353 connectés
Quels sont les avantages du Noctua NH-U12 P qui sont les plus importants pour vous ? (2 choix max)
Sondage à 2 choix possibles.
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  41  42  43  44  45  46
[Topic Unique] Noctua NH-U12P: NH-U12+NF P12/NH-U12DO/U9DX
n°2158248
Charles K
Posté le 26-09-2011 à 15:21:26  profilanswer
J'ai mail noctua pour avoir plus d'infos sur le ventirad low profile présenté au computex
question :
Hi,
I am a member of Hardware.fr forum and I as well as other members would like to have some more info on one of your product to come.
I'm very interested in the low profile cooler you showed at computex 2011 (this one to be clear : http://www.noctua.at/images/comput [...] rofile.jpg )  and I would like to know if there is a approximate date of availability.
I also would like to know if it will leave a pci-express clearance with mini-itx boards on which the pci-express port is very close to the socket, like the h67 ones for example. In that case it will be a perfect fit in cases where the psu is right above the motherboard like in some Silverstone's and a lot of Lian Li's, with the 92 mm fan blowing towards the psu.
réponse :
Dear Mr. K,
thanks for contacting Noctua and for your interest in our products.
I'm sorry but please understand that we can't give you a detailed information when this product will be launched. The only thing I can tell you right now is that it is not far away.
Regarding your second question, it will depend on the mainboard's design if memory slots and/or the PCI-E slot are blocked.
Bref, rien de bien concret  :sleep:
Message édité par Charles K le 26-09-2011 à 15:21:33
Workblogs : ~ Cube itx ~  ~ NAS mini-itx ~   ~ Tour mini-itx ~   ~ Boitier m-atx en bois massif ~
n°2159252
bestial-wa​rlust
Posté le 30-09-2011 à 20:23:53  profilanswer
J'ai finalement reçus mon kit pour changer l'orientation du ventirad en le mettant a la verticale
ils sont cool chez Noctua , le 1ier kit qu'ils m'ont envoyé s'est perdus et il m'en ont réexpédie un deuxième promptement
le truc pas cool c'est ma carte mère qui est morte entre temps [:fegafobobos:2]
du coup pour l'instant je ne sais pas si ça améliore quoi que ce soit ce kit  [:hahaguy]
n°2163554
BEBEROM4Ev​er
Anti-troll par nature
Posté le 19-10-2011 à 20:15:43  profilanswer
Bonjour à tous,
heureux possesseur d'un Noctua NH-U12P SE2 j'aimerais savoir si vous préconisait un montage avec les ventilos vers l'arrière ou vers le haut du boitier ?
Pour l'instant je les ai monté pour que le flux d'air donne à l'arrière du boitier mais je vais changer de tour et je me demandais si vers le haut ça ne serait pas mieux (sachant que la tour à une évacuation vers le haut bien sûr, épaulé par un 230mm)
Merci :)
i7-2600K@4,8 GHz - SLI GTX 560 Ti 1 Go
n°2165507
chassonj
BF3: TheJeje_76
Posté le 26-10-2011 à 09:44:06  profilanswer
je dis peut être une bêtise mais tu vas directement aspiré la chaleur de tes CG en positionnant le noctua comme cela.
Du coup la T° du proc va augmenté un peu...
Origin: TheJeje_76 // Steam: TheJeje
n°2166714
El-Gato
jambe
Posté le 30-10-2011 à 17:28:21  profilanswer
Vous savez où on peut acheter un kit de fixation ? Need urgemment :/
Ca devrait être inscrit en première page ça :o
edit : houra j'ai trouvé : http://www.ldlc.com/fiche/PB00094237.html
J'avoue j'avais pas cherché longtemps mais ça m'a pris la tête :o
Message édité par El-Gato le 30-10-2011 à 17:35:24
•• Feed Back ••
n°2166877
Charles K
Posté le 31-10-2011 à 10:01:41  profilanswer
dans quelle urgence ? personnellement ça a mis 4 jour à arriver gratuitement de chez noctua pour moi
n°2167392
starlette2​7
Posté le 02-11-2011 à 10:27:20  profilanswer
j ai commandée un U12P
Quel est le meilleur montage ? ventilo qui souffle vers l'arriere du boitier ou bien vers le haut du boitier?
n°2167396
houckaye
Wouff
Posté le 02-11-2011 à 10:34:13  profilanswer
Je penses que c'est mieux vers l'arrière du PC si tu as une évacuation à l'arrière.
Sur le site et/ou dans le mode d'emploi fournit, il aborde le sujet.
n°2167405
starlette2​7
Posté le 02-11-2011 à 11:28:36  profilanswer
Merci.
y a bien moyen de le monter dans ce sens?car j ai lu qu on ne peut l'installer que dans un seul sens :??:
autre question: est ce que le poid du Noctua ne nuit pas à la CM? :??:
derniere question: comment bien appliquer la pate thermique fournit avec le Noctua?
Message édité par starlette27 le 02-11-2011 à 11:37:27
n°2167410
houckaye
Wouff
Posté le 02-11-2011 à 11:49:44  profilanswer
Tu as toutes les réponses (ou presque) au lien suivant
http://www.noctua.at/main.php?show [...] ts_id=31#3
Pour la pâte, je mets un rien (je laisse sortir 3mm de pâte) au centre et j'applique le radiateur dessus.
Eventuellement, je le retire histoire de voir si la surface avec pâte est raisonnable. Mais j'en mets le moins possible
n°2167422
hametsu
Posté le 02-11-2011 à 13:03:44  profilanswer
Vers l'arrière, tu ne dois pas négliger qu'il refroidit le cpu avec l'air frais qui lui arrive par l'avant du boitier. Dans l'autre sens, en tout cas pour ma part, ça serait l'air chaud de la carte graphique qui lui serait envoyé, donc, peu recommandable !
n°2182473
the_bhaal
PSN : me demander...
Posté le 04-01-2012 à 21:01:46  profilanswer
Ayant commandé une nouvelle config à base d'i5 2500K et de P8P67, il m'a fallu commandé un kit d'upgrade pour y adapter mon Noctua NH-U12. Celui-ci : http://www.rueducommerce.fr/Compos [...] 9&option=1
Pouvez-vous me confirmer que c'est bien le bon ? Car le Intel LGA1155 n'est absolument pas précisé et pourtant la référence "Noctua NM-I3", soit le Kit qui comprend logiquement ce qu'il faut pour ce chipset (LGA1155).
Merci ! ;)
Topic Ventes - Bhaal - Psy
n°2183465
Pichi Pich​i Gal
Posté le 08-01-2012 à 14:20:56  profilanswer
Je suis en train de monter le Noctua NH-12UP SE2, et je bloque au niveau des ventilo à mettre sur le dissipateur, il y a des tiges en métal à fixer, mais même avec la notice je ne comprend pas comment les mettre, j'ai essayé les tutoriels vidéos sur YouTube, mais manque de pot, ce passage est toujour sauté.
@The_bhaal : Ne t'inquiète pas pour les ventirad le 1156 et 1155 sont compatible entre eux, donc même si le 1155 n'est pas précisé, tant que ça prend en charge le 1156, c'est bon.
n°2183705
the_bhaal
Posté le 09-01-2012 à 15:40:59  profilanswer
Super ! Merci Pichi Pichi Gal. :)
n°2183778
houckaye
Wouff
Posté le 09-01-2012 à 20:02:00  profilanswer
Si c'est toujours d'actualité,
ce n'est pas compliqué du tout, tu mets la tige dans la gorge du radiateur en positionnant les embouts avec leurs pliures vers le centre. Ces pliures se caleront dans le trou des vis des ventilos ?
http://www.easycom.com.ua/data/cooler/1007012306/img/25.jpg
As-tu été voir la doc sur le site ?
Message édité par houckaye le 09-01-2012 à 20:06:17
n°2185367
VPJ2M
Boulet inside
Posté le 18-01-2012 à 07:04:18  profilanswer
Pour ma part, nouveau boitier cooler master RC430 et Notcua U12P SE2, et bien montage flux vers le haut du boitier est plus performant que vers l'arriere, et pas qu'un peu, facile 5 à 6° en idle
FeedBack
n°2189871
mydriaze
Posté le 05-02-2012 à 18:40:40  profilanswer
Je vais avoir d'ici peu une 98z68 d'asus, et je souhaite refroidir l'i5 2500k avec ce Noctua. Savez vous si cela rentre dans un Antec Sonata 3, par hasard? Ca m’inquiète...
Message édité par mydriaze le 05-02-2012 à 18:40:55
,.-~*´¨¯¨`*·~-.¸-(Imogen Poots si tu lis HFR contact moi par MP pour faire des bébés)-,.-~*´¨¯¨`*·~-.¸
n°2197069
tangozoulo​u0
Posté le 03-03-2012 à 21:59:21  profilanswer
mieux vaut tard que jamais
 j'ai un SE2  dans mon Antec nsk3480 (bon ça chauffe pas mal mais c'est correct ) , donc j'imagine qu'un boitier plus gros ça ira ;)
Aux US, ils ont Avatar... En France, on a René la Taupe...
n°2197202
darkcross
Posté le 04-03-2012 à 10:52:33  profilanswer
Mon petit fed, je viens d'acheter ce ventirad pour mon 2500K.
Sur une P8P67 avec des rijaws, ca passe, tres limite mais ca passe :)
Mon boitier est un Z9+, avec 3 Noctua NF-S12B @6v.
Resultats :
Avec un seul ventilo @9v, mon processeur est à 33° en pleine charge ! J'etais à 60° environ avec mon ancien Freezer 13 Pro.
Ca me laisse donc une marge pour pouvoir OC tranquillement ;)
Niveau ventilation c'est vraiment du tres bon, je trouve par contre qu'en 12v ca reste assez bruyant (j'avais des quiet fan Zalman avant). L'interet est justement de pouvoir les baisser sans perdre trop en efficacité.
Bref du tout bon !!
n°2198847
iosys99
Authentique aigri
Posté le 10-03-2012 à 14:50:26  profilanswer
Qqun sait ou peut on acheter le nouveau rad NH-L12 ?
http://img192.imageshack.us/img192/996/noctuanh123600x352.jpg
Message édité par iosys99 le 10-03-2012 à 14:51:34
On n'aime que le paraitre et l'hypocrisie mais pas la vérité / Ce que tu ne sais pas ne te fais pas mal.
n°2204054
BEBEROM4Ev​er
Posté le 29-03-2012 à 15:32:00  profilanswer
Merci pour vos réponses, j'ai remonté mon Noctua "vers l'arrière"
n°2204150
iosys99
Authentique aigri
Posté le 29-03-2012 à 20:14:44  profilanswer
Pr info le NH-L12 est dispo
n°2217757
Korgall
Posté le 14-05-2012 à 11:58:05  profilanswer
Je compte monter ce ventirad sur mon 2500K.
Mon problème est que j'ai acheté des Corsair vengeance en RAM, est-ce que ça passera ou pas ?
Je n'arrive pas à me faire une idée via cette photo : http://www.hardware.fr/medias/phot [...] 033236.jpg
Merci d'avance.
n°2217787
suzumebach​i
Powered by i7 2600k
Posté le 14-05-2012 à 13:25:55  profilanswer
Mes G.Skill touchent le ventilo avec le bout du rad donc des corsair qui ont des dissipateur plus haut que les g.skill ça risque d'être chaud.
i7 2600k // Maximus V GENE // HD5850
n°2217800
Korgall
Posté le 14-05-2012 à 13:40:14  profilanswer
Mais le ventilo ne semble pas gêner le deuxième emplacement ou alors c'est à cause de l'angle de la prise de la photo ?
n°2217807
suzumebach​i
Powered by i7 2600k
Posté le 14-05-2012 à 13:53:25  profilanswer
ça dépend de la position des slots sur ta carte mère. Sur mes Asus il n'y a qu'un slot sous le ventilo.
n°2217812
Korgall
Posté le 14-05-2012 à 13:59:56  profilanswer
S'il n'y a qu'un slot sous le ventilo, pourquoi ta barrette touche ? O_o
n°2217816
suzumebach​i
Powered by i7 2600k
Posté le 14-05-2012 à 14:05:04  profilanswer
Parce que j'ai mis volontairement ma barrette en dessous pour pas avoir a partir en mission quand j'ajouterais de la ram.
http://img196.imageshack.us/img196/3905/img0778jt.jpg
http://img138.imageshack.us/img138/8581/captureqvtk.png
Message édité par suzumebachi le 14-05-2012 à 14:11:50
n°2217825
Korgall
Posté le 14-05-2012 à 14:18:33  profilanswer
Ah ok, merci pour ton aide et la photo.
Vu que je compte me contenter de deux barrettes de 4 Go, ça devrait passer si je prend le slot le plus à l'extérieur, même avec des barrettes aussi hautes.
EDIT :
le NH-U12P comme le NH-D14 permettent d'utiliser des barrettes telles que les G.Skill Ripjaws, même si celles utilisant des radiateurs plus imposants telles que les Corsair Vengeance restent à proscrire.
Source : http://www.hardware.fr/focus/44/no [...] b-se2.html
Du coup, je sais plus là :D
Message édité par Korgall le 14-05-2012 à 14:28:34
n°2217837
suzumebach​i
Powered by i7 2600k
Posté le 14-05-2012 à 14:58:20  profilanswer
Bah en gros ils te disent que tu peux utiliser des barrettes comme les G.Skill. Mais que celles qui usent des dissipateurs de grandes taille comme les Corsair Vengeance sont a éviter.
n°2220750
rorogeek
Geek one day, geek everyday !
Posté le 25-05-2012 à 07:17:41  profilanswer
Salut les gars ! Je m'incruste dans votre topic pour une petite question, mais avant ça, j'apporte une petite contribution :
J'ai pour ma part un NH-U12P (pas le SE2, le premier)
J'ai gagné environ 2° en idle (sonde CPU, 2600K a 4,6Ghz 1,35v), et 4° en burn avec la Arctic Cooling MX-2 par rapport à la Arctic Silver 5. OK, l'application de arctic silver datait de 3 jours, donc pas conduction optimale (ils recommandent 200h), mais c'est un des autres avantages de la MX-2 : Elle est efficace à 100% dès l'application, elle est non conductrice, elle sèche moins dans le temps (ils annoncent 8 ans), et elle s'étale mieux (pas besoin de l'étaler d'ailleurs, disposer une mini bille au centre, et des mini mini billes dans les coins, ça marche nickel) ! Au passage, rapport qualité/prix bien plus intéressant sur le tube de 30grammes que sur le petit, tube qui est environ 2x moins cher au gramme que la arctic silver 5... bref, j'ai testé, c'est cool, mais maintenant j'ai mieux, je reviendrai plus jamais en arrière, essayez-la, vous m'en direz des nouvelles ! :D  J'ai aussi fait l'acquisition récente du kit arcti clean, le dissolvant à pate thermique pue, mais ça reste très pratique et bien propre pour les changements de pâte thermique ! Si vous avez l'argent et la motive, hésitez pas à essayer, c'est bien plus propre. ;)
Maintenant ma question : Malgré mes gains qui me laissent penser que ma pate est bien mise, j'ai encore un doute, je trouve que la température monte vraiment d'un gros seuil quand je lance le burn, et quand je l'arrête, idem, elle descend beaucoup...
Par exemple là ça fait 4 minutes que jsuis en burn Aida64, je suis à 61-62°, je coupe le burn, la seconde qui suit je tombe à 43°, et 10 secondes plus tard à 38°, puis ça descend au mini à 33-34. Idem si j'active le burn, ça prend bien 20 bons degrés d'un coup. Pour les cores, c'est exactement le même genre de variations, 20°. Sur le 2500k de ma copine, non OC, sur une P8P67 et le radbox, les variations sont très progressives... J'ai peur que mon CPU ait un mauvais contact entre le die et la première lamelle de contact, je serais rassuré d'avoir vos résultats à vous en OC.
Alors, et vous ?
Plus d'infos :
NH-U12P à 8v environ via rheobus
2600K à 4,6Ghz + Ripjaws X à 2132mhz CL11
Le tout sur une P8Z68 Deluxe, dernier BIOS en date
Température relevée avec Aida sur la sonde CPU, qui est identique à celle relevée par le Ai Suite.
Message édité par rorogeek le 25-05-2012 à 07:19:19
GLHF !
n°2220840
Oryx
Posté le 25-05-2012 à 14:48:34  profilanswer
Même Ventirad que toi et une t° de 30 à 35° suivant la saison sous 900 trm via connecteurs noctua et Vcore < 1.2.
En cas de stress-test je monte dans les mêmes valeurs avec un retour très rapide vers 40° puis progressif (mais court) à t° de base.
Je n'en déduis pas un mauvais montage mais plutôt que le ventirad fait son boulot et que le flux boitier (P180 mais ventilateurs Noctua) est optimal surtout que la t° de la carte graphique est stable => évacuation ok   :D
Dans ton cas c'est encore mieux car on ne dois pas avoir le même Vcore et en burn tu dois envoyer du lourd  ;)
Ta copine travailles "stock" et les radbox suffisent et en plus ils sont en 4 pins pour la gestion => progressif
C2Q 9650 E0 9x333@3000 1,11V / Noctua NH-U12P / 2x4Go KomputerBay Cas5 / P5Q DeLuxe / Asus EAH5770 v2 / Antec P180 / Seven Intégral
n°2220855
rorogeek
Posté le 25-05-2012 à 15:30:36  profilanswer
Merci de ton retour. ^^   Tu as encore ton Q9650 ou bien tu es sur 2600K aussi ?  La carte mère compte aussi pour la sonde CPU si je me trompe pas, c'est elle qui la comporte.  Après si ta température est aussi élevée que moi, mais à 1,2V, soit y'a un pépin dans ton montage (pate thermique ?), soit c'est une question de ventilation de boîtier ! Moi j'ai un Fractal Design R3 avec tous les ventilos prix, rad qui souffle vers le haut, des silentwings sur le dessus, le dessous, et le côté, les fractal à l'avant, et un XL2 sous volté à l'arrière. :)
Je sais bien qu'un rad stock suffit à refroidir un CPU à une temp stock, mais ça suffit pas à combler le désir de silence de mes oreilles surtout !
GLHF !
n°2220875
Oryx
Posté le 25-05-2012 à 17:08:37  profilanswer
Ma signature est à jour, toujours Q9650 et pour un bout de temps encore vu que j'ai changé ma RAM 4x1 en 2x4 Go => 3,6 Ghz si besoin  :sol:
Je ne pense pas avoir un pb de montage car 30° pour un composant dans un air ambiant à 20~25° ...
J'ai un "bon" boitier ET "silencieux" (tous mes ventilos sont en low).
Même mon compartiment DD est à 30° ...
Les T° burn sont nominales, les 4 coeurs à 100% c'est pas non plus du courant et ~60° c'est largement correct vu que c'est stable.
Le Vcore est suffisant pour 3 Ghz, donc n'influe pas (trop) sur les Tmax.
Pour info, ma pâte c'est de la Noctua livré avec le rad.
n°2220876
rorogeek
Posté le 25-05-2012 à 17:11:23  profilanswer
En effet, pour un Q9650, tes temps sont largement correctes ! Ca me rassure quand même déjà pas mal ! Pour être totalement rassuré il me faudra le retour d'un utilisateur 2500K ou 2600k overclocké, sur du Asus. Y'en a un paquet donc je perds pas espoir. ^^
N'empêche que de tels écarts, ça pue la mauvaise conduction thermique interne du processeur.... ://
Message édité par rorogeek le 25-05-2012 à 17:12:07
GLHF !
n°2220896
Oryx
Posté le 25-05-2012 à 18:39:25  profilanswer
Pas sûr ... car quand tu lances ton burn tu dois avoir pas mal de volts qui arrivent au galop et ça doit virer au rouge là-dedans.
Le fait d'avoir un ventirad avec un pas fixe, donc qui ne peux suivre linéairement l'augmentation de t° contrairement à un modèle PWM doit te provoquer cet "engorgement" brusque des calories.
Après, les calories étant réparties dans les ailettes, la pression du noctua permet de ralentir puis de stabiliser la Tmax
Tu pourrais essayer de monter ton burn par palier de 25% tout en suivant tes Vcores pour voir si ça se vérifie ...
... ce n'est que mon (très) humble avis  :sol:
Message édité par Oryx le 25-05-2012 à 18:41:11
n°2220950
rorogeek
Posté le 26-05-2012 à 04:27:04  profilanswer
Oulla, je suis pas d'accord !
Quand tu burn, la tension (les volts) ne bougent pas, elle a même tendance à diminuer si t'as pas de compensation, vu que tu tires du courant !  L'intensité et au final la puissance, oui, forcément ils augmentent... Cela dit, la montée en température, elle, devrait être bien plus linéaire, sinon ça veut dire que la conduction entre l'intérieur et l'extérieur est mauvaise. C'est comme quand tu chauffes une casserolle vide, elle chauffe bien plus vite qu'une casserole pleine.
D'ailleurs je suis avec un ami qui a un 1090T d'AMD, qui a un TDP bien supérieur à mon CPU, même avec OC, et sa température monte et baisse bien plus linéairement que la mienne, et pourtant il a un CPNS9900 de Zalman, supposé être moins bon que le NH-U12P
Pour le PWM, aucun rapport, je parle d'un montée de 20° en 5 secondes, PWM ou pas, ça ne changerait rien.
J'ai pas compris la dernière phrase... Avec l'anti vdrop que j'ai mis, que je sois en burn ou en idle, ma tension CPU est quasi identique.
Message édité par rorogeek le 26-05-2012 à 04:38:28
GLHF !
n°2221027
KraMeR
Posté le 26-05-2012 à 17:37:33  profilanswer
Moi non plus je ne suis pas d'accord ! Avec le C1E et le CEIST d'activé dans le bios, quand le proc est en idle, sa tension d'alimentation est diminuée ainsi que sa fréquence, donc la tension bouge quand tu passes en burn, ce qui contribue également à l'augmentation de la température du CPU. Et l'échauffement rapide est normal, comme çà l'est pour le GPU et bcp de pièces électroniques.
[VDS] Divers (boitier HTPC, mobo 775, C2D, DDR2, connectiques, ...)
n°2221036
rorogeek
Posté le 26-05-2012 à 18:27:49  profilanswer
Evidemment, je parlais du fonctionnement sans ces options d'optimisation d'énergie !
GLHF !
n°2221526
rorogeek
Posté le 29-05-2012 à 00:57:41  profilanswer
Salut à tous !
Quelqu'un pour comparer ses températures avec les miennes sur le rude Linx ou OCCT ?
Config
Fractal Design R3, avec 4 Silentwings 140mm, 2 ventilos fractal 120mm, un ventilo XL2 120mm, le tout à environ 7-9v
2600K @ 4,6Ghz 1.375v
Asus P8Z68 Deluxe
Alim Seasonic-X 850W
Ram G.Skill Ripjaws X 1600Mhz CL7 @ 2133Mhz CL10 @ 1,6v
Rad : Noctua NH-12P @ environ 9v
Idle
http://image.noelshack.com/fichiers/2012/22/1338242310-Idle.png
LinX burn au moment le plus chaud (j'ai remarqué que la temp faisait du yoyo à la fin et au début de chaque "Run", chaque ligne quoi)
http://image.noelshack.com/fichiers/2012/22/1338242095-LinX.png
OCCT Burn (juste pour voir ce qu'est un burn normal supérieur à du jeu, et pour me rassurer)
http://image.noelshack.com/fichiers/2012/22/1338242798-BurnOCCT.png
PS : j'ai attendu que les températures soient stables pendant mini 2-3 minutes pour screener, ça servait à rien de faire durer plus.
Graphe de OCCT après burn pour montrer que la temp bouge pas (elle monte et baisse, mais c'est dû à la puissance du burn qui monte et diminue...)
http://image.noelshack.com/fichiers/2012/22/1338243535-2012-05-29-00h18-Core1.png
GLHF !
n°2221552
suzumebach​i
Powered by i7 2600k
Posté le 29-05-2012 à 09:24:27  profilanswer
Le miens est un peu plus froid sauf qu'il tourne @ 4.6ghz pour 1.32
[Topic Unique] BDD overclocking HD 38x0 : Nouveau Topic P1[Topic Unique] Swiftech H20-220 MAJ au 10/06/08
[Topic Unique] Scythe Ninja 100% cuivre !O/C E4500 @ 3.6Ghz Besoin Avis sur Noctua !!!!
[Topic unique] Votre Température eau[Topic unique] Syndrome-oc Overclocking Compétition 1st Edition
[Topic pas unique] Noctua NH-U12P[Topic Unique] Overclocking 8800GT
Noctua NH-U12F vs Zalman 9500AT
Plus de sujets relatifs à : [Topic Unique] Noctua NH-U12P: NH-U12+NF P12/NH-U12DO/U9DX
Hit-Parade
