7454 connectés
  Linux et OS Alternatifs
  Installation
  Reception de notification nagios
n°1289930
anzian
Posté le 09-09-2011 à 14:04:22  profilanswer
Bonjour à Tous,
je mis en place un serveur  nagios 3.2.3 couplé avec centreon 2.2.0 sous debian 5.
Je souhaite maintenant recevoir des alertes en cas de problème.
Les tutos que j'ai sur postfix ne me permettent pas de recevoir les mails. Voici mon fichier main.cf
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
append_dot_mydomain = no
readme_directory = no
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
myhostname = svr-nagios
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = svr-nagios.localdomain, localhost.localdomain, localhost
relayhost = 192.168.9.88
mynetworks = 127.0.0.0/8 [:ffff:127.0.0.0]/104 [:1]/128
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = loopback-only
Au cours du test d'encoi de mail voici mon mail.log
Sep  9 11:59:46 srv-nagios postfix/pickup[3315]: 1BFB6BFE76: uid=0 from=<root>
Sep  9 11:59:46 srv-nagios postfix/cleanup[7412]: 1BFB6BFE76: message-id=<20110909115946.1BFB6BFE76@svr-nagios>
Sep  9 11:59:46 srv-nagios postfix/qmgr[3319]: 1BFB6BFE76: from=<root@svr-nagios>, size=301, nrcpt=1 (queue active)
Sep  9 11:59:48 srv-nagios postfix/smtp[7414]: 1BFB6BFE76: to=<rkonan@andi-ci.com>, relay=192.168.9.88[192.168.9.88]:25, delay=2.2, delays=0.03/0.01/0/2.2, dsn=5.7.1, status=bounced (host 192.168.9.88[192.168.9.88] said: 554 5.7.1 <rkonan@andi-ci.com>: Relay access denied (in reply to RCPT TO command))
Sep  9 11:59:48 srv-nagios postfix/cleanup[7412]: 4CAECBF77D: message-id=<20110909115948.4CAECBF77D@svr-nagios>
Sep  9 11:59:48 srv-nagios postfix/bounce[7445]: 1BFB6BFE76: sender non-delivery notification: 4CAECBF77D
Sep  9 11:59:48 srv-nagios postfix/qmgr[3319]: 4CAECBF77D: from=<>, size=2067, nrcpt=1 (queue active)
Sep  9 11:59:48 srv-nagios postfix/qmgr[3319]: 1BFB6BFE76: removed
Sep  9 11:59:49 srv-nagios postfix/smtp[7414]: 4CAECBF77D: to=<root@svr-nagios>, relay=192.168.9.88[192.168.9.88]:25, delay=1.5, delays=0.01/0/0.03/1.5, dsn=5.7.1, status=bounced (host 192.168.9.88[192.168.9.88] said: 554 5.7.1 <root@svr-nagios>: Relay access denied (in reply to RCPT TO command))
Sep  9 11:59:49 srv-nagios postfix/qmgr[3319]: 4CAECBF77D: removed
Pouvez vous me mettre sur le bon chemin ???
Merci d'avance
n°1289934
exeral
Posté le 09-09-2011 à 14:35:26  profilanswer
apparemment tu à un serveur smtp relais.
je trouve que postfix pour juste relayer les mails de notif c'est un peu un bazooka pour tuer une mouche. tu as des packages debian bien plus light pour les relais et surtout plus faciles à configurer (genre esmtp si je me souviens bien).
ça serait pas le serveur smtp qui n'accepte pas de relayer les mails du serveur nagios ça ?  :??:
n°1289936
anzian
Posté le 09-09-2011 à 15:01:14  profilanswer
Je vais faire de tests avec senmail ou esmtp
n°1289940
anzian
Posté le 09-09-2011 à 16:24:50  profilanswer
je viens de mettre en place mon serveur sendmail.
j'arrive à envoyer les messages, mais côté nagios je ne reçois pas de notification.
Y a t il des modifications à faire dans la configuration de nagios ??
n°1290328
anzian
Posté le 13-09-2011 à 21:08:08  profilanswer
Toujours pas de solution pour mon problème
  Installation
Nagios et fichier hosts.cfgIncompréhension Nagios
[Résolu] Nagios capricieuxNagios Centreon "Could not read object configuration data"
Nagios : checker des LVMs?Linux - notification d'insertion disque
Erreurs nagios gui[Nagios] LAN de machines derrière une passerelle
Problème sur NAGIOSCentreon 2 + Nagios 3 : stats & graphs... marchent a moitier!
Plus de sujets relatifs à : Reception de notification nagios
