2732 connectés
  Linux et OS Alternatifs
  Installation
  [UBUNTU] Demarrage excessivement lent sur un Amilo V7010
n°952105
Ace17
Posté le 10-09-2007 à 18:00:53  profilanswer
Salut tout le monde, je viens d'installer Ubuntu Feisty sur mon ordinateur portable (un Fujitsu Siemens Amilo V7010) et tout marche bien, sauf que l'OS met trois plombes a demarrer :
Le log complet est en fin de message. Cependant, le boot semble se bloquer sur les lignes suivantes :
Sep 10 09:48:03 caroline-laptop kernel: [   26.303341] Early unpacking initramfs... done
Sep 10 09:48:03 caroline-laptop kernel: [   39.771627] checking if image is initramfs... it is
A chaque fois, la ligne se rapport a l'image initramfs. Des idees ?
Merci d'avance.
Sep 10 09:48:03 caroline-laptop kernel: [   26.185623] Built 1 zonelists.  Total pages: 186802
Sep 10 09:48:03 caroline-laptop kernel: [   26.185630] Kernel command line: root=UUID=87418c1e-060b-4315-8747-457b26646c07 ro quiet splash
Sep 10 09:48:03 caroline-laptop kernel: [   26.185814] mapped APIC to ffffd000 (fee00000)
Sep 10 09:48:03 caroline-laptop kernel: [   26.185818] mapped IOAPIC to ffffc000 (fec00000)
Sep 10 09:48:03 caroline-laptop kernel: [   26.185821] Enabling fast FPU save and restore... done.
Sep 10 09:48:03 caroline-laptop kernel: [   26.185825] Enabling unmasked SIMD FPU exception support... done.
Sep 10 09:48:03 caroline-laptop kernel: [   26.185838] Initializing CPU#0
Sep 10 09:48:03 caroline-laptop kernel: [   26.185906] PID hash table entries: 4096 (order: 12, 16384 bytes)
Sep 10 09:48:03 caroline-laptop kernel: [   26.186945] Console: colour VGA+ 80x25
Sep 10 09:48:03 caroline-laptop kernel: [   26.187704] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Sep 10 09:48:03 caroline-laptop kernel: [   26.188895] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Sep 10 09:48:03 caroline-laptop kernel: [   26.205331] Memory: 735288k/753088k available (1993k kernel code, 17168k reserved, 900k data, 328k init, 0k highmem)
Sep 10 09:48:03 caroline-laptop kernel: [   26.205342] virtual kernel memory layout:
Sep 10 09:48:03 caroline-laptop kernel: [   26.205344]     fixmap  : 0xfff4e000 - 0xfffff000   ( 708 kB)
Sep 10 09:48:03 caroline-laptop kernel: [   26.205345]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
Sep 10 09:48:03 caroline-laptop kernel: [   26.205346]     vmalloc : 0xee800000 - 0xff7fe000   ( 271 MB)
Sep 10 09:48:03 caroline-laptop kernel: [   26.205348]     lowmem  : 0xc0000000 - 0xedf70000   ( 735 MB)
Sep 10 09:48:03 caroline-laptop kernel: [   26.205349]       .init : 0xc03d9000 - 0xc042b000   ( 328 kB)
Sep 10 09:48:03 caroline-laptop kernel: [   26.205350]       .data : 0xc02f2434 - 0xc03d36d4   ( 900 kB)
Sep 10 09:48:03 caroline-laptop kernel: [   26.205351]       .text : 0xc0100000 - 0xc02f2434   (1993 kB)
Sep 10 09:48:03 caroline-laptop kernel: [   26.205355] Checking if this processor honours the WP bit even in supervisor mode... Ok.
Sep 10 09:48:03 caroline-laptop kernel: [   26.285868] Calibrating delay using timer specific routine.. 5070.08 BogoMIPS (lpj=10140169)
Sep 10 09:48:03 caroline-laptop kernel: [   26.286763] Security Framework v1.0.0 initialized
Sep 10 09:48:03 caroline-laptop kernel: [   26.286770] SELinux:  Disabled at boot.
Sep 10 09:48:03 caroline-laptop kernel: [   26.287143] Mount-cache hash table entries: 512
Sep 10 09:48:03 caroline-laptop kernel: [   26.287810] CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000 0000441d 00000000 00000000
Sep 10 09:48:03 caroline-laptop kernel: [   26.287821] monitor/mwait feature present.
Sep 10 09:48:03 caroline-laptop kernel: [   26.287823] using mwait in idle threads.
Sep 10 09:48:03 caroline-laptop kernel: [   26.287832] CPU: Trace cache: 12K uops, L1 D cache: 16K
Sep 10 09:48:03 caroline-laptop kernel: [   26.287835] CPU: L2 cache: 256K
Sep 10 09:48:03 caroline-laptop kernel: [   26.287839] CPU: Hyper-Threading is disabled
Sep 10 09:48:03 caroline-laptop kernel: [   26.287841] CPU: After all inits, caps: bfebfbff 00000000 00000000 00003180 0000441d 00000000 00000000
Sep 10 09:48:03 caroline-laptop kernel: [   26.287854] Compat vDSO mapped to ffffe000.
Sep 10 09:48:03 caroline-laptop kernel: [   26.287859] Remapping vsyscall page to ffffe000
Sep 10 09:48:03 caroline-laptop kernel: [   26.287880] Checking 'hlt' instruction... OK.
Sep 10 09:48:03 caroline-laptop kernel: [   26.301991] SMP alternatives: switching to UP code
Sep 10 09:48:03 caroline-laptop kernel: [   26.302348] Freeing SMP alternatives: 11k freed
Sep 10 09:48:03 caroline-laptop kernel: [   38.727252] ACPI: Core revision 20060707
Sep 10 09:48:03 caroline-laptop kernel: [   38.764569] ACPI: Looking for DSDT in initramfs... file /DSDT.aml not found, using machine DSDT.
Sep 10 09:48:03 caroline-laptop kernel: [   38.776325] CPU0: Intel(R) Celeron(R) CPU 2.53GHz stepping 01
Sep 10 09:48:03 caroline-laptop kernel: [   38.776857] Total of 1 processors activated (5070.08 BogoMIPS).
Sep 10 09:48:03 caroline-laptop kernel: [   38.777304] ENABLING IO-APIC IRQs
Sep 10 09:48:03 caroline-laptop kernel: [   38.778429] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Sep 10 09:48:03 caroline-laptop kernel: [   38.818291] ..MP-BIOS bug: 8254 timer not connected to IO-APIC
Sep 10 09:48:03 caroline-laptop kernel: [   38.818573] ...trying to set up timer (IRQ0) through the 8259A ...  failed.
Sep 10 09:48:03 caroline-laptop kernel: [   38.818738] ...trying to set up timer as Virtual Wire IRQ... works.
Sep 10 09:48:03 caroline-laptop kernel: [   38.965341] Brought up 1 CPUs
Sep 10 09:48:03 caroline-laptop kernel: [   38.974806] Booting paravirtualized kernel on bare hardware
Sep 10 09:48:03 caroline-laptop kernel: [   38.976036] Time:  9:46:16  Date: 08/10/107
Sep 10 09:48:03 caroline-laptop kernel: [   38.977191] NET: Registered protocol family 16
Sep 10 09:48:03 caroline-laptop kernel: [   38.979035] EISA bus registered
Sep 10 09:48:03 caroline-laptop kernel: [   38.979192] ACPI: bus type pci registered
Sep 10 09:48:03 caroline-laptop kernel: [   39.031530] PCI: PCI BIOS revision 2.10 entry at 0xfd993, last bus=2
Sep 10 09:48:03 caroline-laptop kernel: [   39.031675] PCI: Using configuration type 1
Sep 10 09:48:03 caroline-laptop kernel: [   39.031792] Setting up standard PCI resources
Sep 10 09:48:03 caroline-laptop kernel: [   39.183899] ACPI: Interpreter enabled
Sep 10 09:48:03 caroline-laptop kernel: [   39.184013] ACPI: Using IOAPIC for interrupt routing
Sep 10 09:48:03 caroline-laptop kernel: [   39.207020] ACPI: PCI Root Bridge [PCI0] (0000:00)
Sep 10 09:48:03 caroline-laptop kernel: [   39.207165] PCI: Probing PCI hardware (bus 00)
Sep 10 09:48:03 caroline-laptop kernel: [   39.256856] Boot video device is 0000:01:05.0
Sep 10 09:48:03 caroline-laptop kernel: [   39.260422] PCI: Transparent bridge - 0000:00:14.4
Sep 10 09:48:03 caroline-laptop kernel: [   39.262272] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Sep 10 09:48:03 caroline-laptop kernel: [   39.356859] ACPI: PCI Interrupt Link [LNK0] (IRQs 10 11) *0, disabled.
Sep 10 09:48:03 caroline-laptop kernel: [   39.367941] ACPI: PCI Interrupt Link [LNK1] (IRQs 10 11) *0, disabled.
Sep 10 09:48:03 caroline-laptop kernel: [   39.379019] ACPI: PCI Interrupt Link [LNK2] (IRQs 10 11) *0, disabled.
Sep 10 09:48:03 caroline-laptop kernel: [   39.390200] ACPI: PCI Interrupt Link [LNK3] (IRQs 10 11) *0, disabled.
Sep 10 09:48:03 caroline-laptop kernel: [   39.483621] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGP_._PRT]
Sep 10 09:48:03 caroline-laptop kernel: [   39.511451] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2P_._PRT]
Sep 10 09:48:03 caroline-laptop kernel: [   39.532617] Linux Plug and Play Support v0.97 (c) Adam Belay
Sep 10 09:48:03 caroline-laptop kernel: [   39.532963] pnp: PnP ACPI init
Sep 10 09:48:03 caroline-laptop kernel: [   39.665459] pnp: PnP ACPI: found 9 devices
Sep 10 09:48:03 caroline-laptop kernel: [   39.665583] PnPBIOS: Disabled by ACPI PNP
Sep 10 09:48:03 caroline-laptop kernel: [   39.667192] PCI: Using ACPI for IRQ routing
Sep 10 09:48:03 caroline-laptop kernel: [   39.667327] PCI: If a device doesn't work, try "pci=routeirq".  If it helps, post a report
Sep 10 09:48:03 caroline-laptop kernel: [   39.684270] NET: Registered protocol family 8
Sep 10 09:48:03 caroline-laptop kernel: [   39.684401] NET: Registered protocol family 20
Sep 10 09:48:03 caroline-laptop kernel: [   39.694341] pnp: 00:07: ioport range 0x1080-0x1080 has been reserved
Sep 10 09:48:03 caroline-laptop kernel: [   39.694529] pnp: 00:07: ioport range 0x40b-0x40b has been reserved
Sep 10 09:48:03 caroline-laptop kernel: [   39.694711] pnp: 00:07: ioport range 0x4d0-0x4d1 has been reserved
Sep 10 09:48:03 caroline-laptop kernel: [   39.694895] pnp: 00:07: ioport range 0x4d6-0x4d6 has been reserved
Sep 10 09:48:03 caroline-laptop kernel: [   39.702082] PCI: Bridge: 0000:00:01.0
Sep 10 09:48:03 caroline-laptop kernel: [   39.702227]   IO window: 9000-9fff
Sep 10 09:48:03 caroline-laptop kernel: [   39.702391]   MEM window: f0100000-f01fffff
Sep 10 09:48:03 caroline-laptop kernel: [   39.702557]   PREFETCH window: f8000000-fbffffff
Sep 10 09:48:03 caroline-laptop kernel: [   39.703082] PCI: Bus 3, cardbus bridge: 0000:02:01.0
Sep 10 09:48:03 caroline-laptop kernel: [   39.703227]   IO window: 0000a000-0000a0ff
Sep 10 09:48:03 caroline-laptop kernel: [   39.703380]   IO window: 0000a400-0000a4ff
Sep 10 09:48:03 caroline-laptop kernel: [   39.703544]   PREFETCH window: 40000000-43ffffff
Sep 10 09:48:03 caroline-laptop kernel: [   39.703711]   MEM window: 4c000000-4fffffff
Sep 10 09:48:03 caroline-laptop kernel: [   39.703858] PCI: Bus 7, cardbus bridge: 0000:02:01.1
Sep 10 09:48:03 caroline-laptop kernel: [   39.704004]   IO window: 0000a800-0000a8ff
Sep 10 09:48:03 caroline-laptop kernel: [   39.704268]   IO window: 0000ac00-0000acff
Sep 10 09:48:03 caroline-laptop kernel: [   39.704430]   PREFETCH window: 44000000-47ffffff
Sep 10 09:48:03 caroline-laptop kernel: [   39.704597]   MEM window: 50000000-53ffffff
Sep 10 09:48:03 caroline-laptop kernel: [   39.704729] PCI: Bridge: 0000:00:14.4
Sep 10 09:48:03 caroline-laptop kernel: [   39.704871]   IO window: a000-bfff
Sep 10 09:48:03 caroline-laptop kernel: [   39.705033]   MEM window: f0200000-f07fffff
Sep 10 09:48:03 caroline-laptop kernel: [   39.705199]   PREFETCH window: 40000000-49ffffff
Sep 10 09:48:03 caroline-laptop kernel: [   39.705572] ACPI: PCI Interrupt 0000:02:01.0[A] -> GSI 17 (level, low) -> IRQ 16
Sep 10 09:48:03 caroline-laptop kernel: [   39.705896] PCI: Enabling device 0000:02:01.1 (0004 -> 0007)
Sep 10 09:48:03 caroline-laptop kernel: [   39.706067] ACPI: PCI Interrupt 0000:02:01.1[B] -> GSI 18 (level, low) -> IRQ 17
Sep 10 09:48:03 caroline-laptop kernel: [   39.707177] NET: Registered protocol family 2
Sep 10 09:48:03 caroline-laptop kernel: [   39.746023] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Sep 10 09:48:03 caroline-laptop kernel: [   39.749095] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Sep 10 09:48:03 caroline-laptop kernel: [   39.751047] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
Sep 10 09:48:03 caroline-laptop kernel: [   39.752270] TCP: Hash tables configured (established 131072 bind 65536)
Sep 10 09:48:03 caroline-laptop kernel: [   39.752408] TCP reno registered
Sep 10 09:48:03 caroline-laptop kernel: [  102.205821] Freeing initrd memory: 6780k freed
Sep 10 09:48:03 caroline-laptop kernel: [  102.212330] audit: initializing netlink socket (disabled)
Sep 10 09:48:03 caroline-laptop kernel: [  102.212580] audit(1189417639.104:1): initialized
Sep 10 09:48:03 caroline-laptop kernel: [  102.215840] VFS: Disk quotas dquot_6.5.1
Sep 10 09:48:03 caroline-laptop kernel: [  102.216502] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Sep 10 09:48:03 caroline-laptop kernel: [  102.218032] io scheduler noop registered
Sep 10 09:48:03 caroline-laptop kernel: [  102.218161] io scheduler anticipatory registered
Sep 10 09:48:03 caroline-laptop kernel: [  102.218299] io scheduler deadline registered
Sep 10 09:48:03 caroline-laptop kernel: [  102.219195] io scheduler cfq registered (default)
Sep 10 09:48:03 caroline-laptop kernel: [  102.751712] isapnp: Scanning for PnP cards...
Sep 10 09:48:03 caroline-laptop kernel: [  103.106384] isapnp: No Plug & Play device found
Sep 10 09:48:03 caroline-laptop kernel: [  103.636848] Real Time Clock Driver v1.12ac
Sep 10 09:48:03 caroline-laptop kernel: [  103.637665] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Sep 10 09:48:03 caroline-laptop kernel: [  103.647166] ACPI: PCI Interrupt 0000:00:14.6[B] -> GSI 17 (level, low) -> IRQ 16
Sep 10 09:48:03 caroline-laptop kernel: [  103.647398] ACPI: PCI interrupt for device 0000:00:14.6 disabled
Sep 10 09:48:03 caroline-laptop kernel: [  103.648702] mice: PS/2 mouse device common for all mice
Sep 10 09:48:03 caroline-laptop kernel: [  103.663738] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
Sep 10 09:48:03 caroline-laptop kernel: [  103.668405] input: Macintosh mouse button emulation as /class/input/input0
Sep 10 09:48:03 caroline-laptop kernel: [  103.669372] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Sep 10 09:48:03 caroline-laptop kernel: [  103.669536] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Sep 10 09:48:03 caroline-laptop kernel: [  103.671818] PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSE0] at 0x60,0x64 irq 1,12
Sep 10 09:48:03 caroline-laptop kernel: [  103.674915] i8042.c: Detected active multiplexing controller, rev 1.1.
Sep 10 09:48:03 caroline-laptop kernel: [  103.677887] serio: i8042 KBD port at 0x60,0x64 irq 1
Sep 10 09:48:03 caroline-laptop kernel: [  103.678144] serio: i8042 AUX0 port at 0x60,0x64 irq 12
Sep 10 09:48:03 caroline-laptop kernel: [  103.678333] serio: i8042 AUX1 port at 0x60,0x64 irq 12
Sep 10 09:48:03 caroline-laptop kernel: [  103.678523] serio: i8042 AUX2 port at 0x60,0x64 irq 12
Sep 10 09:48:03 caroline-laptop kernel: [  103.678714] serio: i8042 AUX3 port at 0x60,0x64 irq 12
Sep 10 09:48:03 caroline-laptop kernel: [  103.680644] EISA: Probing bus 0 at eisa.0
Sep 10 09:48:03 caroline-laptop kernel: [  103.680887] Cannot allocate resource for EISA slot 1
Sep 10 09:48:03 caroline-laptop kernel: [  103.681229] Cannot allocate resource for EISA slot 8
Sep 10 09:48:03 caroline-laptop kernel: [  103.681364] EISA: Detected 0 cards.
Sep 10 09:48:03 caroline-laptop kernel: [  103.720246] TCP cubic registered
Sep 10 09:48:03 caroline-laptop kernel: [  103.720564] NET: Registered protocol family 1
Sep 10 09:48:03 caroline-laptop kernel: [  103.721714] Using IPI No-Shortcut mode
Sep 10 09:48:03 caroline-laptop kernel: [  103.723121] ACPI: (supports S0 S3 S4 S5)
Sep 10 09:48:03 caroline-laptop kernel: [  103.724726] Time: tsc clocksource has been installed.
Sep 10 09:48:03 caroline-laptop kernel: [  103.727186]   Magic number: 7:956:777
Sep 10 09:48:03 caroline-laptop kernel: [  103.729739] Freeing unused kernel memory: 328k freed
Sep 10 09:48:03 caroline-laptop kernel: [  103.743993] input: AT Translated Set 2 keyboard as /class/input/input1
Sep 10 09:48:03 caroline-laptop kernel: [  105.314569] Capability LSM initialized
Sep 10 09:48:03 caroline-laptop kernel: [  105.709807] ACPI: CPU0 (power states: C1[C1] C2[C2])
Sep 10 09:48:03 caroline-laptop kernel: [  105.709835] ACPI Exception (acpi_processor-0677): AE_NOT_FOUND, Processor Device is not present [20060707]
Sep 10 09:48:03 caroline-laptop kernel: [  106.008993] ACPI: Thermal Zone [THRM] (50 C)
Sep 10 09:48:03 caroline-laptop kernel: [  107.508389] usbcore: registered new interface driver usbfs
Sep 10 09:48:03 caroline-laptop kernel: [  107.508441] usbcore: registered new interface driver hub
Sep 10 09:48:03 caroline-laptop kernel: [  107.508496] usbcore: registered new device driver usb
Sep 10 09:48:03 caroline-laptop kernel: [  107.509771] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
Sep 10 09:48:03 caroline-laptop kernel: [  107.509835] ACPI: PCI Interrupt 0000:00:13.0[A] -> GSI 19 (level, low) -> IRQ 18
Sep 10 09:48:03 caroline-laptop kernel: [  107.509862] ohci_hcd 0000:00:13.0: OHCI Host Controller
Sep 10 09:48:03 caroline-laptop kernel: [  107.510045] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 1
Sep 10 09:48:03 caroline-laptop kernel: [  107.510136] ohci_hcd 0000:00:13.0: irq 18, io mem 0xf0001000
Sep 10 09:48:03 caroline-laptop kernel: [  107.546133] SCSI subsystem initialized
Sep 10 09:48:03 caroline-laptop kernel: [  107.553249] libata version 2.20 loaded.
Sep 10 09:48:03 caroline-laptop kernel: [  108.108307] usb usb1: configuration #1 chosen from 1 choice
Sep 10 09:48:03 caroline-laptop kernel: [  108.108371] hub 1-0:1.0: USB hub found
Sep 10 09:48:03 caroline-laptop kernel: [  108.108439] hub 1-0:1.0: 3 ports detected
Sep 10 09:48:03 caroline-laptop kernel: [   81.716000] Time: acpi_pm clocksource has been installed.
Sep 10 09:48:03 caroline-laptop kernel: [   81.844000] ACPI: PCI Interrupt 0000:00:13.1[A] -> GSI 19 (level, low) -> IRQ 18
Sep 10 09:48:03 caroline-laptop kernel: [   81.844000] ohci_hcd 0000:00:13.1: OHCI Host Controller
Sep 10 09:48:03 caroline-laptop kernel: [   81.844000] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 2
Sep 10 09:48:03 caroline-laptop kernel: [   81.844000] ohci_hcd 0000:00:13.1: irq 18, io mem 0xf0002000
Sep 10 09:48:03 caroline-laptop kernel: [   82.408000] usb usb2: configuration #1 chosen from 1 choice
Sep 10 09:48:03 caroline-laptop kernel: [   82.408000] hub 2-0:1.0: USB hub found
Sep 10 09:48:03 caroline-laptop kernel: [   82.408000] hub 2-0:1.0: 3 ports detected
Sep 10 09:48:03 caroline-laptop kernel: [   82.924000] ACPI: PCI Interrupt 0000:00:13.2[A] -> GSI 19 (level, low) -> IRQ 18
Sep 10 09:48:03 caroline-laptop kernel: [   82.924000] ehci_hcd 0000:00:13.2: EHCI Host Controller
Sep 10 09:48:03 caroline-laptop kernel: [   82.924000] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 3
Sep 10 09:48:03 caroline-laptop kernel: [   82.924000] ehci_hcd 0000:00:13.2: irq 18, io mem 0xf0003000
Sep 10 09:48:03 caroline-laptop kernel: [   82.924000] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Sep 10 09:48:03 caroline-laptop kernel: [   82.928000] usb usb3: configuration #1 chosen from 1 choice
Sep 10 09:48:03 caroline-laptop kernel: [   82.928000] hub 3-0:1.0: USB hub found
Sep 10 09:48:03 caroline-laptop kernel: [   82.928000] hub 3-0:1.0: 6 ports detected
Sep 10 09:48:03 caroline-laptop kernel: [   83.032000] ATIIXP: IDE controller at PCI slot 0000:00:14.1
Sep 10 09:48:03 caroline-laptop kernel: [   83.032000] ACPI: Unable to derive IRQ for device 0000:00:14.1
Sep 10 09:48:03 caroline-laptop kernel: [   83.032000] ACPI: PCI Interrupt 0000:00:14.1[A]: no GSI
Sep 10 09:48:03 caroline-laptop kernel: [   83.032000] ATIIXP: chipset revision 0
Sep 10 09:48:03 caroline-laptop kernel: [   83.032000] ATIIXP: not 100%% native mode: will probe irqs later
Sep 10 09:48:03 caroline-laptop kernel: [   83.032000]     ide0: BM-DMA at 0x8070-0x8077, BIOS settings: hda:DMA, hdb:pio
Sep 10 09:48:03 caroline-laptop kernel: [   83.032000]     ide1: BM-DMA at 0x8078-0x807f, BIOS settings: hdc:DMA, hdd:pio
Sep 10 09:48:03 caroline-laptop kernel: [   83.032000] Probing IDE interface ide0...
Sep 10 09:48:03 caroline-laptop kernel: [   83.324000] hda: FUJITSU MHT2040AT, ATA DISK drive
Sep 10 09:48:03 caroline-laptop kernel: [   83.996000] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Sep 10 09:48:03 caroline-laptop kernel: [   84.392000] Probing IDE interface ide1...
Sep 10 09:48:03 caroline-laptop kernel: [   85.132000] hdc: HL-DT-STCD-RW/DVD DRIVE GCC-4243N, ATAPI CD/DVD-ROM drive
Sep 10 09:48:03 caroline-laptop kernel: [   85.468000] ide1 at 0x170-0x177,0x376 on irq 15
Sep 10 09:48:03 caroline-laptop kernel: [   85.476000] b44.c:v1.01 (Jun 16, 2006)
Sep 10 09:48:03 caroline-laptop kernel: [   85.476000] ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 19 (level, low) -> IRQ 18
Sep 10 09:48:03 caroline-laptop kernel: [   85.480000] eth0: Broadcom 4400 10/100BaseT Ethernet 00:c0:9f:78:a2:3b
Sep 10 09:48:03 caroline-laptop kernel: [   85.492000] hda: max request size: 128KiB
Sep 10 09:48:03 caroline-laptop kernel: [   85.516000] hda: 78140160 sectors (40007 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
Sep 10 09:48:03 caroline-laptop kernel: [   85.516000] hda: cache flushes supported
Sep 10 09:48:03 caroline-laptop kernel: [   85.516000]  hda: hda1 hda2 hda3 < hda5 hda6 >
Sep 10 09:48:03 caroline-laptop kernel: [   85.620000] hdc: ATAPI 24X DVD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Sep 10 09:48:03 caroline-laptop kernel: [   85.620000] Uniform CD-ROM driver Revision: 3.20
Sep 10 09:48:03 caroline-laptop kernel: [   87.096000] Attempting manual resume
Sep 10 09:48:03 caroline-laptop kernel: [   87.096000] swsusp: Resume From Partition 3:6
Sep 10 09:48:03 caroline-laptop kernel: [   87.096000] PM: Checking swsusp image.
Sep 10 09:48:03 caroline-laptop kernel: [   87.096000] PM: Resume from disk failed.
Sep 10 09:48:03 caroline-laptop kernel: [   87.180000] kjournald starting.  Commit interval 5 seconds
Sep 10 09:48:03 caroline-laptop kernel: [   87.180000] EXT3-fs: mounted filesystem with ordered data mode.
Sep 10 09:48:03 caroline-laptop kernel: [  107.180000] NET: Registered protocol family 17
Sep 10 09:48:03 caroline-laptop kernel: [  108.296000] Linux agpgart interface v0.102 (c) Dave Jones
Message édité par Ace17 le 10-09-2007 à 18:01:29
n°952710
Ace17
Posté le 12-09-2007 à 11:50:00  profilanswer
Bon ben finalement, j'ai craque et j'ai compile un nouveau noyau capable de demarrer sans initramfs, et ca demarre beaucoup plus vite.
Le mystere reste entier ...
  Installation
Installation Ubuntu....Installation double ecran sous Ubuntu
autoriser connexion entrante telnet sur Linux/Ubuntuvideo HD saccade sous Ubuntu
Boot UBUNTU live par PXE - PROBLEMEProblème de compilation de noyau UBUNTU [ABANDON]
Ubuntu 64 bits : contrôle à distance multi sessionsVLC + multiposte + Ubuntu
Ubuntu / GParted / Raid 5Linux (Ubuntu Feisty Fawn 7.04)
Plus de sujets relatifs à : [UBUNTU] Demarrage excessivement lent sur un Amilo V7010
