1165 connectés
  Linux et OS Alternatifs
  Installation
  Squid + SquidGuard = rien de bloqué.
n°865851
Walk_Man
To live is to die.
Posté le 24-11-2006 à 16:17:41  profilanswer
Bonjour, bon voila, ca fait pas mal de temps que je suis dessus, et sincerement je bloque.
Mon squid bloque que dalle.
squid.conf
http_port 3128 transparent
icp_port 0
visible_hostname                            serv001
#acls
acl                                         all src 0.0.0.0/0.0.0.0
acl                                         localhost src 127.0.0.1/255.255.255.255
acl                                         manager proto cache_object
acl                                         from_localhost src 127.0.0.1/255.255.255.255
acl                                         from_dmz src 192.0.1.0/24
cache_mgr                                   m.xxxxxxxxxxxx@xxxxxxxxxxxxxxxxxx.fr
logfile_rotate                              60
cache_dir                                   ufs /cache/squid 2048 16 256
cache_store_log                             /dev/null
cache_log                                   /dev/null
access_log                                  /var/log/squid/access.log squid
pid_filename                                /cache/squid/squid.pid
redirect_program                            /usr/local/bin/squidGuard  -c /usr/local/etc/squid/squidGuard.conf
http_access                                 allow from_dmz
http_access                                 allow manager from_localhost
http_access                                 deny manager
http_access                                 deny all
squidguard.conf
logdir /var/log/squid/
dbhome /var/db/squidGuard
#src admin {
#       ip 192.0.1.200-192.0.1.254
#src multipostes {
#       ip 192.0.1.1-192.0.1.199
dest forums {
        domainlist /var/db/squidGuard/forums/domains
        urllist /var/db/squidGuard/forums/urls
dest gambling {
        domainlist /var/db/squidGuard/gambling/domains
        urllist /var/db/squidGuard/gambling/urls
dest games {
        domainlist /var/db/squidGuard/games/domains
        urllist /var/db/squidGuard/games/urls
dest mail {
        domainlist /var/db/squidGuard/mail/domains
        urllist /var/db/squidGuard/mail/urls
dest mixed_adult {
        domainlist /var/db/squidGuard/mixed_adult/domains
dest porn {
        domainlist /var/db/squidGuard/porn/domains
        urllist /var/db/squidGuard/porn/urls
dest proxy {
        domainlist /var/db/squidGuard/proxy/domains
        urllist /var/db/squidGuard/proxy/urls
dest radio {
        domainlist /var/db/squidGuard/radio/domains
        urllist /var/db/squidGuard/radio/urls
dest warez {
        domainlist /var/db/squidGuard/warez/domains
        urllist /var/db/squidGuard/warez/urls
acl {
        admin {
        pass all
acl {
    default {
        pass !forums !gambling !games !mail !mixed_adult !porn !proxy !radio !warez all
        redirect http://192.0.1.209/index.html
Deux choses m'intriguent.
La premiere rien n'est écris dans mon access.log
La deuxieme est que j'ai bien les process qui tournent
root@serv001:~# ps -aux | grep squid
squid   477  3.0  0.3  4560  1752  ??  Ds    4:10PM   0:30.04 (squidGuard) -c /usr/local/etc/squid/squidGuard.conf (squidGuard)
squid   478  2.0  0.3  4560  1752  ??  Ds    4:10PM   0:30.22 (squidGuard) -c /usr/local/etc/squid/squidGuard.conf (squidGuard)
squid   482  1.9  0.3  4560  1752  ??  Ds    4:10PM   0:30.32 (squidGuard) -c /usr/local/etc/squid/squidGuard.conf (squidGuard)
squid   472  1.8  0.3  4560  1744  ??  Ds    4:10PM   0:29.64 (squidGuard) -c /usr/local/etc/squid/squidGuard.conf (squidGuard)
squid   474  1.7  0.3  4560  1752  ??  Ds    4:10PM   0:28.61 (squidGuard) -c /usr/local/etc/squid/squidGuard.conf (squidGuard)
squid   458  0.0  0.3  3188  1460  ??  Is    4:10PM   0:00.00 /usr/local/sbin/squid -D
squid   461  0.0  1.4  7896  7136  ??  S     4:10PM   0:00.14 (squid) -D (squid)
squid   492  0.0  0.1  1172   540  ??  Is    4:10PM   0:00.00 (unlinkd) (unlinkd)
Merci pour votre bonté  [:tetardking]
n°865853
Walk_Man
To live is to die.
Posté le 24-11-2006 à 16:21:30  profilanswer
Et j'oubliais de préciser, dans /var/log/squidGuard.log tout se lance correctement, aucune trace de viandage
n°865862
boobaka
Posté le 24-11-2006 à 16:59:56  profilanswer
Tes clients tu les fais passer par ton Proxy?
n°865873
carot0
Posté le 24-11-2006 à 18:01:09  profilanswer
ok je vois ton probleme, tu fais un proxy transparent mais tu doit rediriger le trafique entrant sur le port 80 vers celui du proxy 3128
il faut une regle iptables pour cela : iptables -t nat -A PREROUTING -p tcp -m tcp --dport 80 -j REDIRECT --to-port 3128
edit : j'ai monté un squid + squidGuard la semaine derniere lol
Message édité par carot0 le 24-11-2006 à 18:02:07
In a world without walls and fences, who needs Windows and Gates
n°865997
Walk_Man
To live is to die.
Posté le 25-11-2006 à 03:55:21  profilanswer
boobaka -> pour le moment ya juste un poste de test :D
carot0 -> La redirection est faite, d'ailleurs, c'est pas un iptables mais un packet filter car c'est sur une gate FreeBSD et j'ai rajouté la ligne
rdr on $internal inet proto tcp from <lan> to !<lan> port 80 -> 127.0.0.1 port 3128
n°866006
carot0
Posté le 25-11-2006 à 09:30:46  profilanswer
la page http://192.0.1.209/index.html existe bien ?
ah oui quelle version de squid car la 2.6 stable 1 est buggé sur le proxy transparent
n°866450
Walk_Man
To live is to die.
Posté le 27-11-2006 à 10:18:38  profilanswer
Oui la page http://192.0.1.209/index.html existe bel et bien
heu, je suis en 2.6 Stable 1 ....  [:lezioul]
n°866736
Walk_Man
To live is to die.
Posté le 28-11-2006 à 12:37:23  profilanswer
J'ai trouvé !
Ca venait juste des droits sur mes .db apres avoir fait un squidguard -C all
ca basculait les droits sur root.
Tiens sinon, en message d'erreur vous mettez quoi ? La j'ai mis un pauvre index.html, vous preferez les cgi ?
n°866742
carot0
Posté le 28-11-2006 à 12:41:22  profilanswer
Walk_Man a écrit :
J'ai trouvé !
je deteste pas les cgi mais ceux fourni avec squidguard merde sur les caractere fr...
puis je m'en fais un perso en C++ au moins ca dira ce que je veux!
n°866771
Walk_Man
To live is to die.
Posté le 28-11-2006 à 14:32:45  profilanswer
Tu voudrais pas le partager a une pauvre ame en peine ? :whistle:
n°866773
carot0
Posté le 28-11-2006 à 14:37:07  profilanswer
deja il est pas fini puis il est vachement personalisé avec le style de ma boite...
mais je peux te filer des bout de code C pour en faire un toi meme si tu veux
n°866776
Walk_Man
To live is to die.
Posté le 28-11-2006 à 15:02:45  profilanswer
Ca serait avec plaisir :jap:
n°866785
carot0
Posté le 28-11-2006 à 15:37:24  profilanswer
voila de koi commencer :
Code :
  1. #include <stdlib.h>
  2. #include <iostream>
  3. using namespace std;
  4. int main ( int argc, char ** argv)
  5. {
  6. string site;
  7. site=getenv("QUERY_STRING" );
  8. cout<<"Content-type: text/html\n\n"<<endl;
  9. //head
  10. cout<<"<!DOCTYPE html PUBLIC \"-//W3C//DTD HTML 4.01 Transitional//EN\"><html><head><meta content=\"text/html; charset=ISO-8859-1\" http-equiv=\"content-type\"><title> </title><link href=\"style.css\" rel=\"stylesheet\" type=\"text/css\"></head>"<<endl;
  11. //body
  12. cout<<"<body> </body></html>"<<endl;
  13. return 0;
  14. }
avec getenv("QUERY_STRING" ); qui retourne les arguments passer au cgi. Peut necessiter un traitement
n°866786
Walk_Man
To live is to die.
Posté le 28-11-2006 à 15:38:42  profilanswer
Ok je vais voir ca :jap:
Au fait, question SUPER conne.
le cgi, besoin de le compiler, ou l'interpreteur d'apache s'en sert, et on mets donc direct ca dans le rep cgi-bin ?
n°866793
Walk_Man
To live is to die.
Posté le 28-11-2006 à 15:47:56  profilanswer
En fait je vais google :x
n°866796
carot0
Posté le 28-11-2006 à 16:04:16  profilanswer
c'est du c/c++ cela necessite une compilation + linkage donc g++ nomdufichier.cpp -o nomdubinaire
n°866830
Walk_Man
To live is to die.
Posté le 28-11-2006 à 17:50:06  profilanswer
Merci bcp :jap:
n°871908
Walk_Man
To live is to die.
Posté le 18-12-2006 à 16:39:30  profilanswer
Me re-voila !
Je monte un deuxieme serveur squid, à base de meme distrib, meme type de machine, blabla easy.
Je reprends tout mes conf je c/p, et la j'ai une tuile, quand je fais une requete, ce con de squid me sort
192.0.1.190 TCP_MISS/503 1409 GET http://www.meetic.fr:3128/ - DIRECT/62.23.26.6 text/html
au lieu de
192.0.1.190 TCP_IMS_HIT/304 259 GET http://www.meetic.fr/CSS/sheet.css - NONE/- text/html
et oui il y a le :3128 en trop.
Je ne comprends pas pourquoi squid patoge comme ca :(
merci d'avance :jap:
¡ Viva la Revolución !
n°871919
Tomate
Posté le 18-12-2006 à 17:20:13  profilanswer
et personne n'a couplé un squid avec clamav par hasard ? :D
n°871920
toniotonio
Posté le 18-12-2006 à 17:22:20  profilanswer
tu peux le faire avec squidclam ou bien squidwall
cela marche tres bien avec un temps de reponse tres bon
dansguardian le fait egalement en plus du reste mais il n'est gratuit que pour une utilisation personnelle
Message édité par toniotonio le 18-12-2006 à 17:22:58
n°871924
Walk_Man
To live is to die.
Posté le 18-12-2006 à 17:34:56  profilanswer
J'en suis bien loin malheuresement :)
n°871925
Tomate
Posté le 18-12-2006 à 17:35:25  profilanswer
ah parce que moi il me dit à chaque fois qu'il ne traite pas car pas dans la liste :lol:
bon je ferais un topic à l'occasion ;)
:: Light is Right ::
n°872230
Walk_Man
To live is to die.
Posté le 19-12-2006 à 16:44:14  profilanswer
Bon, au cas où quelqu'un suive encore mes ébats avec squid.
J'ai un petit probleme avec certains sites.
Par exemple
les messageries genre hotmail, on s'auth, et rien ne se passe ou alors
guilwebonline.com, la page timeout, alors qu'en direct ca fonctionne sans probleme.
n°872253
Tomate
Posté le 19-12-2006 à 17:07:55  profilanswer
pour hotmail c'est un avantage :whistle:
n°872263
Walk_Man
To live is to die.
Posté le 19-12-2006 à 17:21:51  profilanswer
Pas quand une conne n'a rien trouvé de mieu que de se faire une boite pro dessus  [:tetardking]
n°872268
Zzozo
Modérateur
Un peu, passionément, à la fol
Posté le 19-12-2006 à 17:29:00  profilanswer
[:xx_xx]
Pro ... ouais, c'est ce qu'elle essaye de te faire croire  [:cupra]
Remarque, elle a quelle profession en fait ? :whistle:
Message édité par Zzozo le 19-12-2006 à 17:30:08
« Ce qui ne vous tue pas vous rend plus fort » F. Nietzsche | « Vise_ la Lune. Si tu rates, au pire, t'es dans la merde » Un poète disparu dans le cercle
n°872297
Walk_Man
To live is to die.
Posté le 19-12-2006 à 18:10:12  profilanswer
Zzozo a écrit :
[:xx_xx]
Sisi j'ai deja vu les mails.
Et heu je prefere ne rien dire au sujet de la société !
/me sort son fusil anti-chacal :D
Edit : bon sinon une idée quand meme pour me sortir du pétrin ? :x
Message édité par Walk_Man le 19-12-2006 à 18:10:27
n°872312
Tomate
Posté le 19-12-2006 à 19:31:43  profilanswer
beh à part te dire de regarder les logs pour l'instant :spamafote:
Message édité par Tomate le 19-12-2006 à 19:31:49
n°872404
Walk_Man
To live is to die.
Posté le 20-12-2006 à 01:24:53  profilanswer
Ah bah oui tiens, j'ai pas copié les logs :D
Ca m'apprendra a poster cerveau éteint  [:shinji_kun64]
n°872456
Walk_Man
To live is to die.
Posté le 20-12-2006 à 11:31:55  profilanswer
Bon, je ne me suis pas fait chier, j'ai nat l'https et pouf on en parle plus.
pass in on $internal inet proto tcp from any to any port 443 keep state
n°894324
Walk_Man
To live is to die.
Posté le 11-03-2007 à 22:37:23  profilanswer
Hello les gens.
Me revoila avec mon squid, et j'ai une question assez simple.
Connaissez-vous un bon moyen de générer des pages de stats genre telle ip a surfez sur tant de temps sur internet, et a ramené xxxx mo depuis internet ?
Ce genre de chose quoi.
J'ai regardé sur http://www.squid-cache.org/related-software.html mais je n'ai rien trouvé de bien passionant.
Merci par avance.
  Installation
Squid + Ncsa authentificationSQUID ou la réstriction par IP et site
créer un proxy squid dans un squid existant ?SquidGuard+Blacklist savoir quelle destination bloc ?
Quel soft pour analyser mes logs Squid[debian] probleme Samba, question Squid
Pb squid et webmin[Squid] probleme vers le UPStream -> DNS ?
Squid et ldap_authViralator + SquidGuard
Plus de sujets relatifs à : Squid + SquidGuard = rien de bloqué.
