1449 connectés
  ** Options cachées dans bios AMI **
n°523492
Petrus75
Posté le 19-06-2002 à 12:26:16  profilanswer
Voici les options suplementaires (en gras) du bios AMI de ma Gigabyte GA-7VRXP(KT333) que j'obtiens en faisant CTRL + F1 sur la page principale :
Code :
  1. [Bios Features Setup]
  2. Bios Flash Protection     :Auto
  3. Pri Master ARMD Emulated a:Auto
  4. Pri Slave ARDM Emulated as:Auto
  5. Sec Master ARMD Emulated a:Auto
  6. Sec Slave ARMD Emulated as:Auto
  7. 1st Boot Device           :IDE-0
  8. 2nd Boot Device           :Disabled
  9. 3rd Boot Device           :Disabled
  10. Show Fulle Screen Logo    :Disabled
  11. Floppy Drive Seck         :Disabled
  12. Boot Up Num Lock          :On
  13. Password Check            :Setup
  14. S.M.A.R.T. for Hard Disks :Enabled
  15. Interrupt Mode            :APIC
  16. [Chipset Features Setup]
  17. Top Performance           :Disabled
  18. Fast Command              :Ultra
  19. Configure SDRAM by SPD    :Disabled
  20. SDRAM Frequency           :333MHz
  21. SDRAM CAS# Latency        :2.5
  22. Precharge to Active CMD   :3T
  23. Active CMD to Precharge   :6T
  24. Active to CMD             :2T
  25. SDRAM Command Rate        :1T Command
  26. AGP Mode                  :4x
  27. AGP Comp Driving          :Auto
  28. Manual AGP Comp Driving   :DA
  29. AGP Fast Write            :Enabled
  30. AGP Aperture Size         :128MB
  31. AGP Read Synchronization  :Enabled
  32. PCI Delay Transaction     :Disabled
  33. USB Controller            :All USB Port
  34. USB Legacy Support        :All Device
  35. USB Port 64/40 Emulation  :Disabled
  36. ClkSen Spread Spectrum    :Disabled
  37. SB Uplink CMD(4c)         :82
  38. Write Recovery Time(55b0) :2T
  39. DRAM Access Time(66b6)    :2T
  40. Page Active(6bb6)         :Enabled
  41. Burst Refresh(66b5)       :Enabled
  42. PCI Master Read Buf(70b2) :Enabled
  43. Probe Next Tag State(94b6):Enabled
  44. P2C Pipeline(9Eb0)        :Enabled
  45. MD AD 1T(9Fb7)            :Disabled
  46. MAA/MAB Selsetion(RxBF)   :8Eh
  47. DRAM Drive Strenght       :Auto
  48. Reg(F0)                   :00
  49. (Rx6C 7:6)                :01
Savez vous a quoi servent tous les derniers parametres?
Peut etre que tous les bios AMI ont des choses a devoiler, essayez donc sur votre carte :)
n°523507
Oxygen3
Tears from the moon
Posté le 19-06-2002 à 12:38:38  profilanswer
ca marche sur les autres ? :D
Metro-PoleRéseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°523510
UnlesseD
qui ne dit mot, consent
Posté le 19-06-2002 à 12:39:30  profilanswer
Hr a écrit a écrit :
Oh, un cheat code !
Il ya les les vies infinies ? [:ddr555]
:ange:
n°523535
T@nker-xXx
Overclocker retraité
Posté le 19-06-2002 à 13:09:58  profilanswer
ca existe pas pour mon asus a bios award ??
pace ke g plein d'option mankantes par rapport aux autre asus comme moi :(
n°523737
Petrus75
Posté le 19-06-2002 à 15:20:28  profilanswer
"Comme moi" ca veut dire du meme model?
Si c'est ca tu n'as pas la meme version de bios, voir de PCB.
Sinon, demande a ceux qui ont la meme carte.
n°523911
Petrus75
Posté le 19-06-2002 à 18:46:21  profilanswer
Alors, personne ne peut m'expliquer ces parametres?
:bounce:
n°552321
vanessam
Posté le 12-07-2002 à 20:44:09  profilanswer
slt,
jai la meme carte que toi, mais personne pour m'aider sur celle ci !
J' aimerais bien savoir a quoi servent ces machins surtout qu' ils n' apparaissent pas dans le manuel
n°554505
Petrus75
Posté le 15-07-2002 à 11:35:29  profilanswer
Desole j'en sais pas plus, m'y interesse pas trop finalement.
En fait j'ai charge le bios optimized, et ca change du coup tous ces parametres.
Dans le dernier bios ils ont retire celles concernant ARMD Emulated
nouveau bios pour p4b266 - 1007 final/asus update v3.30.04Dernier bios bien pour la Epox 8KHA+
Probleme avec mon bios !ya t-il des bios mod pour abit kr7a-raid ??
quel bios le mieux pour la bd7???Meilleur bios pour KT7-A
flasher le bios d'une MSI K7T PRO ?Kel bonne CM pr o/c Athlon ? haut Vcore, VDDR, mods, plein d'options..
Transformer sa Ti 4400 en Ti4600 via le bios?Bios
Plus de sujets relatifs à : ** Options cachées dans bios AMI **
