1786 connectés
[workblog]mountain mod ufo
n°2197505
ambroisec
Posté le 05-03-2012 à 16:23:49  profilanswer
voila mon mod quasi terminé encore quelques regalges et affinements oc
details de la config:
boitier:mountain mod ascension black mirror
processeur:intel i7 2600k
carte mere:asus maximus 4 extreme
ram:16go corsair dominator
gpu:quad sli gtx 590
alim:enermax 1250w
dd:ssd revodrive x2 100go+ vertex3 100go+ vertex 2 120go+3 *2to samsung
watercooling:4 rad slim 360 xspc pompe; laing d5 + top;reservoir baie xspc
WaterBlock CPU EK-SUPREME HF FULL NICKEL,waterblock gpu ek +backplate noir acetal
embouts bitspower 13mn,tuyau 13/19 tygon blanc
ecran:tri ecran 3d vion surround acer
http://img543.imageshack.us/img543/975/1kjpu.jpg
http://img818.imageshack.us/img818/4012/6n911.jpg
http://img813.imageshack.us/img813/4016/41e7j.jpg
http://img684.imageshack.us/img684/5250/cn92o.jpg
http://img525.imageshack.us/img525/1212/ddwhx.jpg
http://img99.imageshack.us/img99/9989/dit9t.jpg
http://img201.imageshack.us/img201/7788/gexaf.jpg
http://img210.imageshack.us/img210/7201/gigzm.jpg
http://img577.imageshack.us/img577/2580/goqhq.jpg
http://img585.imageshack.us/img585/5159/hgzzu.jpg
http://img12.imageshack.us/img12/687/hyknv.jpg
http://img171.imageshack.us/img171/713/i3bsg.jpg
http://img708.imageshack.us/img708/1893/img1718q.jpg
http://img4.imageshack.us/img4/34/img1719l.jpg
http://img35.imageshack.us/img35/9537/img1720t.jpg
http://img705.imageshack.us/img705/7964/img1721dv.jpg
http://img577.imageshack.us/img577/6492/img1740j.jpg
http://img402.imageshack.us/img402/5778/img2005ka.jpg
http://img594.imageshack.us/img594/3685/img2006j.jpg
http://img585.imageshack.us/img585/4907/img2007u.jpg
http://img17.imageshack.us/img17/7633/img2008ha.jpg
http://img802.imageshack.us/img802/1509/img2115d.jpg
http://img855.imageshack.us/img855/1011/img2116k.jpg
http://img444.imageshack.us/img444/936/img2117qy.jpg
http://img842.imageshack.us/img842/3189/img2118ux.jpg
http://img405.imageshack.us/img405/3558/img2120yi.jpg
http://img18.imageshack.us/img18/6209/img2121aq.jpg
http://img841.imageshack.us/img841/3903/img2123uh.jpg
http://img821.imageshack.us/img821/2484/img2124qe.jpg
http://img141.imageshack.us/img141/3562/img2125d.jpg
http://img837.imageshack.us/img837/5013/jgkw9.jpg
http://img836.imageshack.us/img836/2395/jsl7y.jpg
http://img26.imageshack.us/img26/5973/mlsot.jpg
http://img3.imageshack.us/img3/1066/ncv3l.jpg
http://img585.imageshack.us/img585/3356/otnig.jpg
http://img856.imageshack.us/img856/3964/pzq7s.jpg
http://img813.imageshack.us/img813/6310/qrx3h.jpg
http://img190.imageshack.us/img190/9536/r7nyz.jpg
http://img576.imageshack.us/img576/1293/sa2hi.jpg
http://img192.imageshack.us/img192/4879/t8k9v.jpg
http://img191.imageshack.us/img191/6313/tjrlu.jpg
http://img138.imageshack.us/img138/1034/wi6wj.jpg
http://img21.imageshack.us/img21/2640/xb7jb.jpg
http://img812.imageshack.us/img812/5646/zdrfz.jpg
http://img99.imageshack.us/img99/2876/zmj9s.jpg
Message édité par ambroisec le 05-03-2012 à 17:03:36
n°2197507
Bynaris
Posté le 05-03-2012 à 16:33:04  profilanswer
Sympa tout ça mais des photos plus grandes ne seraient pas du luxe.
n°2197519
ambroisec
Posté le 05-03-2012 à 17:04:02  profilanswer
voila qui est fait
n°2197526
Bynaris
Posté le 05-03-2012 à 17:19:14  profilanswer
Beaucoup mieux.
C'est encore plus sympa avec des photos de bonne tailles.
Très belle intégration.
n°2197537
ambroisec
Posté le 05-03-2012 à 17:52:45  profilanswer
par contre petite question je trouve mes températures un peu haute surtout que je n ai rien oc
en idle ca irait encore a peu pres mes gpu sont a  40-45 et full 60-70
et le cpu en idle 35-40 et full monte assez haut jusqu a 60-70 et sous bf3 apres une heure de jeux le cpu s est coupé atteignant 90 degre
tres etrange
des idées ?
n°2197543
Bynaris
Posté le 05-03-2012 à 17:59:04  profilanswer
Tu as un SLI de 590 je te rappelle. Donc 4GPU.
Les 17 chauffent également pas mal.
Sinon fait les vérification standards (pâte thermique, waterblock ...).
Si tu n'as pas peur du bruit tu peux mettre touts tes radiateur en push/pull.
n°2197545
thegyufi
Posté le 05-03-2012 à 18:04:02  profilanswer
:ouch: la taille !
Ta du déposer un permis de construire à la mairie ?!
Très belle intégration en tout cas  :sol:
G5-yufi - Apple Cube
n°2197548
ambroisec
Posté le 05-03-2012 à 18:11:08  profilanswer
je vais refaire la pate de mon cpu deja pour voir
etsinon je croisqueje vais rajouter un rad 120 juste apres mes gpu pour aller alimenter le cpu ou l eau n arrive pas trop a refroidir entre les deux car il est vrai les 4 gpu chauffent quand meme pas mal
n°2197552
Bynaris
Posté le 05-03-2012 à 18:17:37  profilanswer
Faire deux circuit pourrait aussi aidé, mais il faut les moyens (quoi que juste une pompe et de nouveaux tuyaux).
n°2197554
ambroisec
Posté le 05-03-2012 à 18:19:44  profilanswer
j y ai pensé aussi
n°2197558
Bynaris
Posté le 05-03-2012 à 18:24:19  profilanswer
Vu qu’apparemment c'est processeur qui souffre à cause de tes cartes graphiques et que les températures de ces dernières sont acceptables, je crois que c'est la meilleure solution.
[Workblog]FF7 par Yareah-08/02/13 Gainage encore.....[Workblog] Fractal Black Mirror > nettoyage printemps <
[WorkBlog] Petite boite HM Mini-ITX (assemblage/peinture)[workblog] Projet N1 Darkblue {28/08 nouveau shooting}
[WorkBlog] Mod 800D Silver[workblog] Elysium acide MAJ 02/05
[Workblog]TJ-11 & The Mass effect Mod... 98%[▀▄▀▄▀rkBlg] White Mountain Mods P24 - MAJ en cours...
[Workblog] MM H2gO, nouvelles photos en pages une !
Plus de sujets relatifs à : [workblog]mountain mod ufo
