pack that shipped with the S-45 and S-50.)
n°287718
vroom39-93
Posté le 14-05-2004 à 10:42:54  profilanswer
Attendons des tests car je voudrai bien voir la distorsion et la perte de piqué aux focales extrèmes...
n°287721
Cpu Toaste​r
R pixel overclocking!
Posté le 14-05-2004 à 10:46:58  profilanswer
-Le topic en caps... ça fait mal aux yeux.. :(
Sinon comme je l'ai dit sur le poste précédent, ben ce qui m'intéresse c'est la acro à 5 cm :)
Photo Toaster - Flickr Toaster - Blog Toaster
n°287778
chaca
Posté le 14-05-2004 à 12:12:25  profilanswer
sa sortie est prévue pour Juin mais + de 600€ quand-même!à ce prix il a intérêt à être bien meilleur que le S50 qui se défend plutôt bien (je l'ai depuis 3 semaines et en suis très satisfait)et qu'on trouve vers 420€ sur le net!salut
n°328891
lor
Posté le 26-06-2004 à 03:03:51  profilanswer
salut,
j'attends avec impatience les nouveaux utilisateurs du canon s60!!!! Avec une fiche technique aussi allêchante...!!!
Sinon, pour le meme prix vaut t'il un S50 pro (1 go de carte) ou un s60 de base ??? est ce que le s60 est il meilleur, en tout cas assez pour justifier cette différence de prix.
En tout cas, les touches au dos sont plus fonctionnelles! le 28-105  plus exploitable...
j'attends avec impatience ce redoutable concurrent du G5!
n°328893
Cpu Toaste​r
Posté le 26-06-2004 à 04:10:29  profilanswer
Concurrent du G5, ils sont pas fou au point de faire de la concurrence interne, le G5 est beaucoup plus fonctionnel.
n°328895
lor
Posté le 26-06-2004 à 04:26:00  profilanswer
ya quoi de plus fonctionnel, mis à part un écran rotatif, une roullette et un porte flash ??? étant possesseur d'un G3, mis à part le format, pour moi c'est clair et net le G5 à un look un peu plus pro et peu recevoir un flash externe. à part ca, rien de plus. D'ou une certaine concurence.
De plus le S60 enregistre un Jpeg avec le Raw.
n°328897
lor
Posté le 26-06-2004 à 04:44:07  profilanswer
la question à se poser est:
ESt ce que le s60 vaut bien le s50 avec 1 Go microdrive pour le même prix ?????
n°328901
Cpu Toaste​r
Posté le 26-06-2004 à 05:08:12  profilanswer
Ben par rapport au G3/5 maintenant que j'ai besoin d'un porte flash... la différence, je la trouve énorme, le nombre de photos que je voudrais faire mais que je peux pas parce que je n'ai pas de flash externe, ça me prend la tête... L'écran rotatif... marrant mais moins important que le porte flash. Puis bon qu'est ce qu'il y a encore... les batteries... tiennent surement plus longtemps..
Voilà, c'est pour ça que je préfère la gamme G finalement (pourtant j'ai un S)
Mais bon là où on enterre le G, c'est le poids...
Entre S60 et 50, le 60 est plus léger, plus fin et a un plus grand angle. Ensuite faut voir si l'optique arrivera a délivré des images d'aussi bonne qualité... Moi je m'attends pas à des miracles, niveau des toffeurs à hong kong, ils disent que l'optique du Ricoh Captio GX va le surclasser... à voir..
Et puis les 1go tu en as vraiment besoin? si tu as un G3, tu devrais déjà avoir des CF non?
n°328907
lor
Posté le 26-06-2004 à 05:42:14  profilanswer
En effet, en considérant le besoin d'un flash externe, la question ne se pose même pas.
Au niveau du caplio GX, j'ai pas encore vu de samples, donc peu pas dire grand chose.
Sinon, une petite avant premiére, voici des échantillions du S60:
 http://www.imaging-resource.com/PRODS/S60/S60THMB.HTM
Ca date du 18 juin il me semble.
sur le forum imaging-ressource:
http://www.photo-forums.com/WebX?8 [...] 6@.ee9935c
sinon en effet, les 1go ne sont pas vraiment necessaire... mais bon plus on en a mieux c'est pour le RAW...
ce qui m'interresse surtout dessus c'est sont format qui permet de le transporter partout, mais aussi biensûr sont 28-100 qui est je pense plus exploitable que mon 35-140.
un pti echantillion du G3, Voici Kasper mon petit chat:
n°328909
lor
Posté le 26-06-2004 à 05:47:19  profilanswer
[img]C:\Documents and Settings\Lauryble-Jennyal\Mes documents[/img]
n°328910
lor
Posté le 26-06-2004 à 05:48:52  profilanswer
Vraiment désolé, je sais pas mettre une image :(
snifff
bon je vais coucher
n°328912
Cpu Toaste​r
Posté le 26-06-2004 à 06:21:25  profilanswer
n°329148
lor
Posté le 26-06-2004 à 13:49:09  profilanswer
n°329155
lor
Posté le 26-06-2004 à 14:11:42  profilanswer
qq'un a déjà essayé le Télé-convertisseur 2x. aimanté
pour diamêtre d'objectif de 17 à 22 mm de cokin: COKIN MAGNE-FIX R760 MS ???
Si ca marche, avec ca, le S60 sera plus que complet...
n°329157
lor
Posté le 26-06-2004 à 14:12:10  profilanswer
Bon, je me lance,
JE COMMANDE :) :) :) :)
n°330428
LToPiQ[PPC​]
Boolay de formation
Posté le 28-06-2004 à 11:10:22  profilanswer
n°330743
LToPiQ[PPC​]
Boolay de formation
Posté le 28-06-2004 à 16:33:19  profilanswer
Pour ceux qui auraient la flegme de lire l'article dcresource (le plus intéressant selon moi), en voici un résumé-résumé-résumé :
Tout est parfait, sauf :
1 : tendance à faire des yeux rouges, malgré la fonction de protect (que faire contre sinon retoucher) ?
2 : le mode vidéo, 10 i/s seulement, 30 sec max en 640*480
3 : un peu de "softness" dans les coins, mais rien d'alarmant
4 : petit effet "plastique" (cheap) près de l'emplacement mémoire
Sinon très belles photos, rapide, intuitif, tout niquel... L'angle super large pour un si petit appareil les a bluffé puisqu'on ne retrouve cela que sur des 8 Mpix, qui ne sont plus vraiment "compacts". Aussi les possibilités de réglage (balance des blancs et des couleurs).
Y'a rien eu de VRAIMENT *exceptionnel*, mais ils sont très satisfaits/surpris de la qualité de l'appareil, de A à Z dans tous les menus/fonctions/timings/résultats/... Très homogène apparemment.
Message édité par LToPiQ[PPC] le 28-06-2004 à 16:39:32
n°331577
Potter
Posté le 29-06-2004 à 14:14:02  profilanswer
Bonjour à tous,
J'étais parti pour m'acheter le G5 et en allant une dernière fois à la boutique pour le prendre en main, j'apprend l'existence du S60. Quasiment les mêmes caractéristiques excepté un zoom moins grand (3.6x vs. 4x) et une optique un poil moins performante dixit le vendeur. Mais surtout une compacité bien meilleure.
Alors évidemment, me voila reparti dans mes interrogations. Le (léger) supplément pour le G5 est-il justifié? La qualité d'image est-elle réellement meilleure? (je veux dire par la, la différence sera t'elle flagrante ou seulement visible en format poster par des experts...). Le gain en compacité du S60 est-il à mettre en rapport avec un appareil globalement moins bon?
Sachant que c'est un appareil qui va venir remplacer mon vieux Nikon 2m pixel, qu'il devra photographier aussi bien mes soirée (intérieur avec faible luminosité) que mes vacances (paysages…), bref utilisation normale quoi. Je compte m'amuser un peu avec les possibilités manuelles de l'appareil, c un point important.
Voilà, tout ça retarde mon achat. je voudrais pas me tromper. Je compte le garder un bout de temps quand même. La différence de prix (€50 environ) les mets quasiment sur un pied d'égalité.
J'ai besoin de vos lumières...
n°331610
LToPiQ[PPC​]
Boolay de formation
Posté le 29-06-2004 à 14:48:30  profilanswer
Imaging Resource vient de sortir un test :
Avant ils n'avaient eu que la bêta et avaient juste publié leur "feeling", maintenant c'est un vrai test.
Potter > tu peux attendre l'avis de connaisseurs plus pros que moi, mais pour ce qui est de mon avis, tu as un intérêt avec le G5 si et uniquement :
- tu es capable de te servir des fonctions manuelles de façon un peu poussée
- tu veux vraiment un gros zoom optique (3.6x est déjà très bien !)
- la faible différence en mode "obscur" est vraiment très importante pour toi
Pour tout le reste, j'ai l'impression que le S60 est aussi bon que le G5, notamment pour la qualité de la photo.
Message édité par LToPiQ[PPC] le 29-06-2004 à 14:49:39
n°331705
chaca
Posté le 29-06-2004 à 16:56:56  profilanswer
ayant le S50 qui ,par ailleurs, fait vraiment d'excellentes photos tout à fait comparable au G5,avec le S60 l'optique semble encore meilleure,28mm!!concernant le S50/S6O les fonctions avancées sont au niveau du G5(réglage puissance du flash+1er rideau,2ème rideau,lent,tous les BKT,...)Modes PSAM balance des blancs etc...la vitesse du S6o est dite + rapide,meilleure autonomie aussi ergonomie revue et + compacte!que du bon quoi!mais 600€!le S50 - de 400€!!A voir tout ça!salut
n°331779
lor
Posté le 29-06-2004 à 19:15:48  profilanswer
salut avous,
je ressois le miens mercredi from Pixmania.
Pour moi, le s60 est mieux que le G5. Il a les MEMES fonction, plus compact, plus grans angle, et plus rapide. De plus il enregistre des vignettes en meme temps que le RAW. Ce qui permet de visualiser les images.
Le G5 est a favoriser pour celui qui veut utiliser un flash externe. De plus il a un écran qui pivote. Mais bon c'est pas la même compacité.
Pour ce qui est de la qualité, je G3 et au-dessus du G5. Bizarre, non???
C'est parceque le capteur est optimisé pour 4Mp!!! Comment ont ils fait ???
Pour simplifier, ils ont prix le même capteur, diminuer la taille des photons ou pixels, pour pouvoir en mettre 5 Mp, mais étant plus petit, ils captent moins de lumiére. Ce qui en résulte des photos avec plus de bruits et plus d'abération chromatique ... Si je me trompe , n'hésitait pas à me corriger!
C'est pour cela que j'ai choisi le G3 qui pour moi est le meilleur APN sur le marché (si on arrive encore à le trouver...), que je viens de revendre au profit du s60 pour sa compacité, macro 4cm, blablabla et son grand angle. De plus il a les mêmes fonctions. Il manque juste un porte flash... Mais bon, comme j'utilise pas de flash externe...
Bef, vivement mercredi!
n°332195
Potter
Posté le 30-06-2004 à 11:29:02  profilanswer
Merci à tous pour vos conseils.
Je crois que je vais me diriger vers le S60, il me plait bien. La taille du G5 n'apporte visiblement pas grand chose en terme de performance. Je m'acheterai un vrai appareil haut de gamme (type reflex) lorsque j'en aurai les moyens dans quelques années. D'ici-la ce petit compact va bien m'occuper.
Des que j'ai pu le prendre en main, je fonce
Potter
n°334135
Cpu Toaste​r
Posté le 02-07-2004 à 10:16:38  profilanswer
dispo à HK pour 3980HK$ soit un peu plus de 400 €. Il n'a pas l'ai aussi fin qu'il le laisse penser, mais est plus fin qu'un S45-50.
l'est dispo en Europe je pense :)
Message édité par Cpu Toaster le 02-07-2004 à 10:17:03
n°334214
LToPiQ[PPC​]
Boolay de formation
Posté le 02-07-2004 à 12:27:54  profilanswer
Bien sûr qu'il est dispo, cf n'importe quel comparateur de prix (ex http://www.lesprix.net/prix/affprix-22463-1.html )
Message édité par LToPiQ[PPC] le 07-07-2004 à 13:29:34
n°334330
vinzz
Posté le 02-07-2004 à 14:51:45  profilanswer
Ayé c commandé  , sur Nomatica il est dispo depuis aujourd hui (48h logiquement) , le tout pour 511€ FDP inclus.
j espere l avoir lundi ou mardi je vous tiens au courant !!
edit 5/7 : en fait Nomatica ne l'a plus en stock , j ai donc annulé ma commande et je l'ai commandé sur pixmania , je vais le chercher demain au retrait sur Paris :)
Message édité par vinzz le 05-07-2004 à 13:05:02
n°338665
vinzz
Posté le 07-07-2004 à 13:20:13  profilanswer
Salut , ayé j ai mon S60 , commandé sur Pixmania, dispo sans probleme , avec le code de reduc EUROQUIZFR2 ca fais -20e , ce qui fais 490€ FdP inclus :)
J ai pas eu bcp de tps pour l essayer , mais il a l air trés rapide et super agreable :)
a+ :)
n°338672
LToPiQ[PPC​]
Boolay de formation
Posté le 07-07-2004 à 13:28:18  profilanswer
Viens nous mettre tes premières impressions quand tu l'auras un peu plus essayé :)
n°338711
vinzz
Posté le 07-07-2004 à 14:14:59  profilanswer
Ok , pour l instant j suis un peu un amateur en photo , j ai préféré prendre celui plutot qu un ixus paske j ai envie d apprendre un peu a me servir des fonctions manuelles , mais je connais pas gd chose encore lol :)
Hier j ai essayé de prendre une photo en intérieur , avec mon S60 et la même avec un ixus , ben j peux deja dire que le grand angle est trés appréciable :)
Message édité par vinzz le 07-07-2004 à 14:17:06
n°339410
lor
Posté le 08-07-2004 à 01:55:14  profilanswer
salut à vous,
j'ai reçu le miens ya une petite semaine. J'ai eu le temps de le tester. Mes impressions:
ya quand même de la distorsion en grand angle
photos de bonne qualité mais en dessous de mon G3 (que j'ai revendu pour le S60) et un peu plus bruyante.
bonne compacité et bonne prise en main.
AF plus rapide que G3
Photo un peu moins lumineuse que G3(f2pour g3 contre f2.8 pour s60)
batterie assez faiblarde par rapport au g3 mais correcte.
Bref le G3 fait de meilleures clichés c net, mais le s60est plus pratique par sa taille. je me pose pas la question de savoir si je prends l'APN chaque fois que je sort, il est toujours avec moi. Il prends de bonnes photos, belles couleurs et il est rapide. dommage qu'il manque un peu de luminosité en intérieur et une distorsion qui est parfois gênante, surtout en grand angle et en intérieur, ca se remarque sur les visages situés aux extrêmités. Mais je dois avouer que le grand angle est bien pratique.
Bref, un bon APN avec quelques défauts. Il est tou de même dificile de trouver mieux dans ce type de format. Peut être qu'avec un objectif ouvrant à f2 avec un capteur 4MP aurait était presque parfait!
Prévoyer une deuxiéme batterie. Mais dans l'ensemble, j'en suis satisfait même si je m'attendait à trouver un g3 réduit avec grand angle...
n°339420
albatar197​6
Posté le 08-07-2004 à 02:39:36  profilanswer
quand vous comparez le g3 ou le g5 avec le s60, vous oubliez une chose importante. C'est que le g3 et le g5 ouvrent à f2.0 en grand angle et à f3.0 en télé alors que le s60 n'ouvre qu'à f2.8 en grand angle et à f5.3 en télé... Ce n'est quand même pas négligeable.
après c'est une question de priorité. Soit on a une optique lumineuse, soit on a un apn assez compact pour l'avoir toujours avec soi  ;)
n°344849
Majic
Posté le 16-07-2004 à 10:15:57  profilanswer
dslé, images en time out sur serveur canon, posterai les bons liens prochainement
Message édité par Majic le 16-07-2004 à 11:38:08
n°348658
Majic
Posté le 21-07-2004 à 14:47:35  profilanswer
http://sites.estvideo.net/pom2ter/photos/IMG_0564.JPG
http://sites.estvideo.net/pom2ter/photos/IMG_0587.JPG
http://sites.estvideo.net/pom2ter/photos/IMG_0665.JPG
http://sites.estvideo.net/pom2ter/photos/IMG_0698.JPG
http://sites.estvideo.net/pom2ter/photos/IMG_0775.JPG
Quelques samples de mon week-end à paris.
Les fans reconnaitront un shot de Simon and Garfunkel, concert lundi soir à Bercy :love:
edit : je sais pas pourquoi, mais certaines ne s'affichent pas, pourtant aucun pb en local :/
Message édité par Majic le 21-07-2004 à 15:06:06
n°348751
Cpu Toaste​r
Posté le 21-07-2004 à 17:04:26  profilanswer
Beurk, j'ai cliké sur la dernière... et j'ai vraiment failli gerbé...
Sinon c'est bizarre la gestion des parties trop blanches... (cramées quoi)
n°349120
Majic
Posté le 22-07-2004 à 09:12:24  profilanswer
C'est du muesli avec un yaourth, en macro :D
je posterai après d'autres photos plus itéressantes
n°349160
Majic
Posté le 22-07-2004 à 10:05:06  profilanswer
n°350373
bzzz99
Posté le 24-07-2004 à 01:25:25  profilanswer
Quelques photos que j'ai prises avec le S60, pour compléter la collection de Magic :
http://perso.wanadoo.fr/jylo/1.jpg
http://perso.wanadoo.fr/jylo/2.jpg
http://perso.wanadoo.fr/jylo/3.jpg
http://perso.wanadoo.fr/jylo/4.jpg
n°351709
LToPiQ[PPC​]
Boolay de formation
Posté le 26-07-2004 à 16:25:42  profilanswer
Je suis étonné de ça quand je vois qu'un minuscule (bien plus petit que le S60) Pentax Optio 430/440/450/455 ouvre à 2.6... Comment ça se fait ?
n°351716
Cpu Toaste​r
Posté le 26-07-2004 à 16:40:51  profilanswer
ça dépend aussi de la longueur de focale.. l'ouverture doit se lire avec la focale. Sur les APN ça se jouent à quelques milimètre près.
Et puis l'encombrement n'est pas forcément croissant, j'ai 3 optique fixe, un 50 et un 35, en f1,5 et 1,7 et ben, le 35 est plus gros même s'il ouvre moins...
 Page :   1  2  3  4
Page Précédente
  Photo numérique
  Appareil
Canon A70 / A80 : ou acheter?QUELQUES PHOTOS DU CANON S1 IS
Canon A60/70 en mode webcam?Canon PowerShot S60
Adaptateur secteur canonCANON 300D et mode RAW
[TOPIK UNIK] Canon A60Nettoyage Powershot A80
Plus de sujets relatifs à : [ Topic unique] Canon Powershot S60
Hit-Parade
