daedalus@orthancvar/log$ cat xorg.0.log.old
cat: xorg.0.log.old: Aucun fichier ou dossier de ce type
daedalus@orthancvar/log$ cat Xorg.0.log.old
[ 13.539]
X.Org X Server 1.14.5
Release Date: 2013-12-12
[ 13.539] X Protocol Version 11, Revision 0
[ 13.539] Build Operating System: Linux 3.2.0-37-generic x86_64 Ubuntu
[ 13.539] Current Operating System: Linux orthanc 3.11.0-18-generic #32-Ubuntu SMP Tue Feb 18 21:11:14 UTC 2014 x86_64
[ 13.539] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-18-generic root=UUID=b11b3df9-f382-4717-8594-9b8afe20983b ro quiet splash
[ 13.539] Build Date: 17 December 2013 10:06:15AM
[ 13.539] xorg-server 2:1.14.5-1ubuntu2~saucy1 (For technical support please see http://www.ubuntu.com/support)
[ 13.539] Current version of pixman: 0.30.2
[ 13.539] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 13.539] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 13.539] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 31 12:48:32 2014
[ 13.568] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 13.568] (==) No Layout section. Using the first Screen section.
[ 13.568] (==) No screen section available. Using defaults.
[ 13.568] (**) |-->Screen "Default Screen Section" (0)
[ 13.568] (**) | |-->Monitor "<default monitor>"
[ 13.568] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 13.568] (==) Automatically adding devices
[ 13.568] (==) Automatically enabling devices
[ 13.568] (==) Automatically adding GPU devices
[ 13.568] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 13.568] Entry deleted from font path.
[ 13.568] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 13.568] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 13.568] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 13.568] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 13.569] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 13.569] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 13.569] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 13.569] (II) Loader magic: 0x7f856b7fcd20
[ 13.569] (II) Module ABI versions:
[ 13.569] X.Org ANSI C Emulation: 0.4
[ 13.569] X.Org Video Driver: 14.1
[ 13.569] X.Org XInput driver : 19.1
[ 13.569] X.Org Server Extension : 7.0
[ 13.569] (--) PCI:*(0:1:0:0) 10de:1201:10b0:0801 rev 161, Mem @ 0xf4000000/33554432, 0xe8000000/134217728, 0xf0000000/67108864, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 13.569] (II) Open ACPI successful (/var/run/acpid.socket)
[ 13.569] Initializing built-in extension Generic Event Extension
[ 13.569] Initializing built-in extension SHAPE
[ 13.569] Initializing built-in extension MIT-SHM
[ 13.569] Initializing built-in extension XInputExtension
[ 13.569] Initializing built-in extension XTEST
[ 13.569] Initializing built-in extension BIG-REQUESTS
[ 13.569] Initializing built-in extension SYNC
[ 13.569] Initializing built-in extension XKEYBOARD
[ 13.569] Initializing built-in extension XC-MISC
[ 13.569] Initializing built-in extension SECURITY
[ 13.569] Initializing built-in extension XINERAMA
[ 13.569] Initializing built-in extension XFIXES
[ 13.569] Initializing built-in extension RENDER
[ 13.569] Initializing built-in extension RANDR
[ 13.569] Initializing built-in extension COMPOSITE
[ 13.569] Initializing built-in extension DAMAGE
[ 13.569] Initializing built-in extension MIT-SCREEN-SAVER
[ 13.569] Initializing built-in extension DOUBLE-BUFFER
[ 13.569] Initializing built-in extension RECORD
[ 13.569] Initializing built-in extension DPMS
[ 13.569] Initializing built-in extension X-Resource
[ 13.569] Initializing built-in extension XVideo
[ 13.569] Initializing built-in extension XVideo-MotionCompensation
[ 13.569] Initializing built-in extension SELinux
[ 13.569] Initializing built-in extension XFree86-VidModeExtension
[ 13.569] Initializing built-in extension XFree86-DGA
[ 13.569] Initializing built-in extension XFree86-DRI
[ 13.569] Initializing built-in extension DRI2
[ 13.569] (II) "glx" will be loaded by default.
[ 13.569] (WW) "xmir" is not to be loaded by default. Skipping.
[ 13.569] (II) LoadModule: "dri2"
[ 13.569] (II) Module "dri2" already built-in
[ 13.569] (II) LoadModule: "glamoregl"
[ 13.624] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 13.714] (II) Module glamoregl: vendor="X.Org Foundation"
[ 13.714] compiled for 1.14.3, module version = 0.5.1
[ 13.714] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.714] (II) LoadModule: "glx"
[ 13.714] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 13.730] (II) Module glx: vendor="NVIDIA Corporation"
[ 13.730] compiled for 4.0.2, module version = 1.0.0
[ 13.730] Module class: X.Org Server Extension
[ 13.730] (II) NVIDIA GLX Module 304.88 Wed Mar 27 14:46:57 PDT 2013
[ 13.730] Loading extension GLX
[ 13.730] (==) Matched nvidia as autoconfigured driver 0
[ 13.730] (==) Matched nouveau as autoconfigured driver 1
[ 13.730] (==) Matched vesa as autoconfigured driver 2
[ 13.730] (==) Matched modesetting as autoconfigured driver 3
[ 13.730] (==) Matched fbdev as autoconfigured driver 4
[ 13.730] (==) Assigned the driver to the xf86ConfigLayout
[ 13.730] (II) LoadModule: "nvidia"
[ 13.730] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 13.732] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 13.732] compiled for 4.0.2, module version = 1.0.0
[ 13.732] Module class: X.Org Video Driver
[ 13.732] (II) LoadModule: "nouveau"
[ 13.739] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 13.739] (II) Module nouveau: vendor="X.Org Foundation"
[ 13.739] compiled for 1.14.2.901, module version = 1.0.9
[ 13.739] Module class: X.Org Video Driver
[ 13.739] ABI class: X.Org Video Driver, version 14.1
[ 13.740] (II) LoadModule: "vesa"
[ 13.740] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 13.740] (II) Module vesa: vendor="X.Org Foundation"
[ 13.740] compiled for 1.14.1, module version = 2.3.2
[ 13.740] Module class: X.Org Video Driver
[ 13.740] ABI class: X.Org Video Driver, version 14.1
[ 13.740] (II) LoadModule: "modesetting"
[ 13.740] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 13.740] (II) Module modesetting: vendor="X.Org Foundation"
[ 13.740] compiled for 1.14.1, module version = 0.8.0
[ 13.740] (II) LoadModule: "fbdev"
[ 13.740] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 13.741] (II) Module fbdev: vendor="X.Org Foundation"
[ 13.741] compiled for 1.14.1, module version = 0.4.3
[ 13.741] Module class: X.Org Video Driver
[ 13.741] ABI class: X.Org Video Driver, version 14.1
[ 13.741] (II) NVIDIA dlloader X Driver 304.88 Wed Mar 27 14:28:14 PDT 2013
[ 13.741] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 13.741] (II) NOUVEAU driver Date: Wed Jul 31 10:51:03 2013 +1000
[ 13.741] (II) NOUVEAU driver for NVIDIA chipset families :
[ 13.741] RIVA TNT (NV04)
[ 13.741] RIVA TNT2 (NV05)
[ 13.741] GeForce 256 (NV10)
[ 13.741] GeForce 2 (NV11, NV15)
[ 13.741] GeForce 4MX (NV17, NV18)
[ 13.741] GeForce 3 (NV20)
[ 13.741] GeForce 4Ti (NV25, NV28)
[ 13.741] GeForce FX (NV3x)
[ 13.741] GeForce 6 (NV4x)
[ 13.741] GeForce 7 (G7x)
[ 13.741] GeForce 8 (G8x)
[ 13.741] GeForce GTX 200 (NVA0)
[ 13.741] GeForce GTX 400 (NVC0)
[ 13.741] (II) VESA: driver for VESA chipsets: vesa
[ 13.741] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 13.741] (II) FBDEV: driver for framebuffer: fbdev
[ 13.741] (++) using VT number 7
[ 13.754] (II) Loading sub module "fb"
[ 13.754] (II) LoadModule: "fb"
[ 13.754] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 13.754] (II) Module fb: vendor="X.Org Foundation"
[ 13.754] compiled for 1.14.5, module version = 1.0.0
[ 13.754] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.755] (II) Loading sub module "wfb"
[ 13.755] (II) LoadModule: "wfb"
[ 13.755] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 13.755] (II) Module wfb: vendor="X.Org Foundation"
[ 13.755] compiled for 1.14.5, module version = 1.0.0
[ 13.755] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.755] (II) Loading sub module "ramdac"
[ 13.755] (II) LoadModule: "ramdac"
[ 13.755] (II) Module "ramdac" already built-in
[ 13.755] (WW) Falling back to old probe method for vesa
[ 13.755] (WW) Falling back to old probe method for modesetting
[ 13.755] (EE) open /dev/dri/card0: No such file or directory
[ 13.755] (WW) Falling back to old probe method for fbdev
[ 13.755] (II) Loading sub module "fbdevhw"
[ 13.755] (II) LoadModule: "fbdevhw"
[ 13.755] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 13.755] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 13.755] compiled for 1.14.5, module version = 0.0.2
[ 13.755] ABI class: X.Org Video Driver, version 14.1
[ 13.755] (EE) open /dev/fb0: No such file or directory
[ 13.755] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 13.755] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 13.755] (==) NVIDIA(0): RGB weight 888
[ 13.755] (==) NVIDIA(0): Default visual is TrueColor
[ 13.755] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 13.755] (**) NVIDIA(0): Enabling 2D acceleration
[ 14.327] (II) NVIDIA(GPU-0): Display (AOC 2350 (DFP-0)) does not support NVIDIA 3D Vision
[ 14.327] (II) NVIDIA(GPU-0): stereo.
[ 14.328] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 560 (GF114) at PCI:1:0:0 (GPU-0)
[ 14.328] (--) NVIDIA(0): Memory: 1048576 kBytes
[ 14.328] (--) NVIDIA(0): VideoBIOS: 70.24.21.00.00
[ 14.328] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 14.328] (--) NVIDIA(0): Interlaced video modes are supported on this GPU
[ 14.329] (--) NVIDIA(0): Valid display device(s) on GeForce GTX 560 at PCI:1:0:0
[ 14.329] (--) NVIDIA(0): CRT-0
[ 14.329] (--) NVIDIA(0): CRT-1
[ 14.329] (--) NVIDIA(0): AOC 2350 (DFP-0) (connected)
[ 14.329] (--) NVIDIA(0): DFP-1
[ 14.329] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 14.329] (--) NVIDIA(0): CRT-1: 400.0 MHz maximum pixel clock
[ 14.329] (--) NVIDIA(0): AOC 2350 (DFP-0): 330.0 MHz maximum pixel clock
[ 14.329] (--) NVIDIA(0): AOC 2350 (DFP-0): Internal Dual Link TMDS
[ 14.329] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 14.329] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[ 14.329] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 14.329] (**) NVIDIA(0): device AOC 2350 (DFP-0) (Using EDID frequencies has been
[ 14.329] (**) NVIDIA(0): enabled on all display devices.)
[ 14.330] (==) NVIDIA(0):
[ 14.330] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 14.330] (==) NVIDIA(0): will be used as the requested mode.
[ 14.330] (II) NVIDIA(0): Validated MetaModes:
[ 14.330] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 14.330] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 14.356] (--) NVIDIA(0): DPI set to (95, 94); computed from "UseEdidDpi" X config
[ 14.356] (--) NVIDIA(0): option
[ 14.356] (II) UnloadModule: "nouveau"
[ 14.356] (II) Unloading nouveau
[ 14.357] (II) UnloadModule: "vesa"
[ 14.357] (II) Unloading vesa
[ 14.357] (II) UnloadModule: "modesetting"
[ 14.357] (II) Unloading modesetting
[ 14.357] (II) UnloadModule: "fbdev"
[ 14.357] (II) Unloading fbdev
[ 14.357] (II) UnloadSubModule: "fbdevhw"
[ 14.357] (II) Unloading fbdevhw
[ 14.357] (--) Depth 24 pixmap format is 32 bpp
[ 14.357] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 14.357] (II) NVIDIA: access.
[ 14.361] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 14.390] Loading extension NV-GLX
[ 14.435] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 14.435] (==) NVIDIA(0): Backing store disabled
[ 14.435] (==) NVIDIA(0): Silken mouse enabled
[ 14.435] (==) NVIDIA(0): DPMS enabled
[ 14.435] Loading extension NV-CONTROL
[ 14.435] Loading extension XINERAMA
[ 14.436] (II) Loading sub module "dri2"
[ 14.436] (II) LoadModule: "dri2"
[ 14.436] (II) Module "dri2" already built-in
[ 14.436] (II) NVIDIA(0): [DRI2] Setup complete
[ 14.436] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 14.436] (--) RandR disabled
[ 14.438] (II) SELinux: Disabled on system
[ 14.438] (II) Initializing extension GLX
[ 14.444] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 14.445] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 14.445] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 14.445] (II) LoadModule: "evdev"
[ 14.446] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 14.446] (II) Module evdev: vendor="X.Org Foundation"
[ 14.446] compiled for 1.14.1, module version = 2.7.3
[ 14.446] Module class: X.Org XInput Driver
[ 14.446] ABI class: X.Org XInput driver, version 19.1
[ 14.446] (II) Using input driver 'evdev' for 'Power Button'
[ 14.446] (**) Power Button: always reports core events
[ 14.446] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 14.446] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 14.446] (--) evdev: Power Button: Found keys
[ 14.446] (II) evdev: Power Button: Configuring as keyboard
[ 14.446] (**) Option "config_info" "udevsys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 14.446] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 14.446] (**) Option "xkb_rules" "evdev"
[ 14.446] (**) Option "xkb_model" "pc105"
[ 14.446] (**) Option "xkb_layout" "fr"
[ 14.447] (II) XKB: reuse xkmfile /var/lib/xkb/server-1CA37FD61409D6C1EDB80880DF2DB1A574556A6A.xkm
[ 14.447] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 14.447] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 14.447] (II) Using input driver 'evdev' for 'Power Button'
[ 14.447] (**) Power Button: always reports core events
[ 14.447] (**) evdev: Power Button: Device: "/dev/input/event0"
[ 14.447] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 14.447] (--) evdev: Power Button: Found keys
[ 14.447] (II) evdev: Power Button: Configuring as keyboard
[ 14.447] (**) Option "config_info" "udevsys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0"
[ 14.447] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 14.447] (**) Option "xkb_rules" "evdev"
[ 14.447] (**) Option "xkb_model" "pc105"
[ 14.447] (**) Option "xkb_layout" "fr"
[ 14.447] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event10)
[ 14.447] (II) No input driver specified, ignoring this device.
[ 14.447] (II) This device may have been added with another device file.
[ 14.448] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[ 14.448] (II) No input driver specified, ignoring this device.
[ 14.448] (II) This device may have been added with another device file.
[ 14.448] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event12)
[ 14.448] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event13)
[ 14.448] (II) config/udev: Adding input device USB Keyboard (/dev/input/event15)
[ 14.448] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 14.448] (II) Using input driver 'evdev' for ' USB Keyboard'
[ 14.448] (**) USB Keyboard: always reports core events
[ 14.448] (**) evdev: USB Keyboard: Device: "/dev/input/event15"
[ 14.448] (--) evdev: USB Keyboard: Vendor 0x4d9 Product 0x1603
[ 14.448] (--) evdev: USB Keyboard: Found keys
[ 14.448] (II) evdev: USB Keyboard: Configuring as keyboard
[ 14.448] (**) Option "config_info" "udevsys/devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10:1.0/input/input15/event15"
[ 14.448] (II) XINPUT: Adding extended input device " USB Keyboard" (type: KEYBOARD, id 8)
[ 14.448] (**) Option "xkb_rules" "evdev"
[ 14.448] (**) Option "xkb_model" "pc105"
[ 14.448] (**) Option "xkb_layout" "fr"
[ 14.448] (II) config/udev: Adding input device USB Keyboard (/dev/input/event16)
[ 14.448] (**) evdev: USB Keyboard: Device: "/dev/input/event16"
[ 14.448] (**) Option "config_info" "udevsys/devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10:1.1/input/input16/event16"
[ 14.448] (II) XINPUT: Adding extended input device " USB Keyboard" (type: KEYBOARD, id 9)
[ 14.448] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event14)
[ 14.448] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 14.448] (II) Using input driver 'evdev' for 'USB Optical Mouse'
[ 14.448] (**) USB Optical Mouse: always reports core events
[ 14.448] (**) evdev: USB Optical Mouse: Device: "/dev/input/event14"
[ 14.448] (--) evdev: USB Optical Mouse: Vendor 0x15ca Product 0xc3
[ 14.448] (--) evdev: USB Optical Mouse: Found 3 mouse buttons
[ 14.448] (--) evdev: USB Optical Mouse: Found scroll wheel(s)
[ 14.448] (--) evdev: USB Optical Mouse: Found relative axes
[ 14.448] (--) evdev: USB Optical Mouse: Found x and y relative axes
[ 14.448] (II) evdev: USB Optical Mouse: Configuring as mouse
[ 14.448] (II) evdev: USB Optical Mouse: Adding scrollwheel support
[ 14.448] (**) evdev: USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 14.448] (**) evdev: USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 14.448] (**) Option "config_info" "udevsys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0/input/input14/event14"
[ 14.448] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 10)
[ 14.448] (II) evdev: USB Optical Mouse: initialized for relative axes.
[ 14.448] (**) USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 14.448] (**) USB Optical Mouse: (accel) acceleration profile 0
[ 14.448] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[ 14.448] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[ 14.448] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[ 14.449] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event2)
[ 14.449] (II) No input driver specified, ignoring this device.
[ 14.449] (II) This device may have been added with another device file.
[ 14.449] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event3)
[ 14.449] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event4)
[ 14.449] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event5)
[ 14.449] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event6)
[ 14.449] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event7)
[ 14.449] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event8)
[ 14.449] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event9)
[ 31.504] (II) NVIDIA(GPU-0): Display (AOC 2350 (DFP-0)) does not support NVIDIA 3D Vision
[ 31.504] (II) NVIDIA(GPU-0): stereo.
[ 31.504] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 31.504] (**) NVIDIA(0): device AOC 2350 (DFP-0) (Using EDID frequencies has been
[ 31.504] (**) NVIDIA(0): enabled on all display devices.)
[ 46.019] (II) NVIDIA(GPU-0): Display (AOC 2350 (DFP-0)) does not support NVIDIA 3D Vision
[ 46.019] (II) NVIDIA(GPU-0): stereo.
[ 46.019] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 46.019] (**) NVIDIA(0): device AOC 2350 (DFP-0) (Using EDID frequencies has been
[ 46.019] (**) NVIDIA(0): enabled on all display devices.)
[ 46.066] (II) NVIDIA(GPU-0): Display (AOC 2350 (DFP-0)) does not support NVIDIA 3D Vision
[ 46.067] (II) NVIDIA(GPU-0): stereo.
[ 46.067] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 46.067] (**) NVIDIA(0): device AOC 2350 (DFP-0) (Using EDID frequencies has been
[ 46.067] (**) NVIDIA(0): enabled on all display devices.)
