2623 connectés
  Photo numérique
  Appareil
  [Topik unique] Samsung Digimax i6 PMP !!! ( Premier apn au monde )
n°920669
jojo2005
Posté le 19-03-2006 à 20:23:07  profilanswer
Caracteristique
Image Sensor Type 1/2.5″CCD
Effective Pixels Approx. 6.0 Mega-pixel
Total Pixels Approx. 6.1 Mega-pixel
Lens Focal Length SHD Lens f = 6.6 ~ 19.8mm (35mm film equivalent : 39~117mm)
F No. F3.5 ~ F4.5
Digital Zoom Still Image mode : 1.0X ~ 5.0X
Play mode : 1.0X ~ 11.0X (depends on image size)
Viewfinder LCD Monitor 2.5" Colour TFT LCD (230,000 pixels)
Focusing Type TTL auto focus
Range Normal : 50cm ~ infinity
Macro : 5cm~50cm (Wide), 25cm ~ 50cm (Tele)
Auto Macro : 5cm~Infinity (Wide), 50cm~ Infinity (Tele)
Super Macro : 1cm~5cm (Wide)
Shutter Type Mechanical and Electronic shutter
Speed 1 ~ 1/2,000 sec. (Night : 16 ~ 1/2,000 sec.)
Exposure Control Program AE
Metering : Multi, Spot
Compensation ±2EV (0.5EV steps)
ISO Equivalent Auto, 100, 200, 400
Flash Modes Auto, Auto & Red-eye reduction, Fill-in flash, Slow sync, Flash off
Range Wide : 0.2m ~ 2.4m, Tele : 0.3m ~ 1.9m (ISO Auto)
Recharging Time Approx. 4 sec.
Sharpness Soft, Normal, Vivid
Effect Normal, B&W, Sepia, Negative, Red, Green, Blue, RGB
Voice Recording Voice Recording (max 1 hour)
Voice Memo in Still Image (max. 10 sec.)
Date Imprinting Date, Date&Time, Off (user selectable)
Still image Modes : Auto, Program, Scene, ASR
* Scene : Night, Portrait, Children, Landscape, Text, Close-up, Sunset, Dawn, Backlight, Fireworks, Beach & Snow, Continuous : Single, Continuous
White Balance Auto, Daylight, Cloudy, Fluorescent_H, Fluorescent_L, Tungsten, Custom
Movies With Audio (recording time : Depend on Storage size)
Size : 640x480, 320x240, 160x128 (3X Optical Zoom and Mute in Zooming)
Frame rate : 30 fps, 15 fps
Movie Stabilizer (User Selectable)
Movie Editing (Embeded) : Pause during recording, Still Image Capture, Time Trimming
Storage Media Internal memory: About 45MB
External memory: SD card /MMC (Up to 1GB Guaranteed)
File Format Still Image : JPEG (DCF), EXIF 2.2, DPOF 1.1, PictBridge 1.0
Movie : AVI(MPEG-4)
Audio : WAV
Image Size 6M : 2816x2112 pixel
5M : 2592x1944 pixels, 4M : 2272x1704 pixels,
3M :2048x1536 pixels, 2M : 1600x1200 pixels,
1M : 1024x768 pixels, VGA : 640x480 pixels
Capacity(64MB) 6M : Super Fine 18 Fine 35 Normal 52
5M : Super Fine 22 Fine 42 Normal 61
4M : Super Fine 27 Fine 54 Normal 79
3M : Super Fine 35 Fine 65 Normal 93
2M : Super Fine 57 Fine 101 Normal 139
1M : Super Fine 139 Fine 197 Normal 250
VGA :Super Fine 289 Fine 341 Normal 417
* These figures are measured under Samsung’s standard conditions and
may vary depending on shooting conditions and camera settings.
Self-Timer 2 sec., 10 sec., Double(10 sec., 2 sec.)
Image Play Type : Single image, Thumbnails, Slide show(with MP3), Movie
Editing : Trimming, Resizing, Rotate, Effect
Interface Digital output connector : USB 2.0
Audio : Mono
Video output : NTSC, PAL (user selectable)
DC power input connector : 24pin Connector
Power Source Rechargeable battery : SLB-0837 (860mAh)
Adaptor : SAC-42
Optional Cradle
* Included battery may depending on sales region.
Dimensions(WxHxD) 96x61x18.5mm
Weight 129.5g
Software Camera Driver Storage Driver (Windows98/98SE/2000/ME/XP, Mac OS 9.0 ~ 10.4)
Application Digimax Master, Digimax Converter*, Digimax Reader
 *Supported OS : Windows 98SE/2000/ME/XP
 *Above Pentium Ⅲ 500MHZ processor (Recommend to use Pentium Ⅳ;)
For Windows PC with processor better than Pentium II 450MHz (Pentium 700MHz recommended)
Windows 98/98SE/2000/ME/XP
Minimum 64MB RAM
200MB of available hard-disk space
USB port
CD-ROM drive
1024x768 pixels, 16-bit colour display compatible monitor (24-bit colour display recommended)
Microsoft DirectX 9.0C
For Machintosh Power Mac G3 or later
Mac OS 9.0 ~ 10.4
 * Movie clip play condition : Above Mac OS 10.1 (need to install MPlayer or VLC)
Minimum 64MB RAM
Audio(MP3) Frequency 20Hz~20KHz
Earphone Port 3.5mm Port (Stereo Type)
Output Maximum Volume  Left 15mW + Right 15mW(16Ω)
Noise Ratio 86 dB with 20 KHz LPF
File(MP3) File Format MP3 (MPEG-1/2/2.5 Layer 3)
Bit Rate 48 ~ 320kbps
Play Mode(MP3) - All, Repeat One, Repeat All, Random, Random Repeat
- Skipping in Play, Auto Skipping
- Slide Show On/Off (User Selectable),
- MP3&Capturing (Capturing Mode is Auto Default, 3M)
- Auto reload function (Remember last played file)
- Background skin of MP3 playback using user images
PMP Decoder Movie Xvid MPEG4 (Using Digimax Converter S/W)
Audio MPEG1 Layer 2 (Using Digimax Converter S/W)
Play Mode(PMP) - Seeking in Play (Max 32X), Skipping in Play,
- Auto skipping after one file played
- Auto reload function (Remember last played frame)
- Support Full Screen in Converting S/W
Subtitle(PMP) Support SMI file (Using Digimax Converter S/W)
Image de l'appareil
http://www.samsungcamera.co.kr/upload/editor/200601/digimaxi6_en03_200611811441262.jpg
http://www.samsungcamera.co.kr/upload/editor/200601/digimaxi6_en09.jpg
http://www.samsungcamera.com/upload/product/SL2-63/gview_20060302_1_i6PMP.jpg
http://www.letsgodigital.org/images/producten/1140/specs/samsung_digimax_i6_front.jpg
http://www.letsgodigital.org/images/producten/1140/specs/samsung_digimax_i6_back.jpg
http://www.pc.com/news/d/i/digimax_i6_pmp.jpg
[img]http://www.dphoto.it/images/stories/Samsung/samsung_i6.jpg[img]
http://www.dphoto.it/images/stories/Samsung/samsung_i6_back.jpg
http://fotopolis.pl/obrazki/i6s_top.jpg
Photo prise avec l'appareil
http://www.samsungcamera.com/upload/product/sample/200603/view_20060308_0_SSL29280.JPG
http://www.samsungcamera.com/upload/product/sample/200603/view_20060308_0_SSL29310.JPG
http://www.samsungcamera.com/upload/product/sample/200603/view_20060308_0_SSL29316.JPG
http://www.samsungcamera.com/upload/product/sample/200603/view_20060308_0_SSL29321.JPG
http://www.samsungcamera.com/upload/product/sample/200603/view_20060308_0_SSL29322.JPG
http://www.samsungcamera.com/upload/product/sample/200603/view_20060308_0_SSL29329.JPG
Ps : Ils viennent du site Samsung
apparement, il est dans la pub de MEDIAMARKT et il coute 377 Euro pour un Premier PMP au monde et Full option, Pas mal
donnez vos avis ici, ou d'autres site proposant des tests
Message édité par jojo2005 le 22-03-2006 à 23:49:21
n°924132
jojo2005
Posté le 21-03-2006 à 17:37:08  profilanswer
personne repond ?
qui la acheter ?
n°925419
jojo2005
Posté le 22-03-2006 à 12:37:05  profilanswer
personne ?
n°925691
cemoi13
Posté le 22-03-2006 à 16:24:51  profilanswer
effectivement il a de la gueule, par contre qu'est-ce qu'il vaut niveau qualité photo ???
http://www.digitalworld.fr/photo/t [...] 6-297.html
n°926022
jojo2005
Posté le 22-03-2006 à 19:29:40  profilanswer
oui c'est vrai complet mais voir !
n°961737
_SHLAVOD_
Posté le 19-04-2006 à 12:10:09  profilanswer
Il a l'air pas trop mal, cet appareil photo, mais toujours pas de test où que ce soit...
n°961760
_nicolas_
Posté le 19-04-2006 à 12:45:20  profilanswer
Sujet : [Topik unique] Samsung Digimax i6 PMP !!! ( Premier apn au monde )
www.imagezone.fr
n°961872
_SHLAVOD_
Posté le 19-04-2006 à 14:07:56  profilanswer
je pense qu'il voulait dire APN n° 1 au monde !
n°961927
lionoche
Posté le 19-04-2006 à 14:52:20  profilanswer
Ou premier APN avec MP3...
A quand un apn qui fait le café et la vaisselle ?
http://www.flickr.com/lionoche
n°961989
_SHLAVOD_
Posté le 19-04-2006 à 15:27:00  profilanswer
on se contenterait déjà bien d'un APN qui fait de bonnes photos ... Mais peut-être que c'est le cas pour celui-là...
n°980284
Mister Fug​u
Ab Umbra Veritas
Posté le 02-05-2006 à 22:51:08  profilanswer
J'ai acheté cet appareil il y a de cela un mois maintenant, et le bilan est plutôt moyen/bon on va dire. La finition est exemplaire, l'ergonomie remarquable, la lecture et le transfert de MP3 et de vidéos est assez simple et plutôt bonne (le bon écran aidant), mais niveau photo c'est assez moyen. Le système anti flou de bougé est bof, la qualité des photos est moyenne malgré un mode super macro assez performant, et la prise de vidéo a le son qui se coupe quand on zoome. Ce n'est pas un mauvais appareil, loin de là, surtout pour le prix et pour toutes ses fonctions, mais c'est un premier pas vers les hybrides conjuguant MP3 vidéo et photos, donc à parfaire dans le futur. ;)
n°981008
sculptis
www.sylvain-weber.com
Posté le 03-05-2006 à 14:01:51  profilanswer
Un pavé jetté dans la marre qui pourra peut être faire des vagues et initier d'autres modèles plus performant pour notre plus grand plaisir.
www.decouvrir-mayotte.fr www.artisandart.com
n°981035
Cygne_d_et​ang
Modérateur
Punk's not dead
Posté le 03-05-2006 à 14:21:07  profilanswer
Mister Fugu a écrit :
...niveau photo c'est assez moyen. Le système anti flou de bougé est bof, la qualité des photos est moyenne ...
C'est ballot pour un appareil photo :lol:
Morphine 'n whisky - Arrière les Esquimaux! Je rentre seul. Un matador rentre toujours seul! Plus il est grand, plus il est seul. Je vous laisse à vos banquises, à vos igloos, à vos pingouins. ¡ Por favor Señora! À quelle heure le train pour Madrid?
n°982626
alexp25
Eddy...
Posté le 04-05-2006 à 12:11:05  profilanswer
Encore un combiné foireux qui donne au final un mauvais apn dans balladeur mp3 ou l'inverse...
Et si ton mp3 tombe en rade, t'as plus d'apn, et l'inverse...
Pas convaincu moi.
n°1175429
Am2chaM
Pseudo PSN > TheLYoN
Posté le 10-09-2006 à 17:21:24  profilanswer
Désolé de uper ce topic assez ancien, mais je compte me l'acheter vers octobre, croyez-vous que je dois attendre Noël pour voir les derniers modèles, sachant que je tiens à avoir un Samsung uniquement.
  Photo numérique
  Appareil
[Topic Unique] RICOH Caplio R4Ou trouver le TEST du Samsung Digimax i6
[Topic Unique] Canon Ixus 800 ISLe topic de la visée (écrans, viseurs optiques...)
Mon premier numérique[Topic Unique] Topic des fondus du focus manuel [M42 et autres]
[Topic unique] Canon PowerShot S3 IS[Topic Unique] Nikon Capture NX
Plus de sujets relatifs à : [Topik unique] Samsung Digimax i6 PMP !!! ( Premier apn au monde )
Hit-Parade
