iii)copy configuration file "RT2500STA.dat" to /etc/Wireless/RT2500STA/RT2500STA.dat.
Please refer to 3.1) for details.
3.1) Configuration File : RT2500STA.dat
# Copy this file to /etc/Wireless/RT2500STA/RT2500STA.dat
# This file is a binary file and will be read on loading rt2500.o module.
# Use "vi -b RT2500STA.dat" to modify settings according to your need.
# 1.) set NetworkType to "Adhoc" for using Adhoc-mode, otherwise using Infrastructure
# 2.) set Channel to "0" for auto-select on Infrastructure mode
# 3.) set SSID for connecting to your Accss-point.
# 4.) AuthMode can be "OPEN", "SHARED", "WPAPSK", "WPANONE"
# 5.) EncrypType can be "NONE", "WEP", "TKIP", "AES"
# for more information refer to the Readme file.
