367 connectés
  Air Cooling
  [Topic Unique] Thermaltake RamOrb : refroidir la RAM !
n°1824182
Fssabbagh
Satsui no Hado
Posté le 03-12-2008 à 15:09:27  profilanswer
Salut tout le monde et bienvenue sur le topic unique dédié au RamOrb, ventirad destiné au refroidissement de votre RAM.
Caractéristiques
    *  Orb series inspired memory cooler with single channel heatpipe cooling architecture
    * Superb thermal module, 5cm fan with copper heatpipe penetrating copper fins, allows for
      extreme thermal conductivity
    * Angle adjustable design to maximize mechanical compatibility
    * Aluminum extruded heat spreader provides additional heat dissipating surface area
Heatsink Dimension       155(L) x 17(W) x 105(H) mm
Heatsink Material
Heat Spreader     Aluminum
Thermal Module
6mm Heatpipe & Copper Fin
Fan Dimension     50 x 50 x 10 mm
Fan Speed     4500 RPM
LED Fan     ----
Max. Air Flow     8.18 CFM
Max. Air Pressure     1.67 mmH2O
Noise Level     20 dBA
Power Connector     4 Pins
Rated Voltage     12 V
Started Voltage     8 V
Rated Current     ----
Power Input     ----
MTBF     50,000 Hrs
Compatibility     DDR, DDR2 RAM
Weight     136 g
Déballage avec photos
la boîte contenant le matos :
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_01.JPG
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_02.JPG
Déballage :
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_05.JPG
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_07.JPG
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_13.JPG
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_04.JPG
Messatsu !
n°1824185
Fssabbagh
Satsui no Hado
Posté le 03-12-2008 à 15:13:01  profilanswer
Installation
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_06.JPG
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_08.JPG
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_09.JPG
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_10.JPG
Intégration dans le boîtier :
http://www.techwarelabs.com/reviews/cooling/thermaltake_ramorb/images/fullsize/RamORB_15.JPG
Platforme de test :
Processor
Intel - Q6600 2.4 GHz Overclocked to 3.15 GHz
Motherboard
XFX 680i LT
RAM
Kingston KVR800D2N5/1G
PSU
Kingwin - MACH 1 700 W
CPU Cooler
Thermaltake Big Water SE
HDD
Seagate - 7200.11 1.5 TB
Résultats :
température obtenue sans le RamOrb : 38°
température avec le RamOrb : 29°
Messatsu !
n°1824187
dave3810
E=MC² Matiere <=> Energie
Posté le 03-12-2008 à 15:15:56  profilanswer
[:drap]
c est le dissi stock de certains kits ddr3, mais je savais pas que c etait un dissi TT... :jap:
"°°°A LIRE°°° °°°MetaTopic Overclocking°°°"   "°°°Topics VoltMod HD48xx/Overclock QuadCore i7°°°"
n°1824189
Fssabbagh
Satsui no Hado
Posté le 03-12-2008 à 15:16:50  profilanswer
Thermaltake ne fait que de mauvais ventirads
Messatsu !
n°1824192
dave3810
Posté le 03-12-2008 à 15:21:48  profilanswer
http://www.materiel.net/ctl/PC_de_ [...] 0_GT1.html
sur les gskill par exemple...
pour la DDR3 ca doit etre pas mal, pour les puces qui chquffent et pour oc...
par contre deux rettes avec ce dissi ne se genent pas entre elles?
Message édité par dave3810 le 03-12-2008 à 15:23:12
n°1824197
Fssabbagh
Satsui no Hado
Posté le 03-12-2008 à 15:39:55  profilanswer
je ne crois pas, ça frôle mais sans toucher. Sinon d'autres tests :
http://www.thinkcomputers.org/inde [...] ews&id=879
http://www.tweaktown.com/reviews/1 [...] index.html
http://www.rbmods.com/Articles/The [...] morb/1.php
edit : d'après le dernier test c'est bien silencieux
Message édité par Fssabbagh le 03-12-2008 à 15:40:33
Messatsu !
n°1824199
dave3810
Posté le 03-12-2008 à 15:51:28  profilanswer
The fan on the RamOrb is surprisingly silent, no need to slow it down by a fan controller or 5v adapter.
on peut meme orienter le ventirad, position verticale et horizontale...
pas top avec les mobos amd et leur slots ram d apres l article, ca passe pas...
Message édité par dave3810 le 03-12-2008 à 15:52:01
n°1824200
Fssabbagh
Satsui no Hado
Posté le 03-12-2008 à 15:55:30  profilanswer
ok mais pour intel ça passe :ange:
Messatsu !
n°1824206
dave3810
Posté le 03-12-2008 à 15:59:41  profilanswer
I guess that the only downside I can think of is the fact that it probably will not work on an AMD motherboard with the memory in adjacent slots. I hope that AMD eventually changes the memory slot configuration on their boards, there have been a few times lately that I would have liked to use some OCZ ReaperX on a couple of AMD boards, but it just won't work.
  Air Cooling
[Topic Unique]Thermaltake TMG IA1 : la performance selon Thermaltake[Topic Unique] Thermolab Baram
Fréquence RAM d'origine : est-ce que je peux monter ?[Topic Unique] Powercolor 4870 PCS+ Silencieuse S2
HELP : Impossible de modifier la fréquence de la RAM[Topic Unique] OC sur ASUS Rampage Formula (X48)
Refroidir un E6400[Topic Unique] Voltmods -[SOFTMOD DES 4870/4890/GTX200 VIA RIVATUNER]-
THERMALTAKE Aqua RX UFO CL-W0092
Plus de sujets relatifs à : [Topic Unique] Thermaltake RamOrb : refroidir la RAM !
Hit-Parade
