Reprise du message précédent :http://www.abload.de/img/img_6696w2uih.jpg http://www.abload.de/img/img_6700viuew.jpg http://www.abload.de/img/img_6706cxuai.jpg http://www.abload.de/img/img_6770ier9n.jpg http://www.abload.de/img/img_6769sgqwt.jpg http://www.abload.de/img/img_6739hiovp.jpg http://www.abload.de/img/img_6744yvoh4.jpg http://www.abload.de/img/img_67635irge.jpg http://www.abload.de/img/img_6764k3osn.jpg http://www.abload.de/img/img_6749e1pou.jpg http://www.abload.de/img/img_6750i1qld.jpg http://www.abload.de/img/img_6752vwpvv.jpg http://www.abload.de/img/img_67564jqol.jpg http://www.abload.de/img/img_6757lroqg.jpg http://www.abload.de/img/img_6759s3qd6.jpg http://www.abload.de/img/img_67609foub.jpg
very nice collection, the banchetto 101 is very beautiful
Yes indeed, it´s a grrrrreaaat benchtable !
Fractal Design Arc Mini Case ASRock Z77E-ITX Kingston HyperX DIMM Kit 16GB PC3L-17066U CL11 (DDR3-2133) (KHX21C11T1BK2/16X) Kingston HyperX 3K SSD 240GB Intel Core i5-3450, @ 4x 3.7 GHz Cougar GX G600 600W PSU ATX 2.3 Swiftech Apogee Drive II Swiftech ⅜” x ⅝” Lok-Seal™ Compression Fitting Swiftech Helix 120 Fans Aquacomputer Airplex Pro 240 Radiator Alphacool Cape Corp AGB2 Black Rev. 2 Reservoir XSPC ⅜” x ⅝” (16/10mm) Tubing
Worldpremiere
One more time : very beautiful picture. (The waterblock is amazing !)
Oui, one of the best block for the GTX680 series
Many thanks to Sapphire !
Welcome to HFR Mr Bundymania
Thanks and visit my Facebook Page as well for more pictures and other stuff http://www.facebook.com/pages/Bund [...] 7709912606
Here you can find more pics and infos: http://www.mcool.de/referenzen/index.php
Very interesting this reservoir (tank ?)... I think I'll change mine. Are you craft the grid ?
It´s not my sys. , i posted it to show the res. in action
drap
BTW: Mcool.de is willing to send those nice reservoirs europe wide. He can make versions for 120mm, 140mm and 2x120mm Fan mounting places
which fans are the white ones ?
Those are the brandnew Noiseblocker ELoop Fans, great as case fan or radiator usage http://www.noiseblocker.de/eLoop120.php
For an user who look for silence, do you think they are better than xl1 ?
Yes !
An other question, I think you know that some fans aren't very good at the horizontal, Do you notice something in this position ?
A User reported some motor noise in pull config. I can´t hear this with my fans, just the air noise. You can find more infos about the ELoop Fans here: http://www.overclock.net/t/1289723 [...] eller-fans
