1771 connectés
Problème clef wifi
n°1349737
chaosphere​2
Posté le 20-12-2013 à 10:19:05  profilanswer
Je me suis monté un pc qui me sert de seedbox sous XUbuntu 13.10, le problème c'est que ma clef wifi se met à bugger au bout d'un moment, le voyant de la clef s'éteint, et la connexion est perdue.
En fouillant dans les logs j'ai trouvé ca :
/var/log/syslog :
Dec 20 02:04:16 seedbox kernel: [17978.800041] ieee80211 phy11: wlan0: No probe response from AP 4e:86:86:c9:19:d4 after 500ms, disconnecting.
Dec 20 02:04:16 seedbox kernel: [17978.872236] cfg80211: Calling CRDA to update world regulatory domain
Dec 20 02:04:16 seedbox wpa_supplicant[1040]: wlan0: CTRL-EVENT-DISCONNECTED bssid=4e:86:86:c9:19:d4 reason=4
Dec 20 02:04:16 seedbox NetworkManager[857]: <info> (wlan0): supplicant interface state: completed -> disconnected
Dec 20 02:04:17 seedbox NetworkManager[857]: <info> (wlan0): supplicant interface state: disconnected -> scanning
Dec 20 02:04:17 seedbox kernel: [17979.123082] cfg80211: World regulatory domain updated:
Dec 20 02:04:17 seedbox kernel: [17979.123092] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Dec 20 02:04:17 seedbox kernel: [17979.123098] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Dec 20 02:04:17 seedbox kernel: [17979.123103] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Dec 20 02:04:17 seedbox kernel: [17979.123109] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Dec 20 02:04:17 seedbox kernel: [17979.123114] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Dec 20 02:04:17 seedbox kernel: [17979.123119] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Dec 20 02:04:32 seedbox NetworkManager[857]: <warn> (wlan0): link timed out.
Dec 20 02:04:32 seedbox NetworkManager[857]: <info> (wlan0): device state change: activated -> failed (reason 'SSID not found') [100 120 53]
Dec 20 02:04:32 seedbox NetworkManager[857]: <warn> Activation (wlan0) failed for connection 'Chaosphere'
Dec 20 02:04:32 seedbox dbus[719]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Dec 20 02:04:32 seedbox NetworkManager[857]: <info> (wlan0): device state change: failed -> disconnected (reason 'none') [120 30 0]
Dec 20 02:04:32 seedbox NetworkManager[857]: <info> (wlan0): deactivating device (reason 'none') [0]
Dec 20 02:04:32 seedbox whoopsie[918]: offline
Dec 20 02:04:32 seedbox NetworkManager[857]: <info> (wlan0): canceled DHCP transaction, DHCP client pid 3652
Dec 20 02:04:32 seedbox kernel: [17994.413115] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Dec 20 02:04:32 seedbox NetworkManager[857]: <warn> DNS: plugin dnsmasq update failed
Dec 20 02:04:32 seedbox NetworkManager[857]: <info> Removing DNS information from /sbin/resolvconf
Dec 20 02:04:32 seedbox dnsmasq[1066]: configuration des serveurs amonts à partir de DBus
Dec 20 02:04:32 seedbox avahi-daemon[797]: Withdrawing address record for fe80::20f:b5ff:fed5:e803 on wlan0.
Dec 20 02:04:32 seedbox avahi-daemon[797]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::20f:b5ff:fed5:e803.
Dec 20 02:04:32 seedbox avahi-daemon[797]: Interface wlan0.IPv6 no longer relevant for mDNS.
Dec 20 02:04:32 seedbox avahi-daemon[797]: Withdrawing address record for 192.168.0.1 on wlan0.
Dec 20 02:04:32 seedbox avahi-daemon[797]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.1.
Dec 20 02:04:32 seedbox avahi-daemon[797]: Interface wlan0.IPv4 no longer relevant for mDNS.
Dec 20 02:04:32 seedbox dbus[719]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dec 20 02:04:32 seedbox NetworkManager[857]: <info> (wlan0): supplicant interface state: scanning -> disconnected
Je ne sais pas si ca viens de ma clef qui est défectueuse ou si le probleme est logiciel...
Est-ce que quelqu'un aurais une idée svp ?
Merci d'avance
Problème cohabition ubuntu win8ubuntu ne démarre pas a partir d'une clef usb help
Kali linux, sauvegarder les modifications et problème de tailleCarte wifi activée mais wifi toujours indisponible
[RESOLU] Problème avec UnetBootin sur CentOS 6.4Problème de boot avec Grub
problème de configuration de postfixProblème NTP sur Vmware ESXI5
Problème d'importation de BDD Wordpress
Plus de sujets relatifs à : Problème clef wifi
