2748 connectés
  Linux et OS Alternatifs
  Logiciels
  probleme avec lilo
probleme avec lilo
n°698387
mardi_soir
Posté le 26-06-2005 à 16:37:34  profilanswer
bon j'ai des probleme avec lilo > j'ai un 2 disques
 hda1 = windowsme      hda2 = /usr   hdc1 = swap  hdc2 = /  hdc3= /home
lilo sur hdc2 me dit
   1.
      husss:/home/mardi_soir# lilo -v
   2.
      LILO version 22.6.1, Copyright (C) 1992-1998 Werner Almesberger
   3.
      Development beyond version 21 Copyright (C) 1999-2004 John Coffman
   4.
      Released 17-Nov-2004, and compiled at 12:32:32 on May 25 2005
   5.
      Debian GNU/Linux
   6.
   7.
      Reading boot sector from /dev/hdc2
   8.
      Using BITMAP secondary loader
   9.
      Calling map_insert_data
  10.
      Mapping bitmap file /boot/coffee.bmp
  11.
      Calling map_insert_file
  12.
  13.
      Boot image: /boot/vmlinuz-2.4.27.050605
  14.
      Added Lin_img0 *
  15.
  16.
      Boot image: /boot/vmlinuz-2.6.8-2-686
  17.
      Mapping RAM disk /boot/initrd.img-2.6.8-2-686
  18.
      Added Lin_2.6.8img1
  19.
  20.
      Boot other: /dev/hda2, on /dev/hda, loader CHAIN
  21.
      Fatal: First sector of /dev/hda2 doesn't have a valid boot signature
  22.
et voici mon lilo.conf
  1.
      # Generated by liloconfig
   2.
   3.
      # This allows booting from any partition on disks with more than 1024
   4.
      # cylinders.
   5.
      lba32
   6.
   7.
      # Specifies the boot device
   8.
      boot=/dev/hdc2
   9.
  10.
      # Specifies the device that should be mounted as root.
  11.
      # If the special name CURRENT is used, the root device is set to the
  12.
      # device on which the root file system is currently mounted. If the root
  13.
      # has been changed with  -r , the respective device is used. If the
  14.
      # variable ROOT is omitted, the root device setting contained in the
  15.
      # kernel image is used. It can be changed with the rdev program.
  16.
      root=/dev/hdc2
  17.
  18.
      # Bitmap configuration for /boot/coffee.bmp
  19.
      bitmap=/boot/coffee.bmp
  20.
      bmp-colors=12,,11,15,,8
  21.
      bmp-table=385p,100p,1,10
  22.
      bmp-timer=38,2,13,1
  23.
  24.
      # Enables map compaction:
  25.
      # Tries to merge read requests for adjacent sectors into a single
  26.
      # read request. This drastically reduces load time and keeps the map
  27.
      # smaller. Using COMPACT is especially recommended when booting from a
  28.
      # floppy disk.
  29.
      # compact
  30.
  31.
      # Install the specified file as the new boot sector.
  32.
      # LILO supports built in boot sectory, you only need
  33.
      # to specify the type, choose one from 'text', 'menu' or 'bitmap'.
  34.
      # new: install=bmp      old: install=/boot/boot-bmp.b
  35.
      # new: install=text     old: install=/boot/boot-text.b
  36.
      # new: install=menu     old: install=/boot/boot-menu.b or boot.b
  37.
      # default: 'menu' is default, unless you have a bitmap= line
  38.
      # Note: install=bmp must be used to see the bitmap menu.
  39.
      # install=menu
  40.
      install=bmp
  41.
  42.
      # Specifies the number of _tenths_ of a second LILO should
  43.
      # wait before booting the first image.  LILO
  44.
      # doesn't wait if DELAY is omitted or if DELAY is set to zero.
  45.
      # delay=20
  46.
  47.
      # Prompt to use certaing image. If prompt is specified without timeout,
  48.
      # boot will not take place unless you hit RETURN
  49.
      prompt
  50.
      timeout=50
  51.
  52.
      # Specifies the location of the map file. If MAP is
  53.
      # omitted, a file /boot/map is used.
  54.
      map=/boot/map
  55.
  56.
      # Specifies the VGA text mode that should be selected when
  57.
      # booting. The following values are recognized (case is ignored):
  58.
      #   NORMAL  select normal 80x25 text mode.
  59.
      #   EXTENDED  select 80x50 text mode. The word EXTENDED can be
  60.
      #     abbreviated to EXT.
  61.
      #   ASK  stop and ask for user input (at boot time).
  62.
      #   <number>  use the corresponding text mode. A list of available modes
  63.
      #     can be obtained by booting with  vga=ask  and pressing [Enter].
  64.
      vga=normal
  65.
  66.
      # These images were automagically added. You may need to edit something.
  67.
  68.
      image=/boot/vmlinuz-2.4.27.050605
  69.
              label="Lin img0"
  70.
              read-only
  71.
  72.
      image=/boot/vmlinuz-2.6.8-2-686
  73.
              label="Lin 2.6.8img1"
  74.
              initrd=/boot/initrd.img-2.6.8-2-686
  75.
              read-only
  76.
  77.
      # If you have another OS on this machine (say DOS),
  78.
      # you can boot if by uncommenting the following lines
  79.
      # (Of course, change /dev/hda2 to wherever your DOS partition is.)
  80.
      other=/dev/hda2
  81.
         label="MS Windows"
voila merci
n°698393
Mjules
Modérateur
Parle dans le vide
Posté le 26-06-2005 à 16:40:32  profilanswer
hda1 = windowsme
    other=/dev/hda2
     label="MS Windows"
:gratgrat:
Message édité par Mjules le 26-06-2005 à 16:40:37
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°698939
mardi_soir
Posté le 27-06-2005 à 18:31:22  profilanswer
merci beaucoup j'ai vu ca hier j'ai honte ...
pardon pardon
  Logiciels
  probleme avec lilo
Mandrake 10.1 - probleme Lilo.confLILO: probleme de démarrage windows
Probleme avec LILO et windowsProbleme pour réinstaller lilo
Problème de boot LILO Mandrake Community 10.1Problème avec lilo: Fatal: stat /dev/hda
Probleme pour demarrer windows xp avec lilo?probleme avec lilo
Windows inaccessible... problème grub-lilo -> boot win hsProbleme avec lilo // Resolu par Mjules
Plus de sujets relatifs à : probleme avec lilo
