1638 connectés
  Linux et OS Alternatifs
  Installation
  [Ubuntu] Quelles sources utilisez-vous ?
n°682844
Zolex2
Posté le 25-05-2005 à 10:01:25  profilanswer
Je viens d'installer Ubuntu (kbuntu plus précisement) et j'ai utilisé le sources.list que j'ai trouvé sur le site ubuntuguide.org :
Code :
  1. ## Uncomment the following two lines to fetch updated software from the network
  2. deb http://us.archive.ubuntu.com/ubuntu hoary main restricted
  3. deb-src http://us.archive.ubuntu.com/ubuntu hoary main restricted
  4. ## Uncomment the following two lines to fetch major bug fix updates produced
  5. ## after the final release of the distribution.
  6. deb http://us.archive.ubuntu.com/ubuntu hoary-updates main restricted
  7. deb-src http://us.archive.ubuntu.com/ubuntu hoary-updates main restricted
  8. ## Uncomment the following two lines to add software from the 'universe'
  9. ## repository.
  10. ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
  11. ## team, and may not be under a free licence. Please satisfy yourself as to
  12. ## your rights to use the software. Also, please note that software in
  13. ## universe WILL NOT receive any review or updates from the Ubuntu security
  14. ## team.
  15. deb http://us.archive.ubuntu.com/ubuntu hoary universe
  16. deb-src http://us.archive.ubuntu.com/ubuntu hoary universe
  17. deb http://security.ubuntu.com/ubuntu hoary-security main restricted
  18. deb-src http://security.ubuntu.com/ubuntu hoary-security main restricted
  19. deb http://security.ubuntu.com/ubuntu hoary-security universe
  20. deb-src http://security.ubuntu.com/ubuntu hoary-security universe
  21. deb http://archive.ubuntu.com/ubuntu hoary multiverse
  22. deb-src http://archive.ubuntu.com/ubuntu hoary multiverse
  23. deb ftp://ftp.nerim.net/debian-marillat stable main
  24. deb ftp://ftp.nerim.net/debian-marillat unstable main
  25. deb ftp://ftp.nerim.net/debian-marillat testing main
Je ne sais pas si c'est normal, mais avec ces sources, pas mal de soft sont un peu dépassés (Firefox est en version 1.0.2 au lieu de 1.0.4).
Pouvez-vous me donner un exemple des sources que vous utilisez, en sachant que j'ai besoin de Firefox + Plugin java et flash, Evolution, codec audio/video, ... + qques autres petits soft sans grande importance ?
Merci d'avance.
n°682846
newportabl​e
Laboris gloria Ludi
Posté le 25-05-2005 à 10:04:14  profilanswer
il faut que tu rajoute les backports, elles sont dans le guide quelques ligne après celle des dépots
n°682847
newportabl​e
Laboris gloria Ludi
Posté le 25-05-2005 à 10:05:16  profilanswer
deb http://backports.ubuntuforums.org/ubp hoary-backports main universe multiverse restricted
deb http://backports.ubuntuforums.org/ubp hoary-extras main universe multiverse restricted
Ca plus tes sources c'est suffisant pour installer tout ce que tu veux
Message édité par newportable le 25-05-2005 à 10:06:10
n°682899
Zolex2
Posté le 25-05-2005 à 11:31:02  profilanswer
Merci beaucoup pour ta réponse.
Si je te suis bien, je dois utiliser les sources du guide et ajouter simplement les 2 backports ?
Est-ce grace aux backport que j'aurai les dernières versions de me soft ?
Ne vais-je pas avoir de conflit (Firefox 1.0.2 + Firefox 1.0.4) ?
n°682925
newportabl​e
Laboris gloria Ludi
Posté le 25-05-2005 à 12:40:15  profilanswer
ouai ouai tu les met tout bêtement à la fin de ta liste de source et tu fais une mise à jour normal et le tour est joué
n°683096
Zolex2
Posté le 25-05-2005 à 16:30:15  profilanswer
Merci beaucoup
  Installation
Se connecter à un réseau IPSEC depuis ubuntuMon disque dur n'est plus reconnu !!! (ubuntu)
(Ubuntu) Probleme résolution de l'ecrangdesklet ubuntu
gyach et ubuntuUbuntu vs Fedora3 vs Mepis 3.3.1 et Suse 9.3 vs RHEL4
pb de detection lecteur cd a l install ubuntu[kernel] sources , patch etc.. quelque questions ;)
Ubuntu probleme de dependence ducoup plus de locales ...Mandriva LE2005 : Sources toujours !
Plus de sujets relatifs à : [Ubuntu] Quelles sources utilisez-vous ?
