Jun 3 21:50:47 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:50:47 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: completed -> scanning
Jun 3 21:50:47 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='ssid' freq=2417 MHz)
Jun 3 21:50:47 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:50:47 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:50:48 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:50:48 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:50:48 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> 4-way handshake
Jun 3 21:50:48 vincent wpa_supplicant[718]: eth1: WPA: Key negotiation completed with 7c:4f:b5:c8:cf:88 [PTK=CCMP GTK=CCMP]
Jun 3 21:50:48 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-CONNECTED - Connection to 7c:4f:b5:c8:cf:88 completed (reauth) [id=0 id_str=]
Jun 3 21:50:48 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: 4-way handshake -> completed
Jun 3 21:50:48 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:50:48 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: completed -> disconnected
Jun 3 21:50:49 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:50:49 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='ssid' freq=2417 MHz)
Jun 3 21:50:49 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:50:49 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:50:51 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:50:51 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:50:51 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> 4-way handshake
Jun 3 21:50:55 vincent wpa_supplicant[718]: eth1: WPA: Key negotiation completed with 7c:4f:b5:c8:cf:88 [PTK=CCMP GTK=CCMP]
Jun 3 21:50:55 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-CONNECTED - Connection to 7c:4f:b5:c8:cf:88 completed (reauth) [id=0 id_str=]
Jun 3 21:50:55 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: 4-way handshake -> completed
Jun 3 21:51:07 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:51:07 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: completed -> disconnected
Jun 3 21:51:07 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:51:07 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='ssid' freq=2417 MHz)
Jun 3 21:51:07 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:51:07 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:51:07 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:51:07 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:51:07 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> 4-way handshake
Jun 3 21:51:10 vincent wpa_supplicant[718]: eth1: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Jun 3 21:51:10 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:51:10 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: 4-way handshake -> disconnected
Jun 3 21:51:10 vincent NetworkManager[646]: <info> Activation (eth1/wireless): disconnected during association, asking for new key.
Jun 3 21:51:10 vincent NetworkManager[646]: <info> (eth1): device state change: activated -> need-auth (reason 'supplicant-disconnect') [100 60 8]
Jun 3 21:51:10 vincent whoopsie[903]: offline
Jun 3 21:51:10 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> inactive
Jun 3 21:51:10 vincent dbus[535]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 3 21:51:12 vincent dbus[535]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 3 21:51:20 vincent NetworkManager[646]: get_secret_flags: assertion 'is_secret_prop (setting, secret_name, error)' failed
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) scheduled...
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) started...
Jun 3 21:51:20 vincent NetworkManager[646]: <info> (eth1): device state change: need-auth -> prepare (reason 'none') [60 40 0]
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) scheduled...
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) complete.
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) starting...
Jun 3 21:51:20 vincent NetworkManager[646]: <info> (eth1): device state change: prepare -> config (reason 'none') [40 50 0]
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Activation (eth1/wireless): connection 'ssid' has security, and secrets exist. No new secrets needed.
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Config: added 'ssid' value 'ssid'
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Config: added 'scan_ssid' value '1'
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Config: added 'key_mgmt' value 'WPA-PSK'
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Config: added 'psk' value '<omitted>'
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) complete.
Jun 3 21:51:20 vincent NetworkManager[646]: <info> Config: set interface ap_scan to 1
Jun 3 21:51:20 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: inactive -> scanning
Jun 3 21:51:20 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:51:20 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:51:20 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:51:20 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:51:20 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:51:24 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> 4-way handshake
Jun 3 21:51:24 vincent wpa_supplicant[718]: eth1: WPA: Key negotiation completed with 7c:4f:b5:c8:cf:88 [PTK=CCMP GTK=CCMP]
Jun 3 21:51:24 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-CONNECTED - Connection to 7c:4f:b5:c8:cf:88 completed (reauth) [id=0 id_str=]
Jun 3 21:51:24 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: 4-way handshake -> completed
Jun 3 21:51:24 vincent NetworkManager[646]: <info> Activation (eth1/wireless) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'Joachim-Friedrich-Str'.
Jun 3 21:51:24 vincent NetworkManager[646]: <info> Activation (eth1) Stage 3 of 5 (IP Configure Start) scheduled.
Jun 3 21:51:24 vincent NetworkManager[646]: <info> Activation (eth1) Stage 3 of 5 (IP Configure Start) started...
Jun 3 21:51:24 vincent NetworkManager[646]: <info> (eth1): device state change: config -> ip-config (reason 'none') [50 70 0]
Jun 3 21:51:24 vincent NetworkManager[646]: (nm-device.c:2049):dhcp4_start: runtime check failed: (priv->dhcp4_client == NULL)
Jun 3 21:51:24 vincent NetworkManager[646]: <info> (eth1): canceled DHCP transaction, DHCP client pid 3054
Jun 3 21:51:24 vincent NetworkManager[646]: <info> Activation (eth1) Beginning DHCPv4 transaction (timeout in 45 seconds)
Jun 3 21:51:25 vincent NetworkManager[646]: <info> dhclient started with pid 3752
Jun 3 21:51:25 vincent NetworkManager[646]: <info> Activation (eth1) Stage 3 of 5 (IP Configure Start) complete.
Jun 3 21:51:25 vincent dhclient: Internet Systems Consortium DHCP Client 4.2.4
Jun 3 21:51:25 vincent dhclient: Copyright 2004-2012 Internet Systems Consortium.
Jun 3 21:51:25 vincent dhclient: All rights reserved.
Jun 3 21:51:25 vincent dhclient: For info, please visit https://www.isc.org/software/dhcp/
Jun 3 21:51:25 vincent dhclient: Listening on LPF/eth1/00:16:6f:45:c7:0e
Jun 3 21:51:25 vincent NetworkManager[646]: <info> (eth1): DHCPv4 state changed nbi -> preinit
Jun 3 21:51:25 vincent dhclient: Sending on LPF/eth1/00:16:6f:45:c7:0e
Jun 3 21:51:25 vincent dhclient: Sending on Socket/fallback
Jun 3 21:51:25 vincent dhclient: DHCPREQUEST of 192.168.1.62 on eth1 to 255.255.255.255 port 67 (xid=0x2d79b189)
Jun 3 21:51:28 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:51:28 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: completed -> disconnected
Jun 3 21:51:28 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:51:28 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:51:28 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:51:28 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:51:28 vincent dhclient: DHCPREQUEST of 192.168.1.62 on eth1 to 255.255.255.255 port 67 (xid=0x2d79b189)
Jun 3 21:51:29 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:51:29 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:51:29 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> 4-way handshake
Jun 3 21:51:31 vincent wpa_supplicant[718]: eth1: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Jun 3 21:51:31 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:51:31 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: 4-way handshake -> disconnected
Jun 3 21:51:31 vincent NetworkManager[646]: <info> Activation (eth1/wireless): disconnected during association, asking for new key.
Jun 3 21:51:31 vincent NetworkManager[646]: <info> (eth1): device state change: ip-config -> need-auth (reason 'supplicant-disconnect') [70 60 8]
Jun 3 21:51:31 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> inactive
Jun 3 21:51:31 vincent dhclient: DHCPREQUEST of 192.168.1.62 on eth1 to 255.255.255.255 port 67 (xid=0x2d79b189)
Jun 3 21:51:34 vincent NetworkManager[646]: get_secret_flags: assertion 'is_secret_prop (setting, secret_name, error)' failed
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) scheduled...
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) started...
Jun 3 21:51:34 vincent NetworkManager[646]: <info> (eth1): device state change: need-auth -> prepare (reason 'none') [60 40 0]
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) scheduled...
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) complete.
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) starting...
Jun 3 21:51:34 vincent NetworkManager[646]: <info> (eth1): device state change: prepare -> config (reason 'none') [40 50 0]
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Activation (eth1/wireless): connection 'Joachim-Friedrich-Str' has security, and secrets exist. No new secrets needed.
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Config: added 'ssid' value 'Joachim-Friedrich-Str'
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Config: added 'scan_ssid' value '1'
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Config: added 'key_mgmt' value 'WPA-PSK'
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Config: added 'psk' value '<omitted>'
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) complete.
Jun 3 21:51:34 vincent NetworkManager[646]: <info> Config: set interface ap_scan to 1
Jun 3 21:51:34 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: inactive -> scanning
Jun 3 21:51:34 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:51:34 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:51:34 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:51:34 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:51:34 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:51:37 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:51:37 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> disconnected
Jun 3 21:51:37 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:51:37 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:51:37 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:51:37 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:51:37 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:51:37 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:51:38 vincent dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 3 (xid=0x5c7d7fd4)
Jun 3 21:51:41 vincent dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 4 (xid=0x5c7d7fd4)
Jun 3 21:51:41 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> 4-way handshake
Jun 3 21:51:41 vincent wpa_supplicant[718]: eth1: WPA: Key negotiation completed with 7c:4f:b5:c8:cf:88 [PTK=CCMP GTK=CCMP]
Jun 3 21:51:41 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-CONNECTED - Connection to 7c:4f:b5:c8:cf:88 completed (reauth) [id=0 id_str=]
Jun 3 21:51:41 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: 4-way handshake -> completed
Jun 3 21:51:41 vincent NetworkManager[646]: <info> Activation (eth1/wireless) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'Joachim-Friedrich-Str'.
Jun 3 21:51:41 vincent NetworkManager[646]: <info> Activation (eth1) Stage 3 of 5 (IP Configure Start) scheduled.
Jun 3 21:51:41 vincent NetworkManager[646]: <info> Activation (eth1) Stage 3 of 5 (IP Configure Start) started...
Jun 3 21:51:41 vincent NetworkManager[646]: <info> (eth1): device state change: config -> ip-config (reason 'none') [50 70 0]
Jun 3 21:51:41 vincent NetworkManager[646]: (nm-device.c:2049):dhcp4_start: runtime check failed: (priv->dhcp4_client == NULL)
Jun 3 21:51:41 vincent NetworkManager[646]: <info> (eth1): canceled DHCP transaction, DHCP client pid 3752
Jun 3 21:51:41 vincent NetworkManager[646]: <info> Activation (eth1) Beginning DHCPv4 transaction (timeout in 45 seconds)
Jun 3 21:51:41 vincent NetworkManager[646]: <info> dhclient started with pid 3757
Jun 3 21:51:41 vincent NetworkManager[646]: <info> Activation (eth1) Stage 3 of 5 (IP Configure Start) complete.
Jun 3 21:51:41 vincent dhclient: Internet Systems Consortium DHCP Client 4.2.4
Jun 3 21:51:41 vincent dhclient: Copyright 2004-2012 Internet Systems Consortium.
Jun 3 21:51:41 vincent dhclient: All rights reserved.
Jun 3 21:51:41 vincent dhclient: For info, please visit https://www.isc.org/software/dhcp/
Jun 3 21:51:41 vincent NetworkManager[646]: <info> (eth1): DHCPv4 state changed nbi -> preinit
Jun 3 21:51:41 vincent dhclient: Listening on LPF/eth1/00:16:6f:45:c7:0e
Jun 3 21:51:41 vincent dhclient: Sending on LPF/eth1/00:16:6f:45:c7:0e
Jun 3 21:51:41 vincent dhclient: Sending on Socket/fallback
Jun 3 21:51:41 vincent dhclient: DHCPREQUEST of 192.168.1.62 on eth1 to 255.255.255.255 port 67 (xid=0x3118edfd)
Jun 3 21:51:44 vincent dhclient: DHCPREQUEST of 192.168.1.62 on eth1 to 255.255.255.255 port 67 (xid=0x3118edfd)
Jun 3 21:51:44 vincent dhclient: DHCPACK of 192.168.1.62 from 192.168.1.1
Jun 3 21:51:44 vincent dhclient: bound to 192.168.1.62 -- renewal in 287455 seconds.
Jun 3 21:51:44 vincent NetworkManager[646]: <info> (eth1): DHCPv4 state changed preinit -> reboot
Jun 3 21:51:44 vincent NetworkManager[646]: <info> address 192.168.1.62
Jun 3 21:51:44 vincent NetworkManager[646]: <info> prefix 24 (255.255.255.0)
Jun 3 21:51:44 vincent NetworkManager[646]: <info> gateway 192.168.1.1
Jun 3 21:51:44 vincent NetworkManager[646]: <info> nameserver '192.168.1.1'
Jun 3 21:51:44 vincent NetworkManager[646]: <info> domain name 'localdomain'
Jun 3 21:51:44 vincent NetworkManager[646]: <info> Activation (eth1) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Jun 3 21:51:44 vincent NetworkManager[646]: <info> Activation (eth1) Stage 5 of 5 (IPv4 Commit) started...
Jun 3 21:51:44 vincent NetworkManager[646]: <info> (eth1): device state change: ip-config -> secondaries (reason 'none') [70 90 0]
Jun 3 21:51:44 vincent NetworkManager[646]: <info> Activation (eth1) Stage 5 of 5 (IPv4 Commit) complete.
Jun 3 21:51:44 vincent NetworkManager[646]: <info> (eth1): device state change: secondaries -> activated (reason 'none') [90 100 0]
Jun 3 21:51:44 vincent NetworkManager[646]: <info> Activation (eth1) successful, device activated.
Jun 3 21:51:44 vincent dbus[535]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 3 21:51:44 vincent dbus[535]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 3 21:51:45 vincent whoopsie[903]: offline
Jun 3 21:51:46 vincent whoopsie[903]: online
Jun 3 21:51:53 vincent ntpdate[3794]: adjust time server 91.189.94.4 offset -0.025102 sec
Jun 3 21:51:57 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:51:57 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: completed -> disconnected
Jun 3 21:51:57 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:51:57 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:51:57 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:51:57 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:51:58 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:51:58 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:51:58 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> 4-way handshake
Jun 3 21:51:58 vincent wpa_supplicant[718]: eth1: WPA: Key negotiation completed with 7c:4f:b5:c8:cf:88 [PTK=CCMP GTK=CCMP]
Jun 3 21:51:58 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-CONNECTED - Connection to 7c:4f:b5:c8:cf:88 completed (reauth) [id=0 id_str=]
Jun 3 21:51:58 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: 4-way handshake -> completed
Jun 3 21:51:59 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:51:59 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: completed -> disconnected
Jun 3 21:51:59 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:51:59 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:51:59 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:51:59 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:52:01 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:52:01 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:52:01 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> 4-way handshake
Jun 3 21:52:01 vincent wpa_supplicant[718]: eth1: WPA: Key negotiation completed with 7c:4f:b5:c8:cf:88 [PTK=CCMP GTK=CCMP]
Jun 3 21:52:01 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-CONNECTED - Connection to 7c:4f:b5:c8:cf:88 completed (reauth) [id=0 id_str=]
Jun 3 21:52:01 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: 4-way handshake -> completed
Jun 3 21:52:07 vincent whoopsie[903]: online
Jun 3 21:52:11 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:52:11 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: completed -> disconnected
Jun 3 21:52:11 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:52:12 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:52:12 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:52:12 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:52:12 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:52:12 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:52:12 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> 4-way handshake
Jun 3 21:52:15 vincent wpa_supplicant[718]: eth1: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Jun 3 21:52:15 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:52:15 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: 4-way handshake -> disconnected
Jun 3 21:52:15 vincent NetworkManager[646]: <info> Activation (eth1/wireless): disconnected during association, asking for new key.
Jun 3 21:52:15 vincent NetworkManager[646]: <info> (eth1): device state change: activated -> need-auth (reason 'supplicant-disconnect') [100 60 8]
Jun 3 21:52:15 vincent dbus[535]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 3 21:52:15 vincent whoopsie[903]: offline
Jun 3 21:52:15 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> inactive
Jun 3 21:52:15 vincent dbus[535]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 3 21:52:20 vincent NetworkManager[646]: <warn> No agents were available for this request.
Jun 3 21:52:20 vincent NetworkManager[646]: <info> (eth1): device state change: need-auth -> failed (reason 'no-secrets') [60 120 7]
Jun 3 21:52:20 vincent NetworkManager[646]: <info> Marking connection 'Joachim-Friedrich-Str' invalid.
Jun 3 21:52:20 vincent NetworkManager[646]: <warn> Activation (eth1) failed for connection 'Joachim-Friedrich-Str'
Jun 3 21:52:20 vincent NetworkManager[646]: <info> (eth1): device state change: failed -> disconnected (reason 'none') [120 30 0]
Jun 3 21:52:20 vincent NetworkManager[646]: <info> (eth1): deactivating device (reason 'none') [0]
Jun 3 21:52:20 vincent whoopsie[903]: offline
Jun 3 21:52:20 vincent NetworkManager[646]: <info> (eth1): canceled DHCP transaction, DHCP client pid 3757
Jun 3 21:52:20 vincent NetworkManager[646]: <warn> DNS: plugin dnsmasq update failed
Jun 3 21:52:20 vincent NetworkManager[646]: <info> Removing DNS information from /sbin/resolvconf
Jun 3 21:52:20 vincent kernel: [ 4867.836428] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Jun 3 21:52:20 vincent avahi-daemon[620]: Withdrawing address record for fe80::216:6fff:fe45:c70e on eth1.
Jun 3 21:52:20 vincent dnsmasq[1060]: configuration des serveurs amonts à partir de DBus
Jun 3 21:52:20 vincent avahi-daemon[620]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::216:6fff:fe45:c70e.
Jun 3 21:52:20 vincent avahi-daemon[620]: Interface eth1.IPv6 no longer relevant for mDNS.
Jun 3 21:52:20 vincent avahi-daemon[620]: Withdrawing address record for 192.168.1.62 on eth1.
Jun 3 21:52:20 vincent avahi-daemon[620]: Leaving mDNS multicast group on interface eth1.IPv4 with address 192.168.1.62.
Jun 3 21:52:20 vincent avahi-daemon[620]: Interface eth1.IPv4 no longer relevant for mDNS.
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Activation (eth1) starting connection 'Joachim-Friedrich-Str'
Jun 3 21:52:23 vincent NetworkManager[646]: <info> (eth1): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) scheduled...
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) started...
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) scheduled...
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) complete.
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) starting...
Jun 3 21:52:23 vincent NetworkManager[646]: <info> (eth1): device state change: prepare -> config (reason 'none') [40 50 0]
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Activation (eth1/wireless): access point 'Joachim-Friedrich-Str' has security, but secrets are required.
Jun 3 21:52:23 vincent NetworkManager[646]: <info> (eth1): device state change: config -> need-auth (reason 'none') [50 60 0]
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) complete.
Jun 3 21:52:23 vincent NetworkManager[646]: <info> (eth1): device state change: need-auth -> prepare (reason 'none') [60 40 0]
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Activation (eth1/wireless): connection 'Joachim-Friedrich-Str' has security, and secrets exist. No new secrets needed.
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Config: added 'ssid' value 'Joachim-Friedrich-Str'
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Config: added 'scan_ssid' value '1'
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Config: added 'key_mgmt' value 'WPA-PSK'
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Config: added 'psk' value '<omitted>'
Jun 3 21:52:23 vincent NetworkManager[646]: <info> Config: set interface ap_scan to 1
Jun 3 21:52:24 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: inactive -> scanning
Jun 3 21:52:24 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:52:24 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:52:24 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:52:24 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:52:24 vincent kernel: [ 4872.298451] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Jun 3 21:52:24 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:52:25 vincent whoopsie[903]: offline
Jun 3 21:52:25 vincent avahi-daemon[620]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::216:6fff:fe45:c70e.
Jun 3 21:52:25 vincent avahi-daemon[620]: New relevant interface eth1.IPv6 for mDNS.
Jun 3 21:52:25 vincent avahi-daemon[620]: Registering new address record for fe80::216:6fff:fe45:c70e on eth1.*.
Jun 3 21:52:27 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:52:27 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> disconnected
Jun 3 21:52:27 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:52:27 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:52:27 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:52:27 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:52:28 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:52:28 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:52:31 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:52:31 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> disconnected
Jun 3 21:52:31 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:52:31 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:52:31 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:52:31 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:52:31 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:52:31 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:52:32 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:52:32 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> disconnected
Jun 3 21:52:32 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:52:32 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:52:32 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:52:32 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:52:33 vincent wpa_supplicant[718]: rfkill: WLAN hard blocked
Jun 3 21:52:33 vincent avahi-daemon[620]: Interface eth1.IPv6 no longer relevant for mDNS.
Jun 3 21:52:33 vincent avahi-daemon[620]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::216:6fff:fe45:c70e.
Jun 3 21:52:33 vincent avahi-daemon[620]: Withdrawing address record for fe80::216:6fff:fe45:c70e on eth1.
Jun 3 21:52:33 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> disabled
Jun 3 21:52:34 vincent NetworkManager[646]: <info> WiFi now disabled by radio killswitch
Jun 3 21:52:34 vincent NetworkManager[646]: <info> (eth1): device state change: config -> unavailable (reason 'none') [50 20 0]
Jun 3 21:52:34 vincent NetworkManager[646]: <info> (eth1): deactivating device (reason 'none') [0]
Jun 3 21:52:34 vincent whoopsie[903]: offline
Jun 3 21:52:41 vincent NetworkManager[646]: <info> WiFi now enabled by radio killswitch
Jun 3 21:52:41 vincent NetworkManager[646]: <info> (eth1): bringing up device.
Jun 3 21:52:41 vincent kernel: [ 4889.453573] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Jun 3 21:52:41 vincent wpa_supplicant[718]: nl80211: Driver does not support authentication/association or connect commands
Jun 3 21:52:41 vincent kernel: [ 4889.458684] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Jun 3 21:52:42 vincent kernel: [ 4890.448049] ipw2200: Failed to send CARD_DISABLE: Command timed out.
Jun 3 21:52:42 vincent NetworkManager[646]: <info> (eth1) supports 1 scan SSIDs
Jun 3 21:52:42 vincent NetworkManager[646]: <warn> Trying to remove a non-existant call id.
Jun 3 21:52:42 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: starting -> ready
Jun 3 21:52:42 vincent NetworkManager[646]: <info> (eth1): device state change: unavailable -> disconnected (reason 'supplicant-available') [20 30 42]
Jun 3 21:52:42 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: ready -> inactive
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Activation (eth1) starting connection 'Joachim-Friedrich-Str'
Jun 3 21:52:49 vincent NetworkManager[646]: <info> (eth1): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) scheduled...
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) started...
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) scheduled...
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Activation (eth1) Stage 1 of 5 (Device Prepare) complete.
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) starting...
Jun 3 21:52:49 vincent NetworkManager[646]: <info> (eth1): device state change: prepare -> config (reason 'none') [40 50 0]
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Activation (eth1/wireless): connection 'Joachim-Friedrich-Str' has security, and secrets exist. No new secrets needed.
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Config: added 'ssid' value 'Joachim-Friedrich-Str'
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Config: added 'scan_ssid' value '1'
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Config: added 'key_mgmt' value 'WPA-PSK'
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Config: added 'psk' value '<omitted>'
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Activation (eth1) Stage 2 of 5 (Device Configure) complete.
Jun 3 21:52:49 vincent whoopsie[903]: offline
Jun 3 21:52:49 vincent NetworkManager[646]: <info> Config: set interface ap_scan to 1
Jun 3 21:52:49 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: inactive -> scanning
Jun 3 21:52:50 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:52:50 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:52:50 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:52:50 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:52:50 vincent kernel: [ 4897.732115] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Jun 3 21:52:50 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:52:50 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:52:50 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> disconnected
Jun 3 21:52:51 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:52:51 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:52:51 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:52:51 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:52:51 vincent avahi-daemon[620]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::216:6fff:fe45:c70e.
Jun 3 21:52:51 vincent avahi-daemon[620]: New relevant interface eth1.IPv6 for mDNS.
Jun 3 21:52:51 vincent avahi-daemon[620]: Registering new address record for fe80::216:6fff:fe45:c70e on eth1.*.
Jun 3 21:52:53 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:52:53 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:52:53 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-DISCONNECTED bssid=7c:4f:b5:c8:cf:88 reason=0
Jun 3 21:52:53 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> disconnected
Jun 3 21:52:54 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: disconnected -> scanning
Jun 3 21:52:54 vincent wpa_supplicant[718]: eth1: Trying to associate with 7c:4f:b5:c8:cf:88 (SSID='Joachim-Friedrich-Str' freq=2417 MHz)
Jun 3 21:52:54 vincent wpa_supplicant[718]: eth1: Association request to the driver failed
Jun 3 21:52:54 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: scanning -> associating
Jun 3 21:52:56 vincent wpa_supplicant[718]: eth1: Associated with 7c:4f:b5:c8:cf:88
Jun 3 21:52:56 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associating -> associated
Jun 3 21:53:00 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: associated -> 4-way handshake
Jun 3 21:53:00 vincent wpa_supplicant[718]: eth1: WPA: Key negotiation completed with 7c:4f:b5:c8:cf:88 [PTK=CCMP GTK=CCMP]
Jun 3 21:53:00 vincent wpa_supplicant[718]: eth1: CTRL-EVENT-CONNECTED - Connection to 7c:4f:b5:c8:cf:88 completed (auth) [id=0 id_str=]
Jun 3 21:53:00 vincent NetworkManager[646]: <info> (eth1): supplicant interface state: 4-way handshake -> completed
Jun 3 21:53:00 vincent NetworkManager[646]: <info> Activation (eth1/wireless) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'Joachim-Friedrich-Str'.
Jun 3 21:53:00 vincent NetworkManager[646]: <info> Activation (eth1) Stage 3 of 5 (IP Configure Start) scheduled.
Jun 3 21:53:00 vincent NetworkManager[646]: <info> Activation (eth1) Stage 3 of 5 (IP Configure Start) started...
Jun 3 21:53:00 vincent NetworkManager[646]: <info> (eth1): device state change: config -> ip-config (reason 'none') [50 70 0]
Jun 3 21:53:00 vincent NetworkManager[646]: <info> Activation (eth1) Beginning DHCPv4 transaction (timeout in 45 seconds)
Jun 3 21:53:00 vincent NetworkManager[646]: <info> dhclient started with pid 3890
Jun 3 21:53:00 vincent avahi-daemon[620]: Withdrawing address record for fe80::216:6fff:fe45:c70e on eth1.
Jun 3 21:53:00 vincent avahi-daemon[620]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::216:6fff:fe45:c70e.
Jun 3 21:53:00 vincent avahi-daemon[620]: Interface eth1.IPv6 no longer relevant for mDNS.
Jun 3 21:53:00 vincent NetworkManager[646]: <info> Activation (eth1) Stage 3 of 5 (IP Configure Start) complete.
Jun 3 21:53:00 vincent dhclient: Internet Systems Consortium DHCP Client 4.2.4
Jun 3 21:53:00 vincent dhclient: Copyright 2004-2012 Internet Systems Consortium.
Jun 3 21:53:00 vincent dhclient: All rights reserved.
Jun 3 21:53:00 vincent dhclient: For info, please visit https://www.isc.org/software/dhcp/
Jun 3 21:53:00 vincent NetworkManager[646]: <info> (eth1): DHCPv4 state changed nbi -> preinit
Jun 3 21:53:00 vincent dhclient: Listening on LPF/eth1/00:16:6f:45:c7:0e
Jun 3 21:53:00 vincent dhclient: Sending on LPF/eth1/00:16:6f:45:c7:0e
Jun 3 21:53:00 vincent dhclient: Sending on Socket/fallback
Jun 3 21:53:00 vincent dhclient: DHCPREQUEST of 192.168.1.62 on eth1 to 255.255.255.255 port 67 (xid=0x6dc677e2)
Jun 3 21:53:01 vincent avahi-daemon[620]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::216:6fff:fe45:c70e.
Jun 3 21:53:01 vincent avahi-daemon[620]: New relevant interface eth1.IPv6 for mDNS.
Jun 3 21:53:01 vincent avahi-daemon[620]: Registering new address record for fe80::216:6fff:fe45:c70e on eth1.*.
Jun 3 21:53:03 vincent dhclient: DHCPREQUEST of 192.168.1.62 on eth1 to 255.255.255.255 port 67 (xid=0x6dc677e2)
Jun 3 21:53:04 vincent dhclient: DHCPACK of 192.168.1.62 from 192.168.1.1
Jun 3 21:53:04 vincent dhclient: bound to 192.168.1.62 -- renewal in 238821 seconds.
Jun 3 21:53:04 vincent NetworkManager[646]: <info> (eth1): DHCPv4 state changed preinit -> reboot
Jun 3 21:53:04 vincent NetworkManager[646]: <info> address 192.168.1.62
Jun 3 21:53:04 vincent NetworkManager[646]: <info> prefix 24 (255.255.255.0)
Jun 3 21:53:04 vincent NetworkManager[646]: <info> gateway 192.168.1.1
Jun 3 21:53:04 vincent NetworkManager[646]: <info> nameserver '192.168.1.1'
Jun 3 21:53:04 vincent NetworkManager[646]: <info> domain name 'localdomain'
Jun 3 21:53:04 vincent NetworkManager[646]: <info> Activation (eth1) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Jun 3 21:53:04 vincent NetworkManager[646]: <info> Activation (eth1) Stage 5 of 5 (IPv4 Commit) started...
Jun 3 21:53:04 vincent avahi-daemon[620]: Joining mDNS multicast group on interface eth1.IPv4 with address 192.168.1.62.
Jun 3 21:53:04 vincent avahi-daemon[620]: New relevant interface eth1.IPv4 for mDNS.
Jun 3 21:53:04 vincent avahi-daemon[620]: Registering new address record for 192.168.1.62 on eth1.IPv4.
Jun 3 21:53:05 vincent NetworkManager[646]: <info> (eth1): device state change: ip-config -> secondaries (reason 'none') [70 90 0]
Jun 3 21:53:05 vincent NetworkManager[646]: <info> Activation (eth1) Stage 5 of 5 (IPv4 Commit) complete.
Jun 3 21:53:05 vincent NetworkManager[646]: <info> (eth1): device state change: secondaries -> activated (reason 'none') [90 100 0]
Jun 3 21:53:05 vincent NetworkManager[646]: <info> Policy set 'Joachim-Friedrich-Str' (eth1) as default for IPv4 routing and DNS.
Jun 3 21:53:05 vincent NetworkManager[646]: <info> Writing DNS information to /sbin/resolvconf
Jun 3 21:53:05 vincent dnsmasq[1060]: configuration des serveurs amonts à partir de DBus
Jun 3 21:53:05 vincent dnsmasq[1060]: utilise le serveur de nom 192.168.1.1#53
Jun 3 21:53:06 vincent NetworkManager[646]: <info> Activation (eth1) successful, device activated.
Jun 3 21:53:06 vincent dbus[535]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 3 21:53:06 vincent whoopsie[903]: offline
