joce Architecte / Développeur principal "BugHunter" | J'arrive pas à avoir d'image sur le moniteur 2 avec le xinerama :
(II) RADEON(0): EDID data from the display on port 1 ----------------------
(II) RADEON(0): Manufacturer: DEL Model: a010 Serial#: 808531795
(II) RADEON(0): Year: 2005 Week: 33
(II) RADEON(0): EDID Version: 1.3
(II) RADEON(0): Digital Display Input
(II) RADEON(0): Max H-Image Size [cm]: horiz.: 52 vert.: 33
(II) RADEON(0): Gamma: 2.20
(II) RADEON(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) RADEON(0): Default color space is primary color space
(II) RADEON(0): First detailed timing is preferred mode
(II) RADEON(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.607
(II) RADEON(0): blueX: 0.149 blueY: 0.060 whiteX: 0.312 whiteY: 0.328
(II) RADEON(0): Supported VESA Video Modes:
(II) RADEON(0): 720x400@70Hz
(II) RADEON(0): 640x480@60Hz
(II) RADEON(0): 640x480@75Hz
(II) RADEON(0): 800x600@60Hz
(II) RADEON(0): 800x600@75Hz
(II) RADEON(0): 1024x768@60Hz
(II) RADEON(0): 1024x768@75Hz
(II) RADEON(0): 1280x1024@75Hz
(II) RADEON(0): Manufacturer's mask: 0
(II) RADEON(0): Supported Future Video Modes:
(II) RADEON(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) RADEON(0): #1: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
(II) RADEON(0): #2: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) RADEON(0): #3: hsize: 1680 vsize 1050 refresh: 60 vid: 179
(II) RADEON(0): Supported additional Video Mode:
(II) RADEON(0): clock: 154.0 MHz Image Size: 519 x 324 mm
(II) RADEON(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
(II) RADEON(0): v_active: 1200 v_sync: 1203 v_sync_end 1209 v_blanking: 1235 v_border: 0
(II) RADEON(0): Serial No: M675458A017S
(II) RADEON(0): Monitor name: DELL 2405FPW
(II) RADEON(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 81 kHz, PixClock max 170 MHz
(II) RADEON(0): EDID data from the display on port 2-----------------------
(II) RADEON(0): Manufacturer: DEL Model: a00f Serial#: 808537683
(II) RADEON(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
(II) RADEON(0): Sync: Separate Composite SyncOnGreen
(II) RADEON(0): Serial No: M675458A01NS
(II) RADEON(0):
(II) RADEON(0): Primary:
Monitor -- TMDS
Connector -- DVI-I
DAC Type -- TVDAC/ExtDAC
TMDS Type -- Internal
DDC Type -- DVI_DDC
(II) RADEON(0): Secondary:
Monitor -- CRT
Connector -- VGA
DAC Type -- Primary
TMDS Type -- NONE
DDC Type -- VGA_DDC
(II) RADEON(0): PLL parameters: rf=2700 rd=12 min=20000 max=40000; xclk=29700
(WW) RADEON(0): Failed to detect secondary monitor, MergedFB/Clone mode disabled
Pourtant ce con il a bien détecté les deux moniteurs et le fait que le deuxième soit sur le connecteur VGA
et il configure bien RADEON(1) en plus
(II) RADEON(1): MMIO registers at 0xfdff0000
(II) RADEON(1): PCI bus 1 card 0 func 0
(++) RADEON(1): Depth 24, (--) framebuffer bpp 32
(II) RADEON(1): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) RADEON(1): Default visual is TrueColor
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Reloading /usr/X11/lib/modules/libvgahw.so
(II) RADEON(1): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(==) RADEON(1): RGB weight 888
(II) RADEON(1): Using 8 bits per RGB (8 bit DAC)
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Reloading /usr/X11/lib/modules/libint10.so
(II) RADEON(1): initializing int10
(II) RADEON(0): Primary V_BIOS segment is: 0xc000
(**) RADEON(1): Chipset: "ATI Radeon 9600 AP (AGP)" (ChipID = 0x4150)
(--) RADEON(1): Linear framebuffer at 0xd0000000
(--) RADEON(1): VideoRAM: 131072 kByte (128 bit DDR SDRAM)
(II) RADEON(1): Using 65536k of videoram for secondary head
(II) RADEON(1): Color tiling disabled
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Reloading /usr/X11/lib/modules/libddc.so
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Reloading /usr/X11/lib/modules/libi2c.so
(II) RADEON(1): I2C bus "DDC" initialized.
(II) RADEON(1): Legacy BIOS detected
(II) RADEON(1): PLL parameters: rf=2700 rd=12 min=20000 max=40000; xclk=29700
(==) RADEON(1): Using gamma correction (1.0, 1.0, 1.0)
(II) RADEON(1): Validating modes on Secondary head ---------
(II) RADEON(1): Monitor1: Using hsync range of 30.00-81.00 kHz
(II) RADEON(1): Monitor1: Using vrefresh range of 56.00-76.00 Hz
(II) RADEON(1): Clock range: 20.00 to 400.00 MHz
à moins que ca soit le
(II) RADEON(1): Not using default mode "1920x1200" (hsync out of range)
(II) RADEON(1): Not using default mode "960x600" (bad mode clock/interlace/doublescan)
(--) RADEON(1): Virtual size is 1920x1200 (pitch 1920)
(**) RADEON(1): *Default mode "1920x1200": 151.2 MHz, 73.5 kHz, 59.6 Hz
(II) RADEON(1): Modeline "1920x1200" 151.20 1920 1928 1992 2056 1200 1202 1206 1234 +hsync +vsync
(--) RADEON(1): Display dimensions: (520, 330) mm
(--) RADEON(1): DPI set to (93, 92)
qui déconne |
