1612 connectés
La 15.0 est là (en vrai !)
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  73  74  75  ..  107  108  109  110  111  112
[SLACKWARE] du présent - 15.0
n°1408032
cycojesus
Mèo Lười
Posté le 20-09-2017 à 07:08:03  profilanswer
Tue Sep 19 20:49:07 UTC 2017
l/freetype-2.8-x86_64-1.txz:  Upgraded.
  Reverted due to rendering issues with programs such as Firefox that violate
  the Freetype API. We'll revisit this after upstream programs have some time
  to catch up.
x/libinput-1.8.2-x86_64-1.txz:  Upgraded.
les bêtises de firefox
Chết rồi ! ✍ ⌥⌘ http://github.com/gwenhael-le-moine/slackbuilds/
n°1408042
cycojesus
Mèo Lười
Posté le 21-09-2017 à 08:58:37  profilanswer
Thu Sep 21 01:23:24 UTC 2017
n/samba-4.6.8-x86_64-1.txz:  Upgraded.
  This is a security release in order to address the following defects:
  SMB1/2/3 connections may not require signing where they should. A man in the
  middle attack may hijack client connections.
  SMB3 connections don't keep encryption across DFS redirects. A man in the
  middle attack can read and may alter confidential documents transferred via
  a client connection, which are reached via DFS redirect when the original
  connection used SMB3.
  Server memory information leak over SMB1. Client with write access to a share
  can cause server memory contents to be written into a file or printer.
  For more information, see:
    https://www.samba.org/samba/security/CVE-2017-12150.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12150
    https://www.samba.org/samba/security/CVE-2017-12151.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12151
    https://www.samba.org/samba/security/CVE-2017-12163.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12163
  (* Security fix *)
Désolé, aucune réponse n'a été trouvée !
n°1408109
cycojesus
Mèo Lười
Posté le 23-09-2017 à 10:51:34  profilanswer
Sat Sep 23 01:02:32 UTC 2017
Good hello! Python 3 has made its entry into -current. :-) Huge thanks are due
to Heinz Wiesinger for a great effort maintaining and testing this on the side
for months now, and for queuing it up for an easy merge without all that many
changes needed, and to Audrius Kažukauskas for maintaining the Python 3
build scripts on slackbuilds.org for years (on which our Python 3 SlackBuild
was based). Enjoy!
a/glibc-solibs-2.26-x86_64-3.txz:  Rebuilt.
a/kmod-24-x86_64-2.txz:  Rebuilt.
  Added python3 bindings.
a/util-linux-2.30.2-x86_64-1.txz:  Upgraded.
ap/hplip-3.17.9-x86_64-1.txz:  Upgraded.
  Switch to using python3.
ap/pamixer-1.3.1-x86_64-4.txz:  Rebuilt.
  Compiled against boost-1.65.1.
ap/rpm-4.13.0.1-x86_64-1.txz:  Upgraded.
d/Cython-0.26.1-x86_64-1.txz:  Upgraded.
d/cmake-3.9.3-x86_64-1.txz:  Upgraded.
d/gdb-8.0.1-x86_64-2.txz:  Rebuilt.
d/python-2.7.14-x86_64-1.txz:  Upgraded.
  Updated to the latest 2.7.x release.
  This fixes some security issues related to the bundled expat library.
  Note that -current is now using the system expat library instead.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0718
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4472
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9063
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9233
  (* Security fix *)
d/python-pip-9.0.1-x86_64-1.txz:  Added.
d/python-setuptools-36.5.0-x86_64-1.txz:  Upgraded.
d/python3-3.6.2-x86_64-1.txz:  Added.
kde/calligra-2.9.11-x86_64-15.txz:  Rebuilt.
kde/kdev-python-1.7.3-x86_64-1.txz:  Upgraded.
kde/kdevelop-4.7.4-x86_64-1.txz:  Upgraded.
kde/kdevelop-php-1.7.4-x86_64-1.txz:  Upgraded.
kde/kdevelop-php-docs-1.7.4-x86_64-1.txz:  Upgraded.
kde/kdevplatform-1.7.4-x86_64-1.txz:  Upgraded.
kde/kig-4.14.3-x86_64-6.txz:  Rebuilt.
kde/pykde4-4.14.3-x86_64-6.txz:  Rebuilt.
  Added python3 version.
l/M2Crypto-0.26.2-x86_64-1.txz:  Upgraded.
l/PyQt-4.12.1-x86_64-1.txz:  Upgraded.
l/QScintilla-2.10.1-x86_64-1.txz:  Upgraded.
l/akonadi-1.13.0-x86_64-7.txz:  Rebuilt.
l/boost-1.65.1-x86_64-1.txz:  Upgraded.
  Added libboost_python3.
  Shared library .so-version bump.
l/dbus-python-1.2.4-x86_64-3.txz:  Rebuilt.
l/glibc-2.26-x86_64-3.txz:  Rebuilt.
  Applied an upstream patch to fix finding the location of shared libraries
  with some Steam games and possibly other programs. Thanks to sbolokanov.
l/glibc-i18n-2.26-x86_64-3.txz:  Rebuilt.
l/glibc-profile-2.26-x86_64-3.txz:  Rebuilt.
l/libcaca-0.99.beta19-x86_64-2.txz:  Rebuilt.
l/libcap-ng-0.7.8-x86_64-2.txz:  Rebuilt.
l/libproxy-0.4.15-x86_64-1.txz:  Upgraded.
l/libwebp-0.6.0-x86_64-2.txz:  Rebuilt.
l/libxml2-2.9.5-x86_64-1.txz:  Upgraded.
  This release fixes some security issues:
  Detect infinite recursion in parameter entities (Nick Wellnhofer),
  Fix handling of parameter-entity references (Nick Wellnhofer),
  Disallow namespace nodes in XPointer ranges (Nick Wellnhofer),
  Fix XPointer paths beginning with range-to (Nick Wellnhofer).
  (* Security fix *)
l/libxslt-1.1.30-x86_64-1.txz:  Upgraded.
l/newt-0.52.20-x86_64-2.txz:  Rebuilt.
l/pycairo-1.15.3-x86_64-1.txz:  Upgraded.
l/pycups-1.9.73-x86_64-3.txz:  Rebuilt.
l/pycurl-7.43.0-x86_64-3.txz:  Rebuilt.
l/pygobject-2.28.6-x86_64-4.txz:  Rebuilt.
l/pygobject3-3.24.1-x86_64-2.txz:  Rebuilt.
l/pygtk-2.24.0-x86_64-4.txz:  Rebuilt.
l/pyparsing-2.2.0-x86_64-1.txz:  Added.
l/python-appdirs-1.4.3-x86_64-1.txz:  Added.
l/python-certifi-2017.7.27.1-x86_64-1.txz:  Added.
l/python-chardet-3.0.4-x86_64-1.txz:  Added.
l/python-docutils-0.14-x86_64-1.txz:  Added.
l/python-idna-2.6-x86_64-1.txz:  Added.
l/python-packaging-16.8-x86_64-1.txz:  Added.
l/python-pillow-4.2.1-x86_64-1.txz:  Upgraded.
l/python-requests-2.18.4-x86_64-1.txz:  Added.
l/python-sane-2.8.3-x86_64-1.txz:  Added.
l/python-six-1.10.0-x86_64-2.txz:  Rebuilt.
l/python-urllib3-1.22-x86_64-1.txz:  Added.
l/sip-4.19.3-x86_64-1.txz:  Upgraded.
l/system-config-printer-1.5.9-x86_64-1.txz:  Upgraded.
l/taglib-1.11.1-x86_64-2.txz:  Rebuilt.
l/urwid-1.0.3-x86_64-2.txz:  Rebuilt.
n/NetworkManager-1.8.4-x86_64-1.txz:  Upgraded.
n/getmail-5.1-x86_64-1.txz:  Upgraded.
n/gpgme-1.9.0-x86_64-2.txz:  Rebuilt.
n/obexftp-0.24.2-x86_64-2.txz:  Rebuilt.
n/pssh-2.3.1-x86_64-2.txz:  Rebuilt.
x/intel-gpu-tools-1.19-x86_64-1.txz:  Upgraded.
x/vulkan-sdk-1.0.61.1-x86_64-1.txz:  Upgraded.
x/xcb-proto-1.12-x86_64-2.txz:  Rebuilt.
xap/blueman-2.0.4-x86_64-3.txz:  Rebuilt.
  Don't autostart applet in KDE. Thanks to Robby Workman.
xap/network-manager-applet-1.8.4-x86_64-1.txz:  Upgraded.
snek in the slack
n°1408164
cycojesus
Mèo Lười
Posté le 25-09-2017 à 07:03:11  profilanswer
Sun Sep 24 19:03:35 UTC 2017
a/os-prober-1.76-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.17.7-x86_64-1.txz:  Upgraded.
d/help2man-1.47.5-x86_64-1.txz:  Upgraded.
l/SDL2-2.0.6-x86_64-1.txz:  Upgraded.
l/imagemagick-6.9.9_15-x86_64-1.txz:  Upgraded.
l/pulseaudio-11.1-x86_64-1.txz:  Upgraded.
x/fontconfig-2.12.6-x86_64-1.txz:  Upgraded.
xap/audacious-3.9-x86_64-1.txz:  Upgraded.
xap/audacious-plugins-3.9-x86_64-1.txz:  Upgraded.
[:10-david:4]
n°1408195
cycojesus
Mèo Lười
Posté le 26-09-2017 à 07:10:30  profilanswer
Tue Sep 26 02:37:01 UTC 2017
l/libxslt-1.1.30-x86_64-3.txz:  Rebuilt.
  Fixed bashism in configure.in that resulted in pkg-config not being used
  properly unless /bin/sh was bash. Thanks to Willy Sudiarto Raharjo.
Tue Sep 26 00:39:15 UTC 2017
a/util-linux-2.30.2-x86_64-2.txz:  Rebuilt.
  Renamed old BSD version of strings to "strings-BSD".
ap/cups-filters-1.17.7-x86_64-2.txz:  Rebuilt.
  Recompiled against poppler-0.59.0 and qpdf-7.0.0.
ap/qpdf-7.0.0-x86_64-1.txz:  Upgraded.
d/binutils-2.29.1-x86_64-1.txz:  Upgraded.
  Don't rename strings to "strings-GNU", but provide a symlink from strings-GNU
  to strings in case any user-created scripts are using the name we gave the
  GNU version of strings for many years. The GNU version of strings has more
  features and is what most scripts expect to find installed. Any existing
  scripts that use BSD specific options may need to be patched to use
  equivalent GNU options (or to use strings-BSD instead).
d/meson-0.42.1-x86_64-1.txz:  Added.
  Thanks to Heinz Wiesinger.
d/ninja-1.8.2-x86_64-1.txz:  Added.
  Thanks to alienBOB.
d/oprofile-1.2.0-x86_64-1.txz:  Upgraded.
  Compiled against binutils-2.29.1.
d/re2c-1.0.2-x86_64-1.txz:  Added.
  Thanks to LukenShiro.
kde/calligra-2.9.11-x86_64-16.txz:  Rebuilt.
  Recompiled against poppler-0.59.0.
l/LibRaw-0.18.5-x86_64-1.txz:  Upgraded.
l/libxslt-1.1.30-x86_64-2.txz:  Rebuilt.
  Be a bit more generous with xsltMaxDepth to avoid a false positive on
  infinite recursion. This fixes building the Samba docs.
l/poppler-0.59.0-x86_64-1.txz:  Upgraded.
xfce/tumbler-0.2.0-x86_64-2.txz:  Rebuilt.
n°1408254
cycojesus
Mèo Lười
Posté le 28-09-2017 à 12:38:13  profilanswer
tiens
Thu Sep 28 05:31:20 UTC 2017
Thanks to Robby Workman for preparing nearly all of the updates in this batch.
a/dbus-1.10.24-x86_64-1.txz:  Upgraded.
a/hwdata-0.304-noarch-1.txz:  Upgraded.
a/lvm2-2.02.174-x86_64-1.txz:  Upgraded.
a/mcelog-153-x86_64-1.txz:  Upgraded.
a/xfsprogs-4.13.1-x86_64-1.txz:  Upgraded.
ap/mpg123-1.25.7-x86_64-1.txz:  Upgraded.
ap/sysstat-11.6.0-x86_64-1.txz:  Upgraded.
d/Cython-0.27-x86_64-1.txz:  Upgraded.
l/adwaita-icon-theme-3.26.0-noarch-1.txz:  Upgraded.
l/at-spi2-atk-2.26.0-x86_64-1.txz:  Upgraded.
l/at-spi2-core-2.26.0-x86_64-1.txz:  Upgraded.
l/atk-2.26.0-x86_64-1.txz:  Upgraded.
l/babl-0.1.30-x86_64-1.txz:  Upgraded.
l/gc-7.6.0-x86_64-1.txz:  Upgraded.
l/gegl-0.2.0-x86_64-5.txz:  Rebuilt.
  Patched integer overflows in operations/external/ppm-load.c that could allow
  a denial of service (application crash) or possibly the execution of
  arbitrary code via a large width or height value in a ppm image.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-4433
  (* Security fix *)
l/glib-networking-2.54.0-x86_64-1.txz:  Upgraded.
l/glib2-2.54.0-x86_64-1.txz:  Upgraded.
l/glibmm-2.54.1-x86_64-1.txz:  Upgraded.
l/gobject-introspection-1.54.0-x86_64-1.txz:  Upgraded.
l/gsettings-desktop-schemas-3.24.1-x86_64-1.txz:  Upgraded.
l/gst-plugins-base-1.12.3-x86_64-1.txz:  Upgraded.
l/gst-plugins-good-1.12.3-x86_64-1.txz:  Upgraded.
l/gst-plugins-libav-1.12.3-x86_64-1.txz:  Upgraded.
l/gstreamer-1.12.3-x86_64-1.txz:  Upgraded.
l/gtkmm3-3.22.2-x86_64-1.txz:  Upgraded.
l/hicolor-icon-theme-0.17-noarch-1.txz:  Upgraded.
l/hunspell-1.6.2-x86_64-1.txz:  Upgraded.
l/iso-codes-3.76-noarch-1.txz:  Upgraded.
l/libsoup-2.60.0-x86_64-1.txz:  Upgraded.
l/media-player-info-23-noarch-1.txz:  Upgraded.
l/pcre2-10.30-x86_64-1.txz:  Added.
  Thanks to Larry Hajali.
l/pygobject3-3.26.0-x86_64-1.txz:  Upgraded.
l/qca-2.1.3-x86_64-1.txz:  Upgraded.
n/cifs-utils-6.7-x86_64-1.txz:  Upgraded.
n/gnupg2-2.2.1-x86_64-1.txz:  Upgraded.
n/ipset-6.34-x86_64-1.txz:  Upgraded.
n/libmbim-1.14.2-x86_64-1.txz:  Upgraded.
n/openvpn-2.4.4-x86_64-1.txz:  Upgraded.
n/p11-kit-0.23.8-x86_64-1.txz:  Upgraded.
x/libwacom-0.26-x86_64-1.txz:  Upgraded.
xap/gucharmap-10.0.1-x86_64-1.txz:  Upgraded.
xap/xpdf-4.00-x86_64-1.txz:  Upgraded.
xfce/xfce4-clipman-plugin-1.4.2-x86_64-1.txz:  Upgraded.
ça
n°1408257
cycojesus
Mèo Lười
Posté le 29-09-2017 à 06:14:14  profilanswer
Thu Sep 28 21:03:26 UTC 2017
ap/mariadb-10.2.9-x86_64-1.txz:  Upgraded.
l/pcre2-10.30-x86_64-2.txz:  Rebuilt.
  Remove the .la files before they have a chance to creep into any other ones.
  These generally aren't helpful for libraries that support pkg-config.
n/net-snmp-5.7.3-x86_64-5.txz:  Rebuilt.
  Recompiled with MariaDB support. Thanks to Kris Karas.
xap/mozilla-firefox-56.0-x86_64-1.txz:  Upgraded.
  This release contains security fixes and improvements.
    https://www.mozilla.org/security/known-vulnerabilities/firefox.html
  (* Security fix *)
n°1408302
cycojesus
Mèo Lười
Posté le 30-09-2017 à 08:08:17  profilanswer
Fri Sep 29 22:58:54 UTC 2017
ap/cups-filters-1.17.8-x86_64-1.txz:  Upgraded.
l/libpng-1.6.34-x86_64-1.txz:  Upgraded.
t/tetex-3.0-x86_64-10.txz:  Removed.
  Thanks to Thomas Esser -- teTeX had a good long run. :-)
t/tetex-doc-3.0-x86_64-10.txz:  Removed.
t/texlive-2017.170622-x86_64-1.txz:  Added.
  Thanks very much to Johannes Schoepfer for the great work on this!
  Also thanks to Robby Workman for adjustments and testing.
:ouch: 's/tetex/texlive/' :ouch:  :ouch:  :ouch:  :ouch:  :ouch:  :ouch:
n°1408345
cycojesus
Mèo Lười
Posté le 02-10-2017 à 07:13:08  profilanswer
Sun Oct  1 20:00:22 UTC 2017
a/kernel-generic-4.9.52-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.9.52-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.9.52-x86_64-1.txz:  Upgraded.
ap/a2ps-4.14-x86_64-6.txz:  Rebuilt.
  Removed embedded copy of psutils (already included in TeXLive).
d/kernel-headers-4.9.52-x86-1.txz:  Upgraded.
k/kernel-source-4.9.52-noarch-1.txz:  Upgraded.
l/openexr-2.2.0-x86_64-2.txz:  Rebuilt.
  Patched bugs that may lead to program crashes or possibly execution of
  arbitrary code. Thanks to Thomas Choi for the patch.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9110
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9111
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9112
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9113
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9114
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9115
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9116
  (* Security fix *)
t/texlive-2017.170622-x86_64-2.txz:  Rebuilt.
  Corrected slack-desc. Thanks to Johannes Schoepfer.
xap/gnuplot-5.2.0-x86_64-1.txz:  Upgraded.
  Thanks to Johannes Schoepfer for the path fixes.
xap/xpdf-4.00-x86_64-2.txz:  Rebuilt.
  Added a config option to fix broken printing.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
ça Bosphore [:ibrahim tatlises:2]
n°1408396
cycojesus
Mèo Lười
Posté le 03-10-2017 à 07:17:48  profilanswer
Mon Oct  2 17:16:06 UTC 2017
n/dnsmasq-2.78-x86_64-1.txz:  Upgraded.
  This update fixes bugs and remotely exploitable security issues that may
  have impacts including denial of service, information leak, and execution
  of arbitrary code. Thanks to Felix Wilhelm, Fermin J. Serna, Gabriel Campana,
  Kevin Hamacher, Ron Bowes, and Gynvael Coldwind of the Google Security Team.
    https://security.googleblog.com/2017/10/behind-masq-yet-more-dns-and-dhcp.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13704
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14491
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14492
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14493
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14494
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14495
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14496
  (* Security fix *)
  When doing a network install, don't download a package if the tagfile is
  going to skip installing it. Thanks to ivandi.
n°1408422
cycojesus
Mèo Lười
Posté le 04-10-2017 à 07:09:35  profilanswer
Tue Oct  3 21:06:59 UTC 2017
ap/gphoto2-2.5.15-x86_64-1.txz:  Upgraded.
l/dconf-0.26.1-x86_64-1.txz:  Upgraded.
l/dconf-editor-3.26.1-x86_64-1.txz:  Upgraded.
l/gdk-pixbuf2-2.36.11-x86_64-1.txz:  Upgraded.
l/glib2-2.54.1-x86_64-1.txz:  Upgraded.
l/gobject-introspection-1.54.1-x86_64-1.txz:  Upgraded.
l/gtk+3-3.22.22-x86_64-1.txz:  Upgraded.
l/gvfs-1.34.1-x86_64-1.txz:  Upgraded.
l/libgphoto2-2.5.15-x86_64-1.txz:  Upgraded.
l/seamonkey-solibs-2.48-x86_64-3.txz:  Rebuilt.
n/openssh-7.6p1-x86_64-1.txz:  Upgraded.
x/mesa-17.2.2-x86_64-1.txz:  Upgraded.
xap/gucharmap-10.0.2-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-56.0-x86_64-2.txz:  Rebuilt.
  Recompiled with --enable-accessibility.
  Thanks to Didier Spaier.
xap/mozilla-thunderbird-52.3.0-x86_64-2.txz:  Rebuilt.
  Recompiled with --enable-accessibility and Google API support.
xap/seamonkey-2.48-x86_64-3.txz:  Rebuilt.
n°1408463
cycojesus
Mèo Lười
Posté le 06-10-2017 à 11:27:29  profilanswer
Fri Oct  6 06:32:32 UTC 2017
a/kernel-generic-4.9.53-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.9.53-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.9.53-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.17.9-x86_64-1.txz:  Upgraded.
ap/ghostscript-9.22-x86_64-1.txz:  Upgraded.
ap/vim-8.0.1175-x86_64-1.txz:  Upgraded.
  Compiled using libperl.so from perl-5.26.1.
d/cmake-3.9.4-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.9.53-x86-1.txz:  Upgraded.
d/perl-5.26.1-x86_64-1.txz:  Upgraded.
  Added the following perl modules to support git send-email (thanks to
  Xsane): Authen-SASL-2.16, MIME-Base64-3.15, and Net-SMTP-SSL-1.04.
d/python3-3.6.3-x86_64-1.txz:  Upgraded.
k/kernel-source-4.9.53-noarch-1.txz:  Upgraded.
  KSM n -> y  (thanks to ivandi)
kde/perlkde-4.14.3-x86_64-4.txz:  Rebuilt.
  Recompiled using libperl.so from perl-5.26.1.
kde/perlqt-4.14.3-x86_64-4.txz:  Rebuilt.
l/gtk+3-3.22.24-x86_64-1.txz:  Upgraded.
l/imagemagick-6.9.9_18-x86_64-1.txz:  Upgraded.
l/libmtp-1.1.14-x86_64-1.txz:  Upgraded.
l/librsvg-2.40.19-x86_64-1.txz:  Upgraded.
l/openjpeg-2.3.0-x86_64-1.txz:  Upgraded.
  This update fixes security issues which may lead to a denial of service
  or possibly remote code execution.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9572
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9573
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9580
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9581
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12982
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14039
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14040
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14041
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14151
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14152
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14164
  (* Security fix *)
l/vte-0.50.1-x86_64-1.txz:  Upgraded.
n/curl-7.56.0-x86_64-1.txz:  Upgraded.
  This update fixes a security issue:
  libcurl may read outside of a heap allocated buffer when doing FTP.
    https://curl.haxx.se/docs/adv_20171004.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-1000254
  (* Security fix *)
n/epic5-2.0.1-x86_64-2.txz:  Rebuilt.
n/irssi-1.0.4-x86_64-2.txz:  Rebuilt.
n/net-snmp-5.7.3-x86_64-6.txz:  Rebuilt.
n/ntp-4.2.8p10-x86_64-2.txz:  Rebuilt.
n/p11-kit-0.23.9-x86_64-1.txz:  Upgraded.
x/libinput-1.8.3-x86_64-1.txz:  Upgraded.
x/xorg-server-1.19.4-x86_64-1.txz:  Upgraded.
  This update fixes two security issues:
  Xext/shm: Validate shmseg resource id, otherwise it can belong to a
  non-existing client and abort X server with FatalError "client not
  in use", or overwrite existing segment of another existing client.
  Generating strings for XKB data used a single shared static buffer,
  which offered several opportunities for errors. Use a ring of
  resizable buffers instead, to avoid problems when strings end up
  longer than anticipated.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13721
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13723
  (* Security fix *)
x/xorg-server-xephyr-1.19.4-x86_64-1.txz:  Upgraded.
x/xorg-server-xnest-1.19.4-x86_64-1.txz:  Upgraded.
x/xorg-server-xvfb-1.19.4-x86_64-1.txz:  Upgraded.
xap/hexchat-2.12.4-x86_64-2.txz:  Rebuilt.
  Built with --enable-python=python3.
xap/pidgin-2.12.0-x86_64-2.txz:  Rebuilt.
xap/vim-gvim-8.0.1175-x86_64-1.txz:  Upgraded.
n°1408484
cycojesus
Mèo Lười
Posté le 07-10-2017 à 09:18:38  profilanswer
Sat Oct  7 02:53:31 UTC 2017
a/btrfs-progs-v4.13.2-x86_64-1.txz:  Upgraded.
ap/texinfo-6.5-x86_64-2.txz:  Rebuilt.
  Rebuilt for perl-5.26.1.
d/perl-5.26.1-x86_64-2.txz:  Rebuilt.
  Replaced Net-SMTP-SSL-1.04 (deprecated upstream) with libnet-3.10.
  Thanks to Matteo Bernardini.
l/libxml2-2.9.6-x86_64-1.txz:  Upgraded.
l/libxslt-1.1.31-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-52.4.0-x86_64-1.txz:  Upgraded.
n°1408571
cycojesus
Mèo Lười
Posté le 10-10-2017 à 22:18:54  profilanswer
Comme ça, ôde et beauté
Tue Oct 10 18:08:31 UTC 2017
a/eudev-3.2.4-x86_64-2.txz:  Rebuilt.
  Fixed a typo in configure.ac. Thanks to Robby Workman.
a/lvm2-2.02.175-x86_64-1.txz:  Upgraded.
a/mkinitrd-1.4.11-x86_64-5.txz:  Rebuilt.
  Save a copy of the command line used to create the initrd as "command_line"
  in /boot/initrd-tree/ and within the initrd itself. Also save a copy of
  /etc/mkinitrd.conf if it exists.
ap/slackpkg-2.82.2-noarch-1.txz:  Upgraded.
  Updated mirrors-x86*.sample to remove dead mirrors and clarify
  intent to use mirrors.slackware.com.
  Add /usr/share/vim/ and /var/yp/ to search path for .new files.
  Minor tweaks to default blacklist file.
  Minor tweaks to manual pages.
ap/tmux-2.6-x86_64-1.txz:  Upgraded.
d/meson-0.43.0-x86_64-1.txz:  Upgraded.
d/perl-5.26.1-x86_64-3.txz:  Rebuilt.
  Don't install a perllocal.pod with information on the vendor_perl bundled
  modules (that file is for local additions) -- ship the file as
  vendor_perl.pod instead. Thanks to Robby Workman.
kde/perlqt-4.14.3-x86_64-5.txz:  Rebuilt.
  Added support for QScintilla. Thanks to oneforall.
l/ffmpeg-3.3.4-x86_64-2.txz:  Rebuilt.
  Patched to build against openjpeg-2.3.0. Thanks to Matteo Bernardini.
l/glib2-2.54.1-x86_64-2.txz:  Rebuilt.
  Applied an upstream patch to fix a race condition. Thanks to Robby Workman.
l/herqq-1.0.0-x86_64-1.txz:  Removed.
l/imagemagick-6.9.9_19-x86_64-1.txz:  Upgraded.
l/libnl3-3.4.0-x86_64-1.txz:  Upgraded.
n/lftp-4.8.3-x86_64-1.txz:  Upgraded.
n°1408979
cycojesus
Mèo Lười
Posté le 19-10-2017 à 07:14:29  profilanswer
des tas de bouts plus secures
Wed Oct 18 18:21:18 UTC 2017
ap/cups-2.2.5-x86_64-1.txz:  Upgraded.
n/wpa_supplicant-2.6-x86_64-2.txz:  Rebuilt.
  This update includes patches to mitigate the WPA2 protocol issues known
  as "KRACK" (Key Reinstallation AttaCK), which may be used to decrypt data,
  hijack TCP connections, and to forge and inject packets. This is the
  list of vulnerabilities that are addressed here:
  CVE-2017-13077: Reinstallation of the pairwise encryption key (PTK-TK) in the
    4-way handshake.
  CVE-2017-13078: Reinstallation of the group key (GTK) in the 4-way handshake.
  CVE-2017-13079: Reinstallation of the integrity group key (IGTK) in the 4-way
    handshake.
  CVE-2017-13080: Reinstallation of the group key (GTK) in the group key
    handshake.
  CVE-2017-13081: Reinstallation of the integrity group key (IGTK) in the group
    key handshake.
  CVE-2017-13082: Accepting a retransmitted Fast BSS Transition (FT)
    Reassociation Request and reinstalling the pairwise encryption key (PTK-TK)
    while processing it.
  CVE-2017-13084: Reinstallation of the STK key in the PeerKey handshake.
  CVE-2017-13086: reinstallation of the Tunneled Direct-Link Setup (TDLS)
    PeerKey (TPK) key in the TDLS handshake.
  CVE-2017-13087: reinstallation of the group key (GTK) when processing a
    Wireless Network Management (WNM) Sleep Mode Response frame.
  CVE-2017-13088: reinstallation of the integrity group key (IGTK) when
    processing a Wireless Network Management (WNM) Sleep Mode Response frame.
    https://www.krackattacks.com/
    https://w1.fi/security/2017-1/wpa-packet-number-reuse-with-replayed-messages.txt
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13077
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13078
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13079
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13080
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13081
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13082
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13084
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13086
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13087
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13088
  (* Security fix *)
x/libXfont2-2.0.2-x86_64-1.txz:  Upgraded.
  This update is a collection of minor fixes since 2.0.1, including
  CVE-2017-13720 and CVE-2017-13722.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13720
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13722
  (* Security fix *)
x/libXres-1.2.0-x86_64-1.txz:  Upgraded.
  Integer overflows may allow X servers to trigger allocation of insufficient
  memory and a buffer overflow via vectors related to the (1)
  XResQueryClients and (2) XResQueryClientResources functions.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1988
  (* Security fix *)
x/xorg-server-1.19.5-x86_64-1.txz:  Upgraded.
  This update fixes integer overflows and other possible security issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12176
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12177
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12178
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12179
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12180
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12181
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12182
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12183
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12184
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12185
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12186
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-12187
  (* Security fix *)
x/xorg-server-xephyr-1.19.5-x86_64-1.txz:  Upgraded.
x/xorg-server-xnest-1.19.5-x86_64-1.txz:  Upgraded.
x/xorg-server-xvfb-1.19.5-x86_64-1.txz:  Upgraded.
n°1409087
cycojesus
Mèo Lười
Posté le 20-10-2017 à 09:12:05  profilanswer
Fri Oct 20 04:44:44 UTC 2017
a/gawk-4.2.0-x86_64-1.txz:  Upgraded.
d/patchelf-0.9-x86_64-1.txz:  Added.
d/rust-1.21.0-x86_64-1.txz:  Upgraded.
  Thanks to Stuart Winter for adding ARM compatibility to the build script, and
  to Andrew Clemons for help getting the 32-bit x86 build working again.
l/ffmpeg-3.4-x86_64-1.txz:  Upgraded.
x/libdrm-2.4.84-x86_64-1.txz:  Upgraded.
x/mesa-17.2.3-x86_64-1.txz:  Upgraded.
n°1409241
cycojesus
Mèo Lười
Posté le 24-10-2017 à 10:18:15  profilanswer
Tue Oct 24 05:31:18 UTC 2017
a/util-linux-2.31-x86_64-1.txz:  Upgraded.
ap/screen-4.6.2-x86_64-1.txz:  Upgraded.
l/seamonkey-solibs-2.49.1-x86_64-1.txz:  Upgraded.
n/curl-7.56.1-x86_64-1.txz:  Upgraded.
  IMAP FETCH response out of bounds read may cause a crash or information leak.
    https://curl.haxx.se/docs/adv_20171023.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-1000257
  (* Security fix *)
n/rfkill-0.5-x86_64-1.txz:  Removed.
xap/seamonkey-2.49.1-x86_64-1.txz:  Upgraded.
n°1409330
cycojesus
Mèo Lười
Posté le 26-10-2017 à 06:59:52  profilanswer
Wed Oct 25 19:09:26 UTC 2017
a/btrfs-progs-v4.13.3-x86_64-1.txz:  Upgraded.
a/e2fsprogs-1.43.7-x86_64-1.txz:  Upgraded.
a/gawk-4.2.0-x86_64-2.txz:  Rebuilt.
  Put the profile scripts in the right place. Thanks to gmgf.
a/glibc-zoneinfo-2017c-noarch-1.txz:  Upgraded.
ap/hplip-3.17.10-x86_64-1.txz:  Upgraded.
ap/rpm-4.14.0-x86_64-1.txz:  Upgraded.
ap/sqlite-3.21.0-x86_64-1.txz:  Upgraded.
d/git-2.14.2-x86_64-1.txz:  Upgraded.
d/scons-3.0.0-x86_64-1.txz:  Upgraded.
l/SDL2-2.0.7-x86_64-1.txz:  Upgraded.
l/apr-1.6.3-x86_64-1.txz:  Upgraded.
l/apr-util-1.6.1-x86_64-1.txz:  Upgraded.
l/atk-2.26.1-x86_64-1.txz:  Upgraded.
l/imagemagick-6.9.9_20-x86_64-1.txz:  Upgraded.
l/lame-3.100-x86_64-1.txz:  Upgraded.
l/libgphoto2-2.5.16-x86_64-1.txz:  Upgraded.
l/libsoup-2.60.1-x86_64-1.txz:  Upgraded.
l/polkit-qt-1-0.112.0-x86_64-1.txz:  Upgraded.
n/ModemManager-1.6.10-x86_64-1.txz:  Upgraded.
n/gnutls-3.6.1-x86_64-1.txz:  Upgraded.
n/httpd-2.4.29-x86_64-1.txz:  Upgraded.
n/irssi-1.0.5-x86_64-1.txz:  Upgraded.
  This update fixes some remote denial of service issues.
    https://irssi.org/security/irssi_sa_2017_10.txt
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-15228
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-15227
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-15721
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-15723
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-15722
  (* Security fix *)
tcl/expect-5.45.3-x86_64-1.txz:  Upgraded.
x/libdrm-2.4.85-x86_64-1.txz:  Upgraded.
xfce/xfce4-notifyd-0.4.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-weather-plugin-0.8.10-x86_64-1.txz:  Upgraded.
  This has a bugfix related to setting the location:
  https://bugzilla.xfce.org/show_bug.cgi?id=13877
n°1409431
cycojesus
Mèo Lười
Posté le 28-10-2017 à 08:40:04  profilanswer
Fri Oct 27 20:34:35 UTC 2017
ap/rpm-4.14.0-x86_64-2.txz:  Rebuilt.
  Recompiled to fix linking to old library versions. Thanks to USUARIONUEVO.
l/SDL2_mixer-2.0.2-x86_64-1.txz:  Upgraded.
l/libmcs-0.7.2-x86_64-1.txz:  Removed.
l/libmowgli-1.0.0-x86_64-1.txz:  Removed.
l/pyrex-0.9.9-x86_64-2.txz:  Removed.
n/php-5.6.32-x86_64-1.txz:  Upgraded.
  Several security bugs were fixed in this release:
  Out of bounds read in timelib_meridian().
  The arcfour encryption stream filter crashes PHP.
  Applied upstream patch for PCRE (CVE-2016-1283).
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1283
  (* Security fix *)
n/wget-1.19.2-x86_64-1.txz:  Upgraded.
  This update fixes stack and heap overflows in in HTTP protocol handling.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13089
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-13090
  (* Security fix *)
bah oui, rpm
n°1409460
macomboh
Posté le 29-10-2017 à 09:58:34  profilanswer
  (* Security fix *)
On remarque une version 2.49.1 de seamonkey alors que le site seamonkey reste en 2.48.
Pour ceux qui cherchent la francisation , le xpi du langpack fr se trouve la :
http://ftp.mozilla.org/pub/seamonk [...] ngpack.xpi
n°1409585
cycojesus
Mèo Lười
Posté le 01-11-2017 à 07:58:20  profilanswer
et
Tue Oct 31 23:53:38 UTC 2017
a/aaa_elflibs-14.2-x86_64-32.txz:  Rebuilt.
  Added libatomic, and updated versions of libcurl, libexpat, libglib-2.0,
  libgmodule-2.0, libgobject-2.0, libgthread-2.0, libidn2, libmpfr, and
  libpng16.
x/libdrm-2.4.87-x86_64-1.txz:  Upgraded.
x/mesa-17.2.4-x86_64-1.txz:  Upgraded.
n°1409678
cycojesus
Mèo Lười
Posté le 03-11-2017 à 08:40:52  profilanswer
Fri Nov  3 03:31:56 UTC 2017
a/sysvinit-scripts-2.0-noarch-38.txz:  Rebuilt.
  Check that rc.mysqld is executable before attempting to shut down the
  database server. Checking for the mysql.pid is not enough, as /var/run/mysql
  might be bind mounted into a container. Thanks to Jakub Jankowski.
ap/cups-2.2.6-x86_64-1.txz:  Upgraded.
ap/mariadb-10.2.10-x86_64-1.txz:  Upgraded.
  This update fixes bugs and security issues.
    https://jira.mariadb.org/browse/MDEV-13819
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-10268
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-10378
  (* Security fix *)
l/expat-2.2.5-x86_64-1.txz:  Upgraded.
l/gegl-0.2.0-x86_64-6.txz:  Rebuilt.
  Replaced deprecated functions in ff-load module. Thanks to Theodore Kilgore.
n/openssl-1.0.2m-x86_64-1.txz:  Upgraded.
  There is a carry propagating bug in the x64 Montgomery squaring procedure.
  No EC algorithms are affected. Analysis suggests that attacks against RSA
  and DSA as a result of this defect would be very difficult to perform and
  are not believed likely. Attacks against DH are considered just feasible
  (although very difficult) because most of the work necessary to deduce
  information about a private key may be performed offline. The amount of
  resources required for such an attack would be very significant and likely
  only accessible to a limited number of attackers. An attacker would
  additionally need online access to an unpatched system using the target
  private key in a scenario with persistent DH parameters and a private
  key that is shared between multiple clients.
  This only affects processors that support the BMI1, BMI2 and ADX extensions
  like Intel Broadwell (5th generation) and later or AMD Ryzen.
    https://www.openssl.org/news/secadv/20171102.txt
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3736
  (* Security fix *)
n°1409705
cycojesus
Mèo Lười
Posté le 04-11-2017 à 09:38:47  profilanswer
hop, quand soudain
Fri Nov  3 18:42:23 UTC 2017
a/openssl-solibs-1.0.2m-x86_64-1.txz:  Upgraded.
n°1410210
cycojesus
Mèo Lười
Posté le 17-11-2017 à 07:21:01  profilanswer
oh boy, oh boy, oh boy!!!
Fri Nov 17 00:56:25 UTC 2017
a/dbus-1.12.2-x86_64-1.txz:  Upgraded.
a/eject-2.1.5-x86_64-4.txz:  Removed.
a/etc-15.0-x86_64-1.txz:  Upgraded.
  /etc/passwd: Added postfix (UID 91), postdrop (UID 92), dovecot (UID 94),
  and dovenull (UID 95).
  /etc/group: Added postfix (GID 91), postdrop (GID 92), dovecot (GID 94),
  and dovenull (GID 95).
a/hostname-3.18-x86_64-1.txz:  Added.
  This is the latest version of the hostname utility, broken out into a new
  package to get rid of duplication between util-linux and net-tools.
a/kernel-firmware-20171109git-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.0-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.0-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.0-x86_64-1.txz:  Upgraded.
a/lvm2-2.02.176-x86_64-1.txz:  Upgraded.
a/pkgtools-15.0-noarch-1.txz:  Upgraded.
  Added Postfix and Dovecot to the services setup menu.
a/smartmontools-6.6-x86_64-1.txz:  Upgraded.
a/sysvinit-scripts-2.0-noarch-39.txz:  Rebuilt.
  rc.M: Set the hostname returned by "hostname" with no arguments to be the
  FQDN (Fully Qualified Domain Name). Technically, it should work either way
  (and mostly does), but in practice there are a few things that either refuse
  to work (mostly commercial software), or require additional configuration if
  hostname returns the short hostname rather than the FQDN.
  rc.M: If rc.sendmail is not present and executable, try rc.postfix.
  rc.M: Run rc.dovecot if it is executable.
  rc.*: Don't source any init scripts.
a/time-1.8-x86_64-1.txz:  Upgraded.
a/util-linux-2.31-x86_64-2.txz:  Rebuilt.
  Don't add hostname, domainname, dnsdomainname, nisdomainname, or ypdomainname
  to the util-linux package. These are provided by the new hostname package.
  Allow the eject utility to build.
ap/alsa-utils-1.1.5-x86_64-1.txz:  Upgraded.
ap/linuxdoc-tools-0.9.72-x86_64-4.txz:  Rebuilt.
 Upgraded to DocBook XSL Stylesheets 1.79.2. Thanks to Stuart Winter.
 Applied patch to fix bus error with xsltproc. Thanks to ecd102 on LQ.
ap/soma-2.11.3-noarch-1.txz:  Upgraded.
ap/sysstat-11.6.1-x86_64-1.txz:  Upgraded.
d/Cython-0.27.3-x86_64-1.txz:  Upgraded.
d/cmake-3.9.6-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.0-x86-1.txz:  Upgraded.
d/re2c-1.0.3-x86_64-1.txz:  Upgraded.
d/scons-3.0.1-x86_64-1.txz:  Upgraded.
d/strace-4.20-x86_64-1.txz:  Upgraded.
k/kernel-source-4.14.0-noarch-1.txz:  Upgraded.
kde/kdelibs-4.14.38-x86_64-1.txz:  Upgraded.
l/SDL2_image-2.0.2-x86_64-1.txz:  Upgraded.
l/alsa-lib-1.1.5-x86_64-1.txz:  Upgraded.
l/alsa-plugins-1.1.5-x86_64-1.txz:  Upgraded.
l/at-spi2-atk-2.26.1-x86_64-1.txz:  Upgraded.
l/at-spi2-core-2.26.2-x86_64-1.txz:  Upgraded.
l/dconf-editor-3.26.2-x86_64-1.txz:  Upgraded.
l/glib-networking-2.54.1-x86_64-1.txz:  Upgraded.
l/glib2-2.54.2-x86_64-1.txz:  Upgraded.
l/gtk+2-2.24.31-x86_64-3.txz:  Rebuilt.
  Added more patches from upstream git. Thanks to Robby Workman.
l/gtk+3-3.22.26-x86_64-1.txz:  Upgraded.
l/harfbuzz-1.7.1-x86_64-1.txz:  Upgraded.
l/libplist-2.0.0-x86_64-1.txz:  Upgraded.
  This update fixes several security issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6440
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6439
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6438
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6437
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6436
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6435
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5836
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5835
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5834
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5545
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5209
  (* Security fix *)
l/libsoup-2.60.2-x86_64-1.txz:  Upgraded.
l/mozilla-nss-3.34-x86_64-1.txz:  Upgraded.
  Upgraded to nss-3.34 and nspr-4.17.
l/pango-1.40.14-x86_64-1.txz:  Upgraded.
l/pygobject3-3.26.1-x86_64-1.txz:  Upgraded.
l/sip-4.19.5-x86_64-1.txz:  Upgraded.
l/vte-0.50.2-x86_64-1.txz:  Upgraded.
n/NetworkManager-1.10.0-x86_64-1.txz:  Upgraded.
  Use the FQDN (Fully Qualified Domain Name) for the hostname as reported by
  "hostname" with no arguments.
n/cyrus-sasl-2.1.26-x86_64-2.txz:  Rebuilt.
  Create /etc/sasl2 configuration directory.
n/dovecot-2.2.33.2-x86_64-1.txz:  Added.
  This will be the new IMAP/POP3 server in the next Slackware release.
  Thanks to Alan Hicks, Mario Preksavec, and /dev/rob0 for assistance.
n/ethtool-4.13-x86_64-1.txz:  Upgraded.
n/gnupg2-2.2.2-x86_64-1.txz:  Upgraded.
n/imapd-2.21-x86_64-1.txz:  Removed.
n/inetd-1.79s-x86_64-10.txz:  Rebuilt.
  Do not run inetd (rc.inetd is now shipped non-executable), or open any ports
  in inetd.conf by default.
n/iproute2-4.14.1-x86_64-1.txz:  Upgraded.
n/libmilter-8.15.2-x86_64-1.txz:  Added.
  This is a compile-time dependency of Postfix.
n/net-tools-20170208_479bb4a-x86_64-1.txz:  Upgraded.
  Don't include hostname, domainname, dnsdomainname, nisdomainname,
  or ypdomainname. These are provided by the new hostname package.
n/network-scripts-15.0-noarch-1.txz:  Upgraded.
  Switch to using ip instead of ifconfig and route.
  Supports create/destroy of virtual tun/tap interfaces and adding
  them to bridges.
  Supports additional IP addresses added to interfaces in a way
  that's compatible with net-tools.
n/postfix-3.2.4-x86_64-1.txz:  Added.
  This will be the default MTA in the next Slackware release. Thanks to
n/samba-4.6.10-x86_64-1.txz:  Upgraded.
n/sendmail-8.15.2-x86_64-2.txz:  Removed.
  Moved to /extra.
n/sendmail-cf-8.15.2-noarch-2.txz:  Removed.
  Moved to /extra.
n/stunnel-5.43-x86_64-1.txz:  Upgraded.
n/wireless-tools-29-x86_64-10.txz:  Rebuilt.
  Use ip instead of ifconfig. Thanks to Robby Workman.
t/texlive-2017.171108-x86_64-1.txz:  Upgraded.
  Fixes, cleanups, and logging support in texmf_get.sh.
  Support for many more languages.
  More manpages and info files included.
  TeX packages moved to texlive-extra (hosted on slackbuilds.org): cc-pl,
  cmexb, cs, ghsystem, kerkis, pl, quran, tipa, and udesoftec.
  Tex packages excluded as obsolete: aleph and its support files, and cslatex.
  PDF files removed from koma-script docs.
  Compiled with --disable-dump-share for better performance.
  TeXLive fonts are now optionally available to other system applications
  through a fontconfig file (/etc/fonts/conf.avail/09-texlive.conf).
  Thanks to Johannes Schoepfer for all of these improvements.
x/bdftopcf-1.1-x86_64-1.txz:  Upgraded.
x/intel-gpu-tools-1.20-x86_64-1.txz:  Upgraded.
x/libXfont-1.5.3-x86_64-1.txz:  Upgraded.
x/libdrm-2.4.88-x86_64-1.txz:  Upgraded.
x/libpciaccess-0.14-x86_64-1.txz:  Upgraded.
x/mesa-17.2.5-x86_64-1.txz:  Upgraded.
xap/gnuplot-5.2.2-x86_64-1.txz:  Upgraded.
xap/gucharmap-10.0.3-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-57.0-x86_64-1.txz:  Upgraded.
  (* Security fix *)
xap/network-manager-applet-1.8.6-x86_64-1.txz:  Upgraded.
xap/xpaint-2.10.2-x86_64-1.txz:  Upgraded.
extra/bash-completion/bash-completion-2.7-noarch-2.txz:  Rebuilt.
  Applied some patches from upstream git, including one that unclobbers the
  rfkill completion from util-linux. Don't clobber mount and umount
  completions from util-linux. Thanks to ill323 on LQ for the heads-up.
extra/sendmail/sendmail-8.15.2-x86_64-2.txz:  Added.
  Moved here from the N series. This is still a solid choice for an MTA, and
  probably the most flexible (although it can be difficult to configure - it
  has been said that the M4 macro language resembles line noise).
  Thanks to Eric Allman and everyone at Sendmail for all the years of work.
extra/sendmail/sendmail-cf-8.15.2-noarch-2.txz:  Added.
ça va toujours dessous, tu tiens ?
n°1410214
cycojesus
Mèo Lười
Posté le 17-11-2017 à 09:03:35  profilanswer
oups
Fri Nov 17 06:49:47 UTC 2017
n/network-scripts-15.0-noarch-2.txz:  Rebuilt.
  netconfig: Added $GATEWAY that was accidentally dropped from the script.
  Thanks to Robby Workman for pointing out my mistake.
n°1410228
cycojesus
Mèo Lười
Posté le 17-11-2017 à 13:24:43  profilanswer
Faisez gaffe quand même que le nouvo kernel 4.14 chie dans la colle sur mon laptop pro et mon serveur @home :/ retourné au 4.9.53 en attendant le temps d'investiguer
n°1410294
cycojesus
Mèo Lười
Posté le 19-11-2017 à 06:19:52  profilanswer
Sun Nov 19 03:36:30 UTC 2017
a/eudev-3.2.4-x86_64-3.txz:  Rebuilt.
  Blacklist all EDAC modules by default as they make some systems unstable.
a/kernel-generic-4.14.0-x86_64-2.txz:  Upgraded.
a/kernel-huge-4.14.0-x86_64-2.txz:  Upgraded.
a/kernel-modules-4.14.0-x86_64-2.txz:  Upgraded.
a/sysvinit-scripts-2.1-noarch-1.txz:  Upgraded.
  rc.M: Don't try to run rc.sendmail unless /usr/sbin/makemap is present.
  rc.M: Don't try to run rc.postfix unless /usr/sbin/postdrop is present.
  rc.S: Source /etc/default/adjtimex.
ap/cgmanager-0.41-x86_64-3.txz:  Rebuilt.
  Prevent the rc.cgmanger script from killing itself at shutdown.
ap/joe-4.5-x86_64-1.txz:  Upgraded.
ap/nano-2.9.0-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.0-x86-2.txz:  Upgraded.
k/kernel-source-4.14.0-noarch-2.txz:  Upgraded.
  -BOOTPARAM_HARDLOCKUP_PANIC n
  -BOOTPARAM_HARDLOCKUP_PANIC_VALUE 0
  -BOOTPARAM_SOFTLOCKUP_PANIC n
  -BOOTPARAM_SOFTLOCKUP_PANIC_VALUE 0
  -HARDLOCKUP_DETECTOR_PERF y
  -LOCKUP_DETECTOR y
   BLK_DEV_IO_TRACE y -> n
   BUG_ON_DATA_CORRUPTION y -> n
   DEBUG_LIST y -> n
   DRM_AMDGPU_CIK n -> y
   DRM_AMDGPU_SI n -> y
   EDAC_DECODE_MCE y -> m
   HARDLOCKUP_DETECTOR y -> n
   SOFTLOCKUP_DETECTOR y -> n
n/postfix-3.2.4-x86_64-2.txz:  Rebuilt.
  Make the start message in postfix-script look a bit more correct for when
  it shows up during boot.
n/yptools-2.14-x86_64-9.txz:  Rebuilt.
  rc.yp: Fix setting nisdomainname.
extra/tigervnc/tigervnc-1.8.0-x86_64-3.txz:  Rebuilt.
  Rebuilt against xorg-server-1.19.5.
n°1410316
macomboh
Posté le 19-11-2017 à 19:34:07  profilanswer
Et en plus le VirtualBox ne se charge pas avec le 4.14!!
n°1410375
cycojesus
Mèo Lười
Posté le 21-11-2017 à 07:19:21  profilanswer
Tue Nov 21 05:05:41 UTC 2017
a/elilo-3.16-x86_64-5.txz:  Rebuilt.
  Double the allowable kernel image size from 8MB to 16MB.
  Patched eliloconfig to work with MMC devices. Thanks to zerouno.
a/sysvinit-scripts-2.1-noarch-2.txz:  Rebuilt.
  inittab: Have agetty display the FQDN, since /bin/login does.
d/cmake-3.10.0-x86_64-1.txz:  Upgraded.
l/elfutils-0.170-x86_64-1.txz:  Upgraded.
  Moved the shared libraries to /lib{,64}. Thanks to ivandi.
l/libgsf-1.14.42-x86_64-1.txz:  Upgraded.
l/libtiff-4.0.9-x86_64-1.txz:  Upgraded.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-8128
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5318
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10095
  (* Security fix *)
l/libxml2-2.9.7-x86_64-1.txz:  Upgraded.
l/libxslt-1.1.32-x86_64-1.txz:  Upgraded.
l/libzip-1.3.2-x86_64-1.txz:  Upgraded.
l/orc-0.4.28-x86_64-1.txz:  Upgraded.
n/dovecot-2.2.33.2-x86_64-2.txz:  Rebuilt.
  rc.dovecot: Use doveadm to shut down the service. Add status option.
  Thanks to Thom1b.
n/gnupg2-2.2.3-x86_64-1.txz:  Upgraded.
n/iptables-1.6.1-x86_64-2.txz:  Rebuilt.
n/libmnl-1.0.4-x86_64-2.txz:  Rebuilt.
  Moved the shared library to /lib{,64}. Thanks to ivandi.
n/libnetfilter_queue-1.0.3-x86_64-1.txz:  Upgraded.
n/libnftnl-1.0.8-x86_64-1.txz:  Upgraded.
n/nettle-3.4-x86_64-1.txz:  Upgraded.
n/network-scripts-15.0-noarch-3.txz:  Rebuilt.
  rc.inet1, rc.inet1.conf: Fix DHCP timeout which was changed from 15 seconds
  back to the 14.2 default of 10 seconds. Thanks to Eduard Rozenberg.
n/nftables-0.8-x86_64-1.txz:  Upgraded.
n°1410376
cycojesus
Mèo Lười
Posté le 21-11-2017 à 07:21:12  profilanswer
There is a patch for that : https://github.com/willysr/SlackHac [...] 5.2.0/4.14
Rapport au 4.14.0, le generic boot bien et sans doute qu'avec l'elilo du jour ça sera mieux.
n°1410436
cycojesus
Mèo Lười
Posté le 22-11-2017 à 09:12:37  profilanswer
Wed Nov 22 05:27:06 UTC 2017
a/kernel-generic-4.14.1-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.1-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.1-x86_64-1.txz:  Upgraded.
a/mt-st-1.3-x86_64-1.txz:  Upgraded.
a/shadow-4.2.1-x86_64-3.txz:  Rebuilt.
  Patched to display the short hostname on the login prompt.
a/sysvinit-scripts-2.1-noarch-3.txz:  Rebuilt.
  On second thought, let's keep using the short hostname on the login prompt
  like we always have before. I'm with GazL on this one. :-)
d/kernel-headers-4.14.1-x86-1.txz:  Upgraded.
k/kernel-source-4.14.1-noarch-1.txz:  Upgraded.
n/ntp-4.2.8p10-x86_64-3.txz:  Rebuilt.
  Fixed a missing "}" in the logrotate file. Thanks to Jakub Jankowski.
xap/blueman-2.0.5-x86_64-1.txz:  Upgraded.
  SeTEFI: Don't use fdisk to detect gpt (it's not neccessary).
  SetEFI: Scan /dev/mmcblk[0-9]. Thanks to zerouno.
  probe: Filter another possible EFI partition label. Thanks to Didier Spaier.
n°1410487
macomboh
Posté le 23-11-2017 à 00:19:51  profilanswer
thanks for the hint , it's ok !
n°1410553
cycojesus
Mèo Lười
Posté le 25-11-2017 à 10:59:40  profilanswer
Sat Nov 25 07:44:07 UTC 2017
a/kernel-firmware-20171124git-noarch-1.txz:  Upgraded.
a/kernel-generic-4.14.2-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.14.2-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.14.2-x86_64-1.txz:  Upgraded.
ap/hplip-3.17.11-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.14.2-x86-1.txz:  Upgraded.
d/rust-1.22.1-x86_64-1.txz:  Upgraded.
k/kernel-source-4.14.2-noarch-1.txz:  Upgraded.
l/libclc-20171115_3d994f2-x86_64-1.txz:  Upgraded.
l/libfakekey-0.3-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-52.5.0-x86_64-1.txz:  Upgraded.
n°1410628
cycojesus
Mèo Lười
Posté le 28-11-2017 à 11:12:20  profilanswer
Bam.
Tue Nov 28 06:20:03 UTC 2017
a/eudev-3.2.5-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20171126git-noarch-1.txz:  Upgraded.
  Remove /lib/firmware/iwlwifi-*-34.ucode until after the next kernel release.
a/usbutils-009-x86_64-1.txz:  Upgraded.
ap/hplip-3.17.11-x86_64-2.txz:  Rebuilt.
  Fixed a few Python scripts that did not have a proper python3 shebang.
  Thanks to dugan.
ap/lxc-2.0.9-x86_64-1.txz:  Upgraded.
ap/man-pages-4.14-noarch-1.txz:  Upgraded.
ap/mc-4.8.20-x86_64-1.txz:  Upgraded.
ap/nano-2.9.1-x86_64-1.txz:  Upgraded.
kde/konsole-4.14.3-x86_64-3.txz:  Rebuilt.
  Fixed scrollUp behavior. Thanks to Andrzej Telszewski.
l/QScintilla-2.10.2-x86_64-1.txz:  Upgraded.
l/ffmpeg-3.4-x86_64-2.txz:  Rebuilt.
  Recompiled against libva.so.2.0.0.
l/sip-4.19.6-x86_64-1.txz:  Upgraded.
l/talloc-2.1.10-x86_64-1.txz:  Added.
l/tdb-1.3.15-x86_64-1.txz:  Added.
l/tevent-0.9.34-x86_64-1.txz:  Added.
n/cyrus-sasl-2.1.26-x86_64-3.txz:  Rebuilt.
  Use /dev/urandom rather than /dev/random to avoid entropy starvation.
  Thanks to mr.spuratic.
n/dhcpcd-6.11.5-x86_64-2.txz:  Rebuilt.
  Use hostname_short in dhcpcd.conf. Thanks to KewlCat.
n/network-scripts-15.0-noarch-4.txz:  Rebuilt.
  Script cleanups from Jakub Jankowski:
  netconfig: Add comment to netconfig-generated rc.inet1.conf
  rc.inet1: Check for iface in /sys/class/net, not /proc/net/dev
  rc.inet1: Remove unnecessary unset num
  rc.inet1: Factor DEBUG_ETH_UP logging to a separate function
  rc.inet1: Use ${array[*]} not ${array[@]} to produce a string
  rc.inet1: Avoid de-/configuring ifaces with indexes >=MAXNICS
  rc.inet1: Avoid code duplication by combining case/esac
  rc.inet1: Add missing 'dev' keyword
  rc.inet1: Remove unnecessary $(echo)
  rc.inet1*: Simplify virtif_* code, add note to example config
  rc.inet1: Test for loopback being "state UNKNOWN" too.
  rc.inet1: Use simple test (-n/-z) for non-empty/empty
  rc.inet1: Replace [ test1 -a test2 ] with [ test1 ] && [ test2 ]
n/openldap-client-2.4.45-x86_64-1.txz:  Upgraded.
n/samba-4.7.3-x86_64-1.txz:  Upgraded.
  CVE-2017-14746 (Use-after-free vulnerability.)
    All versions of Samba from 4.0.0 onwards are vulnerable to a use after
    free vulnerability, where a malicious SMB1 request can be used to
    control the contents of heap memory via a deallocated heap pointer. It
    is possible this may be used to compromise the SMB server.
  CVE-2017-15275 (Server heap memory information leak.)
    All versions of Samba from 3.6.0 onwards are vulnerable to a heap
    memory information leak, where server allocated heap memory may be
    returned to the client without being cleared.
    https://www.samba.org/samba/security/CVE-2017-14746.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14746
    https://www.samba.org/samba/security/CVE-2017-15275.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-15275
  (* Security fix *)
x/intel-vaapi-driver-2.0.0-x86_64-1.txz:  Added.
  This is the replacement for libva-intel-driver (renamed upstream).
x/libva-2.0.0-x86_64-1.txz:  Upgraded.
x/libva-intel-driver-1.7.3-x86_64-1.txz:  Removed.
x/libva-utils-2.0.0-x86_64-1.txz:  Added.
x/mesa-17.2.6-x86_64-1.txz:  Upgraded.
x/xkeyboard-config-2.22-noarch-1.txz:  Upgraded.
xap/gparted-0.30.0-x86_64-1.txz:  Upgraded.
xap/xine-lib-1.2.8-x86_64-4.txz:  Rebuilt.
xfce/Thunar-1.6.13-x86_64-1.txz:  Upgraded.
testing/packages/php-7.1.12-x86_64-1.txz:  Added.
Aïheuuuuu ! [:cyrilletelmer:6]
n°1410677
cycojesus
Mèo Lười
Posté le 29-11-2017 à 11:21:26  profilanswer
bouge ton ChangeLog
Wed Nov 29 08:15:09 UTC 2017
a/coreutils-8.28-x86_64-2.txz:  Rebuilt.
  Removed ancient (1992) aliases "dir, vdir, d, v" from the profile scripts.
a/lzlib-1.9-x86_64-1.txz:  Added.
a/plzip-1.6-x86_64-1.txz:  Added.
ap/man-1.6g-x86_64-3.txz:  Removed.
ap/man-db-2.7.6.1-x86_64-1.txz:  Added.
  This package replaces the good old man package. Thanks to B. Watson.
ap/man-pages-4.14-noarch-2.txz:  Rebuilt.
  Don't ship a whatis database, since man-db doesn't need one.
ap/mariadb-10.2.11-x86_64-1.txz:  Upgraded.
d/git-2.15.1-x86_64-1.txz:  Upgraded.
d/python-setuptools-38.2.3-x86_64-1.txz:  Upgraded.
x/libXcursor-1.1.15-x86_64-1.txz:  Upgraded.
  Fix heap overflows when parsing malicious files. (CVE-2017-16612)
  It is possible to trigger heap overflows due to an integer overflow
  while parsing images and a signedness issue while parsing comments.
  The integer overflow occurs because the chosen limit 0x10000 for
  dimensions is too large for 32 bit systems, because each pixel takes
  4 bytes. Properly chosen values allow an overflow which in turn will
  lead to less allocated memory than needed for subsequent reads.
  The signedness bug is triggered by reading the length of a comment
  as unsigned int, but casting it to int when calling the function
  XcursorCommentCreate. Turning length into a negative value allows the
  check against XCURSOR_COMMENT_MAX_LEN to pass, and the following
  addition of sizeof (XcursorComment) + 1 makes it possible to allocate
  less memory than needed for subsequent reads.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-16612
  (* Security fix *)
x/libXfont-1.5.3-x86_64-1.txz:  Removed.
x/libXfont2-2.0.3-x86_64-1.txz:  Upgraded.
  Open files with O_NOFOLLOW. (CVE-2017-16611)
  A non-privileged X client can instruct X server running under root
  to open any file by creating own directory with "fonts.dir",
  "fonts.alias" or any font file being a symbolic link to any other
  file in the system. X server will then open it. This can be issue
  with special files such as /dev/watchdog (which could then reboot
  the system).
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-16611
  (* Security fix *)
x/xfs-1.2.0-x86_64-1.txz:  Upgraded.
testing/packages/php-7.1.12-x86_64-2.txz:  Rebuilt.
  Load mysqlnd.so before mysqli.so in etc/php.ini*. Thanks to KewlCat.
  Load libphp7.so in mod_php.conf.example. Thanks to Willy Sudiarto Raharjo.
Ondule tes txz [:bakk3]
n°1410696
macomboh
Posté le 29-11-2017 à 18:34:08  profilanswer
PHP 7 Enfin! ca fait longtemps qu'on l'attendait (même en testing)
n°1410709
cycojesus
Mèo Lười
Posté le 30-11-2017 à 06:24:26  profilanswer
Wed Nov 29 21:48:33 UTC 2017
n/curl-7.57.0-x86_64-1.txz:  Upgraded.
  This update fixes security issues:
  SSL out of buffer access
  FTP wildcard out of bounds read
  NTLM buffer overflow via integer overflow
    https://curl.haxx.se/docs/adv_2017-af0a.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-8818
    https://curl.haxx.se/docs/adv_2017-ae72.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-8817
    https://curl.haxx.se/docs/adv_2017-12e7.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-8816
  (* Security fix *)
n°1410797
cycojesus
Mèo Lười
Posté le 03-12-2017 à 07:05:50  profilanswer
Du suspense !
Sat Dec  2 20:32:45 UTC 2017
We're moving back to the 4.9.x kernel series in the main tree until we can
figure out a fix for unstable 4.14.x kernels (especially on 32-bit). Guessing
it's probably going to be fixable with .config changes, since a greatly
simplified .config is stable. Meanwhile, the latest 4.14.x kernels can now be
found in the testing/ directory.
a/kernel-firmware-20171130git-noarch-1.txz:  Upgraded.
a/kernel-generic-4.9.66-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.9.66-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.9.66-x86_64-1.txz:  Upgraded.
ap/soma-2.12.3-noarch-1.txz:  Upgraded.
d/gdb-8.0.1-x86_64-3.txz:  Rebuilt.
  Compiled --without-guile until guile-2.2 support is fixed.
d/guile-2.2.3-x86_64-1.txz:  Upgraded.
d/kernel-headers-4.9.66-x86-1.txz:  Upgraded.
d/make-4.2.1-x86_64-2.txz:  Rebuilt.
  Recompiled against libguile-2.2.
d/mercurial-4.4.2-x86_64-1.txz:  Upgraded.
k/kernel-source-4.9.66-noarch-1.txz:  Upgraded.
l/adwaita-icon-theme-3.26.1-noarch-1.txz:  Upgraded.
l/fftw-3.3.7-x86_64-1.txz:  Upgraded.
l/libunistring-0.9.8-x86_64-1.txz:  Upgraded.
l/libzip-1.3.2-x86_64-2.txz:  Rebuilt.
  Restored missing zipconf.h. Thanks to orbea.
n/gnutls-3.6.1-x86_64-2.txz:  Rebuilt.
n/stunnel-5.44-x86_64-1.txz:  Upgraded.
x/xf86-video-vboxvideo-1.0.0-x86_64-1.txz:  Added.
xap/mozilla-firefox-57.0.1-x86_64-1.txz:  Upgraded.
testing/packages/linux-4.14.3/kernel-generic-4.14.3-x86_64-1.txz:  Added.
testing/packages/linux-4.14.3/kernel-headers-4.14.3-x86-1.txz:  Added.
testing/packages/linux-4.14.3/kernel-huge-4.14.3-x86_64-1.txz:  Added.
testing/packages/linux-4.14.3/kernel-modules-4.14.3-x86_64-1.txz:  Added.
testing/packages/linux-4.14.3/kernel-source-4.14.3-noarch-1.txz:  Added.
testing/packages/php-7.2.0-x86_64-1.txz:  Upgraded.
[:balaste:1]
n°1410813
cycojesus
Mèo Lười
Posté le 04-12-2017 à 07:03:08  profilanswer
Sun Dec  3 22:42:47 UTC 2017
a/btrfs-progs-v4.14-x86_64-1.txz:  Upgraded.
a/logrotate-3.13.0-x86_64-1.txz:  Upgraded.
a/pciutils-3.5.6-x86_64-1.txz:  Upgraded.
a/reiserfsprogs-3.6.27-x86_64-1.txz:  Upgraded.
a/xfsprogs-4.14.0-x86_64-1.txz:  Upgraded.
ap/itstool-2.0.4-x86_64-1.txz:  Upgraded.
ap/mariadb-10.2.11-x86_64-2.txz:  Rebuilt.
  Removed a Darwin-only symbol from the TOKUDB_OK cmake test to fix TokuDB.
ap/mpg123-1.25.8-x86_64-1.txz:  Upgraded.
ap/xfsdump-3.1.8-x86_64-1.txz:  Upgraded.
d/nasm-2.13.02-x86_64-1.txz:  Upgraded.
l/M2Crypto-0.27.0-x86_64-1.txz:  Upgraded.
l/babl-0.1.38-x86_64-1.txz:  Upgraded.
l/python-six-1.11.0-x86_64-1.txz:  Upgraded.
l/shared-mime-info-1.9-x86_64-1.txz:  Upgraded.
n/autofs-5.1.3-x86_64-1.txz:  Upgraded.
n/getmail-5.4-x86_64-1.txz:  Upgraded.
n/sshfs-2.10-x86_64-1.txz:  Upgraded.
n/traceroute-2.1.0-x86_64-1.txz:  Upgraded.
xfce/xfce4-terminal-0.8.6-x86_64-2.txz:  Rebuilt.
  Applied upstream patch to add utempter support. Thanks to Robby Workman.
[:pelle:3]
n°1410855
cycojesus
Mèo Lười
Posté le 04-12-2017 à 16:22:47  profilanswer
Mon Dec  4 14:04:45 UTC 2017
xap/pan-0.143-x86_64-1.txz:  Upgraded.
sur les doigts
n°1411008
cycojesus
Mèo Lười
Posté le 06-12-2017 à 17:58:26  profilanswer
php7
Tiiiimmmmmber
Wed Dec  6 14:13:48 UTC 2017
a/kernel-generic-4.9.67-x86_64-1.txz:  Upgraded.
a/kernel-huge-4.9.67-x86_64-1.txz:  Upgraded.
a/kernel-modules-4.9.67-x86_64-1.txz:  Upgraded.
ap/cups-filters-1.17.9-x86_64-2.txz:  Rebuilt.
  Recompiled against poppler-0.62.0.
ap/sqlite-3.21.0-x86_64-2.txz:  Rebuilt.
  Recompiled against icu4c-60.1.
d/kernel-headers-4.9.67-x86-1.txz:  Upgraded.
d/python-setuptools-38.2.4-x86_64-1.txz:  Upgraded.
d/subversion-1.9.7-x86_64-2.txz:  Rebuilt.
k/kernel-source-4.9.67-noarch-1.txz:  Upgraded.
kde/calligra-2.9.11-x86_64-17.txz:  Rebuilt.
  Recompiled against icu4c-60.1 and poppler-0.62.0.
kde/kdepimlibs-4.14.10-x86_64-4.txz:  Rebuilt.
  Recompiled against libical-3.0.1.
l/apr-util-1.6.1-x86_64-2.txz:  Rebuilt.
l/boost-1.65.1-x86_64-2.txz:  Rebuilt.
l/eigen3-3.2.10-x86_64-1.txz:  Upgraded.
l/gmime-3.0.5-x86_64-1.txz:  Upgraded.
l/gvfs-1.34.1-x86_64-2.txz:  Rebuilt.
l/harfbuzz-1.7.2-x86_64-1.txz:  Upgraded.
  Compiled against icu4c-60.1.
l/icu4c-60.1-x86_64-1.txz:  Upgraded.
l/libgpod-0.8.3-x86_64-3.txz:  Rebuilt.
l/libical-3.0.1-x86_64-1.txz:  Upgraded.
l/libsodium-1.0.15-x86_64-1.txz:  Added.
l/libvisio-0.1.6-x86_64-1.txz:  Upgraded.
l/poppler-0.62.0-x86_64-1.txz:  Upgraded.
l/raptor2-2.0.15-x86_64-3.txz:  Rebuilt.
n/NetworkManager-1.10.0-x86_64-2.txz:  Rebuilt.
n/autofs-5.1.3-x86_64-2.txz:  Rebuilt.
  Fixed incorrect /etc/default/autofs.{,new}. Thanks to alienBOB.
n/bluez-5.47-x86_64-2.txz:  Rebuilt.
n/dovecot-2.2.33.2-x86_64-3.txz:  Rebuilt.
n/httpd-2.4.29-x86_64-2.txz:  Rebuilt.
n/php-7.2.0-x86_64-2.txz:  Upgraded.
  Upgraded from php-5.6.32.
  Compiled against libsodium-1.0.15.
n/postfix-3.2.4-x86_64-3.txz:  Rebuilt.
n/tin-2.4.1-x86_64-2.txz:  Rebuilt.
n/whois-5.2.18-x86_64-2.txz:  Rebuilt.
  Ship the mkpasswd program. Thanks to Adrien Nader.
t/texlive-2017.171108-x86_64-2.txz:  Rebuilt.
tcl/expect-5.45.3-x86_64-2.txz:  Rebuilt.
  Don't install the mkpasswd example program, which is inferior to the
  version shipped with the whois sources.
xap/network-manager-applet-1.8.6-x86_64-2.txz:  Rebuilt.
xap/pan-0.143-x86_64-2.txz:  Rebuilt.
  Recompiled against gmime-3.0.5.
xfce/orage-4.12.1-x86_64-4.txz:  Rebuilt.
xfce/tumbler-0.2.0-x86_64-3.txz:  Rebuilt.
xfce/xfce4-screenshooter-1.8.2-x86_64-3.txz:  Rebuilt.
xfce/xfce4-weather-plugin-0.8.10-x86_64-2.txz:  Rebuilt.
testing/packages/linux-4.14.4/kernel-generic-4.14.4-x86_64-1.txz:  Upgraded.
testing/packages/linux-4.14.4/kernel-headers-4.14.4-x86-1.txz:  Upgraded.
testing/packages/linux-4.14.4/kernel-huge-4.14.4-x86_64-1.txz:  Upgraded.
testing/packages/linux-4.14.4/kernel-modules-4.14.4-x86_64-1.txz:  Upgraded.
testing/packages/linux-4.14.4/kernel-source-4.14.4-noarch-1.txz:  Upgraded.
[:penis_de_castor]
Slackware 9.0[slackware] Suppression de terminaux virtuels ?
!! Configuration reseaux, slackware 9 !!Installer slackware 9.0 par ftp (boot disquette)
[Pb] Installation new HDD sous slackware 8.0[RESOLU] Pb d'execution mysql sur slackware ...
Slackware 9 du pur bonheurMonter une partition NTFS sous linux (slackware 9.0)
Slackware 9.0 Finale OUTJe sens que je vais quitter Slackware (pas en serv)
Plus de sujets relatifs à : [SLACKWARE] du présent - 15.0
