1386 connectés
  Linux et OS Alternatifs
  Installation
  problème lilo : volid read error
n°311311
Taz
bisounours-codeur
Posté le 21-08-2003 à 21:56:44  profilanswer
désolé, mais c'est un peu long, mais je fourni tout
[root@athlon boot]# lilo
Fatal: volid read error
voici la table de mes partitions
[root@athlon boot]# fdisk -l /dev/hda
Disk /dev/hda: 40.0 GB, 40027029504 bytes
255 heads, 63 sectors/track, 4866 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot    Start       End    Blocks   Id  System
/dev/hda1   *         1       191   1534176    7  HPFS/NTFS
/dev/hda2           192      2738  20458777+   7  HPFS/NTFS
/dev/hda3          2739      4866  17093160    f  Win95 Ext'd (LBA)
/dev/hda5          2739      3747   8104761    7  HPFS/NTFS # mon /home, bizarrement, le format n'est pas bon...
/dev/hda6          3748      4800   8458191   83  Linux # mon /
/dev/hda7          4801      4866    530144+  82  Linux swap
et mon lilo.conf
# Support LBA for large hard disks.
lba32
# Overrides the default mapping between harddisk names and the BIOS'
# harddisk order. Use with caution.
#disk=/dev/hde
#    bios=0x81
#disk=/dev/sda
#    bios=0x80
# Specifies the boot device.  This is where Lilo installs its boot
# block.  It can be either a partition, or the raw device, in which
# case it installs in the MBR, and will overwrite the current MBR.
boot=/dev/hda
# Specifies the device that should be mounted as root. (`/')
root=/dev/hda6
# Enable map compaction:
# Tries to merge read requests for adjacent sectors into a single
# read request. This drastically reduces load time and keeps the
# map smaller.  Using `compact' is especially recommended when
# booting from a floppy disk.  It is disabled here by default
# because it doesn't always work.
# compact
# Installs the specified file as the new boot sector
# You have the choice between: bmp, compat, menu and text
# Look in /boot/ and in lilo.conf(5) manpage for details
# n'existe pas
install=/boot/boot-menu.b
# Specifies the location of the map file
map=/boot/map
# You can set a password here, and uncomment the `restricted' lines
# in the image definitions below to make it so that a password must
# be typed to boot anything but a default configuration.  If a
# command line is given, other than one specified by an `append'
# statement in `lilo.conf', the password will be required, but a
# standard default boot will not require one.
# This will, for instance, prevent anyone with access to the
# console from booting with something like `Linux init=/bin/sh',
# and thus becoming `root' without proper authorization.
# Note that if you really need this type of security, you will
# likely also want to use `install-mbr' to reconfigure the MBR
# program, as well as set up your BIOS to disallow booting from
# removable disk or CD-ROM, then put a password on getting into the
# BIOS configuration as well.  Please RTFM `install-mbr(8)'.
# password=tatercounter2000
# Specifies the number of deciseconds (0.1 seconds) LILO should
# wait before booting the first image.
delay=20
# You can put a customized boot message up if you like.  If you use
# `prompt', and this computer may need to reboot unattended, you
# must specify a `timeout', or it will sit there forever waiting
# for a keypress.  `single-key' goes with the `alias' lines in the
# `image' configurations below.  eg: You can press `1' to boot
# `Linux', `2' to boot `LinuxOLD', if you uncomment the `alias'.
# message=/boot/bootmess.txt
prompt
timeout=100
#       prompt
#       single-key
#       delay=100
#       timeout=100
# Specifies the VGA text mode at boot time. (normal, extended, ask, <mode> )
# vga=ask
# vga=9
#vga=791
vga=normal
# Kernel command line options that apply to all installed images go
# here.  See: The `boot-prompt-HOWTO' and `kernel-parameters.txt' in
# the Linux kernel `Documentation' directory.
# append="hdc=ide-scsi"
# Boot up Linux by default.
default=Linux_2.4.21
image=/vmlinuz
        label=Linux_2.2.0
        read-only
#       restricted
#       alias=1
image=/boot/bz-2.4.20
        label=Linux_2.4.20
        read-only
image=/boot/bz-2.4.21
        label=Linux_2.4.21
        read-only
image=/boot/bz-2.6.0-test1
        label=2.6.0-test1
        read-only
# If you have another OS on this machine to boot, you can uncomment the
# following lines, changing the device name on the `other' line to
# where your other OS' partition is.
# other=/dev/hda4
#       label=HURD
#       restricted
#       alias=3
other=/dev/hda1
  label="WindowsXP"
[root@athlon boot]# ls -l
total 5046
-rw-r--r--    1 root     root          512 2003-06-02 12:48 boot.0300
lrwxrwxrwx    1 root     root            9 2003-08-21 21:43 boot.b -> boot.0300
-rw-r--r--    1 root     root       830999 2003-06-13 20:49 bz-2.4.20
-rw-r--r--    1 root     root       851980 2003-08-13 08:19 bz-2.4.21
-rw-r--r--    1 root     root      1122877 2003-07-16 00:47 bz-2.6.0-test1
-rw-r--r--    1 root     root         3888 2003-06-02 12:36 config-2.2.20-idepci
lrwxrwxrwx    1 root     root           38 2003-08-19 17:59 debianlilo.bmp -> /usr/share/lilo/contrib/debianlilo.bmp
-rw-------    1 root     root        54784 2003-08-13 08:21 map
lrwxrwxrwx    1 root     root           33 2003-08-19 17:59 sarge.bmp -> /usr/share/lilo/contrib/sarge.bmp
lrwxrwxrwx    1 root     root           31 2003-08-19 17:59 sid.bmp -> /usr/share/lilo/contrib/sid.bmp
-rw-r--r--    1 root     root       224124 2003-06-02 12:36 System.map-2.2.20-idepci
-rw-r--r--    1 root     root       420929 2003-06-02 12:51 System.map-2.4.20
-rw-------    1 root     root       434494 2003-08-21 21:34 System.map-2.4.21
-rw-r--r--    1 root     root       530382 2003-07-16 00:54 System.map-2.6.0-test1
-rw-r--r--    1 root     root       665509 2003-06-02 12:36 vmlinuz-2.2.20-idepci
que du classic ...
j'y comprends rien, j'ai rien touché ...
n°311692
Taz
bisounours-codeur
Posté le 22-08-2003 à 16:33:32  profilanswer
UP  :cry:
  Installation
Problème de detection sous Mandrake 9.1 avec modem Sagem 800.problème resolution en OpenGL
Awstats : problème bizarre.Encore un problème d'OIDs ... je vais devenir barge ...
Probleme avec le compilateur intel.probleme iptable et nmap
Problème pour copier un fichier sur linux mandrakeproblème install mandrake 9.1
probleme idiot[Debian] Probleme avec apt-get [résolu]
Plus de sujets relatifs à : problème lilo : volid read error
