1471 connectés
  Photo numérique
  Appareil
  Olympus camedia 7070 wide zoom
n°681345
code34
Posté le 05-08-2005 à 11:41:16  profilanswer
Bon voila un nouveau petit topic qui n'existe pas, pour ce petit appareil dont on entend peu parlé. Quels sont vos avis sur cet appareil ?
http://www.olympusamerica.com/img/cpg_images/1152_top1.jpg
CCD Imager    7.1 megapixel effective, 7.41 megapixel gross, 1/1.8” CCD
Lens  5.7–22.9mm (27–110mm equivalent in 35mm photography), 8 lenses in 7 group
Seamless Digital Zoom  Seamless to 20x (4x optical and 5x digital combined)
Aperture Range  f2.8 to f11.0 (adjustable in 1/3 or 1/2 EV step)
Shutter Speeds  1/4000 sec – 16 sec.
ISO  Auto, 80, 100, 200, 400 (equivalent)
Recording Mode(s)  DCF Exif2.2, RAW, TIFF, JPEG
Adjustable Resolutions  3072 x 2304, RAW, TIFF, SHQ, HQ, 3:2
3072 x 2048, TIFF 3:2, SHQ 3:2
2592 x 1944, TIFF, SQ1 High, Normal
2288 x 1712, TIFF, SQ1 High, Normal
2048 x 1536, TIFF, SQ1 High, Normal
1600 x 1200, TIFF, SQ2 High, Normal
1280 x 960, TIFF, SQ2 High, Normal
1024 x 768, TIFF, SQ2 High, Normal
640 x 480, TIFF, SQ2 High, Normal
DPOF (Digital Print Order Format)  Yes
Optimum Image Enlargement
Image Adjustment Modes  (Adj. ±5) sharpness, contrast, color phase
Image Effects  Black and White, Sepia
Panorama  Up to 10 frames automatically stitchable with Olympus Master software when using Olympus brand xD-Picture Card™
Sequence  High-speed 3.3 fps/max 4 images in RAW or JPEG 1.7 fps/max 10 images in HQ
Viewfinder
LCD  1.8” (4.6cm) Semi-transmissive LCD, approx. 130,000 pixel
Focusing System  Dual AF (CCD: Contrast detection/Passive Sensor: Phase detection)
Focusing Ranges  Normal mode: 31” – infinity (0.8m – infinity)
Macro mode: 8” – 31” (0.2m – 0.8m)
Super Macro Mode: 1” – 8” (.03m – 0.2m)
Exposure Control  ±2 EV steps in 1/3 or 1/2 EV steps
Metering System  Digital ESP, Spot, Center Weighted
White Balance System  iESP2 multi-pattern auto TTL, Pre-set (Shade, Overcast, Sunlight, Evening Sun, Tungsten, and Fluorescent), Custom, WB compensation +/- 7
Flash  Built-in; Pop-up; TTL Hot Shoe for optional FL-20 TTL flash, FL-36 TTL flash, FL-50 TTL flash or sync to studio strobes with optional cables
Flash Modes  Auto (for low light and backlit conditions)
Red-eye Reduction
Fill-in
Slow (1st Curtain and 1st Curtain with Red-Eye
Reduction, 2nd Curtain)
Off
Slave
Flash Working Range  Wide: 31” - 21.1ft (0.8 - 3.7m); Tele 31” - 7.2ft. (0.8 - 2.2m)
Flash Charging Time
Removable Media Card  xD-Picture™ Card (16, 32, 64, 128, 256, 512MB, or 1 GB), Compact Flash Type I or Type II (up to 4GB)
Selftimer/Remote  12 seconds/by Remote Control; Auto, 3 seconds
Setting Memorization  On/Off (Hold changes/Reset to default settings)
Outer Connectors  USB connecter (Auto-Connect), Audio/Video, and DC input
Auto-connect USB  2.0 Full Speed
Image Playback  Still image: Index display 4, 9, 16, Up to 7x enlargement, Smooth scroll of index, Histogram, Protect, Rotation
Movie: Normal, Frame-by-frame
Operating Environment  Operation: 32° – 104°F (0° – 40°C), 30 – 90% humidity
Storage: -4° – 140°F (-20° – 60°C), 10 – 90% humidity
Power Supply  Li-Ion Rechargeable Battery (BLM-I), AC Adapter
Date/Time Calendar  Simultaneous recording into image data, Automatic up to 2099
Calendar  Automatic up to 2099
Size  4.6” W x 3.4” H x 2.6” D (116mm x 87mm x 65.5mm)
Weight  13.5 oz (420g) without battery and media card
# 7.1 megapixel CCD
# 4x Wide Zoom + 5x digital zoom = 20x total seamless zoom
# 1.8" Semi-Transmissive Swivel LCD lets you view your images and movies clearly and vividly - inside and out
# Remove red-eye in one simple swoop with our Built-in Red-Eye fix feature and breathe new life into your pictures
# TruePic TURBO Image Processor enables fast camera operation and enables smoother, more accurate images, even at lower resolutions
# Advanced Autofocus features like Predictive AF to keep subjects moving towards you in focus and keep them in focus for longer periods of time, and Target with 143 zones so you can focus on a specific subject
# Twelve (12) selectable shooting modes including Sports, Underwater Wide, and Underwater Macro (underwater modes to be used with available PT-O27 Underwater Housing)
# QuickTime® Movie Mode with audio brings your pictures to life in 30 fps VGA-quality fashion
# Dual Media Slot supports xD-Picture Cards or CompactFlash
# Print out pictures quickly and easily via a direct connection to any PictBridge-enabled printer
# Auto-Connect USB lets you transfer files to and from a computer with a simple connection, no software installation required
# Use the Panorama function to capture an entire scene or landscape
# Four (4) customizable My Mode settings
# Super Macro Mode for capturing details at close range (1.18 inches)
# Built-in flash
# Hot shoe for external flash capability
# OLYMPUS Master image editing software lets you edit, create, print and share images like never before
# Rechargeable Li-Ion battery and charger included so power is never a concern
Lien officiel:
http://www.olympusamerica.com/cpg_ [...] t=1152&fl=
Message édité par code34 le 05-08-2005 à 16:37:39
n°681492
glouglou8
Posté le 05-08-2005 à 14:50:35  profilanswer
Bonne question
n°681600
code34
Posté le 05-08-2005 à 16:21:21  profilanswer
oui, très bonne :) car j'ai un dx7590 qui ne me satisfait qu'a moitié, au niveau de la qualité de l'image, de l'expo, et de l'écran, que je vais peut etre échangé contre cet appareil. Et j'aimerais bien savoir ce que ça vaut :D
Message édité par code34 le 05-08-2005 à 16:30:02
n°681973
loranclo
Les cons ça ose tout ! ...
Posté le 06-08-2005 à 01:09:12  profilanswer
pour une première approche, allez voir le topic du C5060. Le C7070 reprend les qualités du précédent, avec un capteur 7 mpx et des améliorations niveaux temps de latence, célérité, mise au point AF, et gestion du bruit.
Mon avis, il doit pas être mauvais :d
en tous les cas, rien à voir avec un dx7590 AMHA...
puis même si l'on dit que cet un compact, je sais que le C5060 fait parfois (pour pas dire souvent) aussi bien qu'un reflex entrée de gamme avec une optique tout aussi entrée de gamme, si ce n'est pas mieux quand on sait se servir des modes manuels et mypic...
Donc que du bonheur si vous prenez ce "petit compact" :D
... C'est même à ça qu'on les reconnaît. - Site photo
n°683104
code34
Posté le 08-08-2005 à 11:26:52  profilanswer
justement, c'est le mode manu qui m'intérresse. Est ce que la mise au  point est manuel ? C'est le truc qui me soule le plus sur le dx7590, l'AF qui est pas franchement précis, et rapide ...
Message édité par code34 le 08-08-2005 à 14:06:42
n°685154
loranclo
Posté le 10-08-2005 à 22:43:53  profilanswer
la mise au point peut être réalisée en manuel.
Ce n'est pas une bague sur l'objectif mais une échelle des distance à ajuster avec les boutons directionnels.
Voilà
n°941352
Ben622
Posté le 02-04-2006 à 12:54:02  profilanswer
Bonjour
J'ai un Olympus C-7070 wide zoom
J'aimerai y ajouté un complément optique
Je vais donc acheté une bague d'adaptation CLA-7
Je prefererai acheté un complément optique générique (comme le Hama Complèment optique tele 2 X )(car  bien moins cher que l'Olympus)
Mais je ne connais pas le diametre de sortie de la bague d'adapation et je ne sait donc pas si je peut mettre ce complément sur la bague
Pouvais vous me dire si c'est possible et si qq est dans le meme cas, si la mise au point ce fait bien avec un générique ?
D'avance merci
n°951454
BillyLeB
Le gras c'est la vie !
Posté le 10-04-2006 à 08:24:13  profilanswer
Bonjour !
Je vends mon C5060 car j'ai acheté un Minolta 7D.
Si quelqu'un est intéressé je vends la sacoche cuir Olympus et le filtre UV Olympus, qui sont compatibles avec le C7070...
Si vous êtes intéressés vous pouvez me MP ;)
  Photo numérique
  Appareil
batterie Olympus c-7070UltraCompact & Zoom 5X, (HP R818?)
vos utilisations possible avec Zoom 70-250 f1:3.5-4.5 SIGMA ?choix entre les mini olympus
Minolta Zoom 4.5-5.6/75-300 AFcanon 350D et Zoom Makinon
CAMEDIA C-1400LUn Canon A510 mais avec un plus gros zoom ?
choix batterie olympuszoom argentique/numérique
Plus de sujets relatifs à : Olympus camedia 7070 wide zoom
